SN74HC165DR(LX)
SN74HC165DR(LX)
    LINGXING(灵星芯微)
    SOP-16
    移位寄存器 2V~6V SOP-16
SN74HC165DR(LX) 数据手册
深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 SN74HC/HCT165 (LX) 8-bit Parallel-in, Serial out Shift Register Product Specification Specification Revision History: Version Date 2021-12-A1 2021-12 Description New Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第1页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 1、General Description The SN74HC/HCT165 is 8-bit serial or parallel-in/serial-out shift registers. The device features a serial — data input (DS), eight parallel data inputs (D0 to D7) and two complementary serial outputs (Q7 and Q7). — When the parallel load input (PL) is LOW the data from D0 to D7 is loaded into the shift register — asynchronously. When PL is HIGH data enters the register serially at DS. When the clock enable input ( — — CE) is LOW data is shifted on the LOW-to-HIGH transitions of the CP input. A HIGH on CE will disable the CP input. Inputs are overvoltage tolerant to 15V. This enables the device to be used in HIGH-to-LOW level shifting applications. Features: ⚫ Input levels: For SN74HC165: CMOS level For SN74HCT165: TTL level ⚫ Asynchronous 8-bit parallel load ⚫ Synchronous serial input ⚫ Specified from -40℃ to +85℃ ⚫ Packaging information: DIP16/SOP16/TSSOP16 Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第2页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 Ordering Information: Tube packing specifications: Type number Packaging form Markingcode Tube quantity Boxed tube quantity Boxed quantity Packing box number Packing quantity SN74HC165N (LX) DIP16 SN74HC165N 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack SN74HCT165N (LX) DIP16 SN74HCT165N 25 PCS/tube 40 tube/box 1000 PCS/box 10 box/pack 10000 PCS/pack Reel packing specifications: Packaging Type number Marking code form Reel quantity Boxed reel quantity Packing quantity 8000 PCS/box 64000 PCS/pack SN74HC165DR(LX) SOP16 SN74HC165 4000 PCS/reel SN74HCT165DR(LX) SOP16 SN74HCT165 4000 PCS/reel 8000 PCS/box 64000 PCS/pack SN74HC165PW(LX) TSSOP16 SN74HC165 5000 PCS/reel 10000 PCS/box 40000 PCS/pack SN74HCT165PW(LX) TSSOP16 SN74HCT165 5000 PCS/reel 10000 PCS/box 40000 PCS/pack Notes Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Notes Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 10.0mm×3.9mm Pin spacing:1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing:0.65mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing:0.65mm Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第3页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 2、Block Diagram And Pin Description 2.1 、Block Diagram Figure 1. Logic symbol Figure 2. IEC logic symbol Figure 3. Functional diagram Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第4页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 Figure 4. Timing diagram 2.2 、Pin Configurations Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第5页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 2.3 、Pin Description Pin No. Pin Name Description — 1 PL asynchronous parallel load input (active LOW) 2 3 4 5 6 CP D4 D5 D6 D7 clock input (LOW-to-HIGH, edge-triggered) parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) 7 Q7 complementary output from the last stage 8 9 10 11 12 13 14 GND Q7 DS D0 D1 D2 D3 ground (0V) serial output from the last stage serial data input parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) parallel data input (also referred to as Dn) 15 CE VCC — — 16 clock enable input (active LOW) supply voltage 2.4 、Function Table Operating mode parallel load Input — PL CE CP DS D0 to D7 Q0 Q1 to Q6 Q7 Q7 L L X X X X X X L H L H L to L H to H L H H L H L ↑ l X L q0 to q5 q6 q6 H L ↑ h X H q0 to q5 q6 q6 H ↑ L l X L q0 to q5 q6 q6 H ↑ L h X H q0 to q5 q6 q6 H H X X X q0 q1 to q6 q7 q7 H X H X X q0 q1 to q6 q7 q7 serial shift hold "do nothing" Output Qn register — — — Note: H=HIGH voltage level; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L=LOW voltage level; ↑=LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; q=state of the referenced output one set-up time prior to the LOW-to-HIGH clock transition; X=don’t care; ↑=LOW-to-HIGH clock transition. Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第6页 共 19 页 VER:2021-12-A3 — — — — — 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 3、Electrical Parameter 3.1 、Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. V supply voltage -0.5 CC input clamping IIK VI < -0.5V or VI > VCC+0.5V current output clamping IOK VO < -0.5V or VO > VCC+0.5V current output current IO -0.5V < VO < VCC+0.5V ICC supply current I ground current GND -50 total power Ptot dissipation storage Tstg -65 temperature DIP 245 soldering TL 10s temperature SOP 250 Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Max. +7 Unit V ±20 mA ±20 mA ±25 50 - mA mA mA 500 mW +150 ℃ ℃ ℃ 3.2 、Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VI VO VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb Conditions SN74HC165 VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 2.0 0 0 - 5.0 1.67 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V - -40 - +85 ℃ 4.5 0 0 - 5.0 1.67 - 5.5 VCC VCC 139 - V V V ns/V ns/V ns/V -40 - +85 ℃ SN74HCT165 VCC=2.0V VCC=4.5V VCC=6.0V - Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第7页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 3.3 、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. SN74HC165 VCC=2.0V 1.5 HIGH-level VIH VCC=4.5V 3.15 input voltage VCC=6.0V 4.2 VCC=2.0V LOW-level VIL VCC=4.5V input voltage VCC=6.0V IO=-20uA; VCC=2.0V 1.9 IO=-20uA; VCC=4.5V 4.4 HIGH-level VOH VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 output voltage IO=-4.0mA; VCC=4.5V 3.98 IO=-5.2mA; VCC=6.0V 5.48 IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V LOW-level IO=20uA; VCC=6.0V VOL VI = VIH or VIL output voltage IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V input leakage VI= VCC or GND; II current VCC=6.0V VI= VCC or GND; IO=0A; ICC supply current VCC=6.0V input CI capacitance SN74HCT165 HIGH-level VIH VCC=4.5V to 5.5V 2.0 input voltage LOW-level VIL VCC=4.5V to 5.5V input voltage IO=-20uA 4.4 HIGH-level VI = VIH or VIL; VOH output voltage VCC=4.5V IO=-4.0mA 3.98 I =20uA; V =4.5V O CC LOW-level VOL VI = VIH or VIL output voltage IO=5.2mA; VCC=6.0V input leakage VI=VCC or GND; II current VCC=6.0V VI=VCC or GND; IO=0A; supply current ICC VCC=6.0V per input pin; Dn and DS inputs VI=VCC-2.1V; additional ΔICC other inputs at VCC — — supply current or GND; CP, CE, and PL inputs VCC=4.5V to 5.5V input CI capacitance Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com Typ. Max. Unit 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V - ±0.1 uA - 8 uA 3.5 - pF 1.6 - V 1.2 0.8 V 4.5 4.32 0 0.16 0.1 0.26 V V V V - ±0.1 uA - 8.0 uA 35 126 uA 65 234 uA 3.5 - pF 第8页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 3.3.2 、DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. SN74HC165 VCC=2.0V 1.5 HIGH-level VIH VCC=4.5V 3.15 input voltage VCC=6.0V 4.2 VCC=2.0V 0.5 LOW-level VIL VCC=4.5V 1.35 input voltage VCC=6.0V 1.8 IO=-20uA; VCC=2.0V 1.9 IO=-20uA; VCC=4.5V 4.4 HIGH-level IO=-20uA; VCC=6.0V 5.9 VOH VI = VIH or VIL output voltage IO=-4.0mA; VCC=4.5V 3.84 IO=-5.2mA; VCC=6.0V 5.34 IO=20uA; VCC=2.0V 0.1 IO=20uA; VCC=4.5V 0.1 LOW-level VOL VI = VIH or VIL IO=20uA; VCC=6.0V 0.1 output voltage IO=4.0mA; VCC=4.5V 0.33 IO=5.2mA; VCC=6.0V 0.33 input leakage VI=VCC or GND; II ±1 current VCC=6.0V VI=VCC or GND; IO=0A; supply current ICC 80 VCC=6.0V SN74HCT165 HIGH-level VIH VCC=4.5V to 5.5V 2.0 input voltage LOW-level VIL VCC=4.5V to 5.5V 0.8 input voltage IO=-20uA 4.4 HIGH-level VI = VIH or VIL; VOH output voltage VCC=4.5V IO=-4.0mA 3.84 IO=20uA; VCC=4.5V 0.1 LOW-level VOL VI = VIH or VIL output voltage IO=5.2mA; VCC=6.0V 0.33 input leakage VI=VCC or GND; II ±1 current VCC=6.0V VI=VCC or GND; IO=0A; supply current ICC 80 VCC=6.0V per input pin; Dn and DS inputs 157.5 