CRFS
SLIDE SWITCHES
RoHS compliant
INTERNAL STRUCTURE
①
②
③
④
⑧
⑤
⑩
⑦
⑨
Part name
⑥
Material
Flammability
■ FEATURES
①
Cover
Steel (SPCC), Tin-plated
● RoHS compliant
● Covering the DC 1 GHz frequency spectrum
● Gold-plated contact provides excellent reliability
②
Slider
Polyamide
UL94V-0
③
Slider plate ❈1
Polyester
④
Click spring
SWP
⑤
Click ball
SUS
⑥
Slider contact
⑦
Fixed contact
⑧
Housing
⑨
Terminal pin
Copper alloy, Gold-plated
⑩
Ground terminal
■ APPLICATIONS
● Communication devices
● Broadcast equipment
● FA equipment
(Polyphenylenesulphide)
UL94V-0
❈1 : 2 poles 3 contacts only
■ PART NUMBER DESIGNATION
CRFS - 2 2 0 2 W
Series name
Form of packaging
No. of poles
W:Tray packaging
Blank:Bulk in plastic bag
2:2 poles
No. of contacts
Knob length
2:2 contacts
3:3 contacts
2: 5 mm
4:10 mm
Setting position
0:Top setting
※ Please refer to the LIST OF PART NUMBERS when placing orders.
CRFS
SLIDE SWITCHES
■ LIST OF PART NUMBERS
Setting position
Shape of terminals
Knob length
5 mm
Top setting
Through hole pins
10 mm
Tray packaging
Bulk in plastic bag
Tray packaging
Bulk in plastic bag
■ STANDARD SPECIFICATIONS
Operating temp. range
Storage temp. range
Sealing
3
CRFS-2202W
CRFS-2302W
50 pcs./tray
CRFS-2202
CRFS-2302
25 pcs./pack
CRFS-2204W
CRFS-2304W
50 pcs./tray
CRFS-2204
CRFS-2304
25 pcs./pack
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching : DC50 V 100 mA
Switching : DC12 V 100 mA
Minimum : DC20 mV 1μ A
Non- Washable
Contact timing
Non-shorting
70 m Ω maximum
Contact resistance
100 M Ω minimum (DC500 V)
Insulation resistance
Dielectric strength
■ MECHANICAL CHARACTERISTICS
No. of positions
2, 3
Stroke
CFRS-22 □□ ※ 1
A ↔ B : 2.5 ± 1.5 N {0.255 ± 0.153 kgf}
CFRS-23 □□ ※ 2
A → B / C → B : 1.5 ± 1 N {0.153 ± 0.102 kgf}
B → A / B → C : 2.5 ± 1.5 N {0.255 ± 0.153 kgf}
AC500 V, 60 s
■ ENVIRONMENTAL CHARACTERISTICS
Vibration
2 mm
Operating force
Pieces in package
2
− 40 ~ 85 °C
Approx. 1.4 g (CRFS-2202)
Approx. 1.5 g (CRFS-2204)
Approx. 1.9 g (CRFS-2302)
Approx. 2.0 g (CRFS-2304)
Net weight
No. of contacts
Form of packaging
Shock
Load life
Humidity
(Amplitude) 1.5 mmor
(Acceleration) 98 m/s2,
10-500-10 Hz, 3 directions for 10 cycles each
490 m/s2, 11 ms, sinusoidal wave half cycle,
6 directions for 3 times each
Continuous load 10000 cycles,
DC12 ± 0.5 V, 100 ± 10 mA
40 °C, Relative humidity 90 ~ 95 %,
240 h, No load
Stop strength
30 N {3.06 kgf} 15 s
High temp. exposure
85 °C, 96 h, No load
Solderability
245 ± 3 °C
Low temp. exposure
− 40 °C, 96 h, No load
2~3s
Flow : 260 ± 3 °C, 5 ~ 6 s, 2 times maximum
Soldering heat
− 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
Manual soldering : 380 ± 10 °C, 3 ~ 4 s
{ } : Reference only
※1
Thermal shock
A
B
※2
■ HIGH FREQUENCY CHARACTERISTICS
CRFS-22 □□
A
B C
Isolation between terminals
Isolation between circuits
Insertion loss
VSWR
Impedance
CRFS-22□□
CRFS-23□□
770 MHz
28 dB
minimum
30 dB
minimum
0.15 dB
maximum
1.2
maximum
1.0 GHz
26 dB
minimum
28 dB
minimum
0.23 dB
maximum
1.3
maximum
CRFS-23 □□
770 MHz
28 dB
minimum
31 dB
minimum
0.13 dB
maximum
1.3
maximum
75 Ω
1.0 GHz
26 dB
minimum
29 dB
minimum
0.17 dB
maximum
1.3
maximum
CRFS
SLIDE SWITCHES
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● CRFS-22 □□
● CRFS-23 □□
13.8
10
C
① ② ③
C
② ③ ④
6
6.5
①
⑤
④ ⑤ ⑥
C
Schematic
Travel:2
2
Travel : 2
3
4
Production date code
⑥ ⑦ ⑧
C
Schematic
Travel : 2
3
3.5
3
3.5
3
0.5
8.5
Terminal No.5
8.5
Terminal No.4
L
L
0.8
0.3
0.5
2.4
5.5
2 2
9.2
Model number
0.5
0.3
0.8
4
2
12
0.5
2
2.5
6
L (mm)
Model number
L (mm)
CRFS-2202
5
CRFS-2302
5
CRFS-2204
10
CRFS-2304
10
■ SIZE OF P.C.B. PROCESSING
2
2
9.2
2
1.
2
4
6
2.5
5.5
2.4
8
φ
4
φ
1
● CRFS-23 □□
φ
4
6
1
φ
1.
2
● CRFS-22 □□
(Unit : mm)
2
12
■ PACKAGING SPECIFICATIONS
● Tray version is packaged in 50 pcs. per tray. Orders will be
accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc.
● Tray version is boxed with 10 trays.
● The smallest unit of bulk in a plastic bag is 25 pcs. per pack.
Orders will be accepted for unit of minimum 25 pcs., i.e., 25,
50, 75 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 25 pcs.
(standard 50 pcs.) per box.
很抱歉,暂时无法提供与“CRFS-2202W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.94040
- 10+10.70280
- 50+10.04400
- 100+9.89280
