RS256M32LD3D1LMZ-125BT
    RAYSON(晶存)
    BGA178
    LPDDR3
RS256M32LD3D1LMZ-125BT 数据手册
178-Ball, Single-Channel Mobile LPDDR3 SDRAM Features Mobile LPDDR3 SDRAM RS256M32LD3D1LMZ,RS512M32LD3D2LMZ,RS1G32LD3D4LMM Features Options Marking • VDD1/VDD2/VDDCA/VDDQ: 1.8V/1.2V/1.2V/1.2V • Array configuration – 256 Meg x 32 (SDP) – 512 Meg x 32 (DDP) – 1 Gig x 32 (QDP) • Device configuration – 1 die in package – 2 die in package – 4 die in package • 178-ball FBGA “green” package – 11mm x 11.5mm x 0.85mm MAX, 1 die, 2 die – 12mm x 11.5mm x 1.0mm MAX, 4 die • Speed grade, cycle time – 938ps @ RL = 16 – 1.071ns @ RL = 14 – 1.25ns @ RL = 12 • Operating temperature range – From -25°C to +85°C • Revision • Ultra-low-voltage core and I/O power supplies • Frequency range – 1066–10 MHz (data rate range: 2133–20 Mb/s/ pin) • 8n prefetch DDR architecture • 8 internal banks for concurrent operation • Multiplexed, double data rate, command/address inputs; commands entered on each CK_t/CK_c edge • Bidirectional/differential data strobe per byte of data (DQS_t/DQS_c) • Programmable READ and WRITE latencies (RL/WL) • Burst length: 8 • Per-bank refresh for concurrent operation • Temperature-compensated self refresh (TCSR) • Partial-array self refresh (PASR) • Deep power-down mode (DPD) • Selectable output drive strength (DS) • Clock-stop capability • On-die termination (ODT) • RoHS-compliant, “green” packaging L 256M32 512M32 1G32 D1 D2 D4 MZ MM –093 –107 –125 Table 1: Key Timing Parameters Speed Grade Clock Rate (MHz) Data Rate (Mb/s/pin) Write Latency (set A/set B) Read Latency –093 1066 2133 8/13 16 –107 933 1866 8/11 14 –125 800 1600 6/9 12 Table 2: Configuration Addressing Architecture 1 Gig x 32 512 Meg x 32 256 Meg x 32 32Gb 16Gb 8Gb 4 2 1 Ranks (CS_n) per channel 2 2 1 Die per rank CS0_n 2 1 1 CS1_n 2 1 – Density per package Die per package 1 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information Table 2: Configuration Addressing (Continued) Architecture 1 Gig x 32 512 Meg x 32 256 Meg x 32 CS0_n 64 Meg x 16 x 8 banks x 2 rank 32 Meg x 32 x 8 banks 32 Meg x 32 x 8 banks CS1_n 64 Meg x 16 x 8 banks x 2 rank 32 Meg x 32 x 8 banks – Row addressing 32K A[14:0] 32K A[14:0] 32K A[14:0] Column addressing/CS_n 2K A[10:0] 1K A[9:0] 1K A[9:0] Configuration per rank (CS_n) Part Number Ordering Information Figure 1: Part Number Chart 2 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information Contents Ball Assignments ............................................................................................................................................ Ball Descriptions ............................................................................................................................................ Package Block Diagrams ................................................................................................................................. Package Dimensions ....................................................................................................................................... MR0, MR5, MR6, MR8 Readout ....................................................................................................................... IDD Specifications – Single Die ......................................................................................................................... Pin Capacitance ............................................................................................................................................. LPDDR3 Array Configuration .......................................................................................................................... General Notes ............................................................................................................................................ Functional Description ................................................................................................................................... Simplified Bus Interface State Diagram ............................................................................................................ Power-Up and Initialization ............................................................................................................................ Voltage Ramp and Device Initialization ....................................................................................................... Initialization After Reset (Without Voltage Ramp) ........................................................................................ Power-Off Sequence ....................................................................................................................................... Uncontrolled Power-Off Sequence .............................................................................................................. Standard Mode Register Definition .................................................................................................................. Mode Register Assignments and Definitions ................................................................................................ Commands and Timing .................................................................................................................................. ACTIVATE Command ..................................................................................................................................... 8-Bank Device Operation ............................................................................................................................ Read and Write Access Modes ......................................................................................................................... Burst READ Command ................................................................................................................................... tDQSCK Delta Timing ................................................................................................................................. Burst WRITE Command .................................................................................................................................. Write Data Mask ............................................................................................................................................. PRECHARGE Command ................................................................................................................................. Burst READ Operation Followed by PRECHARGE ......................................................................................... Burst WRITE Followed by PRECHARGE ....................................................................................................... Auto Precharge ........................................................................................................................................... Burst READ with Auto Precharge ................................................................................................................. Burst WRITE with Auto Precharge ............................................................................................................... REFRESH Command ...................................................................................................................................... REFRESH Requirements ............................................................................................................................. SELF REFRESH Operation ............................................................................................................................... Partial-Array Self Refresh (PASR) – Bank Masking ......................................................................................... Partial-Array Self Refresh – Segment Masking .............................................................................................. MODE REGISTER READ ................................................................................................................................. MRR Following Idle Power-Down State ........................................................................................................ Temperature Sensor ................................................................................................................................... DQ Calibration ........................................................................................................................................... MODE REGISTER WRITE ................................................................................................................................ MRW RESET Command .............................................................................................................................. MRW ZQ Calibration Commands ................................................................................................................ ZQ External Resistor Value, Tolerance, and Capacitive Loading ..................................................................... MRW – CA Training Mode ........................................................................................................................... MRW - Write Leveling Mode ........................................................................................................................ On-Die Termination (ODT) ............................................................................................................................. ODT Mode Register .................................................................................................................................... Asychronous ODT ...................................................................................................................................... 3 10 12 14 17 19 20 24 25 25 26 28 30 30 32 33 33 34 34 44 45 45 46 47 49 53 57 58 59 60 61 61 62 64 67 69 70 70 72 73 74 75 77 77 78 81 81 83 85 85 85 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information ODT During READ Operations (READ or MRR) ............................................................................................ 86 ODT During Power-Down ........................................................................................................................... 86 ODT During Self Refresh ............................................................................................................................. 86 ODT During Deep Power-Down .................................................................................................................. 86 ODT During CA Training and Write Leveling ................................................................................................ 86 Power-Down .................................................................................................................................................. 89 Deep Power-Down ......................................................................................................................................... 95 Input Clock Frequency Changes and Stop Events ............................................................................................. 96 Input Clock Frequency Changes and Clock Stop with CKE LOW ................................................................... 96 Input Clock Frequency Changes and Clock Stop with CKE HIGH .................................................................. 