MWE3064CH7AQ
MWE3064CH7AQ
    METORAGE(星火半导体)
    BGA153
    MMC 宽温eMMC,-40~85°,64GB应用领域:勘探、轨道交通、电力设备、汽车电子
MWE3064CH7AQ 数据手册
Tentative Product Specification - MIE3XXXCH7AQ – - MWE3XXXCH7AQ – (eMMC 5.1) -Support HS400- Document Number: E22016 (Version 1.1) Metorage Semiconductor Technology Co.,Ltd. Confidential Tentative CH7AQ Series History of Specification Change Revision History Date Author Preliminary version 2022/08/05 Fang 1.1 Update Chapter 5 2022/10/24 Fang M et or ag e Co nf id en tia l 1.0 Confidential Tentative CH7AQ Series Requirement and Notice This product is provided "as is", and Metorage does not make any other guarantees (whether express, implied, statutory or otherwise) with respect to this product or any part of it. Metorage expressly denies any implied warranties of marketability, suitability for specific uses, and non-infringement. id en tia l 1) The products described in this specification refer to the electronic equipment used in vehicles (navigation, driving recorders, AV equipment, etc.) If you have special quality and reliability requirements, product failure or misuse may directly endanger life safety and human health for special uses (aviation, aerospace, transportation equipment, combustion equipment, life support devices, safety devices, etc.) requirements, or consider to use other than our standard use, please contact us to discuss in detail. 2) Please use within the product guarantee range (especially the working voltage range and temperature range). Metorage will not be responsible for all failures of the machine if it exceeds these specifications. In addition, even if it is used within these specifications, please pay attention to avoid infringement of various laws and regulations due to the operation of our products. nf 3) Please avoid tearing off the label attached to the product of this specification and / or changing the label, as doing so may damage the characteristics and / or quality of the product. M et or ag e Co 4) It is forbidden to copy, photocopy, translate or restore all or part of this document to anyone without Metorage written permission by using electronic media or machine-readable form. Confidential Tentative CH7AQ Series Product Overview • - - tia l en M • - id • • • • • • • • • • • nf • - Co • - e • - or ag • - Support JEDEC eMMC 5.1 compliant Compliant with eMMC Specification Ver. 4.3, 4.4, 4.41, 4.5, 4.51, 5.0,5.1 Bus mode Clock frequency :0-200MHz 12 wire bus (clock, command, 8-bit data bus, data strobe and hardware reset) Support three different data bus widths : 1-bit, 4-bit, 8-bit Data transfer rate: up to 52Mbyte/s (using 8 parallel data lines at 52MHz) Single data rate : up to 200Mbyte/s @200MHz Dual data rate : up to 400Mbyte/s @200MHz Operating voltage range: VCCQ = 1.8V/3.3V VCC = 3.3V Error free memory access Internal error correction code (ECC) to protect data communication Security Support secure erase/trim commands Support Replay Protected Memory Block (RPMB) Support Field Firmware Update(FFU) Support Lock/Unlock Support Data Protection for Power Failure Support Power Saving Sleep Mode Support High Priority Interrupt(HPI) Support Packed Commands Support Sampling Tuning Sequence Support Enhanced Strobe Mode Support Production State Awareness(PSA) Multiple Densities and Packages 153-ball standard BGA packages RoHS Compliant NAND Density MI:16/32/64/128GB MW:16/32/64/128GB Temperature range (Ta) Operation: • -25℃~85℃ (MI) • -40℃~85℃ (MW) Storage: • -40℃~85℃ et • • • - Confidential Tentative CH7AQ Series Table of Contents 1 Introduction ...................................................................................................................................................... 7 2 eMMC Device and System ............................................................................................................................... 8 2.1 eMMC System Overview ......................................................................................................................... 8 2.2 eMMC Device Overview ......................................................................................................................... 8 tia l 2.2.1 Clock (CLK) ..................................................................................................................................................... 8 2.2.2 Data Strobe (DS)............................................................................................................................................ 8 2.2.3 Command (CMD) ........................................................................................................................................... 9 2.2.4 Input/Outputs (DAT0-DAT7) ......................................................................................................................... 9 2.3 Bus Protocol .......................................................................................................................................... 10 2.4 Bus Speed Modes.................................................................................................................................. 10 id en 2.4.1 HS200 Bus Speed Mode ................................................................................................................................ 10 2.4.2 HS200 System Block Diagram...................................................................................................................... 11 2.4.3 HS400 Bus Speed mode ............................................................................................................................... 11 2.4.4 HS400 System Block Diagram ..................................................................................................................... 11 e Co nf 3 eMMC Functional Description........................................................................................................................12 3.1 eMMC Overview .....................................................................................................................................12 3.2 Boot Operation Mode............................................................................................................................12 3.3 Device Identification Mode ...................................................................................................................12 3.4 Interrupt Mode ......................................................................................................................................12 3.5 Data Transfer Mode...............................................................................................................................12 3.6 Inactive Mode.........................................................................................................................................12 3.7 H/W Reset Operation .............................................................................................................................13 3.8 Noise Filtering Timing for H/W Reset ..................................................................................................13 3.9 Field Firmware Update(FFU) ............................................................................................................... 14 3.10 Power off Notification for sleep ........................................................................................................ 14 et or ag 4 Register Settings ............................................................................................................................................ 16 4.1 OCR Register.......................................................................................................................................... 16 4.2 CID Register ........................................................................................................................................... 