A20-H
A20-H
    ALLWINNER(全志科技)
    BGA441
    搭配电源芯片AXP209
A20-H 数据手册
Dual-Core Mobile Application Processor Multi-core performance is now a critical requirement of new consumer, home, and auto infotainment devices. As computing resource requirements increase, computing power must adapt in response. Applications like web-browsing, streaming video, gaming, and file sharing are growing in complexity as users require faster and more enjoyable content. Allwinner’s A20 processor, a dual-core Cortex™-A7 system, delivers a multi-core solution for tablets, smart TV, IPTV, and portable devices that effectively balances system cost, performance, and power consumption. Applications The A20 processor is based on a dual-core ARM® Cortex™-A7 CPU architecture, the most energy efficient application processor from ARM®. In addition, ARM®’s dual-core Mali400MP2 GPU enables both smooth UI transitions and fluid 3D gaming performance. A20 also enables a full HD video experience with H.264 1080p@30fps encoding and 2160p decoding. A20 gives customers superior advantages in system cost and time-to-market. A20 lowers system cost by integrating an extensive range of interfaces, codecs, and connectivity including 4-CH CVBS out, VGA, LVDS/RGB LCD, HDMI with HDCP, SATA, USB, GMAC, and audio. A20’s pin-to-pin compatibility with Allwinner’s previous generation A10 simplifies the product design cycle and enables customers to directly upgrade already-mature single-core platforms directly to dual-core. ©2013 Allwinner Technology www.allwinnertech.com Features CPU • ARM® Cortex™-A7 Dual-Core GPU • • ARM® Mali400MP2 Complies with OpenGL ES 2.0/1.1 • • • • • HD H.264 2160p video decoding Multi-format FHD video decoding, including Mpeg1/2, Mpeg4 SP/ASP GMC, H.263, H.264, VP6/8, AVS jizun, Jpeg/Mjpeg, etc. H.264 High Profile 1080p@30fps or 720p@60fps encoding 3840x1080@30fps 3D decoding, BD/SBS/TAB/FP supported Complies with RTSP, HTTP,HLS,RTMP,MMS streaming media protocols Display • • • • • Supports multi-channel HD display Integrated HDMI 1.4 transmitter with HDCP support CPU/RGB/LVDS LCD interface Supports CVBS/YPbPr/VGA Integrated TV decoder Camera • • • • Integrated parallel 8-bit I/F YUV sensor Integrated 24-bit parallel YUV 444 I/F Supports 5M CMOS sensor Supports dual sensors Memory • • DDR2/DDR3/DDR3L controller NAND Flash controller with 64-bit ECC Audio • • Integrated Hi-Fi 100dB audio codec Dual analog mic amplifiers OS • Android 4.2 and above Video ©2013 Allwinner Technology www.allwinnertech.com A20 Brief Selection Guide Allwinner Cortex-A Family A31 A31s A10s A20 A13 CPU Quad-Core Cortex™-A7 Quad-Core Cortex™-A7 Dual-Core Cortex™-A7 Single-Core Cortex™-A8 Single-Core Cortex™-A8 GPU SGX544MP2 SGX544MP2 Mali400MP2 Mali400 Mali400 Video Playback 4Kx2K 2160p 2160p 1080p 1080p Video Capture H.264 HP 1080p@60fps H.264 HP 1080p@30fps 720p@60fps H.264 HP 1080p@30fps 720p@60fps H.264 MP 720p@30fps H.264 MP 720p@30fps LCD 2048X1536 1280x800 1280x800 1024x768 1024x600 Package BGA609 18mmx18mm 0.65mm Pitch BGA460 18mmx18mm 0.80mm Pitch BGA441 19mmx19mm 0.80mm Pitch BGA336 14mmx14mm 0.65mm Pitch eLQFP176 20mmx20mm Applications Tablet Smart TV Phablet Tablet Smart TV HDMI Dongle Tablet E-reader About Allwinner Allwinner Technology is a leading fabless design company dedicated to smart application processor SoCs and smart analog ICs. Its product line includes multi-core application processors for smart devices and smart power management ICs used by brands worldwide. With its focus on cutting edge UHD video processing, high performance multi-core CPU/GPU integration, and ultra-low power consumption, Allwinner Technology is a mainstream solution provider for the global tablet, internet TV, smart home device, automotive in-dash device, smart power management, and mobile connected device markets. Allwinner Technology is headquartered in Zhuhai, China. This brief is for reference only and has no commitment. All content contained herein is subject to changes without notice. For more information, please contact service@allwinnertech.com. ©2013 Allwinner Technology www.allwinnertech.com
A20-H 价格&库存
很抱歉,暂时无法提供与“A20-H”相匹配的价格&库存,您可以联系我们找货