97 NO OPERATION Command ............................................................................................................................ 97 Truth Tables ................................................................................................................................................... 98 Absolute Maximum Ratings ........................................................................................................................... 105 Electrical Specifications – IDD Measurements and Conditions ......................................................................... 106 IDD Specifications ...................................................................................................................................... 108 AC and DC Operating Conditions ................................................................................................................... 110 AC and DC Logic Input Measurement Levels for Single-Ended Signals ............................................................. 111 VREF Tolerances ......................................................................................................................................... 112 Input Signal .............................................................................................................................................. 113 AC and DC Logic Input Measurement Levels for Differential Signals ................................................................ 115 Single-Ended Requirements for Differential Signals .................................................................................... 116 Differential Input Crosspoint Voltage ......................................................................................................... 117 Input Slew Rate ......................................................................................................................................... 118 Output Characteristics and Operating Conditions ........................................................................................... 120 Single-Ended Output Slew Rate .................................................................................................................. 120 Differential Output Slew Rate ..................................................................................................................... 122 HSUL_12 Driver Output Timing Reference Load ......................................................................................... 124 Output Driver Impedance .............................................................................................................................. 125 Output Driver Impedance Characteristics with ZQ Calibration .................................................................... 126 Output Driver Temperature and Voltage Sensitivity ..................................................................................... 126 Output Impedance Characteristics Without ZQ Calibration ......................................................................... 127 ODT Levels and I-V Characteristics ............................................................................................................ 131 Clock Specification ........................................................................................................................................ 132 tCK(abs), tCH(abs), and tCL(abs) ................................................................................................................ 133 Clock Period Jitter .......................................................................................................................................... 133 Clock Period Jitter Effects on Core Timing Parameters ................................................................................. 133 Cycle Time Derating for Core Timing Parameters ........................................................................................ 134 Clock Cycle Derating for Core Timing Parameters ....................................................................................... 134 Clock Jitter Effects on Command/Address Timing Parameters ..................................................................... 134 Clock Jitter Effects on Read Timing Parameters ........................................................................................... 134 Clock Jitter Effects on Write Timing Parameters .......................................................................................... 135 Refresh Requirements .................................................................................................................................... 136 AC Timing ..................................................................................................................................................... 137 CA and CS_n Setup, Hold, and Derating .......................................................................................................... 144 Data Setup, Hold, and Slew Rate Derating ....................................................................................................... 151 Revision History ............................................................................................................................................ 158 Rev. D – 4/16 ............................................................................................................................................. 158 Rev. C – 3/16 .............................................................................................................................................. 158 Rev. B – 9/15 .............................................................................................................................................. 158 Rev. A – 11/14 ............................................................................................................................................ 158 4 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information List of Figures Figure 1: Part Number Chart ............................................................................................................................ 2 Figure 2: 178-Ball Single-Channel FBGA – 1 x 8Gb Die ..................................................................................... 10 Figure 3: 178-Ball Single-Channel FBGA – 2 x 8Gb Die ..................................................................................... 11 Figure 4: 178-Ball Single-Channel FBGA – 4 x 8Gb Die ..................................................................................... 12 Figure 5: Single-Die, Single-Channel Package Block Diagram .......................................................................... 14 Figure 6: Dual-Rank, Dual-Die, Single-Channel Package Block Diagram .......................................................... 15 Figure 7: Quad-Die, Single-Channel Package Block Diagram ........................................................................... 16 Figure 8: 178-Ball FBGA (11mm x 11.5mm), RS256M32LD3D1LMZ,RS512M32LD3D2LMZ............................... 17 Figure 9: 178-Ball FBGA (12.0mm x 11.5mm), RS1G32LD3D4LMM................................................................... 18 Figure 10: Functional Block Diagram ............................................................................................................. 27 Figure 11: Simplified State Diagram ............................................................................................................... 29 Figure 12: Voltage Ramp and Initialization Sequence ...................................................................................... 32 Figure 13: Command and Input Setup and Hold ............................................................................................. 44 Figure 14: CKE Input Setup and Hold ............................................................................................................. 44 Figure 15: ACTIVATE Command .................................................................................................................... 45 Figure 16: tFAW Timing .................................................................................................................................. 46 Figure 17: READ Output Timing ..................................................................................................................... 47 Figure 18: Burst READ – RL = 12, BL = 8, tDQSCK > tCK ................................................................................... 47 Figure 19: Burst READ – RL = 12, BL = 8, tDQSCK < tCK ................................................................................... 48 Figure 20: Burst READ Followed by Burst WRITE – RL = 12, WL = 6, BL = 8 ....................................................... 48 Figure 21: Seamless Burst READ – RL = 6, BL = 8, tCCD = 4 .............................................................................. 49 Figure 22: tDQSCKDL Timing ........................................................................................................................ 50 Figure 23: tDQSCKDM Timing ....................................................................................................................... 51 Figure 24: tDQSCKDS Timing ......................................................................................................................... 52 Figure 25: Data Input (WRITE) Timing ........................................................................................................... 53 Figure 26: Burst WRITE ................................................................................................................................. 54 Figure 27: Method for Calculating tWPRE Transitions and Endpoints ............................................................... 54 Figure 28: Method for Calculating tWPST Transitions and Endpoints ............................................................... 55 Figure 29: Burst WRITE Followed by Burst READ ............................................................................................ 55 Figure 30: Seamless Burst WRITE – WL = 4, BL = 8, tCCD = 4 ............................................................................ 56 Figure 31: Data Mask Timing ......................................................................................................................... 57 Figure 32: Write Data Mask – Second Data Bit Masked .................................................................................... 57 Figure 33: Burst READ Followed by PRECHARGE – BL = 8, RU(tRTP(MIN)/tCK) = 2 ........................................... 59 Figure 34: Burst WRITE Followed by PRECHARGE – BL = 8 .............................................................................. 60 Figure 35: LPDDR3 – Burst READ with Auto Precharge .................................................................................... 61 Figure 36: Burst WRITE with Auto Precharge – BL = 8 ...................................................................................... 62 Figure 37: REFRESH Command Timing .......................................................................................................... 66 Figure 38: Postponing REFRESH Commands .................................................................................................. 66 Figure 39: Pulling In REFRESH Commands .................................................................................................... 