CSSH2512FT1L00
CSSH2512FT1L00
    SEI
    电阻器 1mΩ 1% 3W 2512
CSSH2512FT1L00 数据手册
CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Features: • • • • • • • • High power metal alloy current sense resistor High temperature performance up to 225C (for operation up to 275ºC, contact Stackpole) Low thermal EMF (< 1µ V/C) Proprietary processing technique produces extremely low resistance values Qualified to AEC-Q200 RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications CSS CSS0201 Maximum Power Rating (W) 0.2 CSS0402 0.33 CSS0603 0.33 CSS0508 1 CSS0805 0.5 CSS1206 1 CSS2010 1 CSS2512 2 Type/Code CSS2725 4 CSS2728 3 CSS4527 5 Max. Working Voltage = (P*R) P = Rated Power (W) R = Resistance Value (Ω) Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) ± 200 ± 150 ± 100 ± 150 ± 100 ± 75 ± 150 ± 100 ± 100 ± 75 ± 50 ± 175 ± 75 ± 50 ± 25 ± 15 ± 100 ± 50 ± 25 ± 15 ± 150 ± 100 ± 75 ± 50 0.005 - 0.006 0.007 - 0.015 0.016 - 0.05 0.007 - 0.015 0.016 - 0.049 0.001 0.0011 - 0.003 ± 25 0.0031 - 0.0069 ± 15 ± 100 ± 50 0.007 - 0.05 - ± 25 0.004 - 0.007 ± 15 ± 50 0.008 - 0.019 0.007 - 0.12 0.5% - 1% 0.01, 0.02 0.0025 0.005, 0.006, 0.008, 0.01, 0.015, 0.02 0.002 0.0025, 0.003, 0.004, 0.005 0.01, 0.015, 0.02 0.001, 0.0015 0.002, 0.003, 0.004, 0.005 0.0015 0.002, 0.003, 0.004, 0.005 0.006, 0.007, 0.01, 0.015, 0.02 0.0005 - 0.0006 0.001 - 0.004 0.005 - 0.015 0.016 - 0.05 0.0005 - 0.0009 0.001 - 0.003 0.004 - 0.006 0.007 - 0.1 0.0003 0.0005 - 0.0009 0.0005 - 0.003 0.004 - 0.006 0.08 - 0.5 0.007 - 0.075 0.0002 0.00025 - 0.003 0.004 - 0.007 0.101 - 0.2 0.008 - 0.1 0.0005 - 0.2 5% - 1/2 Please refer to the High-Power Resistor Application Note for more information on designing and implementing high power resistor types. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Electrical Specifications CSSH (High Power) Type/Code Maximum Power Rating (W) CSSH0805 1 CSSH1206 2 CSSH2010 2 CSSH2512 3 CSSH2728 TCR (ppm/ºC) ± 100 ± 75 ± 50 ± 75 ± 100 ± 75 ± 50 ± 25 ± 150 ± 75 0.5% 0.007 - 0.013 0.005 0.007 - 0.012 0.001 0.0011 - 0.0025 0.011 - 0.05 0.003 - 0.01 0.004 - 0.007 0.008 - 0.019 - ± 50 ± 25 ± 25 ± 15 ± 100 4 CSSH3637 7 Max. Working Voltage = (P*R)1/2 P = Rated Power (W) R = Resistance Value (Ω) Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 0.0005 0.001 - 0.002 0.0025 - 0.013 0.001 - 0.005 0.0005 - 0.0009 0.001 - 0.0019 0.002 - 0.0069 0.007 - 0.012 0.0003 0.0005 - 0.0025 0.011 - 0.1 0.003 - 0.01 0.004 - 0.007 0.008 - 0.05 0.0003 Mechanical Specifications CSS0201 – CSS0805 Type/Code Maximum Power Rating (W) Resistance Range (Ω) L W H CSS0201 0.2 0.01, 0.02 0.024 ± 0.006 0.60 ± 0.15 0.012 ± 0.006 0.30 ± 0.15 0.010 ± 0.004 0.25 ± 0.10 CSS0402 0.33 0.039 ± 0.006 1.00 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.012 ± 0.004 0.30 ± 0.10 0.063 ± 0.010 1.60 ± 0.25 0.031 ± 0.010 0.80 ± 0.25 0.016 ± 0.010 0.40 ± 0.25 0.049 ± 0.010 1.25 ± 0.25 0.079 ± 0.010 2.00 ± 0.25 0.017 ± 0.006 0.42 ± 0.15 0.079 ± 0.010 2.00 ± 0.25 0.049 ± 0.010 1.25 ± 0.25 0.016 ± 0.010 0.40 ± 0.25 0.0025 0.005 - 0.02 T1 0.002 CSS0603 0.33 0.0025, 0.003 0.004 - 0.02 0.001 0.0015 CSS0508 1 0.002 0.003 - 0.005 0.0015 CSS0805 0.5 0.002 0.003 - 0.02 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 0.006 0.15 0.012 0.30 0.009 0.23 0.018 0.45 0.014 0.35 0.012 0.30 0.015 0.38 0.015 0.37 0.014 0.36 0.013 0.32 0.028 0.70 0.024 0.60 0.016 0.40 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Specifications CSS1206 – CSS2728 Type/Code Maximum Power Rating (W) Resistance Range (Ω) L W 0.0005 - 0.0006 0.001 - 0.0015 CSS1206 1 0.002 - 0.004 0.126 ± 0.010 3.20 ± 0.25 0.063 ± 0.010 1.60 ± 0.25 0.200 ± 0.010 5.08 ± 0.25 0.100 ± 0.010 2.54 ± 0.25 0.246 ± 0.010 6.25 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.005 0.006 - 0.05 0.0005 - 0.0009 CSS2010 1 0.001 - 0.003 0.0031 - 0.1 0.0003 0.0005 - 0.0007 0.00075 CSS2512 2 0.0008 - 0.004 0.0041 - 0.075 0.08 - 0.1 0.3 - 0.5 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 H 0.039 1.00 0.025 0.65 0.022 0.55 0.022 0.55 0.022 0.55 0.031 0.79 0.031 0.79 0.025 0.65 0.039 1.00 0.031 0.79 0.031 0.79 0.031 0.79 0.026 0.65 0.026 0.65 0.028 0.72 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± T1 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.029 0.73 0.020 0.51 0.020 0.51 0.024 0.60 0.020 0.51 0.057 1.44 0.051 1.30 0.031 0.79 0.080 2.02 0.080 2.02 0.054 1.37 0.074 1.88 0.044 1.12 0.034 0.87 0.034 0.87 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Specifications CSS1206 – CSS2728 (cont.) Type/Code Maximum Power Rating (W) Resistance Range (Ω) L W H T1 0.0002 - 0.0003 0.00035 0.039 ± 0.010 0.99 ± 0.25 0.0004 - 0.00045 0.0005 0.0006 CSS2725 4 0.268 ± 0.010 6.81 ± 0.25 0.00075 0.254 ± 0.010 6.45 ± 0.25 0.043 1.09 0.039 0.99 0.001 0.0015 ± ± ± ± 0.010 0.25 0.010 0.25 0.002 0.035 ± 0.010 0.89 ± 0.25 0.00225 - 0.0025 0.003 CSS2728 3 0.264 ± 0.010 6.71 ± 0.25 0.004 - 0.2 0.283 ± 0.010 7.19 ± 0.25 0.039 ± 0.010 0.99 ± 0.25 0.085 2.16 0.075 1.90 0.051 1.30 0.085 2.16 0.071 1.80 0.059 1.50 0.085 2.16 0.085 2.16 0.071 1.80 0.065 1.65 0.051 1.30 0.045 1.14 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Mechanical Specifications CSS4527 Type/Code Maximum Power Resistance Range Rating (W) (Ω) L W H 0.0005 0.0006 - 0.003 CSS4527 5 0.450 ± 0.010 11.43 ± 0.25 0.004 - 0.005 0.0051 - 0.2 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 0.270 ± 0.010 6.85 ± 0.25 0.059 ± 0.010 1.50 ± 0.25 T1 0.137 3.47 0.127 3.22 0.127 3.22 0.072 1.82 ± ± ± ± ± ± ± ± T2 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Unit inches mm 0.038 ± 0.010 inches 0.97 ± 0.25 mm inches mm inches mm www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Specifications - CSSH Type/Code Maximum Power Rating (W) Resistance Range (Ω) L W 0.0005 0.001 0.0015 CSSH0805 1 0.002 0.081 ± 0.010 2.05 ± 0.25 0.051 ± 0.012 1.30 ± 0.30 0.0025 0.003 - 0.008 0.009 - 0.013 0.001 CSSH1206 2 0.002 - 0.004 0.126 ± 0.010 3.20 ± 0.25 0.063 ± 0.010 1.60 ± 0.25 0.200 ± 0.010 5.08 ± 0.25 0.100 ± 0.010 2.54 ± 0.25 0.246 ± 0.010 6.25 ± 0.25 0.126 ± 0.010 3.20 ± 0.25 0.005 0.0005 - 0.0009 0.001 - 0.003 CSSH2010 2 0.0031 - 0.004 0.0041 - 0.012 0.0003 H 0.024 0.60 0.022 0.55 0.018 0.45 0.014 0.35 0.018 0.45 0.014 0.35 0.015 0.37 0.025 0.65 0.021 0.55 0.021 0.55 0.031 0.79 0.031 0.79 0.025 0.65 0.025 0.65 0.039 1.