PSC5415E
PSC5415E
    PRISEMI(上海芯导电子)
    WLCSP-20
    USB兼容单节锂离子开关充电器,带USB OTG升压调节器
PSC5415E 数据手册
PSC5415E USB-Compliant Single-Cell Li-lon Switching Charger with USB-OTG Boost Regulator Description PSC5415E is a switch-mode charging IC with maximum 1.75A current for lithium battery and lithium polymer battery. The PSC5415E has 5V, 700mA OTG function, and I2C function. The charging parameter such as charging current, full charging voltage and input current can be precisely configured by I2C function. The package type is WLCSP (1.901mmx1.501mm) with 20 pins. The PSC5415E is designed with standard four-stage charging process: active, pre-charging, constant current, constant voltage and perfect protection mechanism for over current, over voltage, under voltage and over temperature. It is integrated with synchronous PW M control, high power MOSFET, and high voltage OVP circuits. The PSC5415E has high charging efficiency (94%), low internal resistance (45mΩ), and high DC withstand voltage (29V). Feature  Fully Integrated, High-Efficiency Charger for Single-Cell  2 Programmable through I C Interface: Li-lon and Li-Polymer Battery Packs -Input Current  Charge Voltage Accuracy: ±0.5% 25℃ -Fast-Charge/Termination Current  ±5% Charge Current Regulation Accuracy -Charger Voltage  29V Absolute Maximum Input Voltage  6V Maximum Input Operating Voltage  1.75A Maximum Charge Rate  5V, 700mA Boost Mode for USB OTG for 3.0 to 4.5V  Small Footprint 1μH External Inductor Battery Input  Perfect protection mechanism:  -Termination Enable  Synchronous Buck PWM Controller with Wide Duty Cycle Range 1.901 mm x 1.501mm 20-Pin WCSP Package -OVP, OCP, OTP Application  Cellular Phones, Smart Phones, PDAs  Tablet, Portable Media Players  Gaming Device, Digital Cameras VBUS L1 VBUS CBUS 4.7μF CCSIN PMID 10KΩ GPIO BATTERY 22μF 0.1μF CMID 10KΩ 10KΩ 10KΩ RSNS CBAT 1μF VAUX 1μH SW PSC5415E SCL SDA STAT OTG DISABLE CSIN VBAT VREF PGND CREF 4.7uF CCSOUT 0.1μF 10KΩ HOST Figure 1: Typical Application Rev.06.1.19 1 www.prisemi.com PSC5415E USB-Compliant Single-Cell Li-lon Switching Charger with USB-OTG Boost Regulator Recommended External Components Key Components Recommended specification L1 Inductor, 1.0-2.2uH, +-20%, Isat>3A CMID Capacitor, 4.7μF, +-10%, >6V Capacitor, 2.2μF, +-10%, >10V ,0402 CREF or Capacitor, 4.7μF, +-10%, >6V,0402 Capacitor, 1μF, +-10%, >25V CBUS Block Diagram VBUS PMID Q3 VREG LDO OVP (6.0V) Charge Pump IN Current Sensor Q1 VREG PWM DRIVER SW Q2 BIAS BUCK BOOST Controller PMID GND 30mA DISABLE OTG STAT SCL SDA I2C Digital Timer (90m/32s/12h) VBAT Figure 2: IC and System Block Diagram Marking Information P15E XXXXX P15E:PSC5415E XXXXX: Production Tracing Code Rev.06.1.19 2 、 www.prisemi.com PSC5415E USB-Compliant Single-Cell Li-lon Switching Charger with USB-OTG Boost Regulator Pin Configuration A1 A2 A3 A4 A4 A3 A2 A1 VBUS VBUS NC SCL SCL NC VBUS VBUS B1 B2 B3 B4 B4 B3 B2 B1 PMID PMID PMID SDA SDA PMID PMID PMID C1 C2 C3 C4 C4 C3 C2 C1 SW SW SW STAT STAT SW SW SW D1 D2 D3 D4 D4 D3 D2 D1 PGND PGND PGND OTG OTG PGND PGND PGND E1 E2 E3 E4 E4 E3 E2 E1 CSIN DISABLE VREF VBAT VBAT VREF DISABLE CSIN