66 Figure 40: All-Bank REFRESH Operation ........................................................................................................ 68 Figure 41: Per-Bank REFRESH Operation ....................................................................................................... 68 Figure 42: SELF REFRESH Operation .............................................................................................................. 70 Figure 43: MRR Timing .................................................................................................................................. 72 Figure 44: READ to MRR Timing .................................................................................................................... 73 Figure 45: Burst WRITE Followed by MRR ...................................................................................................... 73 Figure 46: MRR After Idle Power-Down Exit .................................................................................................... 74 Figure 47: Temperature Sensor Timing ........................................................................................................... 75 Figure 48: MR32 and MR40 DQ Calibration Timing ......................................................................................... 76 Figure 49: MODE REGISTER WRITE Timing ................................................................................................... 77 Figure 50: MODE REGISTER WRITE Timing for MRW RESET .......................................................................... 78 5 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information Figure 51: Figure 52: Figure 53: Figure 54: Figure 55: Figure 56: Figure 57: Figure 58: Figure 59: Figure 60: Figure 61: Figure 62: Figure 63: Figure 64: Figure 65: Figure 66: Figure 67: Figure 68: Figure 69: Figure 70: Figure 71: Figure 72: Figure 73: Figure 74: Figure 75: Figure 76: Figure 77: Figure 78: Figure 79: Figure 80: Figure 81: Figure 82: Figure 83: Figure 84: Figure 85: Figure 86: Figure 87: Figure 88: Figure 89: Figure 90: Figure 91: Figure 92: Figure 93: ZQ Timings ................................................................................................................................... 80 CA Training Timing ....................................................................................................................... 81 Write-Leveling Timing ................................................................................................................... 84 Functional Representation of On-Die Termination .......................................................................... 85 Asynchronous ODT Timing – RL = 12 ............................................................................................. 87 Automatic ODT Timing During READ Operation – RL = m ............................................................... 88 ODT Timing During Power-Down, Self Refresh, Deep Power-Down Entry/Exit ................................. 88 Power-Down Entry and Exit Timing ................................................................................................ 90 CKE Intensive Environment ........................................................................................................... 90 REFRESH to REFRESH Timing in CKE Intensive Environments ....................................................... 91 READ to Power-Down Entry ........................................................................................................... 91 READ with Auto Precharge to Power-Down Entry ............................................................................ 92 WRITE to Power-Down Entry ......................................................................................................... 92 WRITE with Auto Precharge to Power-Down Entry .......................................................................... 93 REFRESH Command to Power-Down Entry .................................................................................... 93 ACTIVATE Command to Power-Down Entry ................................................................................... 94 PRECHARGE Command to Power-Down Entry ............................................................................... 94 MRR Power-Down Entry ................................................................................................................ 95 MRW Command to Power-Down Entry .......................................................................................... 95 Deep Power-Down Entry and Exit Timing ....................................................................................... 96 V REF DC Tolerance and V REF AC Noise Limits ................................................................................. 112 LPDDR3-1600 to LPDDR3-1333 Input Signal ................................................................................. 113 LPDDR3-2133 to LPDDR3-1866 Input Signal ................................................................................. 114 Differential AC Swing Time and tDVAC .......................................................................................... 115 Single-Ended Requirements for Differential Signals ....................................................................... 116 V IX Definition ............................................................................................................................... 118 Differential Input Slew Rate Definition for CK and DQS .................................................................. 119 Single-Ended Output Slew Rate Definition ..................................................................................... 121 Differential Output Slew Rate Definition ........................................................................................ 122 Overshoot and Undershoot Definition ........................................................................................... 123 HSUL_12 Driver Output Reference Load for Timing and Slew Rate ................................................. 124 Output Driver ............................................................................................................................... 125 Output Impedance = 240Ω, I-V Curves After ZQRESET ................................................................... 129 Output Impedance = 240Ω, I-V Curves After Calibration ................................................................. 130 ODT Functional Block Diagram .................................................................................................... 131 Typical Slew Rate and tVAC – tIS for CA and CS_n Relative to Clock ................................................. 147 Typical Slew Rate – tIH for CA and CS_n Relative to Clock ............................................................... 148 Tangent Line – tIS for CA and CS_n Relative to Clock ...................................................................... 149 Tangent Line – tIH for CA and CS_n Relative to Clock ..................................................................... 150 Typical Slew Rate and tVAC – tDS for DQ Relative to Strobe ............................................................. 154 Typical Slew Rate – tDH for DQ Relative to Strobe ........................................................................... 155 Tangent Line – tDS for DQ with Respect to Strobe .......................................................................... 156 Tangent Line – tDH for DQ with Respect to Strobe .......................................................................... 157 6 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information List of Tables Table 1: Key Timing Parameters ....................................................................................................................... 1 Table 2: Configuration Addressing ................................................................................................................... 1 Table 3: Ball/Pad Descriptions ....................................................................................................................... 13 Table 4: IDD Specifications ............................................................................................................................. 20 Table 5: IDD6 Partial-Array Self Refresh Current at 25°C .................................................................................... 23 Table 6: IDD6 Partial-Array Self Refresh Current at 85°C .................................................................................... 23 Table 7: Input/Output Capacitance ................................................................................................................ 24 Table 8: Voltage Ramp Conditions .................................................................................................................. 30 Table 9: Initialization Timing Parameters ....................................................................................................... 32 Table 10: Power Supply Conditions ................................................................................................................ 33 Table 11: Power-Off Timing ............................................................................................................................ 33 Table 12: Mode Register Assignments ............................................................................................................. 34 Table 13: MR0 Device Feature 0 (MA[7:0] = 00h) .............................................................................................. 35 Table 14: MR0 Op-Code BIt Definitions .......................................................................................................... 35 Table 15: MR1 Device Feature 1 (MA[7:0] = 01h) .............................................................................................. 36 Table 16: MR1 Op-Code Bit Definitions .......................................................................................................... 36 Table 17: Burst Sequence ............................................................................................................................... 36 Table 18: MR2 Device Feature 2 (MA[7:0] = 02h) .............................................................................................. 36 Table 19: MR2 Op-Code Bit Definitions .......................................................................................................... 37 Table 20: LPDDR3 READ and WRITE Latency ................................................................................................. 37 Table 21: MR3 I/O Configuration 1 (MA[7:0] = 03h) ......................................................................................... 38 Table 22: MR3 Op-Code Bit Definitions .......................................................................................................... 38 Table 23: MR4 Device Temperature (MA[7:0] = 04h) ........................................................................................ 38 Table 24: MR4 Op-Code Bit Definitions .......................................................................................................... 38 Table 25: MR5 Basic Configuration 1 (MA[7:0] = 05h) ...................................................................................... 