CSNL1206FT15L0
CSNL1206FT15L0
    SEI
    RES 0.015 OHM 1% 1W 1206
CSNL1206FT15L0 数据手册
CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor Features: • • • • • • • • • • Metal element current sensing resistor High power current sense resistor TCR of ±50 ppm/C Resistances down to 0.0005 (1/2mΩ) Current handling up to 63 amps Non-standard resistance values available 100% RoHS compliant and lead free without exemption Halogen free REACH compliant For CSNL2512 with power rating of 3W, see SEI-CSNL2512-3W Electrical Specifications Power Rating (W) 1 @ 80ºC Type/Code CSNL1206 CSNL2010 1.5 @ 80ºC CSNL2512 2 @ 70ºC Dielectric Withstanding Voltage (V) TCR (ppm/ºC) ± 50 200 Ohmic Range (Ω) and Tolerance 1%, 5% 0.001 - 0.05 ± 100 0.0005 ± 50 0.001 - 0.1 ± 50 0.0005 - 0.01 Mechanical Specifications Type/Code Resistance Range (Ω) CSNL1206 0.001 - 0.05 ≤ 0.003 CSNL2010 ≥ 0.0031 0.0005 0.00075 0.001 0.0015 0.002 CSNL2512 0.0025 0.003 0.004 0.005 0.006 0.0065 H Body Height 0.025 ± 0.010 0.65 ± 0.25 0.031 ± 0.010 0.79 ± 0.25 0.025 ± 0.010 0.65 ± 0.25 0.049 ± 0.008 1.25 ± 0.20 0.030 ± 0.008 0.75 ± 0.20 0.026 ± 0.008 0.65 ± 0.20 0.018 ± 0.008 0.45 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.026 ± 0.008 0.65 ± 0.20 0.022 ± 0.008 0.55 ± 0.20 0.018 ± 0.008 0.45 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.013 ± 0.008 0.32 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. a Top Termination 0.020 ± 0.010 0.51 ± 0.25 0.051 ± 0.010 1.30 ± 0.25 0.031 ± 0.010 0.79 ± 0.25 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 1 b Bottom 0.020 ± 0.010 0.51 ± 0.25 0.051 ± 0.010 1.30 ± 0.25 0.031 ± 0.010 0.79 ± 0.25 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 L Body Length 0.126 ± 0.010 3.20 ± 0.25 0.200 ± 0.010 5.08 ± 0.25 0.200 ± 0.010 5.08 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 W Body Width 0.063 ± 0.010 1.60 ± 0.25 0.100 ± 0.010 2.54 ± 0.25 0.100 ± 0.010 2.54 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor Mechanical Specifications (cont.) Type/Code Resistance Range (Ω) 0.007 CSNL2512 0.01 H Body Height 0.011 ± 0.008 0.27 ± 0.20 0.010 ± 0.008 0.25 ± 0.20 a Top Termination 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 b Bottom 0.051 ± 0.015 1.30 ± 0.38 0.051 ± 0.015 1.30 ± 0.38 L Body Length 0.250 ± 0.010 6.35 ± 0.25 0.250 ± 0.010 6.35 ± 0.25 W Body Width 0.125 ± 0.010 3.18 ± 0.25 0.125 ± 0.010 3.18 ± 0.25 Unit inches mm inches mm Performance Characteristics Test Test Method Test Specification Typical Load Life MIL-STD-502F-Method 108A RCWV at 70°C; 1.5 hour ON; 0.5 hour OFF Total 1024 ± 24 hours ± 1% ≤ 0.5% Resistance to Soldering Heat MIL-STD-202F-Method 210E 260 ± 5°C for 10 ± 1 seconds ± 0.5% ≤ 0.25% Solderability MIL-STD-202F-Method 208H 245 ± 5°C for 2 ± 0.5 seconds minimum 95% coverage > 95% Thermal Shock MIL-STD-202F-Method 107G -55°C to 150°C, 100 cycles ± 0.5% ≤ 0.5% Short Time Overload JIS-C-5202-5.5 5x rated power for 5 seconds ± 0.5% ≤ 0.5% Temperature Cycling JIS-C-5202-7.4 -55°C: 30 minutes 25°C: 2 to 3 minutes 155°C: 30 minutes 25°C: 2 to 3 minutes ± 0.5% ≤ 0.5% Moisture Resistance MIL- STD-202F-Method 106G ± 0.5% ≤ 0.5% Insulation Resistance MIL-STD-202F-Method 302 Apply 100 Vdc for 1 minute 1M Ω minimum ≥ 1M Ω 90 seconds minimum ≥ 90 seconds Leach Resistance Operating temperature range is -55°C to +170°C - Power Derating Curve: Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor Recommended Pad Layout Type/Code Resistance Range (Ω) CSNL1206 0.001 - 0.05 ≤ 0.003 CSNL2010 ≥ 0.0031 0.0005 0.00075 0.001 0.0015 CSNL2512 0.002 - 0.0035 0.004 - 0.0045 0.005 - 0.006 0.0065 - 0.007 0.008 - 0.01 a 0.063 1.60 0.114 2.89 0.090 2.29 0.123 3.13 0.115 2.93 0.094 2.38 0.074 1.88 0.064 1.63 0.104 2.63 0.094 2.38 0.074 1.88 0.064 1.63 b 0.086 2.18 0.115 2.92 