GBJ15K
GBJ15K
    GENESICSEMICONDUCTOR
    GBJ
    桥式整流器/整流桥 单相 800V 插件 GBJ
GBJ15K 数据手册
GBJ15J thru GBJ15M Single Phase Glass Passivated Silicon Bridge Rectifier VRRM = 600 V - 1000 V IO = 15 A Features • Epoxy Resin material compliant with 94V-0 standards of UL Material Flammability Provisions • Compliant with RoHS Provisions • Single in-line DIP package, compact size • Low forward voltage, high forward current • High surge current capability • Types from 600 V to 1000 V VRRM GBJ Package • Small size, high heat-conducting performance • Thermal welding performance: 260 oC/10 s • Weight: 7.25 g (0.25 Oz) • Not ESD Sensitive Maximum ratings at TA = 25 °C (ambient temperature), unless otherwise specified GBJ15J GBJ15K GBJ15M Unit VRRM 600 800 1000 V VDC Tj Tstg 600 -50 to 150 -50 to 150 800 -50 to 150 -50 to 150 1000 -50 to 150 -50 to 150 °C °C Unit Parameter Symbol Repetitive peak reverse voltage DC blocking voltage Operating temperature Storage temperature Conditions Electrical characteristics at TA = 25 °C, unless otherwise specified Resistive load, single phase, half sine wave, 60 Hz. For capacitive load derate current by 20%. Parameter Symbol Maximum average forward rectified current Maximum forward surge current Maximum forward voltage IO IFSM VF Max. reverse current leakage at rated DC blocking voltage IR Insulation strengthg (Lead wire to case) Vdis Fusing feature Thermal resistance Mounting torgue I2 t RΘJA RΘJC TOR Conditions GBJ15J GBJ15K GBJ15M TC = 100 °C 15 (1) 15 (1) 15 (1) (2) (2) 3.5 (2) TA = 25 °C 3.5 3.5 A 8.3 ms pulse width, single pulse sine-wave, rated load, Tj = 25 °C 250 250 250 A IF = 7.5 A 1.05 1.05 1.05 V TA = 25 °C 5 5 5 TA = 125 °C 500 500 500 2.5 2.5 2.5 kV 200 200 200 A2s AC Voltage: 1 minute, current leakage < 1 mA 1ms ≤ t < 10ms, Tj=25 °C without heatsink with stated size heatsink (2) 22 1.5 (1) (2) 22 1.5 (1) μA (2) 22 1.5 (1) 1.0 ( 0.8 Nm is recomended ) o C/W Nm Remarks: (1) Install on PCB with stated size heat sink. In order to reach excellent heat dissipation performance, please coat thermal conductive sillica gel in moderation, use M3 screw to screw up. Recommended heatsink size: 12.7*10.2*7.6 cm. (2) Install on PCB without heatsink. Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbj15k.pdf 1 GBJ15J thru GBJ15M Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbj15k.pdf 2 GBJ15J thru GBJ15M Package dimensions and terminal configuration Product is marked with part number and terminal configuration. Dimensions in millimeters Oct. 2018 http://www.diodemodule.com/silicon_products/bridge_rectifiers/gbj15k.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: GBJ15K
GBJ15K 价格&库存
很抱歉,暂时无法提供与“GBJ15K”相匹配的价格&库存,您可以联系我们找货
