PV2G68D
PV2G68D
    PURE-V(朴为)
    DCC6C
    SAW滤波器 1268.52MHz 1.8dB DCC6C
PV2G68D 数据手册
APPROVAL SHEET SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Product Description: SAW Filter 1268.52 MHz SMD 3.0×3.0mm(BW=20.46MHz) Part No. Pages Date Revision PV2G68D 7 2023/10/11 3.1 REACH Mail:sales@pure-v.cn Website:http://www.pure-v.cn Prepared by: Checked by: Approved by: Add:202, Building 7, Future Industrial Park,Hangcheng Zhigu Zhongcheng, SanweiCommunity, Hangcheng Street, Bao 'an District, Shenzhen SAW Filter 20.46 MHz Bandwidth PV2G68D History Record Date Part No. Version No. Modify Content 2022.04.12 PV2G68D 2.0 指标、频谱图更新 2022.06.01 PV2G68D 3.0 封装尺寸图更新 2023.10.11 PV2G68D 3.1 频谱图更新 SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. Remark 1 SAW Filter PV2G68D 20.46 MHz Bandwidth Features Application RoHS compatible Low-loss SAW component Low amplitude ripple Package size 3.00x3.00x1.25mm3 Package Code DCC6C Electrostatic SensitiveDevice(ESD) Sharp rejections at both out-bands Usable passband 20.46 MHz Maximum Rating Item Value Unit VDC 5 V T -40 ~ +85 ℃ Storage Temperature Tstg -40 ~ +85 ℃ RF Power Dissipation P 20 dBm DC Voltage Operation Temperature Package Dimensions (Unit: mm) Test Circui( t Bottom View) Rg 3 4 5 2 S.S.G. 0dBm 1 6 Vi Ri Rg=Ri=50Ω Pin Configuration PV * · 2G68D 2 Input 5 Output 1, 3, 4, 6 Ground Top View, Laser Marking TOLERANCE : ±0.1 UNIT:mm “ · ”: "PV”: Manufacturer’s mark “*”: Lot number (The code shown below varies in a 4-year cycle) “ 2G68D ”: Part number Terminal 1 Code 1 2 3 4 5 6 7 8 9 10 11 12 2021 a b c d e f g h i j k m 2022 n p q r s t u v w x y z 2023 A B C D E F G H J K L M 2024 N P Q R S T U V W X Y Z SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 2 SAW Filter PV2G68D Electronic Characteristics Test Temperature: 25℃±2℃ Item Minimum 20.46 MHz Bandwidth Terminating source impedance: 50Ω Typical Maximum Unit MHz Center Frequency fc 1268.52 Insertion Loss(min) IL 1.4 1.8 dB IL 1.8 2.6 dB △ɑ 0.5 1.0 dB Insertion Loss 1258.29 - 1278.75MHz Amplitude Ripple (p-p) 1258.29 - 1278.75MHz 1 dB Bandwidth BW1dB Group Delay Ripple 1258.29 - 1278.75MHz Absolute Attenuation 28 29 10.0 GDR MHz 25.0 ns ɑ DC - 1200.00 MHz 40.0 42.0 dB 1240.00 MHz 30.0 35.0 dB 1300.00 - 2000.00 MHz 40.0 45.0 dB 2000.00 - 3000.00 MHz 30.0 35.0 dB Input VSWR 1258.29 - 1278.75MHz 1.6:1 2.0:1 / 1258.29 - 1278.75MHz 1.6:1 2.0:1 / Output VSWR Frequency Characteristics SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 3 SAW Filter PV2G68D 20.46 MHz Bandwidth Frequency Characteristics Frequency Response( wideband ) Delay Ripple & S11 VSWR SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 4 SAW Filter PV2G68D 20.46 MHz Bandwidth Reliability( The SAW components shall remain electrical performance after tests ) No. Test item 1 Temperature Storage Test condition (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time:2h±0.5h (2) Temperature: ‒55℃±3℃ , Duration: 250h ,Recovery time:2h±0.5h 2 Humidity Test 3 Thermal Shock Conditions: 60℃±2℃ , 90~95% RH Duration: 250h Heat cycle conditions: TA=-55℃±3℃, TB=85℃±2℃, t1=t2=30min, Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. 