16 4.3 CSD Register.......................................................................................................................................... 16 4.4 Extended CSD Register .........................................................................................................................17 4.5 RCA Register.......................................................................................................................................... 23 4.6 DSR Register .........................................................................................................................................24 5 The eMMC bus ................................................................................................................................................ 25 5.1 Power-up ................................................................................................................................................ 25 M 5.1.1 eMMC power-up ............................................................................................................................................25 5.1.2 eMMC Power Cycling ................................................................................................................................... 26 5.2 Bus Operating Condition ...................................................................................................................... 27 5.2.1 Power supply: eMMC ................................................................................................................................. 27 5.2.2 eMMC Power Supply Voltage...................................................................................................................... 28 5.2.3 Bus Signal Line Load .................................................................................................................................... 28 5.2.4 HS400 reference load.................................................................................................................................. 29 5.3 Bus Signal Levels ................................................................................................................................... 30 5.3.1 Open-drain Mode Bus Signal Level .............................................................................................................. 30 Confidential Tentative CH7AQ Series 5.3.2 Push-pull mode bus signal level — eMMC .................................................................................................. 30 5.3.3 Bus Operating Conditions for HS200 & HS400............................................................................................ 31 5.3.4 Device Output Driver Requirements for HS200 & HS400 ........................................................................... 31 5.4 Bus Timing ..............................................................................................................................................31 5.4.1 Device Interface Timings .............................................................................................................................. 31 5.5 Bus Timing for DAT Signals During Dual Data Rate Operation ......................................................... 33 5.5.1 Dual Data Rate Interface Timings ................................................................................................................33 5.6 Bus Timing Specification in HS200 Mode ...........................................................................................34 tia l 5.6.1 HS200 Clock Timing..................................................................................................................................... 34 5.6.2 HS200 Device Input Timing..........................................................................................................................35 5.6.3 HS200 Device Output Timing .......................................................................................................................35 5.7 Bus Timing Specification in HS400 mode ........................................................................................... 37 id en 5.7.1 HS400 Device Input Timing ..........................................................................................................................37 5.7.2 HS400 Device Output Timing ...................................................................................................................... 38 6 Package connections ..................................................................................................................................... 39 7 Ball Assignment (153 ball).............................................................................................................................. 41 nf 8 Marking...........................................................................................................................................................42 M et or ag e Co 9 Appendix.........................................................................................................................................................42 9.1 Endurance characteristic ...................................................................................................................... 42 Confidential Tentative CH7AQ Series 1 Introduction Metorage eMMC products is a highly integrated solution which combines a feature-wise flash controller and standard NAND flash memory. Its high performance and low power make the Metorage eMMC products a fabulous solution for embedded and portable applications. tia l The Metorage eMMC products leverages industry leading technology and experience in NAND management. In addition, the Metorage eMMC products supports the standard eMMC interface as well as the newly introduced eMMC features such as HS400 mode and FFU. By integrating all the advanced techniques, the Metorage eMMC products is able to further enhance the data transferring efficiency and optimizes the overall performance for embedded systems. id en Available in various densities, the Metorage eMMC products offers the features, performance, and flexibility exactly for mobile handset, navigation, automotive infotainment, multi-function printer, and next-generation consumer applications. With extended temperature support and high data reliability, offering easy and rapid design integration, the Metorage eMMC products also ideally fits the requirements of point-of-sale terminals, networking and telecommunications equipment, and a variety of leading-edge industrial applications. Table 1-1 Product Part Number NAND Density Package Operating voltage MIE3016CH7 16GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V MIE3032CH7 32GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V MIE3064CH7 64GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V MIE3128CH7 128GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V 16GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V 32GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V 64GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V 128GB BGA153 VCC=3.3V VCCQ=1.8V/3.3V MWE3064CH7 or ag MWE3128CH7 Co MWE3032CH7 e MWE3016CH7 nf Product Part Number Table 1-2 Read/Write Performance Products M et MIE3016CH7 MIE3032CH7 MIE3064CH7 MIE3128CH7 MWE3016CH7 MWE3032CH7 MWE3064CH7 MWE3128CH7 Typical value Read Sequential (MB/s) Write Sequential (MB/s) 220 178 178 178 220 178 178 178 48 26 45 63 48 26 45 63 Note 1: Values given for an 8-bit bus width, running HS400 mode from tool, VCC=3.3V,VCCQ=1.8V. Note 2: Performance numbers might be subject to changes without notice. 