AR0603JR-0762KL
AR0603JR-0762KL
    YAGEO(国巨)
    RES SMD 62K OHM 5% 1/10W 0603
AR0603JR-0762KL 数据手册
DATA SHEET CHIP RESISTORS WITH NI/AU TERMINATIONS AR series 5%, 1% sizes 0402/0603/0805/1206 Product specification – December 23, 2008 V.7 Supersedes Date of Mar. 06, 2003 RoHS compliant Product specification Chip Resistor Surface Mount AR 2 9 0402/0603/0805/1206 (RoHS Compliant) SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes AR0402 to AR1206 chip resistors with Ni/Au-terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS AR XXXX X X X XX XXXX YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) (1) ⚫ Power supply in small equipment ⚫ Digital multi-meter 0402 ⚫ Telecommunication 0603 ⚫ Computer ⚫ Industry (2) (3) (4) (5) (6) (1) SIZE 0805 1206 (2) TOLERANCE FEATURES ⚫ RoHS compliant - - Products with lead free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS ⚫ Reducing environmentally hazardous wastes ⚫ High component and equipment reliability ⚫ Saving of PCB space ⚫ None forbidden-materials used in products/production ⚫ Halogen Free Epoxy ⚫ Moisture sensitivity level: MSL 1 F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) OPTIONAL CODE L = optional symbol (Note) Resistance rule of global part number Resistance code rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω O RDERING EXAMPLE The ordering code of a AR0603 chip resistor with gold terminations, value 56 X with ± 1% tolerance, supplied in 7-inch tape reel is: AR0603FR-0756R(L). NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER www.yageo.com Dec. 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 3 9 0402/0603/0805/1206 (RoHS Compliant) MARKING AR0402 No marking ynsc007 Fig. 1 AR0603 Fig. 2 Value = 12.4 KΩ E-96 series: 3 digits for 0603 ± 1% EIA-96 marking method For 0603 ± 1% E-24 series, one short bar under marking letter 563 ynsc003 Fig. 3 E-24 1% Value = 56 KΩ AR0603/0805/1206 03 E-24 series: 3 digits YNSC001 First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ AR0805/1206 Both E-24 and E-96 series: 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ For further marking information, please see special data sheet “Chip resistors marking”. www.yageo.com Dec. 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR 4 9 0402/0603/0805/1206 (RoHS Compliant) SERIES CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (Gold) are added. See fig. 6. OUTLINES For dimension see Table 1 overcoat Primary glass layer resistive layer (Jumper chip is a conductor) inner electrode H termination ceramic substrate I2 overcoat I1 DIMENSIONS Table 1 For outlines see fig. 6 TYPE L (mm) W (mm) W H (mm) I1 (mm) I2 (mm) AR0402 1.00 ± 0.05 0.50 ± 0.05 0.35 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 YNSC075 AR0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AR0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 L Fig. 6 Chip resistor outlines AR1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 ELECTRICAL CHARACTERISTICS Table 2 TYPE RESISTANCE RANGE Operating Max. Temperature Working Range Voltage AR0402 AR0603 1 Ω ≤ R ≤ 10 MΩ AR0805 Zero ohm Jumper < 0.05 Ω AR1206 –55 °C to +155 °C CHARACTERISTICS Max. Dielectric Overload Withstanding Voltage Voltage 50 V 100 V 100 V 50 V 100 V 100 V 150 V 300 V 300 V 200 V 500 V 500 V Temperature Jumper Criteria Coefficient Rated Max. of Resistance Current Current 10 Ω< R ≤10 MΩ: ± 100 ppm/°C 1.0 A 2.0 A 1.0 A 2.0 A 1 Ω≤ R ≤10 Ω: ± 200 ppm/°C 2.0 A 5.0 A 2.0 A 10.0A www.yageo.com Dec. 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 5 9 0402/0603/0805/1206 (RoHS Compliant) FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION AR0402 AR0603 AR0805 AR1206 7" (178 mm) 10,000 5,000 5,000 5,000 Paper taping reel (R) NOTE 1. For Paper/PE tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”. FUNCTIONAL DESCRIPTION O PERATING TEMPERATURE RANGE AR0402 to AR1206: –55 °C to +155 °C MLB206_2 P (%Prated ) 100 P OWER RATING Each type rated power at 70°C: AR0402=1/16 W; AR0603=1/10 W; AR0805=1/8 W; AR1206=1/4 W. 50 R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) or max. working voltage whichever is less 0 55 0 50 70 100 155 o Tamb ( C) Fig. 7 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Dec. 23, 2008 V.7 Product specification Chip Resistor Surface Mount AR SERIES 6 9 0402/0603/0805/1206 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55°C and +25/+125°C Refer to table 2 Formula: R2 − R1 T.C.R= × 106 (ppm/°C) R1( t 2 − t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Life/ Endurance MIL-STD-202 Method 108 IEC 60115-1 7.1 At 70± 2°C for 1,000 hours; RCWV applied for 1.5 hours on and 0.5 hour off, still air required 0075: ± (5%+100mΩ)
AR0603JR-0762KL
物料型号:YAGEO AR系列,包括0402、0603、0805、1206尺寸的贴片电阻。
器件简介:这些电阻采用厚膜工艺制造,具有Ni/Au端子,符合RoHS标准,即无铅。
引脚分配:文档中没有明确指出引脚分配,但通常贴片电阻为两个端子。
参数特性: - 工作温度范围:-55°C 至 +155°C - 最大工作电压:根据型号不同,分别为50V、100V、150V、200V - 最大电压:100V、100V、300V、500V - 电阻温度系数:根据规格而定 - 额定电流和最大电流:根据型号不同,额定电流分别为1.0A、1.0A、2.0A、20A,最大电流分别为2.0A、2.0A、5.0A、10.0A
功能详解: - 符合RoHS标准,减少环境有害废物 - 提高组件和设备可靠性 - 节省PCB空间 - 使用无卤环氧树脂,降低湿度敏感性等级至MSL 1
应用信息: - 小型设备电源 - 数字万用表 - 电信 - 计算机 - 工业领域
封装信息: - 提供7英寸纸带卷装 - 封装尺寸根据型号分别为0402、0603、0805、1206
订购信息:全球零件编号和12NC,包括系列、尺寸、容差、包装类型、温度系数、胶带卷和电阻值。
标记信息:根据电阻值的不同,标记方式也有所不同,例如E96系列和E24系列。
构造:电阻器构建在高级陶瓷基板上,内部金属电极在两端与厚膜电阻元件接触。电阻元件由嵌入玻璃中的贵金属组成,并由第二层玻璃覆盖以防止环境影响。
电气特性:包括电阻范围、特性、额定电流、最大电流和电阻温度系数。
包装风格和包装数量:提供纸带卷装,具体数量根据型号不同而有所差异。
测试和要求:包括电阻温度系数、寿命/耐久性、高温暴露、湿度、热冲击、短时间过载、板弯曲/弯曲、焊接性等测试。
修订历史:自2001年以来,数据表经过多次修订,以反映产品更新和改进。
法律声明:YAGEO保留随时更改产品相关信息的权利,不承担因产品应用或使用引起的任何责任。
AR0603JR-0762KL 价格&库存
很抱歉,暂时无法提供与“AR0603JR-0762KL”相匹配的价格&库存,您可以联系我们找货
AR0603JR-0762KL
    • 550+1.36730
    • 1000+0.92770
    • 2500+0.62900
    • 5000+0.44780
    库存:5000