Top View Bottom View Figure 3: WLCSP-20 Pin Assignments Pin Definitions Pin# Name A1,A2 VBUS A3 NC NC. A4 SCL I C Interface Serial Clock. This pin should not be left floating. B1-B3 PMID B4 SDA I C Interface Serial Data. This pin should not be left floating. C1-C3 SW Switching Node. Connect to output inductor. C4 STAT D1-D3 PGND D4 OTG E1 CSIN E2 DISABLE E3 VREF E4 VBAT Rev.06.1.19 Description Charger Input Voltage and USB-OTG output voltage. Bypass with 1μF capacitor to PGND 2 Power Input Voltage. Power input to the charger regulator, bypass point for the input current sense, and high-voltage input switch. Bypass with a minimum of 4.7μF, 10V capacitor to PGND. 2 Status. Open-drain output indicating charge status. The IC pulls this pin LOW when charge is in process. Power Ground. Power return for gate drive and power transistors. The connection from this pin to the bottom of CMID should be as short as possible. On-The-Go. Enables boost regulator in conjunction with OTG_EN and OTG_PL bits Current-Sense Input. Connect to the sense resistor in series with the battery. The IC uses this node to sense current into the battery. Bypass this pin with a 0.1μF capacitor to PGND. Charge Disable. If this pin is “1”, charging is disabled. When LOW, charging is controlled by I2C registers. Bias voltage. Connect to a 4.7uF capacitor to PGND. The output voltage is PMID, which is limited to 6.5V. Any resistor loading to VREF is NOT recommended. Battery Voltage. Connect to the positive (+) terminal of the battery pack. Bypass with a 0.1μF capacitor to PGND if the battery is connected through long leads. 3 、 www.prisemi.com PSC5415E USB-Compliant Single-Cell Li-lon Switching Charger with USB-OTG Boost Regulator Product dimension E BALL A1 INDEX AREA F A B 1.20 0.03 C Ø0.15 Cu Pad A1 2X D 1.60 0.40 Ø0.18 Solder Ball Size 0.40 0.03 C 2X TOP VIEW RECOMMENDED LAND PATTERN (NSMD TYPE) 0.06 C 0.05 C 0.365±0.018 0.140±0.012 E 0.535 0.475 C SEATING PLANE D SIDE VIEWS NOTES: 0.005 M C A B B.DIMENSIONS ARE IN MILLIMETERS. ᶲ 1.20 0.40 C.DIMENSIONS AND TOLERANCE E PER ASMER14.5M,1994. D C 1.60 B A 0.40 1 2 A.NO JEDEC REGISTRATION APPLIES. D.DATUM C IS DEFINED BY THE SPHERICAL CROWNS OF THE BALLS. (Y) ±0.018 E.PACKAGE NOMINAL HEIGHT IS 586 MICRONS 3 4 ±39 MICRONS(547-625 MICRONS). F (X) ±0.018 F.FOR DIMENSIONS D,E,X,AND Y SEE PRODUCT DATASHEET. BOTTOM VIEW G.DRAWING FILNAME:MKT-UC020AArev2. Figure 41. 20-Ball WLCSP, 4x5 Array, 0.4mm Pitch, 150μm Ball Product-Specific Dimensions (mm) Product D E X Y ᶲ PSC5415E 1.901±0.030 1.501±0.030 0.150 0.150 0.150±0.020 Rev.06.1.19 4 、 www.prisemi.com PSC5415E USB-Compliant Single-Cell Li-lon Switching Charger with USB-OTG Boost Regulator IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Prisemi reserves the right to change the circuitry and/or specifications without notice at any time. Customers should obtain the latest relevant information and datasheets before placing orders and should verify that such information is current and complete. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.1.19 5 、 www.prisemi.com
PSC5415E 价格&库存
很抱歉,暂时无法提供与“PSC5415E”相匹配的价格&库存,您可以联系我们找货
