PV5G68A
PV5G68A
    PURE-V(朴为)
    DCC6C
    SAW滤波器 1.568GHz 1.6dB DCC6C
PV5G68A 数据手册
APPROVAL SHEET SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Product Description: SAW Filter 1568 MHz SMD 3.00×3.00×1.25mm(BW=18 MHz) Part No. Pages Date Revision PV5G68A 7 Prepared by: 2024/01/08 2.1 Checked by: REACH Mail:sales@pure-v.cn Website:http://www.pure-v.cn Approved by: Add:202, Building 7, Future Industrial Park,Hangcheng Zhigu Zhongcheng, SanweiCommunity, Hangcheng Street, Bao 'an District, Shenzhen SAW Filter 18 MHz Bandwidth PV5G68A History Record Date Part No. Version No. 2022.08.11 PV5G68A 2.0 2024.01.08 PV5G68A 2.1 Modify Content Remark 指标、频谱图更新、封装尺寸图更新 SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 载带尺寸图更新 1 SAW Filter 18 MHz Bandwidth PV5G68A Features Application RoHS compatible Low-loss SAW component Low amplitude ripple Package size 3.00x3.00x1.25mm3 Package Code DCC6C Electrostatic Sensitive Device(ESD) Sharp rejections at both out-bands Usable passband 18 MHz Maximum Rating Item Value Unit VDC 5 V T -40 ~ +85 ℃ Storage Temperature Tstg -40 ~+85 ℃ RF Power Dissipation P 20 dBm DC Voltage Operation Temperature Package Dimensions (Unit: mm) Test Circui( t Bottom View) Rg 3 4 5 2 S.S.G. 0dBm 1 6 Vi Ri Rg=Ri=50Ω Pin Configuration PV · 2 Input 5 Output 1,3,4,6 Case Ground Top View, Laser Marking * 5G68A TOLERANCE : ±0.1 UNIT:mm Manufacturer’s mark “*”: Lot number (The code shown below varies in a 4-yearcycle) Code 1 2 2021 a 2022 n 2023 2024 “ 5G68A ”: Part number ” · ”: "PV”: Terminal 1 3 4 5 6 7 8 b c d e f g h p q r s t u v A B C D E F G H N P Q R S T U V SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 9 10 11 12 i j k m w x y z J K L M W X Y Z 2 SAW Filter 18 MHz Bandwidth PV5G68A Electronic Characteristics Test Temperature: 25℃±2℃ Item Minimum Terminating source impedance: 50Ω Typical Maximum Unit MHz Center Frequency fc 1568.00 Insertion Loss(min) IL 1.5 2.0 dB IL 1.9 2.5 dB △ɑ 0.4 1.0 dB Insertion Loss 1559.00 - 1577.00 MHz Amplitude Ripple (p-p) 1559.00 - 1577.00 MHz 1dB Bandwidth BW1dB Group Delay Ripple 1559.00 - 1577.00 MHz Absolute Attenuation 30.0 GDR 35.0 10.0 MHz 40.0 ns ɑ DC - 1512.00 MHz 30.0 35.0 dB 1610.00 -2000.00 MHz 40.0 45.0 dB 2000.00 -3000.00 MHz 22.0 27.0 dB Input VSWR 1559.00 - 1577.00 MHz 1.5:1 2.0:1 / 1559.00 - 1577.00 MHz 1.5:1 2.0:1 / Output VSWR Frequency Characteristics SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 3 SAW Filter PV5G68A 18 MHz Bandwidth Frequency Characteristics Frequency Response( wideband ) Delay Ripple &S11 VSWR SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 4 SAW Filter 18 MHz Bandwidth PV5G68A Reliability( The SAW components shall remain electrical performance after tests ) No. Test item Test condition 1 Temperature Storage (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time:2h±0.5h 2 Humidity Test Conditions: 60℃±2℃ ,90~95% RH 3 Thermal Shock (2) Temperature: –55℃±3℃ , Duration: 250h ,Recovery time:2h±0.5h Duration: 250h Heat cycle conditions: TA=-55℃±3℃, TB=85℃±2℃, t1=t2=30min, Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. 4 Vibration Fatigue 5 Drop Test 6 Solder Ability Test 7 Resistance to Soldering Heat Frequency ofvibration: 10~55Hz Amplitude:1.5mm Directions: X,Y and Z Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Depth: DIP--2/3 , SMD--1/5 Duration: 3.0s--5.0s (1) Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration:10±1s (2) Temperature of Soldering Iron: 350℃±10℃, Duration: 3~4s, Recovery time : 2 ± 0.5h Recommended Reflow Soldering Diagram 280 Maxpeak 260+0/-5℃ 20- 0sec 260 240 220 200 Temp (Deg ℃) 180 160 140 120 100 Pre-heati ng 5 0-180℃ 80 60-90 ec heating220 50-80sec 60 40 20 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320 340 360380 Time (Sec) SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 5 SAW Filter 18 MHz Bandwidth PV5G68A Packing Information Carrier Tape components contained vacant Leader paet vacant TAPE RUNNING DIRECTION Reel Dimensions Unit: mm P2 2.00±0.10 P0 4.00±0.10 T D0 0.30±0.05 Ø1.55±0.05 E 1.75±0.10 W 12.00±0.30 F 5.50±0.10 B0 3.30±0.10 D1 Ø1.50±0.10 P 8.00±0.10 K0 1.40±0.10 A0 3.30±0.10 Outer Packing Unit: mm Notes 1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by electrostatic, so we should pay attention to ESD protect in thetest. 2. Static voltagebetween signal load and ground may cause deterioration and destruction of the component. Please avoid static voltage. 3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic cleaning. 4. Only leads of component may be soldered. Please avoid soldering another part ofcomponent. 5. There is a close relationship between the device's performance and matching network. The specifications of this device are based on the test circuit shown above. L and C values may change depending on board layout. Values shown are intended as a guide only. SHENZHEN PUWEI TECHNOLOGY CO.,LTD. Please read notes at the end of this document. 6
PV5G68A 价格&库存
很抱歉,暂时无法提供与“PV5G68A”相匹配的价格&库存,您可以联系我们找货