VI=VCC-2.1V; additional ΔICC other inputs at VCC — — supply current or GND; 292.5 CP, CE, and PL inputs VCC=4.5V to 5.5V Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第9页 共 19 页 VER:2021-12-A3 Unit V V V V V V V V V V V V V V V V uA uA V V V V V V uA uA uA uA 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 3.3.3 、AC Characteristics 1 (Tamb=25℃, GND=0V, CL=50pf, unless otherwise specified.) Parameter Symbol propagation delay tpd transition time tt pulse width tW recovery time trec set-up time tsu hold time th maximum frequency fmax Conditions SN74HC165 VCC=2.0V — — VCC=4.5V CP, CE to Q7, Q7; VCC=5.0V;CL=15pF see Figure 6 VCC=6.0V VCC=2.0V — — VCC=4.5V PL to Q7, Q7; VCC=5.0V;CL=15pF see Figure 7 VCC=6.0V VCC=2.0V — VCC=4.5V D7 to Q7, Q7; VCC=5.0V;CL=15pF see Figure 8 VCC=6.0V VCC=2.0V — Q7, Q7 output; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V CP input HIGH or LOW; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V — PL input LOW; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — — PL to CP, CE; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — DS to CP, CE; VCC=4.5V see Figure 9 VCC=6.0V — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 VCC=2.0V — Dn to PL; VCC=4.5V see Figure 10 VCC=6.0V — VCC=2.0V DS to CP, CE and — VCC=4.5V Dn to PL; VCC=6.0V see Figure 9 — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 VCC=2.0V CP input; see Figure 6 VCC=4.5V Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com Min. Typ. Max. Unit 80 16 14 80 16 14 100 20 17 80 16 14 80 16 14 80 16 14 5 5 5 5 5 5 6 30 52 19 16 15 50 18 15 14 36 13 11 10 19 7 6 17 6 5 14 5 4 22 8 6 11 4 3 17 6 5 22 8 6 2 2 2 -17 -6 -5 17 51 165 33 28 165 33 28 120 24 20 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz 第 10 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 VCC=5.0V;CL=15pF VCC=6.0V power dissipation capacitance tpd 56 61 - MHz MHz - 35 - pF - 17 14 20 17 14 11 34 40 28 - ns ns ns ns ns ns VCC=4.5V - 7 15 ns VCC=4.5V 16 6 - ns VCC=4.5V 20 9 - ns VCC=4.5V 20 8 - ns VCC=4.5V 20 2 - ns VCC=4.5V 20 7 - ns VCC=4.5V 20 10 - ns VCC=4.5V 7 -1 - ns VCC=4.5V 0 -7 - ns 26 - 44 48 - MHz MHz - 35 - pF per package; VI= GND to VCC CPD SN74HCT165 VCC=4.5V CP, CE to Q7, Q7; VCC=5.0V;CL=15pF see Figure 6 — — VCC=4.5V PL to Q7, Q7; VCC=5.0V;CL=15pF see Figure 7 — VCC=4.5V D7 to Q7, Q7; VCC=5.0V;CL=15pF see Figure 8 — propagation delay 35 — — transition time tt pulse width tW Q7, Q7 output; see Figure 6 CP input; see Figure 6 — PL input; see Figure 7 — recovery time — PL to CP, CE; see Figure 7 trec — DS to CP, CE; see Figure 9 — CE to CP and CP to set-up time — tsu CE; see Figure 9 — Dn to PL; see Figure 10 — DS to CP, CE and — hold time th Dn to PL; see Figure 9 — CE to CP and CP to — CE; see Figure 9 CP input; see Figure 6 VCC=4.5V maximum fmax frequency VCC=5.0V;CL=15pF power per package; dissipation CPD VI= GND to VCC-1.5V capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 11 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. 3.3.4 、AC Characteristics 2 (Tamb=-40℃ to +85℃, GND=0V, CL=50pf, unless otherwise specified.) Parameter Symbol propagation delay tpd transition time tt pulse width tW recovery time trec set-up time tsu hold time th Conditions SN74HC165 VCC=2.0V — — CP, CE to Q7, Q7; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V — — PL to Q7, Q7; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — D7 to Q7, Q7; VCC=4.5V see Figure 8 VCC=6.0V VCC=2.0V — Q7, Q7 output; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V CP input HIGH or LOW; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V — PL input LOW; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — — PL to CP, CE; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — DS to CP, CE; VCC=4.5V see Figure 9 VCC=6.0V — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 VCC=2.0V — Dn to PL; VCC=4.5V see Figure 10 VCC=6.0V — VCC=2.0V DS to CP, CE and — VCC=4.5V Dn to PL; VCC=6.0V see Figure 9 — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com