7 Confidential Tentative CH7AQ Series Table 1-3 User Density Size Device User Density 16GB 32GB 64GB 128GB 15099904 KBytes 30535680 KBytes 61071360 KBytes 122142720 KBytes Table 1-4 Capacity according to partition Boot partition 2 16GB 32GB 64GB 128GB 4096 KB 4096 KB 4096 KB 4096 KB 4096 KB 4096 KB 4096 KB 4096 KB RPMB tia l Boot partition 1 4096 KB 4096 KB 4096 KB 4096 KB id en Capacity 2 eMMC Device and System 2.1 eMMC System Overview nf System Performance The eMMC specification covers the behavior of the interface and the Device controller. As part of this specification the existence of a host controller and a memory storage array are implied but the operation of these pieces is not fully specified. or ag e Co Metorage NAND Device consists of a single chip MMC controller and NAND flash memory module. The microcontroller interfaces with a host system allowing data to be written to and read from the NAND flash memory module. The controller allows the host to be independent from details of erasing and programming the flash memory. et Figure 2-1 eMMC System Overview 2.2 eMMC Device Overview M The eMMC device transfers data via a configurable number of data bus signals. The communication signals are: 2.2.1 Clock (CLK) Each cycle of this signal directs a one bit transfer on the command and either a one bit (1x) or a two bits transfer (2x) on all the data lines. The frequency may vary between zero and the maximum clock frequency. 2.2.2 Data Strobe (DS) This signal is generated by the device and used for output in HS400 mode. The frequency of this signal follows the frequency of CLK. For data output each cycle of this signal directs two bits transfer(2x) on the data - one bit for positive edge and the other bit for negative edge. For CRC status response output and CMD response output 8 Confidential Tentative CH7AQ Series (enabled only HS400 enhanced strobe mode), the CRC status is latched on the positive edge only, and don't care on the negative edge. 2.2.3 Command (CMD) This signal is a bidirectional command channel used for Device initialization and transfer of commands. The CMD signal has two operation modes: open-drain for initialization mode, and push-pull for fast command transfer. Commands are sent from the eMMC host controller to the eMMC Device and responses are sent from the Device to the host. 2.2.4 Input/Outputs (DAT0-DAT7) CLK I DAT0-DAT7 I/O CMD I/O RST_n I Description Clock id Type1 nf Name en Table 2-1 Communication Interface VCC VCCQ VSSQ RCLK CMD e VDDi TX or ag NC RFU Data Command/Response Hardware reset S Supply voltage for Core S Supply voltage for I/O S Supply voltage ground for Core S Supply voltage ground for I/O O eMMC interface Data strobe I/O Command/Response -- Internal voltage node O UART Tx output for debug use - No connect - Reserved for future use. Leave it floating Co VSS tia l These are bidirectional data channels. The DAT signals operate in push-pull mode. Only the Device or the host is driving these signals at a time. By default, after power up or reset, only DAT0 is used for data transfer. A wider data bus can be configured for data transfer, using either DAT0-DAT3 or DAT0- DAT7, by the eMMC host controller. The eMMC Device includes internal pull-ups for data lines DAT1- DAT7. Immediately after entering the 4-bit mode, the Device disconnects the internal pull-ups of lines DAT1, DAT2, and DAT3. Correspondingly, immediately after entering to the 8-bit mode the Device disconnects the internal pull-ups of lines DAT1–DAT7. et Note 1:I: input; O: output; S: power supply. Note 2: VDDi: A 1.0uF capacitor is required for VDDi for core power stabilization. Do not tie to supply voltage or ground. Name Description RCA 2 DSR 2 Device Identification number, an individual number for identification. Relative Device Address is the Device system address, dynamically assigned by the host during initialization. Driver Stage Register, to configure the Device’s output drivers. CSD 16 Device Specific Data, information about the Device operation conditions. OCR 4 EXT_CSD 512 M CID Width (Bytes) 16 Table 2-2 eMMC Registers Operation Conditions Register. Used by a special broadcast command to identify the voltage type of the Device. Extended Device Specific Data. Contains information about the Device capabilities and selected modes. Introduced in standard v4.0 9 Implementation Mandatory Mandatory Mandatory Optional Mandatory Mandatory Confidential Tentative CH7AQ Series The host may reset the device by: • • • Switching the power supply off and back on. The device shall have its own power-on detection circuitry which puts the device into a defined state after the power-on Device. A reset signal By sending a special command 2.3 Bus Protocol tia l After a power-on reset, the host must initialize the device by a special message-based eMMC bus protocol. For more details, refer to section 5.3.1 of the JEDEC Standard Specification No.JESD84-B51. 2.4 Bus Speed Modes eMMC defines several bus speed modes as shown in Table 2-3. id en Table 2-3 Bus Speed Mode Data Rate IO Voltage Bus Width Frequency Max Data Transfer (implies x8 bus width) Backwards Compatibility with legacy MMC card Single 3.3/1.8V 1, 4, 8 0-26MHz 26MB/s High Speed SDR Single 3.3/1.8V 4, 8 0-52MHz 52MB/s High Speed DDR Dual 3.3/1.8V 4, 8 0-52MHz 104MB/s HS200 Single 1.8V 4, 8 0-200MHz 200MB/s HS400 Dual 1.8V 8 0-200MHz 400MB/s Co 2.4.1 HS200 Bus Speed Mode nf Mode Name The HS200 mode offers the following features: or ag e SDR Data sampling method CLK frequency up to 200MHz Data rate – up to 200MB/s 4 or 8-bits bus width supported Single ended signaling with 4 selectable Drive Strength Signaling levels of 1.8V Tuning concept for Read Operations M et • • • • • • 10 Confidential Tentative CH7AQ Series 2.4.2 HS200 System Block Diagram id en tia l Figure 2-2 shows a typical HS200 Host and Device system. The host has a clock generator, which supplies CLK to the Device. For write operations, clock and data direction are the same, write data can be transferred synchronous with CLK, regardless of transmission line delay. For read operations, clock and data direction are opposite; the read data received by Host is delayed by round-trip delay, output delay and latency of Host and Device. For reads, the Host needs to have an adjustable sampling point to reliably receive the incoming data. 2.4.3 HS400 Bus Speed mode The HS400 mode has the following features: Co DDR Data sampling method CLK frequency up to 200MHz, Data rate is – up to 400MB/s Only 8-bit bus width supported Signaling levels of 1.8V Support up to 5 selective Drive Strength Data strobe signal is toggled only for Data out and CRC response e • • • • • • nf Figure 2-2 System Block Diagram or ag 2.4.4 HS400 System Block Diagram M et Figure 2-3 shows a typical HS400 Host and Device system. The host has a clock generator, which supplies CLK to the Device. For read operations, Data Strobe is generated by device output circuit. Host receives the data which is aligned to the edge of Data Strobe. Figure 2-3 HS400 Host and Device block diagram 11 Confidential Tentative 3 eMMC Functional Description CH7AQ Series 3.1 eMMC Overview All communication between host and device are controlled by the host (main chip). The host sends a command, which results in a device response. For more details, refer to section 6.1 of the JEDEC Standard Specification No.JESD84-B51. Five operation modes are defined for the eMMC system: Boot operation mode Device identification mode Interrupt mode Data transfer mode Inactive mode tia l • • • • • en 3.2 Boot Operation Mode id In boot operation mode, the master (eMMC host) can read boot data from the slave (eMMC device) by keeping CMD line low or sending CMD0 with argument + 0xFFFFFFFA, before issuing CMD1. The data can be read from either boot area or user area depending on register setting. For more details, refer to section 6.3 of the JEDEC Standard Specification No.JESD84-B51. nf 3.3 Device Identification Mode 3.4 Interrupt Mode Co While in device identification mode the host resets the device, validates operation voltage range and access mode, identifies the device and assigns a Relative Device Address (RCA) to the device on the bus. All data communication in the Device Identification Mode uses the command line (CMD) only. For more details, refer to section 6.4 of the JEDEC Standard Specification No.JESD84-B51. or ag e The interrupt mode on the eMMC system enables the master (eMMC host) to grant the transmission allowance to the slaves (Device) simultaneously. This mode reduces the polling load for the host and hence, the power consumption of the system, while maintaining adequate responsiveness of the host to a Device request for service. Supporting eMMC interrupt mode is an option, both for the host and the Device. For more details, refer to section 6.5 of the JEDEC Standard Specification No.JESD84-B51. 