OR-357A-S-TP-G-(GK)
OR-357A-S-TP-G-(GK)
    ORIENT(奥伦德)
    SIP4
    光电耦合器 SIP4 3.75KV 工控
OR-357A-S-TP-G-(GK) 数据手册
Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) ORIENT Photo coupler Product Data Sheet 、 Part Number: OR-357-S-(GK) Customer: Date: SHENZHEN ORIENT COMPONENTS CO.,LTD. Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2020 Orient .All rights Reserved 1 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 1. Features (1) Current transfer ratio(CTR : MIN. 50% at IF = 5mA, VCE = 5V, Ta=25℃) (2) High input -output isolation voltage (VISO=3,750Vrms) (3) High collector-emitter voltage (VCEO = 80V) (4) SOP-4 package (5) Operating Temperature -55 ℃ to 125 ℃ (6) ESD pass HBM 8000V/MM 2000V (7) Safety approval UL approved(No.E323844) VDE approved(No.40029733) CQC approved (No.CQC19001231256) (8) In compliance with RoHS, REACH standards (9) MSL Class Ⅰ 2. Instructions  The OR-357-S-(GK) series device consists of an infrared led, photo transistor detector. They are encapsulated in a 4 pin SOP encapsulation.  Pin pitch of OR-357-S-(GK) is 2.54mm 3. Application Range (1) (2) (3) Hybrid substrates that require high density mounting. Programmable controllers System appliance, measuring instruments 4. Functional Diagram Copyright© 2020 Orient .All rights Reserved 2 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 5. Max Absolute rated Value (Normal Temperature=25℃) Parameter Symbol Rated Value Unit Forward Current IF 50 mA Junction Temperature TJ 125 ℃ Reverse Voltage VR 6 V Consume Power P 70 mW Collector and emitter Voltage VCEO 80 Input V Emitter and collector Voltage VECO 7 Collector Current IC 50 mA Consume Power PC 150 mW Total Consume Power Ptot 200 mW *1 Insulation Voltage Viso 3750 Vrms Working Temperature Topr -55 to + 125 Deposit Temperature Tstg -55 to + 150 *2 Soldering Temperature Tsol 260 Output ℃ *1. AC Test, 1 minute, humidity = 40~60% Insulation test method as below: (1) Short circuit both terminals of photo coupler. (2) No Current when testing insulationvoltage. (3) Adding sine wave voltage when testing. *2. soldering time is 10 seconds. Copyright© 2020 Orient .All rights Reserved 3 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 6. Opto-electronic Characteristics Parameter Input Output Transforming Characteristics  Symbol Min Typ.* Max Unit Condition Forward Voltage VF --- 1.2 1.4 V IF=20mA Reverse Current IR --- --- 5 μA VR=5V Collector capacitance Ct --- 30 250 pF V=0, f=1KHz Collector to emitter Current ICEO --- --- 100 nA VCE=20V, IF=0mA Collector and Emitter attenuation Voltage BV CEO 80 --- --- V IC=0.1mA IF=0mA Emitter and Collector attenuation Voltage BV ECO 7 --- --- V IE=0.1mA IF=0mA *1.Current conversion ratio CTR 50 --- 600 % Collector Current IC 2.5 --- 30 mA Collector and Emitter Saturation Voltage V CE(sat) --- --- 0.2 V IF=20mA IC= 1mA Insulation Impedance R iso --- Ω DC500V 40~60%R.H. Floating Capacitance Cf --- 0.6 1 pF V=0, f=1MHz Response Time tr --- 2.9 10 μs Descend Time tf --- 4.5 10 μs 5×1010 1×1011 IF=5mA VCE=5V VCC=2V, IC=2mA , RL=100Ω Current Conversion Ratio = IC / IF × 100% Copyright© 2020 Orient .All rights Reserved 4 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 7. Rank table of current transfer ratio CTR CTR BIN Min (% ) Max (% ) Condition 80 160 VCE = 5V /IF = 5mA,Ta=25℃ 40 100 VCE = 5V /IF = 1mA,Ta=25℃ 130 260 VCE = 5V /IF = 5mA,Ta=25℃ 50 150 VCE = 5V /IF = 1mA,Ta=25℃ 200 400 VCE = 5V /IF = 5mA,Ta=25℃ 80 300 VCE = 5V /IF = 1mA,Ta=25℃ 300 600 VCE = 5V /IF = 5mA,Ta=25℃ 120 400 VCE = 5V /IF = 1mA,Ta=25℃ A B C D 8. Order Information Part Number OR-357X-S-W-Y-Z-(GK) Note X = CTR Rank (A, B, C, D or none) S = Identification. W = Tape and reel option (TP or TP1). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free . GK = Field Code. * VDE Code can be selected. Option Description Packing quantity TP Surface mount lead form (low profile) + TP tape & reel option 3000 units per reel TP1 Surface mount lead form (low profile) + TP1 tape & reel option 3000 units per reel Copyright© 2020 Orient .All rights Reserved 5 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 9. Naming Rule 1. Manufacturer : ORIENT. 2. Part Number : 357. 3. Rank Code 4. Year Code 5. Week Code 6. VDE Code 7. Process Code :S 8. HF Code. 9. Anode. : CTR Rank : '21' means '2021' and so on. : 01 means the first week, 02 means the second week and so on. . (Optional) 10. Identification. * VDE Code can be selected. Copyright© 2020 Orient .All rights Reserved 6 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 10. Outer Dimension 11. Recommended Foot Print Patterns (Mount Pad) unit:mm Copyright© 2020 Orient .All rights Reserved 7 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 12. Taping Dimensions (1)TP type 2.54±0.1 (2)TP1 type Description Symbol Dimension in mm(inch) Tape wide W 12±0.3(0.472) Pitch of sprocket holes P0 4±0.1(0.157) F 5.5±0.1(0.217) P2 2±0.1(0.079) P1 8±0.1(0.315) Distance of compartment Distance of compartment to compartment Package Type TP/TP1 Quantities(pcs) 3000 Copyright© 2020 Orient .All rights Reserved 8 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 13. Package Dimension (1) package dimension Packing Information Packing type Reel type Tape Width 12mm Qty per Reel 3,000pcs Small box (inner) Dimension 345*345*45mm Large box (Outer) Dimension 480x360x360mm Max qty per small box 6,000pcs Max qty per large box 60,000pcs (2)Packing Label Sample Note: 1. 2. Material Code :Product ID. P/N :Contents with "Order Information" in the specification. 3. Lot No. :Product data. 4. D/C :Product weeks. 5. Quantity :Packaging quantity. Copyright© 2020 Orient .All rights Reserved 9 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 14. Reliability Test NO. 1 ITEMS RSH 耐焊接热 Reliability Testing QTY. (Pcs) 22 Condition 260±5℃ Process 10s/3 次 Device Standard 锡炉 JESD22-A106 高温烤箱 测试仪 JESD22-A103 低温箱 测试仪 JESD22-A119 168 hrs 2 HTSL 高温存储 77 125℃ 500 hrs 1000 hrs 168 hrs 3 LTSL 低温存储 77 -55℃ 500 hrs 1000 hrs 4 5 TC 温度循环 TS 温度冲击 77 H:125℃ 15min ∫5min L:-55℃ 15min 300 cycle 冷热冲击机 JESD22-A104 77 H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle 冷热冲击机 JESD22-A106 高温烤箱 测试仪、老 化电路板 JESD22-A108 ESD静电测 试仪 JESD22-A114 锡炉 JESD22-B102 高温烤箱 ,测试仪 JESD22-A103 恒温恒湿 机,测试仪 JESD22-A101 压力锅 JESD22-A102 168 hrs 6 7 8 9 10 11 HTOL 高温操作 ESD-HBM 人体模式 SD 可焊性 HTRB 高温反向偏压 H3TRB 温湿度反向偏 压,寿命试验 Autoclave 压力锅 110°C IF=10mA Vce=5V 500 hrs 22 ≥8KV 1Cycle 1次 22 Pb-free 245±5℃ 5S/1次 77 HTRB @125℃ Vce=80v 77 77 77 H3TRB 85℃,85%RH Vce=80v Ta=121 ℃,100%RH,2atm Copyright© 2020 Orient .All rights Reserved 1000 hrs 168 hrs 500 hrs 1000 hrs 168 hrs 500 hrs 1000 hrs 96hrs 10 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 15. Temperature Profile Of Soldering (1) IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (T Smin ) 150˚C - Temperature Max (T Smax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2020 Orient .All rights Reserved 11 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) (2) Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3) Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2020 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 12 V3 Shenzhen Orient Components Co ., Ltd OR-357-S-(GK) 16. Characteristics Curve Copyright© 2020 Orient .All rights Reserved 13 V3 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 14 OR-357-S-(GK) V3
OR-357A-S-TP-G-(GK) 价格&库存
很抱歉,暂时无法提供与“OR-357A-S-TP-G-(GK)”相匹配的价格&库存,您可以联系我们找货