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.0005 0.0006 - 0.0007 0.00075 CSSH2512 3 0.031 ± 0.010 0.79 ± 0.25 0.0008 - 0.0029 0.003 - 0.0035 0.0036 - 0.004 0.026 ± 0.010 0.65 ± 0.25 0.0041 - 0.01 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 T1 Unit 0.030 ± 0.008 0.75 ± 0.20 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm 0.016 ± 0.008 0.40 ± 0.20 0.020 0.51 0.020 0.51 0.024 0.60 0.057 1.44 0.051 1.30 0.031 0.79 0.031 0.79 0.080 2.02 0.080 2.02 0.080 2.02 0.054 1.37 0.044 1.12 0.074 1.88 0.066 1.68 0.044 1.12 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Mechanical Specifications – CSSH (cont.) Type/Code Maximum Power Rating (W) Resistance Range (Ω) L W H T1 Unit CSSH2728 4 0.004 - 0.05 0.264 ± 0.010 6.71 ± 0.25 0.283 ± 0.010 7.19 ± 0.25 0.039 ± 0.010 0.99 ± 0.25 0.045 ± 0.010 1.14 ± 0.25 inches mm CSSH3637 7 0.0003 0.360 ± 0.010 9.14 ± 0.25 0.378 ± 0.010 9.60 ± 0.25 0.029 ± 0.010 0.73 ± 0.25 0.091 ± 0.010 2.30 ± 0.25 inches mm Power Derating Curve: Performance Characteristics Test Test Method Temperature Coefficient JIS-C-5201-1 4.8 of Resistance (TCR) Short Time Overload Test Specification Per specification (refer to Electrical Specification table) Size Power (W) Max. R Change CSS0201 0.2 ≤ ± 0.5% CSS0402 0.33 ± 1% + 0.5mΩ CSS0603 0.33 ± 1% + 0.5mΩ CSS0508 1 ± 1% + 0.5mΩ CSS0805 0.5 ± 1% + 0.5mΩ CSS1206 1 ≤ ± 0.5% CSS2010 1 ≤ ± 0.5% CSS2512 2 ≤ ± 0.5% JIS C 5201-1 4.13 CSS2725 4 ≤ ± 0.5% CSS2728 3 ≤ ± 0.5% CSS4527 5 ≤ ± 2% CSSH0805 1 ≤ ± 1% CSSH1206 2 ≤ ± 0.5% CSSH2010 2 ≤ ± 0.5% CSSH2512 3 ≤ ± 0.5% CSSH2728 4 ≤ ± 0.5% CSSH3637 7 ≤ 0.5% + 0.5mΩ Test Condition (R2 - R1) X 106 R1 (T2 - T1) R1: resistance of room temperature (T1) R2: resistance of 125ºC (T2) TCR (ppm/ºC) = The number of rated power are as follows: Size Power (W) Rated Power CSS0201 0.2 2.5 times CSS0402 0.33 2.5 times CSS0603 0.33 2.5 times CSS0508 1 2.5 times CSS0805 0.5 2.5 times CSS1206 1 5 times CSS2010 1 5 times CSS2512 2 5 times CSS2725 4 5 times CSS2728 3 5 times CSS4527 5 5 times CSSH0805 1 4 times CSSH1206 2 5 times CSSH2010 2 5 times CSSH2512 3 5 times CSSH2728 4 5 times CSSH3637 7 5 times Rating power duration: 5 seconds. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Method Test Specification Test Condition Insulation Resistance JIS-C-5201-1 4.6 ≥ 109 Ω Put the resistor in the fixture, add 100 VDC in terminal for 60 seconds, then measure the insulation resistance between electrodes and insulating enclosure or between electrodes and base material Dielectric Withstanding Voltage JIS-C-5201-1 4.7 No short or burned in the appearance. Applied 500 VAC for 1 minute and limit surge current 50 mA (max) Operating Temperature Range for size CSS0201 is -55°C to +125°C. Operating Temperature Range for sizes CSS0402, CSS0603 and CSS0805 is -55°C to +155°C. Operating Temperature Range for size CSSH0805, CSSH3637 is -55°C to +170°C. Operating Temperature Range for sizes CSS1206 - CSS4527, CSSH 2512 and CSSH 2728 is -55°C to +225°C. Mechanical Performance Test Item Resistance to Solder Heat Solderability Test Method Test Specifications Test Condition 0201 - 0805 ≤ ± 1% + 0.5mΩ CSSH0805 and above 1206 ≤ ± 0.5% + 0.5mΩ JIS C 5201-1 4.18 CSSH3637 ≤ ± 0.5% + 0.5mΩ Jumper < Rmax 260 ± 5°C for 10 ± 1 seconds JIS C 5201-1 4.17 245 ± 5°C for 3 ± 0.5 seconds > 95 % coverage Span between fulcrums: 90 mm Bend width: 2 mm Substrate Bending JIS C 5201-1 4.33 ± 1% + 0.5mΩ CSSH3637 ≤ ± 0.5% + 0.5mΩ ≤ ± 0.5% Resistance to Solvent JIS C 5201-1 4.29 No evidence of mechanical damage ≤ ± 0.5% Vibration JIS C 5201-1 4.22 Mechanical Shock JIS C 5202 6.7 No evidence of mechanical damage The tested resistor is immersed into isopropyl alcohol of 20 ~ 25°C for 60 seconds, then the resistor is left in the room for 48 hours. The resistor shall be mounted by its terminal leads to the supporting terminals on the solid table. The entire frequency range from 10 Hz to 55 Hz and return to 10 Hz, shall be transferred in 1 minute. Amplitude: 1.5 mm - This motion shall be applied for a period of 4 hours in each 3 mutually perpendicular directions (a total of 12 hours) ± 1% + 0.5mΩ a = 50 G, t = 11 ms, 5 times shock Environmental Performance Test Item Test Method Low Temperature Exposure (Storage) JIS C 5201-1 4.23.4 High Temperature Exposure (Storage) JIS C 5201-1 4.23.2 Test Specifications 0201 - 0805 ≤ ± 1% + 0.5mΩ ≥ 1206 = ± 0.5% 0201 - 0805 ≤ ± 1% + 0.5mΩ CSSH0805 = ± 1% CSSH3637 ≤ ± 1% + 0.5mΩ ≥ 1206 = ± 1% 0201 Jumper < Rmax Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 Test Condition 1000 hours at -55°C ± 2°C 1000 hours at + 155°C ± 2°C 1000 hours at +170°C ± 5°C 1000 hours at + 125°C ± 2°C www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Environmental Performance (cont.) Test Item Temperature Cycling Test Method JIS C 5201-1 4.19 Test Specifications Test Condition 0201 - 0805 ≤ ± 1% + 0.5mΩ 0201 = -55°C to +125°C, 100 cycles 0402 - 0805 = -55°C +155°C, 100 cycles CSSH0805 = ± 0.5% CSSH3637 ≤ ± 0.5% + 0.5mΩ -55°C to +150°C, 100 cycles Lowest temperature: -55 +0/-10°C Highest temperature: 150 + 10/-0°C T = 40 ± 2°C , RH = 90~95%, Load with Rated Current 1.5 hours "ON", 0.5 hours "OFF", 1000 hours ≥ 1206 = ± 0.5% Biased Humidity JIS C 5201-1 4.24 Load Life JIS C 5201-1 4.25 0201 - 0805 ≤ ± 2% + 0.5mΩ 0201 Jumper < R max CSSH0805 = ± 0.5% CSSH3637 ≤ ± 0.5% + 0.5mΩ ≥ 1206 = ± 0.5% 0201 - 0805 ≤ ± 2% + 0.5mΩ 0201 Jumper = R max CSSH0805 = ± 1% CSSH3637 ≤ ± 1% + 0.5mΩ 1206 - 2728 = ± 1% 4527 = ± 2% 1000 hours at +85°C / 85% R.H., 10% of operating power 1.5 hours "ON" and 0.5 hours "OFF T = 70 ± 2°C, load with Rated Current 1.5 hours "ON", 0.5 hours "OFF", 1000 hours Test item (Thermal Shock Test): Testing Condition Minimum Storage Temperature -55 +0 / -10°C Maximum Storage Temperature 85 + 10 / -0°C Temperature-Retaining Time 10 minutes Number of Temperature Cycles 1500 JESD Standard No.22A121 class 2 Whisker Test Max 50μm Inspection: Inspect for whisker formation on specimens that underwent the acceleration