3.5 Data Transfer Mode When the Device is in Stand-by State, communication over the CMD and DAT lines will be performed in push-pull mode. For more details, refer to section 6.6 of the JEDEC Standard Specification No.JESD84-B51. et 3.6 Inactive Mode M The device will enter inactive mode if either the device operating voltage range or access mode is not valid. The device can also enter inactive mode with GO_INACTIVE_STATE command (CMD15). The device will reset to Pre-idle state with power cycle. For more details, refer to section 6.1 of the JEDEC Standard Specification No.JESD84-B51. 12 Confidential Tentative CH7AQ Series id en tia l 3.7 H/W Reset Operation Figure 3-1 H/W Reset Waveform Note 1: Device will detect the rising edge of RST_n signal to trigger internal reset sequence. nf Table 3-1 H/W Reset Timing Parameters Comment tRSTW RST_n pulse width tRSCA RST_n to Command time tRSTH RST_n high period (interval time) Co Symbol Min Max Unit 1 - [us] 2001 - [us] 1 - [us] Note: 74 cycles of clock signal required before issuing CMD1 or CMD0 with argument 0xFFFFFFFA. e 3.8 Noise Filtering Timing for H/W Reset M et or ag Device must filter out 5ns or less pulse width for noise immunity Figure 3-2 Noise Filtering Timing for H/W Reset Device must not detect these rising edge. Device must not detect 5ns or less of positive or negative RST_n pulse. Device must detect more than or equal to 1us of positive or negative RST_n pulse width. 13 Confidential Tentative CH7AQ Series 3.9 Field Firmware Update(FFU) Co nf id en tia l Field Firmware Updates (FFU) enables features enhancement in the field. Using this mechanism the host downloads a new version of the firmware to the eMMC device and, following a successful download, instructs the eMMC device to install the new downloaded firmware into the device. In order to start the FFU process the host first checks if the eMMC device supports FFU capabilities by reading SUPPPORTED_MODES and FW_CONFIG fields in the EXT_CSD. If the eMMC device supports the FFU feature the host may start the FFU process. The FFU process starts by switching to FFU Mode in MODE_CONFIG field in the EXT_CSD. In FFU Mode host should use closed-ended or open ended commands for downloading the new firmware and reading vendor proprietary data. In this mode, the host should set the argument of these commands to be as defined in FFU_ARG field. In case these commands have a different argument the device behavior is not defined and the FFU process may fail. The host should set Block Length to be DATA_SECTOR_SIZE. Downloaded firmware bundle must be DATA_SECTOR_SIZE size aligned (internal padding of the bundle might be required).Once in FFU Mode the host may send the new firmware bundle to the device using one or more write commands. The host could regain regular functionality of write and read commands by setting MODE_CONFIG field in the EXT_CSD back to Normal state. Switching out of FFU Mode may abort the firmware download operation. When host switched back to FFU Mode, the host should check the FFU Status to get indication about the number of sectors which were downloaded successfully by reading the NUMBER_OF_FW_SECTORS_CORRECTLY_PROGRAMMED in the extended CSD. In case the number of sectors which were downloaded successfully is zero the host should re-start downloading the new firmware bundle from its first sector. In case the number of sectors which were downloaded successfully is positive the host should continue the download from the next sector, which would resume the firmware download operation. In case MODE_OPERATION_CODES field is not supported by the device the host sets to NORMAL state and initiates a CMD0/HW_Reset/Power cycle to install the new firmware. In such case the device doesn’t need to use NUMBER_OF_FW_SECTORS_CORRECTLY_PROGRAMMED. In both cases occurrence of a CMD0/HW_Reset/Power occurred before the host successfully downloaded the new firmware bundle to the device may cause the firmware download process to be aborted. 3.10 Power off Notification for sleep M et or ag e The host should notify the device before it powers the device off. This allows the device to better prepare itself for being powered off. Power the device off means to turn off all its power supplies. In particular, the host should issue a power off notification (POWER_OFF_LONG, POWER_OFF_SHORT ) if it intends to turn off both VCC and VCCQ power supplies or it may use to a power off notification (SLEEP_NOTIFICATION ) if it intends to turn-off VCC after moving the device to Sleep state. To indicate to the device that power off notification is supported by the host, a supporting host shall first set the POWER_OFF_NOTIFICATION byte in EXT_CSD [34] to POWERED_ON (0x01). To execute a power off, before powering the device down the host will changes the value to either POWER_OFF_SHORT (0x02) or POWER_OFF_LONG (0x03). Host should waits for the busy line to be de-asserted. Once the setting has changed to either 0x02 or 0x03, host may safely power off the device. The host may issue SLEEP_AWAKE (CMD5) to enter or to exit from Sleep state if POWER_OFF_NOTIFICATION byte is set to POWERED_ON. Before moving to Standby state and then to Sleep state, the host sets POWER_OFF_NOTIFICATION to SLEEP_NOTIFICATION and waits for the DAT0 line de-assertion. While in Sleep (slp) state VCC (Memory supply) may be turned off as defined in 4.1.6. Removing power supplies other than VCC while the device is in the Sleep (slp) state may result in undefined device behavior. Before removing all power supplies, the host should transition the device out of Sleep (slp) state back to Transfer state using CMD5 and CMD7 and then execute a power off notification setting POWER_OFF_NOTIFICATION byte to either POWER_OFF_SHORT or POWER_OFF_LONG. If host continues to send commands to the device after switching to the power off setting (POWER_OFF_LONG, POWER_OFF_SHORT or SLEEP_NOTIFICATION) or performs HPI during its busy condition, the device shall restore the POWER_OFF_NOTIFICATION byte to POWERED_ON. If host tries to change POWER_OFF_NOTIFICATION to 0x00 after writing another value there, a SWITCH_ERROR is generated. The difference between the two power-off modes is how urgent the host wants to turn power off. The device should respond to POWER_OFF_SHORT quickly under the generic CMD6 timeout. If more time is acceptable, POWER_OFF_LONG may be used and the device shall respond to it within the POWER_OFF_LONG_TIME timeout. 14 Confidential Tentative CH7AQ Series While POWER_OFF_NOTIFICATION is set to POWERED_ON, the device expects the host to host shall: • Keep the device power supplies alive (both VCC and VCCQ) and in their active mode • Not power off the device intentionally before changing POWER_OFF_NOTIFICATION to either POWER_OFF_LONG or POWER_OFF_SHORT • Not power off VCC intentionally before changing POWER_OFF_NOTIFICATION to SLEEP_NOTIFICATION and before moving the device to Sleep state M et or ag e Co nf id en tia l Before moving to Sleep state hosts may set the POWER_OFF_NOTIFICATION byte to SLEEP_NOTIFICATION (0x04) if aware that the device is capable of autonomously initiating background operations for possible performance improvements. Host should wait for the busy line to be de-asserted. Busy line may be asserted up the period defined in SLEEP_NOTIFICATION_TIME byte in EXT_CSD [216]. Once the setting has changed to 0x04 host may set the device into Sleep mode (CMD7+CMD5). After getting out from Sleep the POWER_OFF_NOTIFICATION byte will restore its value to POWERED_ON. HPI may interrupt the SLEEP_NOTIFICATION operation. In that case POWER_OFF_NOTIFICATION byte will restore to POWERED_ON. 15 Confidential Tentative 4 Register Settings CH7AQ Series Within the Device interface six registers are defined: OCR, CID, CSD, EXT_CSD, RCA and DSR. These can be accessed only by corresponding commands (see Section 6.10 of JESD84-B51). 