CFP-0412TB
CFP-0412TB
    NIDEC(尼得科)
    SMD8_12.6x8.6mm
    拨码开关 SMD8_12.6x8.6mm
CFP-0412TB 数据手册
PIANO SWITCHES (FULL PITCH) RoHS compliant CFP INTERNAL STRUCTURE ⑧ ⑦ ② ⑤ ① ⑥ Part name ④ ③ Material Flammability ■ FEATURES ① Cover Polyphenylenesulphide ● RoHS compliant ● High-reliability ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ■ APPLICATIONS ⑥ Terminal pin ● Communication devices, Air-conditioning equipment, Vending machines and various control equipment ⑦ Piano lever Polyamide ⑧ Piano cover Polyphenylenesulphide UL94V-0 Polyphenylenesulphide Copper alloy, Gold-plated – UL94V-0 ■ PART NUMBER DESIGNATION C F P - 0 4 0 1 T B Series name Shape of terminal B:Gull wing C:Through hole pin No. of bits 02: 2 bits 05: 5 bits 10:10 bits 03:3 bits 06:6 bits 04:4 bits 08:8 bits ON 方向 ON direction 0:Upper 1:Lower Structure 1:Flat lever (Without seal tape) 2:Convex lever (Without seal tape) ※ Please refer to the LIST OF PART NUMBERS when placing orders. Form of packaging T :Taping (Reel) M:Magazine CFP PIANO SWITCHES (FULL PITCH) ■ LIST OF PART NUMBERS No. of bits ON direction Structure Flat lever (without seal tape) Upper Convex lever (without seal tape) 2 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 3 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 4 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 5 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 6 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 8 Flat lever (without seal tape) Lower Convex lever (without seal tape) Flat lever (without seal tape) Upper Convex lever (without seal tape) 10 Flat lever (without seal tape) Lower Convex lever (without seal tape) Shape of terminals Form of packaging B(Gull wing) C(Through hole pins) Pieces in package Taping CFP-0201TB Magazine CFP-0201MB Taping CFP-0202TB Magazine CFP-0202MB Taping CFP-0211TB Magazine CFP-0211MB Taping CFP-0212TB Magazine CFP-0212MB Taping CFP-0301TB Magazine CFP-0301MB Taping CFP-0302TB Magazine CFP-0302MB Taping CFP-0311TB Magazine CFP-0311MB Taping CFP-0312TB Magazine CFP-0312MB Taping CFP-0401TB Magazine CFP-0401MB Taping CFP-0402TB Magazine CFP-0402MB Taping CFP-0411TB Magazine CFP-0411MB Taping CFP-0412TB Magazine CFP-0412MB Taping CFP-0501TB Magazine CFP-0501MB Taping CFP-0502TB Magazine CFP-0502MB Taping CFP-0511TB Magazine CFP-0511MB Taping CFP-0512TB Magazine CFP-0512MB Taping CFP-0601TB Magazine CFP-0601MB Taping CFP-0602TB Magazine CFP-0602MB Taping CFP-0611TB Magazine CFP-0611MB Taping CFP-0612TB Magazine CFP-0612MB Taping CFP-0801TB Magazine CFP-0801MB Taping CFP-0802TB Magazine CFP-0802MB Taping CFP-0811TB Magazine CFP-0811MB Taping CFP-0812TB Magazine CFP-0812MB Taping CFP-1001TB Magazine CFP-1001MB Taping CFP-1002TB Magazine CFP-1002MB Taping CFP-1011TB Magazine CFP-1011MB Taping CFP-1012TB 500 pcs./reel Magazine CFP-1012MB 16 pcs./stick : Not manufactured ※ Verify the above part numbers when placing orders. Taping and magazine version can be supplied only in reel or stick units. CFP-0201MC CFP-0202MC CFP-0211MC CFP-0212MC CFP-0301MC CFP-0302MC CFP-0311MC CFP-0312MC CFP-0401MC CFP-0402MC CFP-0411MC CFP-0412MC CFP-0501MC CFP-0502MC CFP-0511MC CFP-0512MC CFP-0601MC CFP-0602MC CFP-0611MC CFP-0612MC CFP-0801MC CFP-0802MC CFP-0811MC CFP-0812MC CFP-1001MC CFP-1002MC CFP-1011MC CFP-1012MC 500 pcs./reel 62 pcs./stick 500 pcs./reel 62 pcs./stick 500 pcs./reel 62 pcs./stick 500 pcs./reel 62 pcs./stick 500 pcs./reel 46 pcs./stick 500 pcs./reel 46 pcs./stick 500 pcs./reel 46 pcs./stick 500 pcs./reel 46 pcs./stick 500 pcs./reel 36 pcs./stick 500 pcs./reel 36 pcs./stick 500 pcs./reel 36 pcs./stick 500 pcs./reel 36 pcs./stick 500 pcs./reel 30 pcs./stick 500 pcs./reel 30 pcs./stick 500 pcs./reel 30 pcs./stick 500 pcs./reel 30 pcs./stick 500 pcs./reel 26 pcs./stick 500 pcs./reel 26 pcs./stick 500 pcs./reel 26 pcs./stick 500 pcs./reel 26 pcs./stick 500 pcs./reel 20 pcs./stick 500 pcs./reel 20 pcs./stick 500 pcs./reel 20 pcs./stick 500 pcs./reel 20 pcs./stick 500 pcs./reel 16 pcs./stick 500 pcs./reel 16 pcs./stick 500 pcs./reel 16 pcs./stick CFP PIANO SWITCHES (FULL PITCH) ■ STANDARD SPECIFICATIONS Operating temp. range ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Storage temp. range Sealing Net weight Non-washable Approx. 