test, with a magnifier (stereo microscope) of about 40 or higher magnification. If judgement is difficult with this method, use a scanning electron microscope (SEM) of about 1000 or higher magnification. Storage temperature: 25 ± 5°C. Humidity: 60 ± 20%. Recommended Pad Layouts - CSS Type/Code Maximum Power Rating (W) Resistance Range (Ω) a b i Unit CSS0201 0.2 0.01, 0.02 0.008 0.20 0.013 0.33 CSS0402 0.33 0.024 0.60 0.024 0.60 0.056 1.41 0.053 1.35 0.051 1.30 0.036 0.92 0.010 0.25 0.014 0.35 0.016 0.40 0.015 0.38 0.020 0.50 0.024 0.60 inches mm inches mm inches mm inches mm inches mm inches mm 0.0025 0.005 - 0.02 0.002 CSS0603 0.33 0.0025, 0.003 0.004 - 0.02 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 0.036 0.92 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Recommended Pad Layouts - CSS Type/Code Maximum Power Rating (W) Resistance Range (Ω) a 0.001, 0.0015, 0.002 CSS0508 1 0.003 - 0.005 0.0015, 0.002 CSS0805 0.5 0.003 - 0.02 0.0005 - 0.0006 CSS1206 1 0.001 - 0.05 0.0005 - 0.003 CSS2010 1 0.0031 - 0.1 0.0003 - 0.0007 0.00075 0.0008 - 0.004 CSS2512 2 0.00041 - 0.075 0.08 - 0.1 0.3 - 0.5 0.035 0.90 0.033 0.85 0.061 1.55 0.055 1.40 0.065 1.65 0.063 1.60 0.114 2.89 0.090 2.29 0.120 3.05 0.086 2.19 0.120 3.05 0.083 2.11 0.083 2.11 0.083 2.11 0.125 3.18 CSS2725 4 0.0002 - 0.003 CSS2728 3 0.004 - 0.2 0.108 2.75 0.0005 - 0.005 0.228 5.80 0.0051 - 0.2 0.163 4.15 CSS4527 5 b i Unit 0.145 3.68 0.145 3.68 0.145 3.68 0.145 3.68 0.145 3.68 0.145 3.68 0.270 6.86 0.016 0.40 0.020 0.50 0.020 0.50 0.031 0.80 0.035 0.90 0.039 1.00 0.048 1.22 0.095 2.41 0.050 1.27 0.118 3.00 0.050 1.27 0.125 3.18 0.125 3.18 0.125 3.18 0.052 1.32 0.308 7.82 0.138 3.51 0.268 6.81 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm i Unit 0.012 0.30 0.039 1.00 0.039 1.00 0.048 1.22 0.095 2.41 inches mm inches mm inches mm inches mm inches mm 0.091 2.30 0.057 1.44 0.086 2.18 0.086 2.18 0.115 2.92 0.344 8.74 0.138 3.51 Recommended Pad Layouts - CSSH Type/Code Maximum Power Rating (W) Resistance Range (Ω) a 0.053 1.35 0.039 1.00 0.063 1.60 0.114 2.89 0.090 2.29 0.0005 CSSH0805 1 0.001 - 0.013 CSSH1206 2 CSSH2010 2 0.001 - 0.005 0.0005 - 0.003 0.0031 - 0.012 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 b 0.071 1.80 0.086 2.18 0.115 2.92 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Recommended Pad Layouts – CSSH (cont.) Type/Code Maximum Power Rating (W) CSSH2512 Resistance Range (Ω) a 0.0003 - 0.0005 0.120 3.05 0.0006 - 0.0029 0.086 2.19 3 0.110 2.79 0.086 2.19 0.108 2.75 0.003 - 0.004 0.0101 - 0.1 CSSH2728 4 0.004 - 0.1 CSSH3637 7 0.0003 b 0.152 3.85 0.145 3.68 i Unit 0.050 1.27 inches mm inches mm inches mm inches mm inches mm inches mm 0.118 3.00 0.308 7.82 0.071 1.80 0.118 3.00 0.138 3.51 0.413 10.50 0.114 2.90 Recommended Solder Profiles This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) Maximum 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Recommended 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec 10 Minimum * 60 seconds * 10 seconds * www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile Packaging Specifications Type/Code Tape Width W ØD ØM Unit 0201, 0402, 0603 0508, 0805,1206 8 mm 0.354 ± 0.020 9.00 ± 0.50 2.362 ± 0.079 60.00 ± 2.00 7.008 ± 0.197 178.00 ± 5.00 CSSH0805 8 mm 0.472 ± 0.020 12.00 ± 0.50 2.362 ± 0.079 60.00 ± 2.00 7.008 ± 0.197 178.00 ± 5.00 CSSH3637 16 mm 0.685 ± 0.039 17.40 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 7.008 ± 0.079 178.00 ± 2.00 2010, 2512, 2725, 2728 12 mm 0.543 ± 0.020 13.80 ± 0.50 3.150 ± 0.039 80.00 ± 1.00 7.008 ± 0.197 178.00 ± 5.00 4527 24 mm 0.984 ± 0.039 25.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 7.008 ± 0.197 178.00 ± 5.00 inches mm inches mm inches mm inches mm inches mm Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Plastic Tape Specifications 0201 – 0805 Type/Code W P CSS0201 F ØD Unit 0.079 ± 0.004 2.00 ± 0.10 CSS0402 CSS0603 E 0.315 ± 0.012 8.00 ± 0.30 0.059 +0.004 / -0 1.50 +0.1 / -0 0.069 ± 0.004 1.75 ± 0.10 0.138 ± 0.004 3.50 ± 0.10 A B T Unit 0.016 ± 0.008 0.40 ± 0.20 0.028 ± 0.008 0.70 ± 0.20 0.018 ± 0.002 0.45 ± 0.05 0.026 0.65 0.039 0.98 0.043 1.10 0.073 1.85 0.017 0.42 0.024 0.60 0.028 0.70 0.030 0.75 inches mm inches mm inches mm inches mm inches mm 0.157 ± 0.004 4.00 ± 0.10 CSS0508 CSS0805 Type/Code G H CSS0201 CSS0402 CSS0603 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 CSS0508 ± ± ± ± 0.008 0.20 0.008 0.20 0.061 ± 0.008 1.55 ± 0.20 CSS0805 inches mm inches mm inches mm inches mm inches mm ± ± ± ± 0.008 0.20 0.008 0.20 0.091 ± 0.008 2.30 ± 0.20 ± ± ± ± ± ± ± ± 0.002 0.05 0.004 0.10 0.008 0.20 0.008 0.20 Plastic Tape Specifications 1206 – 4227 Type/Code CSS1206/CSSH1206 (0.0005Ω - 0.0006Ω) CSS1206/CSSH1206 (≥ 0.001Ω) CSS2010/CSSH2010 CSS2512/CSSH2512 (0.0003Ω) CSS2512/CSSH2512 CSS2725 CSS2728 CSS4527 A 0.138 3.50 0.137 3.48 0.215 5.45 0.265 6.74 0.266 6.75 0.281 7.15 0.281 7.15 0.465 11.80 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.075 1.90 0.072 1.83 0.114 2.90 0.138 3.50 0.138 3.50 0.266 6.75 0.303 7.70 0.283 7.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.315 8.00 0.315 8.00 0.472 12.00 0.472 12.00 0.472 12.00 0.472 12.00 0.472 12.00 0.945 24.00 12 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± MA08 E 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Item 0.138 3.50 0.138 3.50 0.217 5.50 0.217 5.50 0.217 5.50 0.217 5.50 0.217 5.50 0.453 11.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± T1 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.050 1.27 0.043 1.10 0.052 1.33 0.063 1.60 0.051 1.30 0.077 1.95 0.057 1.45 0.079 2.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions Plastic Tape Specifications 1206 – 4227 (cont.) Type/Code CSS1206/CSSH1206 (0.0005Ω - 0.0006Ω) CSS1206/CSSH1206 (≥ 0.001Ω) CSS2010/CSSH2010 CSS2512/CSSH2512 (0.0003Ω) CSS2512/CSSH2512 CSS2725 CSS2728 CSS4527 T2 0.009 0.23 0.008 0.20 0.009 0.23 0.009 0.24 0.008 0.20 0.010 0.25 0.010 0.25 0.012 0.30 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± P 0.004 0.10 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 0.157 4.00 0.315 8.00 0.472 12.00 0.472 12.