PSBD2XD30V05F
PSBD2XD30V05F
    PRISEMI(上海芯导电子)
    DFN0603-2
    肖特基二极管 DFN0603-2L 500mA 30V
PSBD2XD30V05F 数据手册
PSBD2XD30V05F Schoktty Barrier Diode Feature  Forward Current: 500mA  Reverse voltage: 30V  Low forward voltage  Low leakage current  Trench MOS barrier Schottky technology  Ultra Small mold type. (DFN0603-2L) DFN0603-2L(Bottom View) Applications  Low current rectification  Voltage clamping Pin1  Protection circuits Pin2  Ultra high-speed switching Circuit Diagram Mechanical Characteristics  Mounting position: Any S Pin1  Qualified max reflow temperature:260℃ Pin2  Device meets MSL 1 requirements  DFN0603-2L without plating Marking (Top View) Electrical characteristics per line@25℃ (unless otherwise specified) Parameter Forward voltage Symbol VF Reverse current IR Junction Capacitance CJ Rev.06.2 Conditions Min. Typ. Max. IF =1mA - 0.25 0.29 IF =10mA - 0.32 0.36 IF =100mA - 0.40 0.46 IF =200mA - 0.46 0.52 IF =500mA - 0.58 0.65 VR = 10V - - 1.5 VR = 30V - - 8.0 VR = 0V,f = 1MHz - 25 - 1 Units V μA pF www.prisemi.com Schoktty Barrier Diode PSBD2XD30V05F Absolute maximum rating@25℃ Rating Reverse voltage (DC) Average rectified forward current Non-Repetitive Peak Forward SurgeCurrent(8.3ms single half sine-wave superimposed on rated load) Junction and Storage Temperature Range Symbol Value Units VRM 30 V Io 500 mA IFSM 4.5 A TJ,TSTG -55~+125 ℃ 1000 1000 100 100 IR - Leakage Current - uA IF - Instantaneous Forward Current - mA Typical Characteristics 10 1 125℃ 0.1 75℃ 25℃ 0.01 125℃ 10 75℃ 1 25℃ 0.1 -25℃ 0.01 -25℃ 0.001 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.001 0 5 10 15 20 25 30 VR - Reverse Voltage - V VF - Instantaneous Forward Voltage - V Fig 2.Leakage Current Fig.1 Typical Forward Characteristics 30 f = 1MHz C - Junction Capacitance - pF 25 20 15 10 5 0 0 5 10 15 20 25 30 VR - Reverse voltage - V Fig 3.Capacitance vs. Reveres voltage Rev.06.2 2 www.prisemi.com Schoktty Barrier Diode PSBD2XD30V05F Solder Reflow Recommendation Preliminary Heating 300 Soldering Cooling(in air) Temperature of Soldering 260℃ (+0,-5℃) 250 245℃ (+0,-5℃) 200 150 120℃ 100 100℃ 50 0 2 to 5 min more than 1 min Less than 10s Remark: Pb free for 260℃;Pb for 245℃. Load with information USER DIRECTION OF FEED 4.0±0.1 Ø1.55±0.1 2.0±0.1 Pin1 3.5±0.1 8.0±0.3 1.75±0.1 2.0±0.1 Unit:mm Rev.06.2 3 www.prisemi.com Schoktty Barrier Diode PSBD2XD30V05F Product dimension (DFN0603-2L) b D b L1 2 L E 1 h L2 e Bottom View Top View Dim A A1 Side View 0.594 0.194 0.206 0.291 Millimeters Inches Min Max Min Max A 0.28 0.34 0.011 0.013 A1 0.00 0.05 0.000 0.002 b 0.12 0.18 0.005 0.007 D 0.59 0.64 0.023 0.025 e 0.40 BSC 0.016 BSC L1 0.038 Ref. 0.001 Ref. L2 0.038 Ref. 0.001 Ref. E 0.29 0.34 0.011 0.013 L 0.22 0.28 0.009 0.011 h 0.035 0.10 0.001 0.004 Unit:mm Suggested PCB Layout Ordering information Device Package Reel Shipping PSBD2XD30V05F DFN0603-2L (Pb-Free) 7" 12000 / Tape & Reel Rev.06.2 4 www.prisemi.com Schoktty Barrier Diode PSBD2XD30V05F IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi), Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 5 www.prisemi.com
PSBD2XD30V05F 价格&库存
很抱歉,暂时无法提供与“PSBD2XD30V05F”相匹配的价格&库存,您可以联系我们找货