0.55 g (CFP-02) Approx. 0.86 g (CFP-04) Approx. 1.19 g (CFP-06) Approx. 1.90 g (CFP-10) Contact resistance Approx. 0.70 g (CFP-03) Approx. 1.03 g (CFP-05) Approx. 1.54 g (CFP-08) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS Operation angle 21 ° Operation force 7 N {0.71 kgf} maximum Stop strength 10 N {1.02 kgf} 60 s Solderability 245 ± 3 °C, 2 ~ 3 s Soldering heat Reflow:255 °C (Peak temperature) Flow:260 ± 3 °C, 5 ~ 6 s, two times maximum (Please refer to the profile below) Shear (Adhesion) 5 N {0.51 kgf} 10 s Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Shock 490 m/s2, 11 ms, 6 directions for 3 times each Load life Continuous load 1000 cycles, DC6 ± 0.5 V, 100 ± 10 mA Humidity −10 ~ 65 °C, Relative humidity 0 ~ 96 %, 24 h for 10 cycles High temp. exposure 85 °C, 96 h Low temp. exposure − 40 °C, 96 h Thermal shock 〈Reflow profile for soldering heat evaluation〉 Temperature 150 100 50 Peak : 250 +5 0 ℃ Over 230 ℃ 180 ℃ 150 ℃ AC500 V, 60 s (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each { } : Reference only 200 1000 M Ω (DC100 V) minimum Vibration 5 N {0.51 kgf} 10 s (℃) 250 50 m Ω maximum ■ ENVIRONMENTAL CHARACTERISTICS Manual soldering:350 ± 10 °C, 3 ~ 4 s Pull-off strength DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μA Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Reflow : two times maximum Soldering Zone −40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CFP PIANO SWITCHES (FULL PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● Flat lever, Gull wing ● Flat lever, Through hole pin L 7.62 +0.1 –0.05 Producion date code 21° 0.6 +0.1 –0.05 2.54±0.15 0.5 +0.1 –0.05 1.4 2.5 2.5 ● Convex lever, Through hole pin 0.25 +0.1 –0.05 L 1.4 0.9 Producion date code Producion date code 0.9 21° 0.2±0.1 3 6.7 7.5 21° 0.6 min 1.4 0.25 +0.1 –0.05 1.5 1.5 10 8.6 8.6 L 0.6 min ● Convex lever, Gull wing 2.54±0.15 7.62 0.2±0.1 3 6.7 21° 7.5 Producion date code 1.4 0.6 min 1.4 0.25 +0.1 –0.05 10 8.6 8.6 0.25 0.6 min L 0.6 +0.1 –0.05 Part number 2.54±0.15 0.5 +0.1 –0.05 1.4 2.5 Schematic No. of bits. L dimension 2.54±0.15 Part number 2.5 Schematic No. of bits. L dimension CFP-02 2 7.5 CFP-06 6 17.7 CFP-03 3 10.05 CFP-08 8 22.8 CFP-04 4 12.6 CFP-10 10 27.9 CFP-05 5 15.15 ■ RECOMMENDED P.C.B. PAD DIMENSIONS ■ SIZE OF P.C.B. PROCESSING (Unit : mm) P:No. of bits 2.54 × (P – 1) 2.5 2.54 × (P – 1) (Unit : mm) 7.62 0 2.5 6.6 0 1 φ 1 P:No. of bits CFP PIANO SWITCHES (FULL PITCH) ■ PACKAGING SPECIFICATIONS ● Taping version are packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. ● Taping version is boxed with 1 reel. ●Embossed tape dimensions ●Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) 25.4±1 (2, 3, 4, 5 bits) 33.4±1 (6 bits) 45.4±1 (8, 10 bits) Empty Filled φ 21±0.8 End 2±0.5 Head 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed φ 80±1 Empty Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the diagrams below: φ 13±0.2 29.4±1 (2, 3, 4, 5 bits) 37.4±1 (6 bits) 49.4±1 (8, 10 bits) φ 330±2 16 ± 0.1 4 ± 0.1 2 ± 0.1 0.5 ± 0.1 16 ± 0.1 φ 1.5 +0.1 0 4 ± 0.1 2 ± 0.1 1.75 ± 0.1 0 φ 1.5 +0.1 ● 6 bits, 8 bits, 10 bits 1.75 ± 0.1 ● 2 bits, 3 bits, 4 bits, 5 bits 0.5 ± 0.1 (CFP-0812B) Installation example Direction of feed B 0.2 ± 0.05 D B C C (CFP-0411B) Installation example 7.5 R 0.75 No. of bits ● Packing quantities of magazines are different depending on the bit number of the switches. Please order the multiple numbers of the specific packing quantities. (e.g. 62 pcs., 124 pcs., 186 pcs., etc., in case of 2 bits version) Pieces in package : 2 bits, 62 pcs./stick 3 bits, 46 pcs./stick 4 bits, 36 pcs./stick 5 bits, 30 pcs./stick 6 bits, 26 pcs./stick 8 bits, 20 pcs./stick 10 bits, 16 pcs./stick 7.5 Direction of feed +0.05 0 B C D 2, 3, 4, 5 24 11.5 ± 0.1 ——— 6 32 14.2 ± 0.1 28.4 ± 0.1 8, 10 44 20.2 ± 0.1 40.4 ± 0.1
CFP-0412TB 价格&库存
很抱歉,暂时无法提供与“CFP-0412TB”相匹配的价格&库存,您可以联系我们找货
CFP-0412TB
    • 1+6.78240
    • 10+6.64200
    • 30+6.53400
    • 100+6.43680
