LTD-1608-DFXJU-A1
LTD-1608-DFXJU-A1
    MAGLAYERS(美磊科技)
    LTD-1608-DFXJU-A1
LTD-1608-DFXJU-A1 数据手册
APPROVAL SHEET (RoHS Compliant & Halogen Free) CUSTOMER : CUSTOMER’S PART NO. : DESCRIPTION : Multi-layer Chip Diplexer for LTE PART NO. : LTD-1608-DFXJU-A1 DATE : AUTHORIZED BY : Derek Wei FULLY APPROVED PARTIALLY APPROVED REJECTED SIGN SUGGESTION 美磊科技股份有限公司 MAG. LAYERS SCIENTIFIC-TECHNICS CO., LTD HEAD OFFICE / PINGZHEN PLANT 270, Nan-Feng Road, Pingzhen District, Taoyuan City, Taiwan TEL:886-3-4159111 FAX:886-3-4192255 http://www.maglayers.com.tw E-mail:info@maglayers.com.tw 1/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 Version Date 1 2018/12/06 2 Description Approved by Prepared by Initial specification. CF LYW 2020/03/17 Modify recommended PCB layout and land pattern. CF LYW 3 2020/04/17 Modify electrical requirements. CF LYW 4 2020/06/05 Update storage condition. CF LYW 2/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 GSM/WCDMA/LTE mobile communication systems. ■ ■ ■ ■ ■ Compact Size Miniaturized SMD packaged in low profile and lightweight. Low loss Low insertion loss, high attenuation. High Soldering Heat Resistance High quality termination allows both flow and re-flow soldering methods to be applied. Characteristics Eliminate noise over a wide frequency range. Idea for high frequency and space limited designs. Available in tape and reel packaging for automatic mounting L T D -  1 6 0 8  - # # # x x  - A1  - □ □   Product Code  Dimension Code  Series Type (### represents center frequency and xx represents material type)  Design Code  Pattern Code 3/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 ■ Low-Band Item Frequency Range(MHz) Min. Typ. Max. Insertion Loss (dB) 698~960 — 0.75 0.90 Return Loss (dB) 698~960 10 18.5 — Attenuation (dB) 1710~2700 25 30 — Item Frequency Range(MHz) Min. Typ. Max. Insertion Loss (dB) 1710~2700 — 0.65 0.80 Return Loss (dB) 1710~2700 10 17 — 698~960 20 26.5 — 5150~5850 20 22 — Frequency Range(MHz) Min. Typ. Max. 698~960 10 17 — 1710~2700 10 17 — Frequency Range(MHz) Min. Typ. Max. 698~960 20 27 — 1710~2700 25 30 — High-Band Attenuation (dB) Common Item Return Loss (dB) Isolation Item Low to High (dB) Operating Temperature Range:-40~85°C Power Capacity:3W max. 4/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 L W T a 1.60±0.10 0.80±0.10 0.60±0.10 0.35±0.10 d b c 0.22±0.05 0.20±0.10 0.22±0.05 NOTE:Dimensions in mm ■ (1) GND (2) Common Port (3) GND (4) Low Frequency Port (5) GND (6) High Frequency Port ■ Test Instrument: Agilent E5071C Network Analyzer or equivalent. 5/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 * * * Unit:mm *Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. 6/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 ■ Mechanical Test Item Test Condition Specification Vibration 10 Hz/min~55 Hz/min~10 Hz/min vibration frequency with 1.5 mm amplitude for two hours in x, y, z directions No apparent damage Drop shock Dropped onto printed circuit board from 100cm height three times in x, y, z directions. The terminals shall be protected. No apparent damage Soldering heat resistance Preheating temperature : 150±10℃ Preheating time : 1 to 2 minutes Solder bath temperature : 260±5℃ Bathing time : 5±0.5 seconds No apparent damage Solder specimen LTCC components on the test printed circuit board (L: 100 x W: 40 x T: 1.6mm) in appended recommended PCB pattern. Apply the load in direction of the arrow until bending reaches 2 mm. Bending test onto printed circuit board No apparent damage Unit: mm The dipped surface of the terminal shall be at least 75% covered with solder after dipped in solder bath of 245±5℃ for 3±0.5 seconds. No apparent damage Thermal shock -40℃~85℃ for 100 cycles each cycle being 30 min No apparent damage Fulfill the electrical spec. after test Humidity resistance 85±2℃, 80~90% R.H. for 500 hours No apparent damage Fulfill the electrical spec. after test Solderability Environment Test High temperature 85±2℃ for 500 hours resistance No apparent damage Fulfill the electrical spec. after test Low temperature resistance No apparent damage Fulfill the electrical spec. after test -40±3℃ for 500 hours 7/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 Peel-off force 165¢XTO 180¢X TOP COVER TAPE BASE TAPE The force for peeling off cover tape is 10 grams in the arrow direction. Dimension (Unit: mm) F A B TYPE A B C D E F 8 mm 178±1 60+0.5 -0 - 13±0.2 9±0.5 12±0.5 12 mm 178±0.3 60±0.2 19.3±0.1 13.5±0.1 13.6±0.1 - C D E Taping quantity SERIES 5824 5724 5320 5220 4532 4516 3225 3216 2520 2012 1608 1005 PCS/Reel 5000 3000 1000 2000 2500 3000 4000 10000 P= 4 mm 8/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 Unit:cm W No. of Reels W L H 2 18±0.5 18±0.5 2.4±0.2 3 18±0.5 18±0.5 3.6±0.2 4 18±0.5 18±0.5 4.8±0.2 5 18±0.5 18±0.5 6.0±0.2 L H ` -40℃~85℃ The temperature should be within -40~85℃ and humidity should be less than 75% RH. The product should be used within 6 months from the time of delivery. (a) PCB shall be designed so that products are not subjected to the mechanical stress for board wrapage. Product shall be located in the sideway direction to the mechanical stress. b a Length: a>b a b (Good example) (Poor example) (b) Products (A,B,C,D) shall be located carefully so that products are not subjected to the mechanical stress due to warping the board. Because they may be subjected to the mechanical stress in order of A>C>B≒D. Seam a C B A b D Slit Length: a>b 9/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020 tP Temperature TP Critical Zone TL to TP Ramp-up TL tL Tsmax Tsmin Ramp-down tS Preheat t=25 ℃ to Peak Time Profile Feature Sn-Pb Pb-Free 60~120 seconds 60~180 seconds Tsmin 100℃ 150℃ Tsmax 150℃ 200℃ 3℃/second max. 3℃/second max. 183℃ 217℃ 60~150 seconds 60~150 seconds 230℃ 250~260℃ 10 seconds 10 seconds 6℃/sec max. 6℃/sec max. 6 minutes max. 8 minutes max. ts Preheat Average ramp-up rate (Tsmax to TP) Time main above Temperature (TL) Time (tL) Peak temperature (TP) Time within 5℃ of actual peak temperature (tP) Ramp-down rate Time 25℃ to peak temperature The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. 10/10 MAG.LAYERS LTD-1608-DFXJU-A1_V04 Jun. 2020
LTD-1608-DFXJU-A1 价格&库存
很抱歉,暂时无法提供与“LTD-1608-DFXJU-A1”相匹配的价格&库存,您可以联系我们找货