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± P0 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ΦD P1 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Plastic Tape Specifications (CSSH0805 and CSSH3637) Type/Code W P E F CSSH0805 (0.0005Ω-0.001Ω) 0.315 ± 0.012 8.00 ± 0.30 G 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 H 0.079 ± 0.004 2.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 A 0.067 ± 0.004 1.70 ± 0.10 0.138 ± 0.004 3.50 ± 0.10 B 0.096 ± 0.004 2.45 ± 0.10 Type/Code W P E F CSSH0805 (0.0015Ω-0.013Ω) 0.315 ± 0.012 8.00 ± 0.30 G 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 H 0.079 ± 0.004 2.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 A 0.067 ± 0.004 1.70 ± 0.10 0.138 ± 0.004 3.50 ± 0.10 B 0.096 ± 0.004 2.45 ± 0.10 Type/Code W P E F CSSH3637 0.630 ± 0.008 16.00 ± 0.20 G 0.157 ± 0.004 4.00 ± 0.10 0.472 ± 0.004 12.00 ± 0.10 H 0.079 ± 0.004 2.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 A 0.378 ± 0.004 9.60 ± 0.10 0.295 ± 0.004 7.50 ± 0.10 B 0.394 ± 0.004 10.00 ± 0.10 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 13 ØD 0.059 +0.004/-0 1.50 +0.10/-0 T1 0.035 ± 0.010 0.90 ± 0.25 ØD 0.059 +0.004/-0 1.50 +0.10/-0 T1 0.022 ± 0.010 0.55 ± 0.25 ØD 0.059 +0.004/-0 1.50 +0.10/-0 T1 0.051 ± 0.004 1.30 ± 0.10 ØD1 Unit 0.039 ± 0.004 1.00 ± 0.10 T 0.008 ± 0.002 0.20 ± 0.05 inches mm Unit inches mm ØD1 Unit 0.039 ± 0.004 1.00 ± 0.10 T 0.008 ± 0.002 0.20 ± 0.05 inches mm Unit inches mm ØD1 Unit 0.059 ± 0.004 1.50 ± 0.10 T 0.010 ± 0.002 0.25 ± 0.05 inches mm Unit inches mm www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR1206 100 milliohm at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 mΩ. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 14 www.seielect.com marketing@seielect.com CSS / CSSH Series Stackpole Electronics, Inc. Ultra-Precision Metal Alloy Current Sensing Chip Resistor Resistive Product Solutions RoHS Compliance Status Standard Product Series CSS CSSH Description Ultra-Precision Current Sensing Chip Resistor Ultra-Precision Current Sensing Chip Resistor (High Power) Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) SMD YES 100% Matte Sn over Ni Always Always SMD YES 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order C S Product Series Code Description CSS Metal Alloy CSSH High Power S 2 Size Size W 0201 0.2 0402 0.33 0603 0.33 0805 0.5 0508 1 (H)0805 1 1206 1 (H)1206 2 2010 1 (H)2010 2 2512 2 (H)2512 3 2728 3 2725 4 (H)2728 4 4527 5 (H)3637 7 7 Tolerance Code Tol D 0.5% F 1% G 2% J 5% Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 5 Code T F T Packaging Description Size 0201, 0402 0603, 0508 0805 1206 Plastic Tape 2010, 2512 2725, 2728 3637 4527 15 3 L Quantity 10000 5000 4000 2000 1000 500 0 0 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of 10-3 for any value under 0.1 ohm. 0.00025 ohm = L250 0.004 ohm = 4L00 0.05 ohm = 50L0 0.12 ohm = R120 www.seielect.com marketing@seielect.com
CSSH2512FT1L00 价格&库存
很抱歉,暂时无法提供与“CSSH2512FT1L00”相匹配的价格&库存,您可以联系我们找货
CSSH2512FT1L00
    • 1+2.39966
    • 200+0.92870
    • 500+0.89608
    • 1000+0.87988