0.115 2.92 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 0.134 3.40 i 0.039 1.00 0.048 1.22 0.095 2.41 0.020 0.52 0.037 0.94 0.080 2.04 0.120 3.04 0.139 3.54 0.061 1.54 0.080 2.04 0.120 3.04 0.139 3.54 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Taping Specifications – Embossed Plastic Tape Type / Code Ohmic Value (Ω) Quantity CSNL1206 0.001 - 0.05 4000 CSNL2010 0.0005 - 0.01 2000 CSNL2512 0.0005 - 0.00075 2000 CSNL2512 0.001 - 0.01 2000 A 0.072 1.83 0.114 2.90 0.134 3.40 ± ± ± ± ± ± B W F E 0.004 0.137 ± 0.004 0.315 ± 0.006 0.138 ± 0.004 0.069 ± 0.10 3.48 ± 0.10 8.00 ± 0.15 3.50 ± 0.10 1.75 ± 0.004 0.215 ± 0.004 0.472 ± 0.006 0.217 ± 0.004 0.069 ± 0.10 5.45 ± 0.10 12.00 ± 0.15 5.50 ± 0.10 1.75 ± 0.004 0.266 ± 0.004 0.472 ± 0.004 0.217 ± 0.002 0.069 ± 0.10 6.75 ± 0.10 12.00 ± 0.10 5.50 ± 0.05 1.75 ± P0 Unit 0.004 0.157 ± 0.004 inches 0.10 4.00 ± 0.10 mm 0.004 0.157 ± 0.004 inches 0.10 4.00 ± 0.10 mm 0.004 0.157 ± 0.004 inches 0.10 4.00 ± 0.10 mm 0.134 ± 0.004 0.266 ± 0.004 0.472 ± 0.004 0.217 ± 0.002 0.069 ± 0.004 0.157 ± 0.004 inches 3.40 ± 0.10 6.75 ± 0.10 12.00 ± 0.10 5.50 ± 0.05 1.75 ± 0.10 4.00 ± 0.10 mm Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor Taping Specifications – Embossed Plastic Tape (cont.) Ohmic Value (Ω) Type / Code Quantity CSNL1206 0.001 - 0.05 4000 CSNL2010 0.0005 - 0.01 2000 CSNL2512 0.0005 - 0.00075 2000 CSNL2512 0.001 - 0.01 2000 T 0.043 1.10 0.052 1.33 0.057 1.45 0.032 0.81 ± ± ± ± ± ± ± ± P1 0.004 0.10 0.004 0.10 0.008 0.20 0.004 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± P2 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ØD0 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 0.061 1.55 0.061 1.55 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 ØD1 Unit 0.055 1.40 0.055 1.40 min. min. min. min. inches mm inches mm inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series CSNL Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Metal Plate Current Sensing Surface Mount Chip Resistor SMD YES 100% Matte Sn over Ni May-04 04/18 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com CSNL Series Stackpole Electronics, Inc. Resistive Product Solutions Metal Plate Current Sensing Chip Resistor How to Order C S Product Series Code Description CSNL Metal Plate N Size Code W 1206 1 2010 1.5 2512 2 L 1 Tolerance Code Tol F 1% J 5% 2 Code T Rev Date: 10/10/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0 6 F Packaging Description 7" Reel - Plastic Tape 6 T Size 1206 2010, 2512 1 Quantity 4000 2000 0 L 0 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of -3 10 for any value under 0.1 ohm. 0.0005 ohm = L500 0.001 ohm = 1L00 0.01 ohm = 10L0 0.1 ohm = R100 www.seielect.com marketing@seielect.com
CSNL1206FT15L0
物料型号:CSNL系列,包括CSNL1206、CSNL2010和CSNL2512。
器件简介:这些是金属板电流检测芯片电阻器,由Stackpole Electronics, Inc.提供,适用于高功率电流检测。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器为表面贴装器件,具有指定的焊盘布局。
参数特性: - 功率范围:CSNL1206为80°C时3W,CSNL2010为1.5W,CSNL2512为70°C时2W。 - 介质耐压:200V。 - 温度系数(TCR):±50 ppm/°C。 - 电阻范围:从0.0005Ω(1/2 mΩ)到0.1Ω不等。 - 电流处理能力:最高63安培。 - 符合RoHS标准,无铅且不含卤素。
功能详解:这些电阻器设计用于检测电流,具有高精度和高功率处理能力,适用于需要高可靠性电流检测的应用。
应用信息:适用于需要高功率电流检测的场合,如电源管理、电机控制等。
封装信息:提供了详细的机械规格,包括电阻范围、体高、顶面和底面终止、体长和体宽等尺寸信息。
CSNL1206FT15L0 价格&库存
很抱歉,暂时无法提供与“CSNL1206FT15L0”相匹配的价格&库存,您可以联系我们找货
CSNL1206FT15L0
    CSNL1206FT15L0
    • 4000+1.588104000+0.20526
    • 8000+1.479768000+0.19126
    • 12000+1.4241112000+0.18407
    • 20000+1.3611620000+0.17593
    • 28000+1.3236528000+0.17108
    • 40000+1.2870240000+0.16635
    库存:248
    CSNL1206FT15L0
    • 1+5.898421+0.76237
    • 10+3.8041610+0.49169
    • 25+3.2400825+0.41878
    • 50+2.8844850+0.37282
    • 100+2.58253100+0.33379
    • 250+2.25022250+0.29084
    • 500+2.04241500+0.26398
    • 1000+1.865791000+0.24115
    库存:248