39 Table 26: MR5 Op-Code Bit Definitions .......................................................................................................... 39 Table 27: MR6 Basic Configuration 2 (MA[7:0] = 06h) ...................................................................................... 39 Table 28: MR6 Op-Code Bit Definitions .......................................................................................................... 39 Table 29: MR7 Basic Configuration 3 (MA[7:0] = 07h) ...................................................................................... 39 Table 30: MR7 Op-Code Bit Definitions .......................................................................................................... 40 Table 31: MR8 Basic Configuration 4 (MA[7:0] = 08h) ...................................................................................... 40 Table 32: MR8 Op-Code Bit Definitions .......................................................................................................... 40 Table 33: MR9 Test Mode (MA[7:0] = 09h) ....................................................................................................... 40 Table 34: MR10 Calibration (MA[7:0] = 0Ah) ................................................................................................... 40 Table 35: MR10 Op-Code Bit Definitions ........................................................................................................ 41 Table 36: MR11 ODT Control (MA[7:0] = 0Bh) ................................................................................................. 41 Table 37: MR11 Op-Code Bit Definitions ........................................................................................................ 41 Table 38: MR16 PASR Bank Mask (MA[7:0] = 010h) .......................................................................................... 41 Table 39: MR16 Op-Code Bit Definitions ........................................................................................................ 42 Table 40: MR17 PASR Segment Mask (MA[7:0] = 011h) .................................................................................... 42 Table 41: MR17 PASR Segment Mask Definitions ............................................................................................ 42 Table 42: MR17 PASR Row Address Ranges in Masked Segments ...................................................................... 42 Table 43: MR63 RESET (MA[7:0] = 3Fh) – MRW Only ....................................................................................... 42 Table 44: Reserved Mode Registers ................................................................................................................. 43 Table 45: Bank Selection for PRECHARGE by Address Bits ............................................................................... 58 Table 46: PRECHARGE and Auto Precharge Clarification ................................................................................. 63 Table 47: REFRESH Command Scheduling Separation Requirements .............................................................. 65 Table 48: Bank- and Segment-Masking Example ............................................................................................. 71 Table 49: Temperature Sensor Definitions and Operating Conditions .............................................................. 74 Table 50: Data Calibration Pattern Description ............................................................................................... 76 7 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information Table 51: Truth Table for MRR and MRW ........................................................................................................ 78 Table 52: CA Training Mode Enable (MR41 (29H, 0010 1001b), OP = A4H (1010 0100b)) .................................... 82 Table 53: CA Training Mode Disable (MR42 (2AH, 0010 1010b), OP = A8H(1010 1000b)) .................................... 82 Table 54: CA to DQ Mapping (CA Training Mode Enabled with MR41) ............................................................. 82 Table 55: CA Training Mode Enable (MR48 (30H, 0011 0000b), OP = C0H (1100 0000b)) .................................... 83 Table 56: CA to DQ Mapping (CA Training Mode Enabled with MR48) ............................................................. 83 Table 57: DRAM Termination Function in Write-Leveling Mode ...................................................................... 87 Table 58: ODT States Truth Table ................................................................................................................... 87 Table 59: Command Truth Table .................................................................................................................... 98 Table 60: CKE Truth Table .............................................................................................................................. 99 Table 61: Current State Bank n to Command to Bank n Truth Table ................................................................ 100 Table 62: Current State Bank n to Command to Bank m Truth Table ............................................................... 102 Table 63: DM Truth Table .............................................................................................................................. 105 Table 64: Absolute Maximum DC Ratings ...................................................................................................... 105 Table 65: Switching for CA Input Signals ........................................................................................................ 106 Table 66: Switching for IDD4R ......................................................................................................................... 106 Table 67: Switching for IDD4W ........................................................................................................................ 107 Table 68: IDD Specification Parameters and Operating Conditions .................................................................. 108 Table 69: Recommended DC Operating Conditions ....................................................................................... 110 Table 70: Input Leakage Current ................................................................................................................... 110 Table 71: Operating Temperature Range ........................................................................................................ 110 Table 72: Single-Ended AC and DC Input Levels for CA and CS_n Inputs ......................................................... 111 Table 73: Single-Ended AC and DC Input Levels for CKE ................................................................................ 111 Table 74: Single-Ended AC and DC Input Levels for DQ and DM ..................................................................... 111 Table 75: Differential AC and DC Input Levels ................................................................................................ 115 Table 76: CK and DQS Time Requirements Before Ringback ( tDVAC) .............................................................. 116 Table 77: Single-Ended Levels for CK and DQS .............................................................................................. 117 Table 78: Crosspoint Voltage for Differential Input Signals (CK, CK_c, DQS_t, DQS_c) ..................................... 118 Table 79: Differential Input Slew Rate Definition ............................................................................................ 118 Table 80: Single-Ended AC and DC Output Levels .......................................................................................... 120 Table 81: Differential AC and DC Output Levels ............................................................................................. 120 Table 82: Single-Ended Output Slew Rate Definition ...................................................................................... 120 Table 83: Single-Ended Output Slew Rate ...................................................................................................... 121 Table 84: Differential Output Slew Rate Definition ......................................................................................... 122 Table 85: Differential Output Slew Rate ......................................................................................................... 122 Table 86: AC Overshoot/Undershoot Specification ......................................................................................... 123 Table 87: Output Driver DC Electrical Characteristics with ZQ Calibration ...................................................... 126 Table 88: Output Driver Sensitivity Definition ................................................................................................ 126 Table 89: Output Driver Temperature and Voltage Sensitivity ......................................................................... 127 Table 90: Output Driver DC Electrical Characteristics Without ZQ Calibration ................................................ 127 Table 91: I-V Curves ..................................................................................................................................... 127 Table 92: ODT DC Electrical Characteristics (RZQ = 240Ω After Proper ZQ Calibration) .................................... 131 Table 93: Definitions and Calculations .......................................................................................................... 132 Table 94: tCK(abs), tCH(abs), and tCL(abs) Definitions ................................................................................... 133 Table 95: Refresh Requirement Parameters (Per Density) ............................................................................... 136 Table 96: AC Timing ..................................................................................................................................... 137 Table 97: CA Setup and Hold Base Values ...................................................................................................... 144 Table 98: CS_n Setup and Hold Base Values ................................................................................................... 145 Table 99: Derating Values for AC/DC-Based tIS/tIH (AC150) ........................................................................... 145 Table 100: Derating Values for AC/DC-Based tIS/tIH (AC135) ......................................................................... 145 Table 101: Required Time for Valid Transition – tVAC > V IH(AC) and < V IL(AC) ..................................................... 146 Table 102: Data Setup and Hold Base Values .................................................................................................. 152 8 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Part Number Ordering Information Table 103: Derating Values for AC/DC-Based tDS/tDH (AC150) ....................................................................... 152 Table 104: Derating Values for AC/DC-Based tDS/tDH (AC135) ....................................................................... 152 Table 105: Required Time for Valid Transition – tVAC > V IH(AC) or < V IL(AC) ....................................................... 