4.1 OCR Register The 32-bit operation conditions register (OCR) stores the VDD voltage profile of the Device and the access mode indication. In addition, this register includes a status information bit. This status bit is set if the Device power up procedure has been finished. The OCR register shall be implemented by all Devices. Table 4-1 OCR Register fields tia l OCR Register Definitions OCR bit [31] nf id en VDD voltage window Value (Device power up status bit(busy) (Note1) 00b(byte mode) [30:29] Access Mode 10b(sector mode) [28:24] Reserved [23:15] 2.7-3.6V 111111111b [14:8] 2.0-2.6V 0000000b [7] 1.7-1.95V 1b [6:0] Reserved Note: This bit is set to LOW if the Device has not finished the power up routine. 4.2 CID Register The Card Identification (CID) register is 128 bits wide. It contains the Device identification information used during the Device identification phase (eMMC protocol). For details, refer to JEDEC Standard Specification No.JESD84-B51 Co Table 4-2 CID Register fields or ag e CID Fields Name Field Width Manufacturer ID MID 8 Reserved 6 Device/BGA CBX 2 OEM/Application ID OID 8 Product name PNM 48 Product revision PRV 8 Product serial number PSN 32 MDT 8 Manufacturing data CRC7 checksum CRC 7 Not used, always “1” 1 Note: The description are same as eMMC™ JEDEC standard. CID slice [127:120] [119:114] [113:112] [111:104] [103:56] [55:48] [47:16] [15:8] [7:1] [0] Value C4h 1h FFh 4D45544F5241h Random by Production month, year - (Note 1) 1h et 4.3 CSD Register M The Card-Specific Data (CSD) register provides information on how to access the contents stored in eMMC. The CSD registers are used to define the error correction type, maximum data access time, data transfer speed, data format…etc. For details, refer to section 7.3 of the JEDEC Standard Specification No.JESD84- B51. Name CSD structure System specification version Reserved Data read access-time 1 Table 4-3 CSD Register fields Field CSD_STRUCTURE SPEC_VERS TAAC 16 Width 2 4 2 8 CSD-slice [127:126] [125:122] [121:120] [119:112] Value 3h 4h 2Fh Confidential Tentative CH7AQ Series 8 [111:104] 1h TRAN_SPEED CCC READ_BL_LEN READ_BL_PARTIAL WRITE_BLK_MISALIGN READ_BLK_MISALIGN DSR_IMP C_SIZE VDD_R_CURR_MIN VDD_R_CURR_MAX VDD_W_CURR_MIN VDD_W_CURR_MAX C_SIZE_MULT ERASE_GRP_SIZE ERASE_GRP_MULT WP_GRP_SIZE WP_GRP_ENABLE DEFAULT_ECC R2W_FACTOR WRITE_BL_LEN WRITE_BL_PARTIAL CONTENT_PROT_APP FILE_FORMAT_GRP COPY PERM_WRITE_PROTECT TMP_WRITE_PROTECT FILE_FORMAT ECC CRC - 8 12 4 1 1 1 1 2 12 3 3 3 3 3 5 5 5 1 2 3 4 1 4 1 1 1 1 1 2 2 7 1 [103:96] [95:84] [83:80] [79] [78] [77] [76] [75:74] [73:62] [61:59] [58:56] [55:53] [52:50] [49:47] [46:42] [41:37] [36:32] [31] [30:29] [28:26] [25:22] [21] [20:17] [16] [15] [14] [13] [12] [11:10] [9:8] [7:1] [0:0] 2Ah DF5h 9h 0h 0h 0h 0h FFFh 6h 6h 6h 6h 7h 1Fh 1Fh 1Fh 1h 0h 1h 9h 0h 0h 0h 0h 0h 0h 0h 0h 1h Co nf id en tia l NSAC or ag e Data read access-time2 in CLK cycle(NSAC*100) Max. bus clock frequency Device command classes Max. read data block length Partial blocks for read allowed Write block misalignment Read block misalignment DSR implemented Reserved Device size Max. read current @ VDD min Max. read current @ VDD max Max. write current @ VDD min Max. write current @ VDD max Device size multiplier Erase group size Erase group size multiplier Write protect group size Write protect group enable Manufacturer default ECC Write speed factor Max. write data block length Partial blocks for write allowed Reserved Content protection application File format group Copy flag (OTP) Permanent write protection Temporary write protection File format ECC code CRC Not used, always ’1’ 4.4 Extended CSD Register M et The Extended CSD register defines the Device properties and selected modes. It is 512 bytes long. The most significant 320 bytes are the Properties segment, which defines the Device capabilities and cannot be modified by the host. The lower 192 bytes are the Modes segment, which defines the configuration the Device is working in. These modes can be changed by the host by means of the SWITCH command. For details, refer to section 7.4 of the JEDEC Standard Specification No.JESD84-B51. Name Table 4-4 Extended CSD Register fields Field Size (Bytes) CSD-slice Value Properties Segment Reserved - 6 [511:506] - Extended Security Commands Error EXT_SECURITY_ERR 1 [505] 0h Supported Command Sets S_CMD_SET 1 [504] 01h 17 Confidential Tentative HPI features CH7AQ Series HPI_FEATURES 1 [503] 03h BKOPS_SUPPORT 1 [502] 01h MAX_PACKED_READS 1 [501] 3Fh MAX_PACKED_WRITES 1 [500] 3Fh Data Tag Support DATA_TAG_SUPPORT 1 [499] 01h Tag Unit Size TAG_UNIT_SIZE 1 [498] 01h [497] 0h [496] 05h [495] 0h [494] 03h 1 [493] 01h 1 [492] 01h 1 [491] 17h 4 [490:487] 0h 1 [486] 0h 177 [485:309] - 1 [308] 0h Background operations support Max packed read commands Max packed write Commands TAG_RES_SIZE 1 CONTEXT_CAPABILITIES 1 Large Unit size LARGE_UNIT_SIZE_M1 1 Extended partitions attribute support EXT_SUPPORT 1 Supported modes SUPPORTED_MODES FFU features FFU_FEATURES Operation codes timeout OPERATION_CODE_TIME_OUT FFU Argument FFU_ARG Barrier support BARRIER_SUPPORT Reserved – CMDQ support CMDQ_SUPPORT CMDQ depth CMDQ_DEPTH 1 [307] 0h Reserved – 1 [306] - 4 [305:302] 0h 32 [301:270] 0h 1 [269] 01h 1 [268] 01h en id nf Co e Number of FW sectors NUMBER_OF_FW_SECTORS_ correctly programmed CORRECTLY_PROGRAMMED Vendor proprietary VENDOR_PROPRIETARY _HEALTH_REPORT health Report Device life time DEVICE_LIFE_TIME_EST_TYP_B estimation type B Device life time estimation DEVICE_LIFE_TIME_EST_TYP_A type A or ag tia l Tag Resources Size Context management Capabilities PRE_EOL_INFO 1 [267] 01h Optimal read size OPTIMAL_READ_SIZE 1 [266] 08h Optimal write size OPTIMAL_WRITE_SIZE 1 [265] 08h Optimal trim unit size OPTIMAL_TRIM_UNIT_SIZE 1 [264] 08h Device version DEVICE_VERSION 2 [263:262] 0h M et Pre EOL information Firmware version FIRMWARE_VERSION 8 [261:254] B0506h Power class for 200MHz, DDR at VCC=3.6V PWR_CL_DDR_200_360 1 [253] 0h Cache size CACHE_SIZE 4 [252:249] 100h Generic CMD6 timeout GENERIC_CMD6_TIME 1 [248] 32h Power off notification(long) Timeout POWER_OFF_LONG_TIME 1 [247] 3Ch 18 Confidential Tentative CH7AQ Series BKOPS_STATUS 1 [246] 0h Number of correctly programmed sectors CORRECTLY_PRG_SECTORS_NUM 4 [245:242] 0h 1st initialization time after Partitioning INI_TIMEOUT_AP 1 [241] 1Eh Cache Flushing Policy CACHE_FLUSH_POLICY 1 [240] 0h PWR_CL_DDR_52_360 1 [239] 0h PWR_CL_DDR_52_195 1 PWR_CL_200_195 1 PWR_CL_200_130 1 [237] 0h [236] 0h 1 [235] 0h 1 [234] 0h 1 [233] – 1 [232] 02h nf MIN_PERF_DDR_R_8_52 0h id en MIN_PERF_DDR_W_8_52 [238] – TRIM Multiplier TRIM_MULT Secure Feature support SEC_FEATURE_SUPPORT 1 [231] 55h Secure Erase Multiplier SEC_ERASE_MULT 1 [230] 1Bh Secure TRIM Multiplier SEC_TRIM_MULT 1 [229] 11h BOOT_INFO 1 [228] 07h Reserved – 1 [227] – Boot partition size BOOT_SIZE_MULTI 1 [226] 20h Access size ACC_SIZE 1 [225] 06h High-capacity erase unit size HC_ERASE_GRP_SIZE 1 [224] 01h High-capacity erase timeout ERASE_TIMEOUT_MULT 1 [223] 01h Reliable write sector count REL_WR_SEC_C 1 [222] 01h High-capacity write protect group size HC_WP_GRP_SIZE 1 [221] 20h Sleep current (VCC) S_C_VCC 1 [220] 07h Sleep current (VCCQ) S_C_VCCQ 1 [219] 07h Production state awareness Timeout PRODUCTION_STATE_AWARE NESS_TIMEOUT 1 [218] 17h M e or ag Boot information Co Reserved et Power class for 52MHz, DDR at 3.6V Power class for 52MHz, DDR at 1.95V Power class for 200MHz at 