Min. Typ. Max. Unit 100 20 17 100 20 17 125 25 21 100 20 17 100 20 17 100 20 17 5 5 5 5 5 5 - 205 41 35 205 41 35 150 30 26 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 第 12 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 maximum frequency CP input; see Figure 6 fmax — VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT165 — - - MHz MHz MHz VCC=4.5V - - 43 ns VCC=4.5V - - 50 ns VCC=4.5V - - 35 ns VCC=4.5V - - 19 ns VCC=4.5V 20 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 9 - - ns VCC=4.5V 0 - - ns 21 - - MHz — PL to Q7, Q7; see Figure 7 tpd 5 24 28 — CP, CE to Q7, Q7; see Figure 6 propagation delay 编号:SN74HC/HCT165-LX-A165 — D7 to Q7, Q7; see Figure 8 — transition time tt pulse width tW Q7, Q7 output; see Figure 6 CP input; see Figure 6 — PL input; see Figure 7 — recovery time — PL to CP, CE; see Figure 7 trec — DS to CP, CE; see Figure 9 — CE to CP and CP to set-up time — tsu CE; see Figure 9 — Dn to PL; see Figure 10 — DS to CP, CE and — hold time th Dn to PL; see Figure 9 — CE to CP and CP to — CE; see Figure 9 CP input; see Figure 6 maximum fmax VCC=4.5V frequency Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD×VCC2×fi×N)+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 13 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 4、Testing Circuit 4.1 、AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance. S1=Test selection switch. 4.2 、AC Testing Waveforms — — Figure 6. The clock (CP) or clock enable (CE) to output (Q7 or Q7) propagation delays, the clock pulse width, the maximum clock frequency and the output transition times Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 14 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 — — Figure 7. The parallel load (PL) pulse width, the parallel load to output (Q7 or Q7) propagation delays, the — parallel load to clock (CP) and clock enable (CE) recovery time — — Figure 8. The data input (D7) to output (Q7 or Q7) propagation delays when PL is LOW — Figure 9. The set-up and hold times from the serial data input (DS) to the clock (CP) and clock enable (CE) — inputs, from the clock enable input (CE) to the clock input (CP) and from the clock input (CP) to the clock — enable input (CE) Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 15 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 — Figure 10. The set-up and hold times from the data inputs (Dn) to the parallel load input (PL) 4.3 、Measurement Points Input Type VI VCC 3V SN74HC165 SN74HCT165 Output VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V 4.4 、Test Data Type SN74HC165 SN74HCT165 Input VI VCC 3.0V Load tr , tf 6.0ns 6.0ns CL 15pF, 50pF 15pF, 50pF Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com RL 1kΩ 1kΩ S1 position tPHL, tPLH open open 第 16 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 5、Package Information 5.1 、DIP16 Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 17 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 5.2 、SOP16 Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 18 页 共 19 页 VER:2021-12-A3 深圳市灵星芯微电子科技有限公司 Shenzhen Lingxing Microelectronics Technology Co., Ltd. 版次:B1 编号:SN74HC/HCT165-LX-A165 5.3 、TSSOP16 6、Statements And Notes 6.1 、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Lead frame ○ ○ Cadm ium and cadmi um comp ounds ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Part name Lead and lead compo unds Mercur y and mercur y compo unds Hexaval ent chromiu m compoun ds Polybro minated biphenyl s Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ :Indicates that the content of hazardous substances or elements in the detection limit explanation of the following the SJ/T11363-2006 standard. ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. 6.2 、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:808, West Building, Feiyada Building, No. 163, Zhenhua Road, Huahang Community, Huaqiang North Street, Futian District, Shenzhen P.C:518000 www.lingxingic.com 第 19 页 共 19 页 VER:2021-12-A3