153 9 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Ball Assignments Ball Assignments Figure 2: 178-Ball Single-Channel FBGA – 1 x 8Gb Die 1 2 3 4 5 6 NU NU VDD1 VDD1 VDD1 NU VSS ZQ NC CA9 VSSCA CA8 7 8 9 10 11 12 13 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU VSS VSSQ DQ31 DQ30 DQ29 DQ28 VSSQ NU NC VSS VSSQ DQ27 DQ26 DQ25 DQ24 VDDQ VSSCA VDD2 VDD2 VDD2 DM3 DQ15 DQS3_t DQS3_c VSSQ CA7 CA6 VSS VSS VSSQ VDDQ DQ14 DQ13 DQ12 VDDQ VDDCA CA5 VSSCA VSS VSSQ DQ11 DQ10 DQ9 DQ8 VSSQ VDDCA VSSCA VSSCA VDD2 VSSQ DM1 VSSQ VDDCA VREFCA VDD2 VDD2 VDDQ VDDQ VSSQ VDDQ VDD2 A B C D E F G DQS1_t DQS1_c VDDQ H VSS J CK_c CK_t VSSCA VDD2 VDD2 ODT VDDQ VDDQ VREFDQ VSS VSS CKE NC VDD2 VDD2 VDDQ NC VSSQ VDDQ VDD2 VDDCA CS_n NC VDD2 VSS DM0 VSSQ VDDCA CA4 VSSCA VSS VSSQ DQ4 DQ5 DQ6 DQ7 VSSQ CA2 CA3 VSS VSS VSSQ VDDQ DQ1 DQ2 DQ3 VDDQ CA1 VSSCA VDD2 VDD2 VDD2 DM2 DQ0 CA0 NC VSS VSS VSSQ DQ20 DQ21 DQ22 DQ23 VDDQ NU VSS VSS VSS VSS VSSQ DQ16 DQ17 DQ18 DQ19 VSSQ NU NU NU VDD1 VDD1 VDD1 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU K L DQS0_t DQS0_c VDDQ M N P DQS2_t DQS2_c VSSQ R T U (Top view) 10 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Ball Assignments Figure 3: 178-Ball Single-Channel FBGA – 2 x 8Gb Die 1 2 3 4 5 6 NU NU VDD1 VDD1 VDD1 NU VSS ZQ NC CA9 VSSCA CA8 7 8 9 10 11 12 13 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU VSS VSSQ DQ31 DQ30 DQ29 DQ28 VSSQ NU NC VSS VSSQ DQ27 DQ26 DQ25 DQ24 VDDQ VSSCA VDD2 VDD2 VDD2 DM3 DQ15 DQS3_t DQS3_c VSSQ CA7 CA6 VSS VSS VSSQ VDDQ DQ14 DQ13 DQ12 VDDQ VDDCA CA5 VSSCA VSS VSSQ DQ11 DQ10 DQ9 DQ8 VSSQ VDDCA VSSCA VSSCA VDD2 VSSQ DM1 VSSQ VDDCA VREFCA VDD2 VDD2 VDDQ VDDQ VSSQ VDDQ VDD2 A B C D E F G DQS1_t DQS1_c VDDQ H VSS J CK_c CK_t VSSCA VDD2 VDD2 ODT VDDQ VDDQ VREFDQ VSS VSS CKE0 CKE1 VDD2 VDD2 VDDQ NC VSSQ VDDQ VDD2 VDDCA CS0_n CS1_n VDD2 VSS DM0 VSSQ VDDCA CA4 VSSCA VSS VSSQ DQ4 DQ5 DQ6 DQ7 VSSQ CA2 CA3 VSS VSS VSSQ VDDQ DQ1 DQ2 DQ3 VDDQ CA1 VSSCA VDD2 VDD2 VDD2 DM2 DQ0 CA0 NC VSS VSS VSSQ DQ20 DQ21 DQ22 DQ23 VDDQ NU VSS VSS VSS VSS VSSQ DQ16 DQ17 DQ18 DQ19 VSSQ NU NU NU VDD1 VDD1 VDD1 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU K L DQS0_t DQS0_c VDDQ M N P DQS2_t DQS2_c VSSQ R T U (Top view) 11 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Ball Descriptions Figure 4: 178-Ball Single-Channel FBGA – 4 x 8Gb Die 1 2 3 4 5 6 NU NU VDD1 VDD1 VDD1 NU VSS ZQ0 ZQ1 CA9 VSSCA CA8 7 8 9 10 11 12 13 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU VSS VSSQ DQ31 DQ30 DQ29 DQ28 VSSQ NU NC VSS VSSQ DQ27 DQ26 DQ25 DQ24 VDDQ VSSCA VDD2 VDD2 VDD2 DM3 DQ15 DQS3_t DQS3_c VSSQ CA7 CA6 VSS VSS VSSQ VDDQ DQ14 DQ13 DQ12 VDDQ VDDCA CA5 VSSCA VSS VSSQ DQ11 DQ10 DQ9 DQ8 VSSQ VDDCA VSSCA VSSCA VDD2 VSSQ DM1 VSSQ VDDCA VREFCA VDD2 VDD2 VDDQ VDDQ VSSQ VDDQ VDD2 A B C D E F G DQS1_t DQS1_c VDDQ H VSS J CK_c CK_t VSSCA VDD2 VDD2 ODT VDDQ VDDQ VREFDQ VSS VSS CKE0 CKE1 VDD2 VDD2 VDDQ NC VSSQ VDDQ VDD2 VDDCA CS0_n CS1_n VDD2 VSS DM0 VSSQ VDDCA CA4 VSSCA VSS VSSQ DQ4 DQ5 DQ6 DQ7 VSSQ CA2 CA3 VSS VSS VSSQ VDDQ DQ1 DQ2 DQ3 VDDQ CA1 VSSCA VDD2 VDD2 VDD2 DM2 DQ0 CA0 NC VSS VSS VSSQ DQ20 DQ21 DQ22 DQ23 VDDQ NU VSS VSS VSS VSS VSSQ DQ16 DQ17 DQ18 DQ19 VSSQ NU NU NU VDD1 VDD1 VDD1 VDD1 VDD2 VDD2 VDD1 VDDQ NU NU K L DQS0_t DQS0_c VDDQ M N P DQS2_t DQS2_c VSSQ R T U (Top view) Ball Descriptions The ball/pad description table below is a comprehensive list of signals for the device family. All signals listed may not be supported on this device. See Ball Assignments for information specific to this device. PDF: 09005aef85f8105e 178b_8-32gb_v01m_mobile-lpddr3.pdf – Rev. D 4/16 EN 12 Micron Technology, Inc. reserves the right to change products or specifications without notice. © 2014 Micron Technology, Inc. All rights reserved. 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Ball Descriptions Table 3: Ball/Pad Descriptions Symbol Type Description CA[9:0] Input Command/address inputs: Provide the command and address inputs according to the command truth table. CK_t, CK_c Input Clock: Differential clock inputs. All CA inputs are sampled on both rising and falling edges of CK. CS and CKE inputs are sampled at the rising edge of CK. AC timings are referenced to clock. CKE[1:0] Input Clock enable: CKE HIGH activates and CKE LOW deactivates the internal clock signals, input buffers, and output drivers. Power-saving modes are entered and exited via CKE transitions. CKE is considered part of the command code. CKE is sampled on the rising edge of CK. CS[1:0]_n Input Chip select: Considered part of the command code and is sampled on the rising edge of CK. DM[3:0] Input Input data mask: Input mask signal for write data. Although DM balls are input-only, the DM loading is designed to match that of DQ and DQS balls. DM[3:0] is DM for each of the four data bytes, respectively. ODT Input On-die termination: Enables and disables termination on the DRAM DQ bus according to the specified mode register settings. For packages that do not support ODT, the ODT signal may be grounded internally. DQ[31:0] I/O Data input/output: Bidirectional data bus. DQS[3:0]_t, DQS[3:0]_c I/O Data strobe: Bidirectional (used for read and write data) and complementary (DQS_t and DQS_c). It is edge-aligned output with read data and centered input with write data. DQS[3:0]_t/DQS[3:0]_c is DQS for each of the four data bytes, respectively. VDDQ Supply DQ power supply: Isolated on the die for improved noise immunity. VSSQ Supply DQ ground: Isolated on the die for improved noise immunity. VDDCA Supply Command/address power supply: Command/address power supply. VSSCA Supply Command/address ground: Isolated on the die for improved noise immunity. VDD1 Supply Core power: Supply 1. VDD2 Supply Core power: Supply 2. VSS Supply Common ground. VREFCA, VREFDQ Supply Reference voltage: VREFCA is reference for command/address input buffers, VREFDQ is reference for DQ input buffers. ZQ[1:0] Reference NU – Not usable: Do not connect. NC – No connect: Not internally connected. (NC) – No connect: Balls indicated as (NC) are no connects; however, they could be connected together internally. External reference ball for output drive calibration: This ball is tied to an external 240Ω resistor (RZQ), which is tied to VSSQ. 13 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Package Block Diagrams Package Block Diagrams Figure 5: Single-Die, Single-Channel Package Block Diagram VDD1 VDD2 VDDQ VDDCA VSS VREFCA VSSCA VSSQ VREFDQ ZQ CS_N RZQ CKE CK_t CK_c DM[3:0] LPDDR3 Die 0 CA[9:0] DQ[31:0], DQS[3:0]_t, DQS[3:0]_c ODT 14 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Package Block Diagrams Figure 6: Dual-Rank, Dual-Die, Single-Channel Package Block Diagram VDD1 VDD2 VDDQVDDCA VSS VSSCA VSSQ VREFCA VREFDQ CS1_n CKE1 ZQ CS0_n RZQ CKE0 CK_t CK_c DM[3:0] LPDDR3 LPDDR3 Die 0 Die 1 CA[9:0] ODT ODT 15 DQ[31:0], DQS[3:0]_t, DQS[3:0]_c 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Package Block Diagrams Figure 7: Quad-Die, Single-Channel Package Block Diagram VDD1 VDD2 VDDQ VDDCA VSS VSSCA VSSQ VREFCA VREFDQ ODT ODT LPDDR3 Die 0 CS1_n CKE1 DM[1:0] LPDDR3 Die 1 DM[3:2] x16 DQ[15:0] CK_t x16 DQ[31:16] CK_c DM[3:0] CA[9:0] x16 DQ[15:0] DM[1:0] CKE0 CS0_n ODT x16 DQ[31:16] DM[3:2] LPDDR3 Die 3 LPDDR3 Die 2 ODT ODT 16 RZQ1 ZQ1 DQ[31:16], DQS[3:2]_t, DQS[3:2]_c DQ[15:0], DQS[1:0]_t, DQS[1:0]_c ZQ0 RZQ0 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Package Dimensions Package Dimensions Figure 8: 178-Ball FBGA (11mm x 11.5mm)-MZ Seating plane A 178X Ø0.3 Dimensions apply to solder balls postreflow on Ø0.28 SMD ball pads. 0.08 A Ball A1 ID 13 12 11 10 9 8 Ball A1 ID 6 5 4 3 2 1 A B C D E F G H J K L M N P R T U 11.5 ±0.1 10.4 CTR 0.65 TYP 0.8 TYP 0.92 ±0.08 9.6 CTR 0.17 MIN 11 ±0.1 Note: 1. All dimensions are in millimeters. 17 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Package Dimensions Figure 9: 178-Ball FBGA (12.0mm x 11.5mm)-MM Seating plane A 178X Ø0.3 Dimensions apply to solder balls postreflow on Ø0.28 SMD ball pads. 0.08 A Ball A1 ID 13 12 11 10 9 8 Ball A1 ID 6 5 4 3 2 1 A B C D E F G H J K L M N P R T U 11.5 ±0.1 10.4 CTR 0.65 TYP 0.8 TYP 0.9 ±0.1 9.6 CTR 0.17 MIN 12 ±0.1 Note: 1. All dimensions are in millimeters. 18 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MR0, MR5, MR6, MR8 Readout MR0, MR5, MR6, MR8 Readout Part Number Total Density OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 MR0 RS256M32LD3D1LMZ 8Gb RS512M32LD3D2LMZ 16Gb RS1G32LD3D4LMM 32Gb OP6 = 1b indicates support for WL set B OP7 = 1b indicates that the option for RL3 is supported OP6 and OP7 =1b for this package MR5 RS256M32LD3D1LMZ 8Gb Manufacturer ID = 1111 1111b RS512M32LD3D2LMZ 16Gb Manufacturer ID = 0000 0110B RS1G32LD3D4LMM 32Gb MR6 RS256M32LD3D1LMZ 8Gb RS512M32LD3D2LMZ 16Gb RS1G32LD3D4LMM 32Gb MR8 RS256M32LD3D1LMZ Revision ID1 = 0000 0011b: Revision B I/O Width/CS_n 8Gb CS0_n CS1_n 00b: x32 – RS512M32LD3D2LMZ 16Gb 00b: x32 00b: x32 RS1G32LD3D4LMM 32Gb 01b: x16 01b: x16 19 Density Type 0111b: 8Gb 11b: S8 178-Ball, Single-Channel Mobile LPDDR3 SDRAM IDD Specifications – Single Die IDD Specifications – Single Die Table 4: IDD Specifications VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V; TC = –25°C to +85°C Speed Symbol IDD01 Supply 2133 1866 1600 1333 VDD1 8 8 8 8 IDD02 VDD2 43 41.5 40 40 IDD0,in VDDCA + VDDQ 6 6 6 6 IDD2P1 VDD1 0.6 0.6 0.6 0.6 IDD2P2 VDD2 1.3 1.3 1.3 1.3 IDD2P,in VDDCA + VDDQ 0.1 0.1 0.1 0.1 IDD2PS1 VDD1 0.6 0.6 0.6 0.6 IDD2PS2 VDD2 1.3 1.3 1.3 1.3 IDD2PS,in VDDCA + VDDQ 0.1 0.1 0.1 0.1 IDD2N1 VDD1 0.6 0.6 0.6 0.6 IDD2N2 VDD2 22.5 21.5 20.5 20 IDD2N,in VDDCA + VDDQ 6 6 6 6 IDD2NS1 VDD1 0.6 0.6 0.6 0.6 IDD2NS2 VDD2 18.5 18.5 18.5 18.5 IDD2NS,in VDDCA + VDDQ 6 6 6 6 VDD1 1 1 1 1 IDD3P1 IDD3P2 VDD2 7 7 7 7 IDD3P,in VDDCA + VDDQ 0.1 0.1 0.1 0.1 20 Unit Parameter/Condition mA Operating one bank active-precharge current = tCK(avg) MIN; tRC = tRC (MIN); CKE is HIGH; CS_n is HIGH between valid commands; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled tCK mA Idle power-down standby current tCK = tCK(avg) MIN; CKE is LOW; CS_n is HIGH; All banks idle; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled mA Idle power-down standby current with clock stop CK_t = LOW, CK_c = HIGH; CKE is LOW; CS_n is HIGH; All banks idle; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT disabled mA Idle non power-down standby current = tCK(avg) MIN; CKE is HIGH; CS_n is HIGH; All banks idle; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled tCK mA Idle non power-down standby current with clock stop CK_t = LOW, CK_c = HIGH; CKE is HIGH; CS_n is HIGH; All banks idle; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT disabled mA Active power-down standby current = tCK(avg) MIN; CKE is LOW; CS_n is HIGH; One bank active; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled tCK 178-Ball, Single-Channel Mobile LPDDR3 SDRAM IDD Specifications – Single Die Table 4: IDD Specifications (Continued) VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V; TC = –25°C to +85°C Speed Symbol IDD3PS1 Supply 2133 1866 1600 1333 VDD1 1 1 1 1 IDD3PS2 VDD2 7 7 7 7 IDD3PS,in VDDCA + VDDQ 0.1 0.1 0.1 0.1 IDD3N1 VDD1 1.3 1.3 1.3 1.3 IDD3N2 VDD2 23 22 21 20.5 IDD3N,in VDDCA + VDDQ 6 6 6 6 IDD3NS1 VDD1 1.3 1.3 1.3 1.3 IDD3NS2 VDD2 19 19 19 19 IDD3NS,in VDDCA + VDDQ 6 6 6 6 IDD4R1 VDD1 2 2 2 2 IDD4R2 VDD2 330 (280) 290 (240) 250 (200) 220 (170) IDD4R,in VDDCA 6 6 6 6 IDD4W1 VDD1 2 2 2 2 IDD4W2 VDD2 325 (275) 285 (235) 245 (195) 215 (165) IDD4W,in VDDCA + VDDQ 6 6 6 6 IDD51 VDD1 30 30 30 30 IDD52 VDD2 150 150 150 150 IDD5,in VDDCA + VDDQ 6 6 6 6 21 Unit Parameter/Condition mA