3.6V Power class for 200MHz, at 1.95V Minimum Write Performance for 8bit, at 52MHz in DDR mode Minimum Read Performance for 8bit, at 52MHz in DDR mode tia l Background operations Status 19 Confidential Tentative CH7AQ Series S_A_TIMEOUT 1 [217] 17h Sleep Notification timeout SLEEP_NOTIFICATION_TIME 1 [216] 11h 4 [215:212] SECURE_WP_INFO 1 [211] 0h MIN_PERF_W_8_52 1 [210] 0h MIN_PERF_R_8_52 1 [209] 0h MIN_PERF_W_8_26_4_52 1 [208] 0h 1 [207] 0h 1 [206] 0h MIN_PERF_R_4_26 1 [205] 0h – 1 [204] – PWR_CL_26_360 1 [203] 0h PWR_CL_52_360 1 [202] 0h PWR_CL_26_195 1 [201] 0h PWR_CL_52_195 1 [200] 0h PARTITION_SWITCH_TIME 1 [199] 05h Out-of-interrupt busy timing OUT_OF_INTERRUPT_TIME 1 [198] 19h I/O Driver Strength DRIVER_STRENGTH 1 [197] 0Fh Device type DEVICE_TYPE 1 [196] 57h Reserved – 1 [195] – CSD structure version CSD_STRUCTURE 1 [194] 02h Reserved – 1 [193] – Extended CSD revision EXT_CSD_REV 1 [192] 08h Command set CMD_SET 1 [191] 0h Reserved – 1 [190] – MIN_PERF_R_8_26_4_52 MIN_PERF_W_4_26 M et e or ag Partition switching timing Co Reserved Power class for 26MHz at 3.6V 1 R Power class for 52MHz at 3.6V 1 R Power class for 26MHz at 1.95V 1 R Power class for 52MHz at 1.95V 1 R en Security write protect information Minimum Write Performance for 8bit at 52MHz Minimum Read Performance for 8bit at 52MHz Minimum Write Performance for 8bit at 26MHz, for 4bit at 52MHz Minimum Read Performance for 8bit at 26MHz, for 4bit at 52MHz Minimum Write Performance for 4bit at 26MHz Minimum Read Performance for 4bit at 26MHz nf Sector Count 20 tia l SEC_COUNT 1CCD000h-16GB 3A3E000h 32GB 747C000h-64GB E8F8000h-128GB id Sleep/awake timeout Confidential Tentative CH7AQ Series CMD_SET_REV 1 [189] 0h Reserved – 1 [188] – Power class POWER_CLASS 1 [187] 0h Reserved – 1 [186] – High-speed interface timing HS_TIMING 1 [185] 0h Strobe support STROBE_SUPPORT 1 [184] 01h Bus width mode BUS_WIDTH 1 [183] 0h Reserved – 1 [182] – Erased memory content ERASED_MEM_CONT Reserved – Partition configuration PARTITION_CONFIG Boot config protection [181] 0h 1 [180] – 1 [179] 0h BOOT_CONFIG_PROT 1 [178] 0h Boot bus Conditions BOOT_BUS_CONDITIONS 1 [177] 0h Reserved – 1 [176] – ERASE_GROUP_DEF 1 [175] 0h BOOT_WP_STATUS 1 [174] 0h BOOT_WP 1 [173] 0h – 1 [172] – User area write protection Register USER_WP 1 [171] 0h Reserved – 1 [170] – FW configuration FW_CONFIG 1 [169] 0h RPMB Size RPMB_SIZE_MULT 1 [168] 20h WR_REL_SET 1 [167] 0h WR_REL_PARAM 1 [166] 14h SANITIZE_START 1 [165] 0h BKOPS_START 1 [164] 0h BKOPS_EN 1 [163] 0h et Co or ag Reserved e High-density erase group Definition Boot write protection status Registers Boot area write protection Register M Write reliability setting Register Write reliability parameter Register Start Sanitize operation Manually start background Operations Enable background operations handshake nf 1 id en tia l Command set revision 21 Confidential Tentative CH7AQ Series H/W reset function RST_n_FUNCTION 1 [162] 0h HPI management HPI_MGMT 1 [161] 0h Partitioning Support PARTITIONING_SUPPORT 1 [160] 07h MAX_ENH_SIZE_MULT 3 [159:157] Partitions attribute PARTITIONS_ATTRIBUTE 1 [156] 0h Partitioning Setting PARTITION_SETTING_COMPLETED 1 [155] 0h GP_SIZE_MULT4 3 [154:152] 0h id en 3 [151:149] 0h 3 [148:146] 0h 3 [145:143] 0h 3 [142:140] 0h ENH_START_ADDR 4 [139:136] 0h – 1 [135] – GP_SIZE_MULT2 GP_SIZE_MULT1 nf ENH_SIZE_MULT SEC_BAD_BLK_MGMNT 1 [134] 0h Production state awareness PRODUCTION_STATE_AWARENESS 1 [133] 0h TCASE_SUPPORT 1 [132] 0h PERIODIC_WAKEUP 1 [131] 0h Program CID/CSD in DDR mode support PROGRAM_CID_CSD_DDR_SUPPORT 1 [130] 01h Reserved – 2 [129:128] – Vendor Specific Fields VENDOR_SPECIFIC_FIELD 61 [127:67] – Error code ERROR_CODE 2 [66:65] 0h Error type ERROR_TYPE 1 [64] 0h Native sector size NATIVE_SECTOR_SIZE 1 [63] 0h Sector size emulation USE_NATIVE_SECTOR 1 [62] 0h Sector size DATA_SECTOR_SIZE 1 [61] 0h 1st initialization after disabling sector size emulation INI_TIMEOUT_EMU 1 [60] 0h Package Case Temperature is controlled M or ag Periodic Wake-up e Bad Block Management Mode et Reserved GP_SIZE_MULT3 Co General Purpose Partition Size General Purpose Partition Size General Purpose Partition Size General Purpose Partition Size Enhanced User Data Area Size Enhanced User Data Start Address tia l Max Enhanced Area Size 13Bh-16GB 26Bh-32GB 4D7h-64GB 9AEh-128GB 22 Confidential Tentative CH7AQ Series CLASS_6_CTRL 1 [59] 0h Number of addressed group to be Released DYNCAP_NEEDED 1 [58] 0h Exception events control EXCEPTION_EVENTS_CTRL 2 [57:56] 0h Exception events status EXCEPTION_EVENTS_STATUS 2 [55:54] 0h Extended Partitions Attribute EXT_PARTITIONS_ATTRIBUTE 2 [53:52] 0h Context configuration CONTEXT_CONF 15 [51:37] - Packed command status PACKED_COMMAND_STATUS 1 [36] 0h Packed command failure PACKED_FAILURE_INDEX 1 [35] 0h Power Off Notification POWER_OFF_NOTIFICATION Control to turn the Cache ON/OFF CACHE_CTRL Flushing of the cache FLUSH_CACHE Barrier control BARRIER CTRL Mode config [34] 0h 1 [33] 0h 1 [32] 0h 1 [31] 0h MODE_CONFIG 1 [30:30] 0h Mode operation codes MODE_OPERATION_CODES 1 [29:29] 0h Reserved – 2 [28:27] – FFU_STATUS 1 [26:26] 0h [25:22] 0h Co e FFU status nf 1 id en tia l Class 6 commands control 4 Max pre loading data size MAX_PRE_LOADING_DATA_SIZE 4 [21:18] Product state awareness Enablement PRODUCT_STATE_AWARENESS_ENABLEM ENT 9D8000h-16GB 1358000h-32GB 26B8000h-64GB 4D70000h-128GB 1 [17:17] 03h Secure removal type SECURE_REMOVAL_TYPE 1 [16:16] 09h Command Queue Mode enable CMQ _MODE_EN 1 [15:15] 0h Reserved – 16 [14:0] – PRE_LOADING_DATA_SIZE M et or ag Per loading data size 4.5 RCA Register The writable 16-bit Relative Device Address (RCA) register carries the Device address assigned by the host during the Device identification. This address is used for the addressed host-Device communication after the Device identification procedure. The default value of the RCA register is 0x0001. The value 0x0000 is reserved to set all Devices into the Stand-by State with CMD7. 23 Confidential Tentative CH7AQ Series 4.6 DSR Register M et or ag e Co nf id en tia l The 16-bit driver stage register (DSR) is described in detail in Section 7.6 of the JEDEC Standard Specification No.JESD84-B51.It can be optionally used to improve the bus performance for extended operating conditions (depending on parameters like bus length, transfer rate or number of Devices). The CSD register carries the information about the DSR register usage. 24 Confidential Tentative 5 The eMMC bus CH7AQ Series The eMMC bus has ten communication lines and three supply lines: Co nf id en • • • CMD:Command is a bidirectional signal. The host and Device drivers are operating in two modes, open drain and push/pull. DAT0-7:Data lines are bidirectional signals. Host and Device drivers are operating in push-pull mode CLK:Clock is a host to Device signal. CLK operates in push-pull mode Data Strobe: Data Strobe is a Device to host signal. Data Strobe operates in push-pull mode. tia l • e Figure 5-1 Bus Circuitry Diagram or ag The ROD is switched on and off by the host synchronously to the open-drain and push-pull mode transitions. The host does not have to have open drain drivers, but must recognize this mode to switch on the ROD. RDAT and RCMD are pull- up resistors protecting the CMD and the DAT lines against bus floating device when all device drivers are in a high- impedance mode. A constant current source can replace the ROD by achieving a better performance (constant slopes for the signal rising and falling edges). If the host does not allow the switchable ROD implementation, a fixed RCMD can be used).Consequently the maximum operating frequency in the open drain mode has to be reduced if the used RCMD value is higher than the minimal one given in. et RDatastrobe is pull-down resistor used in HS400 device. M 5.1 Power-up 5.1.1 eMMC power-up An eMMC bus power-up is handled locally in each device and in the bus master. Figure 5-2 shows the power-up sequence and is followed by specific instructions regarding the power-up sequence. Refer to section 10.1 of the JEDEC Standard Specification No.JESD84-B51 for specific instructions regarding the power-up sequence. 