4 Vibration Fatigue 5 Drop Test 6 Solder Ability Test 7 Resistance to Soldering Heat Frequency of vibration: 10~55Hz Amplitude:1.5mm Directions: X,Y and Z Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Depth: DIP--2/3 , SMD--1/5 Duration: 3.0s--5.0s (1) Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration:10±1s (2) Temperature of Soldering Iron: 350℃±10℃, Duration: 3~4s, Recovery time : 2 ± 0.5h Recommended Reflow Soldering Diagram 280 Max peak 260+0/-5℃ 20-40sec 260 240 220 Temp (Deg ℃) 200 180 160 140 120 100 Pre-heating 50-180℃ 80 60-90sec heating 220℃ 50-80sec 60 40 20 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320 340 360 380 Time (Sec) SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 5 SAW Filter PV2G68D 20.46 MHz Bandwidth Packing Information Carrier Tape vacant components contained vacant Leader paet TAPE RUNNING DIRECTION Reel Dimensions Unit: mm Outer Packing Unit: mm Notes 1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by electrostatic, so we should pay attention to ESD protect in thetest. 2. Static voltage between signal load and ground may cause deterioration and destruction of the component. Please avoid static voltage. 3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic cleaning. 4. Only leads of component may be soldered. Please avoid soldering another part of component. 5. There is a close relationship between the device's performance and matching network. The specifications of this device are based on the test circuit shown above. L and C values may change depending on board layout. Values shown are intended as a guideonly. SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 6
PV2G68D
物料型号:PV2G68D
器件简介: - 该器件是一个声表面波(SAW)滤波器,具有20.46MHz的带宽。 - 产品符合RoHS标准,并且不含铅(Pb free)。
引脚分配: - 引脚配置在顶视图和激光打标图中标识,共有12个引脚加上输入(Input)、输出(Output)和地(Ground)。
参数特性: - 工作温度范围:-40℃至+85℃。 - 存储温度:未特别指明,但通常与工作温度相同。 - RF功率耗散:20dBm。 - 封装尺寸:3.00mm x 3.00mm x 1.25mm。
功能详解: - 该滤波器适用于低损耗SAW组件,具有低幅度波动和在两个外部频带的尖锐抑制。 - 可用通带为20.46MHz。
应用信息: - 推荐用于需要低损耗和良好选择性的射频应用。
封装信息: - 封装代码:DCC6C。 - 标记:包括制造商标志“PV”和型号“2G68D”。
电子特性测试: - 在25℃±2℃下进行,包括中心频率、插入损耗、幅度波动、1dB带宽、群延时波动、绝对衰减、输入和输出VSWR等参数。
可靠性测试: - 包括温度存储、湿度测试、热冲击、振动疲劳、跌落测试、焊锡能力和抗焊锡热测试。
回流焊接图: - 提供了推荐的回流焊接温度曲线。
包装信息: - 包括卷带和外包装的尺寸信息。
注意事项: - 由于SAW产品内部结构的特殊性,容易受到静电破坏,因此在测试中应注意静电放电保护。 - 应避免信号负载与地之间的静态电压,以防止组件劣化和破坏。 - 应避免使用超声波清洗,以免造成组件劣化和破坏。 - 仅组件的引脚可以焊接,避免在组件的其他部分进行焊接。 - 设备的性能与匹配网络密切相关,测试电路中的L和C值可能根据板布局而变化。
PV2G68D 价格&库存
很抱歉,暂时无法提供与“PV2G68D”相匹配的价格&库存,您可以联系我们找货