mA Active power-down standby current with clock stop CK_t = LOW, CK_c = HIGH; CKE is LOW; CS_n is HIGH; One bank active; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT disabled Active non power-down standby current = tCK(avg) MIN; CKE is HIGH; CS_n is HIGH; One bank active; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled tCK mA Active non power-down standby current with clock stop CK_t = LOW, CK_c = HIGH; CKE is HIGH; CS_n is HIGH; One bank active; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT disabled mA Operating burst read current tCK = tCK(avg) MIN; CS_n is HIGH between valid commands; One bank active; BL = 8; RL = RL (MIN); CA bus inputs are SWITCHING; 50% data change each burst transfer; ODT disabled; Values in parenthesis are for x16 bits mA Operating burst write current = tCK(avg) MIN; CS_n is HIGH between valid commands; One bank active; BL = 8; WL = WL (MIN); CA bus inputs are SWITCHING; 50% data change each burst transfer; ODT disabled; Values in parenthesis are for x16 bits tCK mA All bank auto-refresh burst current tCK = tCK(avg) MIN; CKE is HIGH between valid commands; tRC = tRFCab (MIN); Burst refresh; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled 178-Ball, Single-Channel Mobile LPDDR3 SDRAM IDD Specifications – Single Die Table 4: IDD Specifications (Continued) VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V; TC = –25°C to +85°C Speed Symbol Supply 2133 1866 1600 1333 VDD1 3 3 3 3 IDD5AB2 VDD2 23 22 21 20.5 IDD5AB,in VDDCA + VDDQ 6 6 6 6 IDD5PB1 VDD1 3 3 3 3 IDD5PB2 VDD2 23 22 21 20.5 IDD5PB,in VDDCA + VDDQ 6 6 6 6 IDD81 VDD1 24 24 24 24 IDD82 VDD2 9 9 9 9 IDD8,in VDDCA + VDDQ 12 12 12 12 IDD5AB1 Notes: Unit Parameter/Condition mA All bank auto-refresh average current tCK = tCK(avg) MIN; CKE is HIGH between valid commands; tRC = tREFI; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled mA Per bank auto-refresh average current = tCK(avg) MIN; CKE is HIGH between valid commands; tRC = tREFIpb; CA bus inputs are SWITCHING; Data bus inputs are STABLE; ODT disabled tCK μA Deep power-down current CK_t = LOW, CK _c = HIGH; CKE is LOW; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT disabled 1. Published IDD values are the maximum of the distribution of the arithmetic mean. 2. IDD current specifications are tested after the device is properly initialized. 22 178-Ball, Single-Channel Mobile LPDDR3 SDRAM IDD Specifications – Single Die Table 5: IDD6 Partial-Array Self Refresh Current at 25°C VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V PASR Supply Value Unit Full array 1/2 array 1/4 array 1/8 array VDD1 200 (550) VDD2 1100 (1700) VDDCA + VDDQ 10 VDD1 140 (450) VDD2 600 (1000) VDDCA + VDDQ 10 VDD1 110 (400) VDD2 400 (750) VDDCA + VDDQ 10 VDD1 90 (370) VDD2 300 (450) VDDCA + VDDQ 10 Note: μA Parameter/Condition Self refresh current CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT is disabled Values in parentheses are the maximum of the distribution of the arithmetic mean 1. IDD6 25°C is the typical of the distribution of the arithmetic mean. Table 6: IDD6 Partial-Array Self Refresh Current at 85°C VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V PASR Supply Value Unit Full array 1/2 array 1/4 array 1/8 array VDD1 1000 VDD2 7000 VDDCA + VDDQ 12 VDD1 600 VDD2 4100 VDDCA + VDDQ 12 VDD1 400 VDD2 2700 VDDCA + VDDQ 12 VDD1 300 VDD2 2000 VDDCA + VDDQ 12 Note: μA Parameter/Condition Self refresh current CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are STABLE; Data bus inputs are STABLE; ODT is disabled 1. IDD6 85°C is the typical of the distribution of the arithmetic mean. 23 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Pin Capacitance Pin Capacitance Table 7: Input/Output Capacitance Part Number Density Parameter RS256M32LD3D1LMZ 8Gb Part Number Symbol Min Max Unit Notes Input capacitance, CK_t and CK_c CCK 0.5 1.5 pF 1, 2 Input capacitance, all other input-only pins except CS_n, CKE, and ODT CI1 0.5 2.0 pF 1, 2 Input capacitance, CS_n, CKE, and ODT CI2 0.5 2.0 pF 1, 2 Input/output capacitance, DQ, DM, DQS_t, DQS_c CIO 1.0 3.0 pF 1, 2, 3 Input/output capacitance, ZQ CZQ 1.0 2.0 pF 1, 2, 3 Density Parameter RS512M32LD3D2LMZ 16Gb Part Number Symbol Min Max Unit Notes Input capacitance, CK_t and CK_c CCK 1.0 2.5 pF 1, 2 Input capacitance, all other input-only pins except CS_n, CKE, and ODT CI1 1.0 2.5 pF 1, 2 Input capacitance, CS_n, CKE, and ODT CI2 0.5 2.0 pF 1, 2 Input/output capacitance, DQ, DM, DQS_t, DQS_c CIO 1.5 4.5 pF 1, 2, 3 Input/output capacitance, ZQ CZQ 1.5 3.5 pF 1, 2, 3 Symbol Min Max Unit Notes Input capacitance, CK_t and CK_c CCK 2.0 4.0 pF 1, 2 Input capacitance, all other input-only pins except CS_n, CKE, and ODT CI1 2.0 4.5 pF 1, 2 Input capacitance, CS_n, CKE, and ODT CI2 1.0 3.0 pF 1, 2 Input/output capacitance, DQ, DM, DQS_t, DQS_c CIO 1.5 4.5 pF 1, 2, 3 Input/output capacitance, ZQ CZQ 1.5 3.5 pF 1, 2, 3 Density Parameter RS1G32LD3D4LMM 32Gb Notes: 1. This parameter is not subject to production testing. It is verified by design and characterization. 2. These parameters are measured on f = 100 MHz, VOUT = VDDQ/2, TA = +25 °C. 3. DOUT circuits are disabled. 24 178-Ball, Single-Channel Mobile LPDDR3 SDRAM LPDDR3 Array Configuration LPDDR3 Array Configuration The 8Gb Mobile Low-Power DDR3 SDRAM (LPDDR3) is a high-speed CMOS, dynamic random-access memory containing 8,589,934,592-bits. The device is internally configured as an eight-bank DRAM. Each of the x16’s 1,073,741,824-bit banks is organized as 32,768 rows by 2,048 columns by 16 bits. Each of the x32’s 1,073,741,824-bit banks is organized as 32,768 rows by 1024 columns by 32 bits. General Notes Throughout the data sheet, figures and text refer to DQs as “DQ.” DQ should be interpreted as any or all DQ collectively, unless specifically stated otherwise. “DQS” and “CK” should be interpreted as DQS_t, DQS_c and CK_t, CK_c, respectively, unless specifically stated otherwise. “BA” and "CA" include all BA and CA pins, respectively, used for a given density. Complete functionality may be described throughout the entire document. Any page or diagram may have been simplified to convey a topic and may not be inclusive of all requirements. Timing diagrams reflect a single-channel device. In timing diagrams, “CMD” is used as an indicator only. Actual signals occur on CA[9:0]. VREF indicates V REFCA and V REFDQ. Any specific requirement takes precedence over a general statement. Any functionality not specifically stated herein is considered undefined, illegal, is not supported, and will result in unknown operation. 25 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Functional Description Functional Description Mobile LPDDR3 is a high-speed SDRAM internally configured as an 8-bank memory device. LPDDR3 uses a double data rate architecture on the command/address (CA) bus to reduce the number of input pins in the system. The 10-bit CA bus is used to transmit command, address, and bank information. Each command uses one clock cycle, during which command information is transferred on both the rising and falling edges of the clock. LPDDR3 uses a double data rate architecture on the DQ pins to achieve high-speed operation. The double data rate architecture is essentially an 8n prefetch architecture with an interface designed to transfer two data bits per DQ every clock cycle at the I/O pins. A single read or write access for LPDDR3 effectively consists of a single 8n-bit-wide, one-clock-cycle data transfer at the internal SDRAM core and eight corresponding nbit-wide, one-half-clock-cycle data transfers at the I/O pins. Read and write accesses to the device are burst oriented; accesses start at a selected location and continue for a programmed number of locations in a programmed sequence. Accesses begin with the registration of an ACTIVATE command followed by a READ or WRITE command. The address and BA bits registered coincident with the ACTIVATE command are used to select the row and bank to be accessed. The address bits registered coincident with the READ or WRITE command are used to select the bank and the starting column location for the burst access. 26 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Functional Description CK_t CK_c CKE Clock generator Figure 10: Functional Block Diagram CA[9:0] Row address buffer and refresh counter Row decoder Mode register Memory cell array Bank 0 Sense amp. Control logic CS_n Address/command decoder Bank n Column decoder Column address buffer and burst counter Data control circuit Latch circuit Input and Output buffer DQ 27 DQS_t, DQS_c DM ODT 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Simplified Bus Interface State Diagram Simplified Bus Interface State Diagram The state diagram provides a simplified illustration of the bus interface, supported state transitions, and the commands that control them. For a complete description of device behavior, use the information provided in the state diagram with the truth tables and timing specifications. The truth tables describe device behavior and applicable restrictions when considering the actual state of all banks. For command descriptions, see the Commands and Timing section. 28 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Simplified Bus Interface State Diagram Figure 11: Simplified State Diagram Power applied Deep power-down DPDX Power-on RE Automatic sequence SE T MRR R X PD ET ES Resetting power-down EF X DPD PD MRR REF Idle1 Refreshing M X PD D P RW Idle MR reading SR EF Resetting SR Resetting MR reading Command sequence Self refreshing Idle power-down MR writing 2 ACT Active power-down Active MR reading PD X PD PR, PRA R MR Active RD WR WR3 RD 3 WR(A) = WRITE (with auto precharge) Writing PR, PRA RD(A) = READ (with auto precharge) RESET = RESET is achieved through MRW command WRA3 A RD ACT = ACTIVATE W RA PRA = PRECHARGE ALL Reading RDA3 MRW = MODE REGISTER WRITE MRR = MODE REGISTER READ PD = Enter power-down PDX = Exit power-down Writing with auto precharge Reading with auto precharge SREF = Enter self refresh SREFX = Exit self refresh Precharging DPD = Enter deep power-down DPDX = Exit deep power-down REF = REFRESH Notes: 1. All banks are precharged in the idle state. 2. In the case of using MRW to enter CA training mode or write leveling mode, the state machine will not automatically return to the idle state. In these cases, an additional MRW command is required to exit either operating mode and return to the idle state. See the CA Training Mode or Write Leveling Mode sections. 3. Terminated bursts are not allowed. For these state transitions, the burst operation must be completed before a transition can occur. 29 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Up and Initialization 4. The state diagram is intended to provide a floorplan of the possible state transitions and commands used to control them, but it is not comprehensive. In particular, situations involving more than one bank are not captured in full detail. Power-Up and Initialization The device must be powered up and initialized in a predefined manner. Power-up and initialization by means other than those specified will result in undefined operation. Voltage Ramp and Device Initialization The following sequence must be used to power up the device. Unless specified otherwise, this procedure is mandatory. 