25 CH7AQ Series id en tia l Confidential Tentative nf Figure 5-2 eMMC Power-up Diagram 5.1.2 eMMC Power Cycling M et or ag e Co The master can execute any sequence of VCC and VCCQ power-up/power-down. However, the master must not issue any commands until VCC and VCCQ are stable within each operating voltage range. After the slave enters sleep mode, the master can power-down VCC to reduce power consumption. It is necessary for the slave to be ramped up to VCC before the host issues CMD5 (SLEEP_AWAKE) to wake the slave unit. For more information about power cycling see Section 10.1.3 of the JEDEC Standard Specification No. JESD84-B51. Figure 5-3 The eMMC Power Cycle 26 Confidential Tentative CH7AQ Series 5.2 Bus Operating Condition Table 5-1 General Operating Conditions Symbol Min Max Unit Peak voltage on all lines - -0.5 VCCQ +0.5 V - -100 100 μA - -2 2 μA All Inputs Input Leakage Current (before initialization sequence 1 and/or the internal pull up resistors connected) Input Leakage Current (after initialization sequence and the internal pull up resistors disconnected) All Outputs Output Leakage Current (before initialization sequence) Output Leakage Current (after initialization sequence) 2 tia l Parameter -100 100 -2 2 Note1:Initialization sequence is defined in section 10.1 of the JEDEC Standard Specification No. JESD84-B51. Note2:DS (Data strobe) pin is excluded. μA μA en - id 5.2.1 Power supply: eMMC Figure 5-4 eMMC Internal Power Diagram M et or ag e Co nf In the eMMC, VCC is used for the NAND flash device and its interface voltage; VCCQ is for the controller and the MMC interface voltage as shown in Figure 5-4. The core regulator is optional and only required when internal core logic voltage is regulated from VCCQ. A CReg capacitor must be connected to the VDDi terminal to stabilize regulator output on the system. 27 Confidential Tentative CH7AQ Series 5.2.2 eMMC Power Supply Voltage The eMMC supports one or more combinations of VCC and VCCQ as shown in Table 5-2. The VCCQ must be defined at equal to or less than VCC. Table 5-2 eMMC Operating Voltage Symbol VCC Supply voltage (I/O) VCCQ Supply power-up for 3.3V Supply power-up for 1.8V tPRUH tPRUL Min 2.7 1.7 2.7 - Max 3.6 1.95 3.6 35 25 Unit V V V ms ms tia l Parameter Supply voltage (NAND) The eMMC must support at least one of the valid voltage configurations, and can optionally support all valid voltage configurations (see Table ). en Table 5-3 eMMC Voltage Combinations VCCQ 2.7V–3.6V 1 1.7V–1.95V Valid id 2.7V-3.6V Vcc Valid Note: VCCQ (I/O) 3.3 volt range is not supported in HS200 /HS400 devices. nf 5.2.3 Bus Signal Line Load CL = CHOST + CBUS + CDEVICE Co The total capacitance CL of each line of the eMMC bus is the sum of the bus master capacitance CHOST, the bus capacitance CBUS itself and the capacitance CDEVICE of eMMC connected to this line: The sum of the host and bus capacitances must be under 20pF. Table 5-4 Signal Line Load Symbol Min Max Typ Unit 𝑅𝑅𝐶𝐶MD 4.7 50 10 Kohm 10 50 10 Kohm 𝑅𝑅RST_n _n 4.7 50 10 Kohm CL - 30 30 pF 𝐶𝐶BGA - 6 6 pF - - 16 16 nH - 45 55 50 ohm 𝑆𝑆𝑆𝑆𝐶𝐶𝐶𝐶𝐶𝐶 0 47 0 ohm 0 47 0 ohm - 2.2+0.1 10+0.22 2.2+0.1 e Parameter Pull-up resistance for CMD or ag Pull-up resistance for DAT0–7 Pull-up resistance for RST_n Bus signal line capacitance Single Device capacitance et Maximum signal line inductance Impedance on CLK / CMD / DAT0 ~ 7 Serial’s resistance on CLK line Serial’s resistance on CMD / DAT0 ~ 7 line 𝑅𝑅DAT CH1 1 2.2 1 VCC capacitor value - 2.2+0.1 10+0.22 4.7+0.1 μF VDDi capacitor value - 1+0.1 2.2+0.1 1+0.1 μF M VCCQ decoupling capacitor 𝑆𝑆𝑆𝑆𝐶𝐶𝐶𝐶𝐶𝐶 𝑆𝑆R 𝐷𝐷AT0~7 28 μF Confidential Tentative CH7AQ Series 5.2.4 HS400 reference load nf id en tia l The circuit in Figure 5-5 shows the reference load used to define the HS400 Device Output Timings and overshoot / undershoot parameters. The reference load is made up by the transmission line and the CREFERENCE capacitance. The reference load is not intended to be a precise representation of the typical system environment nor a depiction of the actual load presented by a production tester. System designers should use IBIS or other simulation tools to correlate the reference load to system environment. Manufacturers should correlate to their production test conditions. Delay time (td) of the transmission line has been introduced to make the reference load independent from the PCB technology and trace length. M et or ag e Co Figure 5-5 HS400 reference load 29 Confidential Tentative CH7AQ Series 5.3 Bus Signal Levels id en tia l As the bus can be supplied with a variable supply voltage, all signal levels are related to the supply voltage. nf Figure 5-6 Bus Signal Levels 5.3.1 Open-drain Mode Bus Signal Level Table 5-5 Open-drain Bus Signal Level Symbol VOH VOL Min VDD – 0.2 Max - 0.3 Co Parameter Output HIGH voltage Output LOW voltage - Unit V V Conditions IOH = -100 μA IOL = 2 mA The input levels are identical with the push-pull mode bus signal levels. e 5.3.2 Push-pull mode bus signal level — eMMC or ag The device input and output voltages shall be within the following specified ranges for any VDD of the allowed voltage range. For 1.70V – 1.95V VCCQ range (Compatible with EIA/JEDEC Standard “EIA/JESD8-7 Normal Range” as defined in the following table.) Parameter Symbol Min Max Unit Conditions et Table 5-6 Push-pull Signal Level—1.70 -1.95 VCCQ Voltage Range Output HIGH voltage VOH VCCQ – 0.45V - V IOH = -2mA Output LOW voltage VOL - 0.45V V IOL = 2mA 1 0.65 * VCCQ VCCQ + 0.3 V - VSS – 0.3 2 0.35 * VDD V - M Input HIGH voltage Input LOW voltage VIH VIL Note 1: 0.7 * VDD for MMC™4.3 and older revisions. Note 2: 0.3 * VDD for MMC™4.3 and older revisions. 30 Confidential Tentative CH7AQ Series For 2.7V-3.6V VCCQ range (compatible with JESD8C.01) Table 5-7 Push-pull Signal Level—High-voltage eMMC Symbol Min Max Unit Conditions Output HIGH voltage VOH - V IOH = -100 μA @ VCCQ min Output LOW voltage VOL 0.75 * VCCQ V IOL = 100 μA @ VCCQ min Input HIGH voltage VIH 0.125 * VCCQ V - Input LOW voltage VIL V - - VCCQ + 0.3 0.625 * VCCQ VSS – 0.3 0.25 * VCCQ 5.3.3 Bus Operating Conditions for HS200 & HS400 tia l Parameter en The bus operating conditions for HS200 devices is the same as specified in sections 10.5.1 of JESD84- B51 through 10.5.2 of JESD84-B51. 5.3.4 Device Output Driver Requirements for HS200 & HS400 id Refer to section 10.5.4 of the JEDEC Standard Specification No.JESD84-B51. et or ag e Co nf 5.4 Bus Timing Figure 5-7 Timing Diagram M 5.4.1 Device Interface Timings Table 5-8 High-speed Device Interface Timing Parameter Symbol Clock CLK1 Min Max Unit Clock frequency Data Transfer Mode(PP)2 fPP 0 523 MHz Clock frequency Identification Mode(OD) Clock high time fOD tWH 0 6.5 400 kHz ns 31 - Confidential Tentative - 3 3 - 13.7 - 3 ns ns ns ns ns ns ns ns tia l tWL 6.5 tTLH tTHL Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 3 Input hold time tIH 3 Outputs CMD, DAT (referenced to CLK) Output delay time during data transfer tODLY Output hold time tOH 2.5 Signal rise time5 tRISE - CH7AQ Series Clock low time Clock rise time4 Clock fall time en Note1:CLK timing is measured at 50% of VDD. Note2:eMMC shall support the full frequency range from 0-26Mhz or 0-52MHz. Note3:Device can operate as high-speed Device interface timing at 26 MHz clock frequency. Note4:CLK rise and fall times are measured by min (VIH) and max (VIL). Note5:Inputs CMD DAT rise and fall times are measured by min (VIH) and max (VIL) and outputs CMD DAT rise and fall times are measured by min (VOH) and max (VOL). Table 5-9 Backward-compatible Device Interface Timing Symbol Min Max Unit 2 Clock CLK Clock frequency Data Transfer Mode (PP)3 fPP 0 26 MHz Clock frequency Identification Mode (OD) fOD 0 400 kHz Clock high time tWH 10 Clock low time