DATA SHEET
WIRELESS COMPONENTS
Band Pass Filter
BPF1608LM03R2400A
Product Specification –OCT . 16, 2020 V.2
2.4 GHZ
1608 Series
Product specification
WIRELESS COMPONENTS
FEATURES
Compact size design
RoHS compliant
APPLICATIONS
WLAN, 802.11a/n
ISM Band
2
6
Diplexer
ORDERING INFORMATION
All part numbers are identified by the series, packing type,
material, size, antenna type, working frequency and packing
quantity.
PART NUMBER
BPF 1608 LM
(1)
(2)
03 R
(3)
(4)
2400A
(5)
(6)
(1) PRODUCT
BPF = Band Pass Filter
(2) SIZE
1608 = 1.60 × 0.8 mm
(3) MATERIALS
Material Code LM
(4) TYPE
03 = Type 03
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
2400 = 2.4 GHz
www.yageo.com
Oct. 16, 2020 V2.0
WIRELESS COMPONENTS
3
6
Diplexer
SPECIFICATION
Table 1
DESCRIPTION
Value
Pass Band
2400 ~ 2500 MHz
1.5 dB (Max) at 25°C
Insertion Loss
2.0 dB (Max) at –40~85°C
Return Loss
10dB (Min.)
Ripple
0.50 dB
30 min. at 880 ~ 915 MHz
25 min. at 1710 ~ 1785 MHz
25 min. at 1850 ~ 1910 MHz
Attenuation
25 min. at 4800 ~ 5000 MHz
25 min. at 7200 ~ 7500 MHz
-40 ~ 85℃
Operating Temperature
DIMENSIONS
OUTLINES
Table 2 Mechanical Dimension
DIMENSION
L (mm)
1.60 ±0.15
W (mm)
0.80 ±0.15
T (mm)
0.60 ±0.15
P (mm)
0.40 ±0.15
C (mm)
0.55 ±0.15
G (mm)
0.60 ±0.15
E (mm)
0.15 ±0.10
F (mm)
0.15 ±0.10
L (mm)
1.60 ±0.15
Table 3 Termination
configuration
TERMINAL
NAME
FUNCTION
P1
Input
P2
Output
P3
GND
P4
GND
Fig. 1 Filter outlines
www.yageo.com
Oct. 16, 2020 V2.0
WIRELESS COMPONENTS
Diplexer
4
6
Line width should be designed to match 50Ω characteristic impedance, depending on PCB
material and thickness.
Fig. 2 Reference design of evaluation board
www.yageo.com
Oct. 16, 2020 V2.0
WIRELESS COMPONENTS
Diplexer
5
6
ELECTRICAL PERFORMANCES
Fig. 3
Frequency Characteristics
www.yageo.com
Oct. 16, 2020 V2.0
WIRELESS COMPONENTS
6
6
Diplexer
REVISION HISTORY
REVISION DATE
Version 2
Oct. 16, 2020
CHANGE NOTIFICATION
DESCRIPTION
- New data sheet for Band Pass Filter, 2.45 GHz application,
1608 series
www.yageo.com
Oct. 16, 2020 V2.0
很抱歉,暂时无法提供与“BPF1608LM03R2400A”相匹配的价格&库存,您可以联系我们找货