1. Voltage Ramp: While applying power (after Ta), CKE must be held LOW, and all other inputs must be between V ILmin and V IHmax. The device outputs remain at High-Z while CKE is held LOW. Following completion of the voltage ramp (Tb), CKE must be held LOW. DQ, DM and DQS voltage levels must be between V SSQ and V DDQ during voltage ramp to avoid latchup. CK, CS_n, and CA input levels must be between V SSCA and V DDCA during voltage ramp to avoid latch-up. Voltage ramp power supply requirements are provided in the table below. Table 8: Voltage Ramp Conditions After Applicable Conditions Ta is reached VDD1 must be greater than VDD2 - 200mV VDD1 and VDD2 must be greater than VDDCA - 200mV VDD1 and VDD2 must be greater than VDDQ - 200mV VREF must always be less than all other supply voltages Notes: 1. Ta is the point when any power supply first reaches 300mV. 2. Noted conditions apply between Ta and power-down (controlled or uncontrolled). 3. Tb is the point at which all supply and reference voltages are within their defined operating ranges. 4. For supply and reference voltage operating conditions, see the Recommended DC Operating Conditions table. 5. The voltage difference between any VSS, VSSQ, and VSSCA pins must not exceed 100mV. Beginning at Tb, CKE must remain LOW for at least tINIT1, after which CKE can be asserted HIGH. The clock must be stable at least tINIT2 prior to the first CKE LOW-toHIGH transition (Tc). CKE, CS_n, and CA inputs must observe setup and hold requirements (tIS, tIH) with respect to the first rising clock edge and to subsequent falling and rising edges. If any MRRs are issued, the clock period must be within the range defined for tCKb. MRWs can be issued at normal clock frequencies as long as all AC timings are met. Some AC parameters (for example, tDQSCK) could have relaxed timings (such as tDQSCKb) before the system is appropriately configured. While keeping CKE HIGH, NOP commands must be issued for at least tINIT3 (Td). The ODT input signal may be in an undefined state until tIS before CKE is registered HIGH. When CKE is registered 30 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Up and Initialization HIGH, the ODT input signal must be statically held either LOW or HIGH. The ODT input signal remains static until the power-up initialization sequence is finished, including the expiration of tZQINIT. 2. RESET Command: After tINIT3 is satisfied, the MRW RESET command must be issued (Td). An optional PRECHARGE ALL command can be issued prior to the MRW RESET command. Wait at least tINIT4 while keeping CKE asserted and issuing NOP commands. Only NOP commands are allowed during tINIT4. 3. MRRs and Device Auto Initialization (DAI) Polling: After tINIT4 is satisfied (Te), only MRR commands and POWER-DOWN ENTRY/EXIT commands are supported, and CKE can go LOW in alignment with power-down entry and exit specifications (see PowerDown). MRR commands are valid at this time only when the CA bus does not need to be trained. CA training can begin only after time Tf. The MRR command can be initiated to poll the DAI bit, which indicates whether device auto initialization is complete. When the bit indicates completion, the device is in an idle state. The device is also in an idle state after tINIT5 (MAX) has expired, regardless whether the DAI bit has been read by the MRR command. Because the memory output buffers are not properly configured by Te, some AC parameters must use relaxed timing specifications before the system is appropriately configured. After the DAI bit (MR0, DAI) is set to zero by the memory device (DAI complete), the device is in the idle state (Tf). DAI status can be determined by issuing the MRR command to MR0. The device sets the DAI bit no later than tINIT5 after the RESET command. The controller must wait at least tINIT5 (MAX) or until the DAI bit is set before proceeding. 4. ZQ Calibration: If CA training is not required, the MRW INITIALIZATION CALIBRATION (ZQ_CAL) command can be issued to the memory (MR10) after Tf. No other CA commands (other than RESET or NOP) may be issued prior to the completion of CA training. After the completion of CA training (Tf'), the MRW INITIALIZATION CALIBRATION (ZQ_CAL) command can be issued to the memory. This command is used to calibrate output impedance over process, voltage, and temperature. In systems where more than one LPDDR3 device exists on the same bus, the controller must not overlap MRW ZQ_CAL commands. The device is ready for normal operation after tZQINIT. 5. Normal Operation: AftertZQINIT (Tg), MRW commands must be used to properly configure the memory (for example, output buffer drive strength, latencies, and so on). Specifically, MR1, MR2, and MR3 must be set to configure the memory for the target frequency and memory configuration. After the initialization sequence is complete, the device is ready for any valid command. After Tg, the clock frequency can be changed using the procedure described in the Input Clock Frequency Changes and Clock Stop Events section. 31 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Up and Initialization Figure 12: Voltage Ramp and Initialization Sequence Ta Tb tINIT2 Tc Td Te Tf Tf’ Tg CK_t/CK_c tINIT0 Supplies tINIT1 tINIT3 CKE tINIT4 tISCKE CA RESET tZQINIT tINIT5 MRR CA Training MRW ZQ_CAL Valid DQ Static HIGH or LOW ODT Notes: Valid 1. High-Z on the CA bus indicates a valid NOP. 2. For tINIT values, see the Initialization Timing Parameters table. 3. After RESET command time (Tf), RTT is disabled until ODT function is enabled by MRW to MR11 following Tg. 4. CA training is optional. Table 9: Initialization Timing Parameters Parameter Min Max Unit tINIT0 – 20 ms Maximum voltage ramp time (Note 1) tINIT1 100 – ns Minimum CKE LOW time after completion of voltage ramp tINIT2 5 – tCK Minimum stable clock before first CKE HIGH tINIT3 200 – μs Minimum idle time after first CKE assertion tINIT4 1 – μs Minimum idle time after RESET command tINIT5 – 10 μs Maximum duration of device auto initialization (Note 2) tZQINIT 1 – μs ZQ initial calibration tCKb 18 100 ns Clock cycle time during boot Notes: Comment 1. The tINIT0 maximum specification is not a tested limit and should be used as a general guideline. For voltage ramp times exceeding tINIT0 MAX, please contact the factory. 2. If the DAI bit is not read via MRR, the device will be in the idle state after tINIT5 (MAX) has expired. Initialization After Reset (Without Voltage Ramp) If the RESET command is issued before or after the power-up initialization sequence, the reinitialization procedure must begin at Td. 32 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Off Sequence Power-Off Sequence The following procedure is required to power-off the device. While powering off, CKE must be held LOW; all other inputs must be between V ILmin and V IHmax. The device outputs remain at High-Z while CKE is held LOW. DQ, DM, and DQS voltage levels must be between V SSQ and V DDQ during the power-off sequence to avoid latch-up. CK, CS_n, and CA input levels must be between V SSCA and VDDCA during the power-off sequence to avoid latch-up. Tx is the point where any power supply drops below the minimum value specified in the Recommended DC Operating Conditions table. Tz is the point where all power supplies are below 300mV. After Tz, the device is powered off. Table 10: Power Supply Conditions Between... Applicable Conditions Tx and Tz VDD1 must be greater than VDD2 - 200mV VDD1 must be greater than VDDCA - 200mV VDD1 must be greater than VDDQ - 200mV VREF must always be less than all other supply voltages Notes: 1. The voltage difference between any VSS, VSSQ, and VSSCA pins must not exceed 100mV. 2. For supply and reference voltage operating conditions, see Recommended DC Operating Conditions table. Uncontrolled Power-Off Sequence When an uncontrolled power-off occurs, the following conditions must be met. • At Tx, when the power supply drops below the minimum values specified in the Recommended DC Operating Conditions table, all power supplies must be turned off and all power supply current capacity must be at zero, except for any static charge remaining in the system. • After Tz (the point at which all power supplies first reach 300mV), the device must power-off. During this period, the relative voltage between power supplies is uncontrolled. V DD1 and V DD2 must decrease with a slope lower than 0.5 V/μs between Tx and Tz. An uncontrolled power-off sequence can occur a maximum of 400 times over the life of the device. Table 11: Power-Off Timing Parameter Maximum power-off ramp time 33 Symbol Min Max Unit tPOFF – 2 sec 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Standard Mode Register Definition For LPDDR3, a set of mode registers is used for programming device operating parameters, reading device information and status, and for initiating special operations such as DQ calibration, ZQ calibration, and device reset. Mode Register Assignments and Definitions Mode register definitions are provided in the Mode Register Assignments table. An "R" in the access column of the table indicates read-only; "W" indicates write-only; "R/W" indicates read- or write-capable or enabled. The MRR command is used to read from a register. The MRW command is used to write to a register. Table 12: Mode Register Assignments Notes 1–5 apply to entire table MR# MA[7:0] Function Access OP7 OP6 OP5 RL3 WL-B RFU 0 00h Device info R 1 01h Device feature 1 W 2 02h Device feature 2 W 3 03h I/O config-1 W 4 04h SDRAM refresh rate R 5 05h Basic config-1 R OP4 WL Select OP2 RZQI RFU RFU nWRE OP0 DAI Link Go to MR0 BL Go to MR1 RL and WL Go to MR2 DS Go to MR3 RFU RFU TUF OP1 RFU nWR (for AP) WR Lev OP3 Refresh rate Manufacturer ID Go to MR4 Go to MR5 6 06h Basic config-2 R Revision ID1 Go to MR6 7 07h Basic config-3 R Revision ID2 Go to MR7 8 08h Basic config-4 R 9 09h Test mode W I/O width Density Type Vendor-specific test mode Go to MR8 Go to MR9 10 0Ah I/O calibration W 11 0Bh ODT W Calibration code 12–15 0Ch–0Fh Reserved – RFU Go to MR12 16 10h PASR_Bank W PASR bank mask Go to MR16 RFU PD ctl Go to MR10 DQ ODT Go to MR11 17 11h PASR_Seg W PASR segment mask Go to MR17 18–31 12h–1Fh Reserved – RFU Go to MR18–MR31 32 20h DQ calibration pattern A R See Data Calibration Pattern Description 33–39 21h–27h Do not use – 40 28h DQ calibration pattern B R See Data Calibration Pattern Description 41 29h CA training 1 W See MRW - CA Training Mode 42 2Ah CA training 2 W See MRW - CA Training Mode 43–47 2Bh–2Fh Do not use – CA training 3 W See MRW - CA Training Mode Reserved – RFU 48 30h 49–62 31h–3Eh Go to MR33 Go to MR43 34 Go to MR49 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 12: Mode Register Assignments (Continued) Notes 1–5 apply to entire table MR# MA[7:0] Function 63 3Fh 64–255 40h–FFh Access OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 Link RESET W X Go to MR63 Reserved – RFU Go to MR64 Notes: 1. RFU bits must be set to 0 during MRW. 2. RFU bits must be read as 0 during MRR. 3. For Reads to a write-only or RFU register, DQS is toggled and undefined data is returned. 4. RFU mode registers must not be written. 5. Writes to read-only registers must have no impact on the functionality of the device. Table 13: MR0 Device Feature 0 (MA[7:0] = 00h) OP7 OP6 OP5 RL3 WL-B RFU OP4 OP3 OP2 RZQI OP1 RFU OP0 DAI Table 14: MR0 Op-Code BIt Definitions Register Information Tag Type OP Definition DAI Read-only OP0 0b: DAI complete 1b: DAI in progress Built-in self-test for RZQ information RZQI1 Read-only OP[4:3] WL Set B support WL-B Read-only OP[6] 0b: Device does not support WL Set B 1b: Device supports WL Set B RL3 Read-only OP[7] 0b: Device does not support RL = 3, nWR = 3, WL = 1 1b: Device supports RL= 3, nWR = 3, WL = 1 for frequencies ≤166 MHz Device auto initialization status RL3 support Notes: 00b: RZQ self-test not supported 01b: ZQ pin can connect to VDDCA or float 10b: ZQ pin can short to GND 11b: ZQ pin self-test completed, no error condition detected (ZQ pin must not float; connect to VDD or short to GND 1. RZQI will be set upon completion of the MRW ZQ INITIALIZATION CALIBRATION command. 