tWL 10 ns Clock rise time4 tTLH 10 ns Clock fall time tTHL 10 ns Inputs CMD, DAT (referenced to CLK) Input set-up time tISU 3 ns Input hold time tIH 3 ns Outputs CMD, DAT (referenced to CLK) Output set-up time5 tOSU 11.7 ns Output hold time5 tOH 8.3 ns Note1:The Device must always start with the backward-compatible interface timing. The timing mode can be switched to high-speed interface timing by the host sending the SWITCH command (CMD6) with the argument for high-speed interface select. Note2:CLK timing is measured at 50% of VDD. Note3:For compatibility with Devices that support the v4.2 standard or earlier, host should not use > 26 MHz before switching to high-speed interface timing. Note4:CLK rise and fall times are measured by min (VIH) and max (VIL). Note5:tOSU and tOH are defined as values from clock rising edge. However, there may be Devices or devices which utilize clock falling edge to output data in backward compatibility mode. Therefore, it is recommended for hosts either to settWL value as long as possible within the range which will not go over tCK-tOH(min) in the system or to use slow clock frequency, so that host could have data set up margin for those devices. In this case, each device which utilizes clock falling edge might show the correlation either between tWL and tOSU or between tCK and tOSU for the device in its own datasheet as a note or its application notes. M et or ag e Co nf id Parameter 32 Confidential Tentative CH7AQ Series 5.5 Bus Timing for DAT Signals During Dual Data Rate Operation Co nf id en tia l These timings apply to the DAT[7:0] signals only when the device is configured for dual data mode operation. In this dual data mode, the DAT signals operate synchronously of both the rising and the falling edges of CLK. The CMD signal still operates synchronously of the rising edge of CLK and therefore complies with the bus timing specified in section 10.5 of the JEDEC Standard Specification No.JESD84-B51, therefore there is no timing change for the CMD signal. Figure 5-8 Timing Diagram: Data Input/Output in Dual Data Rate Mode 5.5.1 Dual Data Rate Interface Timings Symbol or ag Parameter e Table 5-10 High-speed Dual Data Rate Interface Timing Clock duty cycle Input set-up time Input hold time Min Max Unit 45 55 % - ns ns Input CLK1 - Input DAT (referenced to CLK-DDR mode) tISUddr 2.5 tIHddr 2.5 Output DAT (referenced to CLK-DDR mode) - M et Output delay time during data tODLYd dr 1.5 7 ns transfer Signal rise time (all signals)2 tRISE 2 ns Signal fall time (all signals) tFALL 2 ns Note1:CLK timing is measured at 50% of VDD. Note2:Inputs CMD, DAT rise and fall times are measured by min (VIH) and max (VIL), and outputs CMD, DAT rise and fall times are measured by min (VOH) and max (VOL). 33 Confidential Tentative CH7AQ Series 5.6 Bus Timing Specification in HS200 Mode 5.6.1 HS200 Clock Timing id en tia l Host CLK Timing in HS200 mode shall conform to the timing specified in Figure 5-9 and Table 5-11. CLK input shall satisfy the clock timing over all possible operation and environment conditions. CLK input parameters should be measured while CMD and DAT lines are stable high or low, as close as possible to the Device. The maximum frequency of HS200 is 200MHz. Hosts can use any frequency up to the maximum that HS200 mode allows. Figure 5-9 HS200 Clock Signal Timing nf Note 1:VIH denote VIH(min.) and VIL denotes VIL(max.). Note 2:VT = 50% of VCCQ, indicates clock reference point for timing measurements. Table 5-11 HS200 Clock Signal Timing M et or ag e tTLH, tTHL Duty Cycle Min 5 30 Co Symbol tPERIOD 34 Max t 0.2* PERIOD 70 Unit ns ns % Confidential Tentative CH7AQ Series en tia l 5.6.2 HS200 Device Input Timing id Figure 5-10 HS200 Device Input Timing Note 1: tISU and tIH are measured at VIL(max.) and VIH(min.). Note 2: VIH denote VIH(min.) and VIL denotes VIL(max.). nf Table 5-12 HS200 Device Input Timing Min 1.4 0.8 5.6.3 HS200 Device Output Timing Co Symbol tISU tIH Max - Unit ns ns M et or ag e tPH parameter is defined to allow device output delay to be longer than tPERIOD. After initialization, the tPH may have random phase relation to the clock. The Host is responsible to find the optimal sampling point for the Device outputs, while switching to the HS200 mode. Figure 5-11 and Table 5-13 define Device output timing. While setting the sampling point of data, a long term drift, which mainly depends on temperature drift, should be considered. The temperature drift is expressed by ΔTPH. Output valid data window (tVW) is available regardless of the drift (ΔTPH) but position of data window varies by the drift, as described in Figure 5-12. Figure 5-11 HS200 Device Output Timing Note: VOH denotes VOH(min.) and VOL denotes VOL(max.). 35 Confidential Tentative CH7AQ Series Table 5-13 Output Timing Unit UI ps UI nf id en tia l Symbol Min Max tPH 0 2 -350 (ΔT=-20°C) +1550 (ΔT=90°C) ΔTPH TVW 0.575 Note:Unit Interval (UI) is one bit nominal time. For example, UI=5ns at 200MHz. Co Figure 5-12 ΔTPH consideration M et or ag e Implementation Guide: Host should design to avoid sampling errors that may be caused by the ΔTPH drift. It is recommended to perform tuning procedure while Device wakes up, after sleep. One simple way to overcome the ΔTPH drift is by reduction of operating frequency. 36 Confidential Tentative CH7AQ Series 5.7 Bus Timing Specification in HS400 mode 5.7.1 HS400 Device Input Timing id en tia l The CMD input timing for HS400 mode is the same as CMD input timing for HS200 mode. Figure 5-13 and Table 5-14 show Device input timing. nf Figure 5-13 HS400 Device Data input timing Note 1: tISU and tIH are measured at VIL(max.) and VIH(min.). Note 2: VIH denote VIH(min.) and VIL denotes VIL(max.). Parameter Co Table 5-14 HS400 Device input timing Symbol Min Max Unit Input CLK tPERIOD 5 - - Slew rate SR 1.125 - V/ns tCKDCD 0 0.3 ns tCKMPW 2.2 - ns or ag Duty cycle distortion e Cycle time data transfer mode Minimum pulse width Input DAT (referenced to CLK) tISUddr 0.4 - ns Input hold time tIHddr 0.4 - ns Slew rate SR 1.125 - V/ns M et Input set-up time 37 Confidential Tentative CH7AQ Series 5.7.2 HS400 Device Output Timing en tia l The Data Strobe is used to read data in HS400 mode. The Data Strobe is toggled only during data read or CRC status response. id Figure 5-14 HS400 Device output timing Note: VOH denotes VOH(min.) and VOL denotes VOL(max.). Note: VT = 50% of VCCQ, indicates clock reference point for timing measurements. Symbol Cycle time data transfer mode Slew rate Duty cycle distortion Minimum pulse width Read pre-amble tPERIOD SR tDSDCD tDSMPW tRPRE e Read post- amble Min Data Strobe 5 1.125 0 2 0.4 Co Parameter nf Table 5-15 HS400 Device Output timing tRPST 0.4 or ag Output DAT (referenced to Data Strobe) Slew rate SR 1.125 Note: Measured with HS400 reference load(6.2.4). Max Unit 0.2 - V/ns ns ns tPERIOD - tPERIOD - V/ns Table 5-16 HS400 Capacitance Symbol RCMD RDAT RDS Rint CDevice M et Parameter Pull-up resistance for CMD Pull-up resistance for DAT0-7 Pull-down resistance for Data Strobe Internal pull up resistance DAT1-DAT7 Single Device capacitance 38 Min 4.7 10 10 10 Type - - - Max 50 50 50 150 6 Unit Kohm Kohm Kohm Kohm pF Confidential Tentative 6 Package connections CH7AQ Series M et or ag e Co nf id en tia l Package Mechanical (11.5mm x 13.0mm) 39 CH7AQ Series or ag e Co nf id en tia l Confidential Tentative M et Note: The size data is tentative. 40 Confidential Tentative CH7AQ Series Co nf id en tia l 7 Ball Assignment (153 ball) M et or ag e Figure 7-1 153 ball assignment (Top View, Ball Side Down) 41 Confidential Tentative CH7AQ Series tia l 8 Marking YYYYYYYYYYYY id en XXXXXXXX eMMC logo nf CHINA Co ZZZZZZZZ: Part Number XXXXXXXX: Control Code1 9 Appendix or ag e YYYYYYYYYYYY: Control Code2 9.1 Endurance characteristic M et 3,000 cycles/block (nominal value: under specified conditions) *This value is not guaranteed 42
MWE3064CH7AQ 价格&库存
很抱歉,暂时无法提供与“MWE3064CH7AQ”相匹配的价格&库存,您可以联系我们找货