2. If ZQ is connected to VDDCA to set default calibration, OP[4:3] must be set to 01. If ZQ is not connected to VDDCA, either OP[4:3] = 01 or OP[4:3] = 10 may indicate a ZQ pin assembly error. 3. In the case of a possible assembly error, the device will default to factory trim settings for RON and will ignore ZQ CALIBRATION commands. In either case, the system may not function as intended. 4. If the ZQ self-test returns a value of 11b, it indicates that the device has detected a resistor connection to the ZQ pin. However, that result cannot be used to validate the ZQ resistor value or that the ZQ resistor tolerance meets the specified limit of 240Ω  35 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 15: MR1 Device Feature 1 (MA[7:0] = 01h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 RFU nWR (for AP) OP0 BL Table 16: MR1 Op-Code Bit Definitions Feature Type OP BL Write-only OP[2:0] 011b: BL8 (default) All others: Reserved nWR Write-only OP[7:5] If nWR (MR2 OP[4]) = 0 001b: nWR = 3 100b: nWR = 6 110b: nWR = 8 111b: nWR = 9 If nWR (MR2 OP[4]) = 1 000b: nWR = 10 (default) 001b: nWR = 11 010b: nWR = 12 100b: nWR = 14 110b: nWR = 16 All others: Reserved Notes: Definition Notes 1, 2 1. The programmed value in the nWR register is the number of clock cycles that determine when to start the internal precharge operation for a WRITE burst with AP enabled. It is determined by RU (tWR/tCK). 2. The range of nWR is extended (MR2 OP[4] = 1) by using an extra bit (nWRE) in MR2. Table 17: Burst Sequence Burst Cycle Number and Burst Address Sequence C2 C1 C0 0b 0b 0b 0b 1b 0b 1b 0b 0b 1b 1b 0b Note: BL 8 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 2 3 4 5 6 7 0 1 4 5 6 7 0 1 2 3 6 7 0 1 2 3 4 5 1. C0 input is not present on CA bus; it is implied zero. Table 18: MR2 Device Feature 2 (MA[7:0] = 02h) OP7 OP6 OP5 OP4 WR Lev WL Sel RFU nWRE OP3 OP2 OP1 RL and WL 36 OP0 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 19: MR2 Op-Code Bit Definitions Feature RL and WL Type OP Write-only OP[3:0] Definition If OP[6] = 0 (default, WL Set A) 0001b: RL3/WL1 (≤166 MHz)1 0100b: RL6/WL3 (≤400 MHz) 0110b: RL8/WL4 (≤533 MHz) 0111b: RL9/WL5 (≤600 MHz) 1000b: RL10/WL6 (≤667 MHz, default) 1001b: RL11/WL6 (≤733 MHz) 1010b: RL12/WL6 (≤800 MHz) 1100b: RL14/WL8 (≤933 MHz) 1110b: RL16/WL8 (≤1066 MHz) All others: Reserved If OP[6] = 1 (WL Set B) 0001b: RL3/WL1 (≤166 MHz)1 0100b: RL6/WL3 (≤400 MHz) 0110b: RL8/WL4 (≤533 MHz) 0111b: RL9/WL5 (≤600 MHz) 1000b: RL10/WL8 (≤667 MHz, default) 1001b: RL11/WL9 (≤733 MHz) 1010b: RL12/WL9 (≤800 MHz) 1100b: RL14/WL11 (≤933 MHz) 1110b: RL16/WL13 (≤1066 MHz) All others: Reserved nWRE Write-only OP[4] 0b: Enable nWRE programming ≤9 1b: Enable nWRE programming >9 (default) WL select Write-only OP[6] 0b: Use WL Set A (default) 1b: Use WL Set B2 WR Lev Write-only OP[7] 0b: Disable write leveling (default) 1b: Enable write leveling Notes: 1. See MR0 OP7. 2. See MR0 OP6. Table 20: LPDDR3 READ and WRITE Latency Data Rate (Mb/p/s) tCK(ns) 333 800 1066 1200 1333 1466 1600 1866 2133 6 2.5 1.875 1.67 1.5 1.36 1.25 1.071 0.938 RL 3 6 8 9 10 11 12 14 16 WL (Set A) 1 3 4 5 6 6 6 8 8 WL (Set B) 1 3 4 5 8 9 9 11 13 37 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 21: MR3 I/O Configuration 1 (MA[7:0] = 03h) OP7 OP6 OP5 OP4 OP3 OP2 RFU OP1 OP0 OP1 OP0 DS Table 22: MR3 Op-Code Bit Definitions Feature DS Type OP Definition Write-only OP[3:0] 0001b: 34.3Ω typical 0010b: 40Ω typical (default) 0011b: 48Ω typical 0100b: Reserved 0110b: Reserved 1001b: 34.3Ω pull-down, 40Ω pull-up 1010b: 40Ω pull-down, 48Ω pull-up 1011b: 34.3Ω pull-down, 48Ω pull-up All others: Reserved Table 23: MR4 Device Temperature (MA[7:0] = 04h) OP7 OP6 OP5 OP4 OP3 RFU TUF OP2 SDRAM refresh rate Table 24: MR4 Op-Code Bit Definitions Notes 1–8 apply to entire table Feature Type OP SDRAM refresh rate Read-only OP[2:0] Temperature update flag (TUF) Read-only OP7 Notes: 1. 2. 3. 4. 5. 6. Definition 000b: SDRAM low-temperature operating limit exceeded 001b: 4 × tREFI, 4 × tREFIpb, 4 × tREFW 010b: 2 × tREFI, 2 × tREFIpb, 2 × tREFW 011b: 1 × tREFI, 1 × tREFIpb, 1 × tREFW (≤85˚C) 100b: 0.5 × tREFI, 0.5 × tREFIpb, 0.5 × tREFW, no AC timing derating 101b: 0.25 × tREFI, 0.25 × tREFIpb, 0.25 × tREFW, no AC timing derating 110b: 0.25 × tREFI, 0.25 × tREFIpb, 0.25 × tREFW, timing derating required 111b: SDRAM high-temperature operating limit exceeded 0b: OP[2:0] value has not changed since last read of MR4 1b: OP[2:0] value has changed since last read of MR4 A mode register read from MR4 will reset OP7 to 0. OP7 is reset to 0 at power-up. If OP2 = 1, the device temperature is greater than 85˚C. OP7 is set to 1 if OP[2:0] has changed at any time since the last MR4 read. The device might not operate properly when OP[2:0] = 000b or 111b. For the specified operating temperature range and maximum operating temperature, refer to the Operating Temperature Range table. 38 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition 7. LPDDR3 devices must be derated by adding 1.875ns to the following core timing parameters: tRCD, tRC, tRAS, tRP, and tRRD. The tDQSCK parameter must be derated as specified in the AC Timing table. Prevailing clock frequency specifications and related setup and hold timings remain unchanged. 8. The recommended frequency for reading MR4 is provided in the Temperature Sensor section. Table 25: MR5 Basic Configuration 1 (MA[7:0] = 05h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 Manufacturer ID Table 26: MR5 Op-Code Bit Definitions Feature Manufacturer ID Type OP Definition Read-only OP[7:0] 0000 0011b: Micron 0000 0110B: Hynix Semiconductor 1111 1111b: Micron All others: Reserved Table 27: MR6 Basic Configuration 2 (MA[7:0] = 06h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP1 OP0 Revision ID1 Note: 1. MR6 is vendor-specific. Table 28: MR6 Op-Code Bit Definitions Feature Revision ID1 Type OP Definition Read-only OP[7:0] 0000 0000b: Revision A 0000 0001b: Revision B 0000 0010b: Revision C Table 29: MR7 Basic Configuration 3 (MA[7:0] = 07h) OP7 OP6 OP5 OP4 OP3 Revision ID2 39 OP2 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 30: MR7 Op-Code Bit Definitions Feature Revision ID2 Note: Type OP Read-only OP[7:0] Definition RFU 1. MR7 is vendor-specific. Table 31: MR8 Basic Configuration 4 (MA[7:0] = 08h) OP7 OP6 OP5 OP4 I/O width OP3 OP2 OP1 Density OP0 Type Table 32: MR8 Op-Code Bit Definitions Type OP Type Feature Read-only OP[1:0] Definition 11b: LPDDR3 All other states reserved Density Read-only OP[5:2] 0110b: 4Gb 1110b: 6Gb 0111b: 8Gb 1101b: 12Gb 1000b: 16Gb 1001b: 32Gb All others: Reserved I/O width Read-only OP[7:6] 00b: x32 01b: x16 All others: Reserved Table 33: MR9 Test Mode (MA[7:0] = 09h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 OP2 OP1 OP0 Vendor-specific test mode Table 34: MR10 Calibration (MA[7:0] = 0Ah) OP7 OP6 OP5 OP4 OP3 Calibration code 40 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 35: MR10 Op-Code Bit Definitions Notes 1–4 apply to entire table Feature Type Calibration code Write-only Notes: OP Definition OP[7:0] 0xFF: CALIBRATION command after initialization 0xAB: Long calibration 0x56: Short calibration 0xC3: ZQ reset All others: Reserved 1. The device ignores calibration commands when a reserved value is written into MR10. 2. See AC Timing table for the calibration latency. 3. If ZQ is connected to VSSCA through RZQ, either the ZQ calibration function (see MRW ZQ CALIBRATION Command) or default calibration (through the ZQ RESET command) is supported. If ZQ is connected to VDDCA, the device operates with default calibration and ZQ CALIBRATION commands are ignored. In both cases, the ZQ connection must not change after power is supplied to the device. 4. Devices that do not support calibration ignore the ZQ CALIBRATION command. Table 36: MR11 ODT Control (MA[7:0] = 0Bh) OP7 OP6 OP5 OP4 OP3 Reserved OP2 OP1 PD CTL OP0 DQ ODT Table 37: MR11 Op-Code Bit Definitions Feature Type OP DQ ODT Write-only OP[1:0] PD control Write-only OP[2] Note: Definition 00b: Disable (default) 01b: RZQ/4 (Note1) 10b: RZQ/2 11b: RZQ/1 00b: ODT disabled by DRAM during power-down (default) 01b: ODT enabled by DRAM during power-down 1. RZQ/4 is supported for LPDDR3-1866 and LPDDR3-2133 devices. RZQ/4 support is optional for LPDDR3-1333 and LPDDR3-1600 devices. Consult Micron specifications for RZQ/4 support for LPDDR3-1333 and LPDDR3-1600. Table 38: MR16 PASR Bank Mask (MA[7:0] = 010h) OP7 OP6 OP5 OP4 OP3 PASR bank mask 41 OP2 OP1 OP0 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 39: MR16 Op-Code Bit Definitions Feature Bank[7:0] mask Type OP Write-only OP[7:0] Definition 0b: Refresh enable to the bank = unmasked (default) 1b: Refresh blocked = masked Table 40: MR17 PASR Segment Mask (MA[7:0] = 011h) OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 PASR segment mask Table 41: MR17 PASR Segment Mask Definitions Feature Segment[7:0] mask Type OP Write-only OP[7:0] Definition 0b: Refresh enable to the segment = unmasked (default) 1b: Refresh blocked = masked Table 42: MR17 PASR Row Address Ranges in Masked Segments 4Gb 6Gb2, 8Gb, 12Gb2 & 16Gb 32Gb R[13:11] R[14:12] TBD Segment OP Segment Mask 0 0 XXXXXXX1 000b 1 1 XXXXXX1X 001b 2 2 XXXXX1XX 010b 3 3 XXXX1XXX 011b 4 4 XXX1XXXX 100b 5 5 XX1XXXXX 101b 6 6 X1XXXXXX 110b 7 7 1XXXXXXX 111b Notes: 1. X = “Don’t Care” for the designated segment. 2. No memory present at addresses with R13 = R14 = HIGH. Segment masks 6 and 7 are ignored. Table 43: MR63 RESET (MA[7:0] = 3Fh) – MRW Only OP7 OP6 OP5 OP4 OP3 OP2 OP1 OP0 X or 0xFCh Note: 1. For additional information on MRW RESET, see the Mode Register Write (MRW) section. 42 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Standard Mode Register Definition Table 44: Reserved Mode Registers Mode Register MA Address Restriction MR[12:15] MA[7:0] 0Ch-0Fh Reserved Reserved MR[18:31] 12h–1Fh Reserved Reserved MR[33:39] 21h–27h DNU DNU OP7 OP6 OP5 OP4 OP3 MR[43:47] 2Bh–2Fh DNU DNU MR[49:62] 31h–3Eh Reserved Reserved MR[64:255] 40h–FFh Reserved Reserved Note: 1. DNU = Do not use; RVU = Reserved for vendor use. 43 OP2 OP1 OP0 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Commands and Timing Commands and Timing The setup and hold timings shown in the figures below apply for all commands. Figure 13: Command and Input Setup and Hold T0 T1 T2 T3 tIS tIH tIS tIH CK_c CK_t CS_n VIL(DC) VIL(AC) VIH(AC) tIS tIH CA[9:0] CA rise CA fall CA rise NOP CMD VIH(DC) tIS tIH CA fall Command CA rise CA fall NOP Don’t Care Note: CA rise CA fall Command Transitioning data 1. Setup and hold conditions also apply to the CKE pin. For timing diagrams related to the CKE pin, see the Power-Down section. Figure 14: CKE Input Setup and Hold T0 T1 Tx Tx + 1 CK_c CK_t tIHCKE CKE VIHCKE tISCKE tIHCKE VILCKE VILCKE tISCKE VIHCKE HIGH or LOW, but defined Notes: 1. After CKE is registered LOW, the CKE signal level is maintained below VILCKE for tCKE specification (LOW pulse width). 2. After CKE is registered HIGH, the CKE signal level is maintained above VIHCKE for tCKE (HIGH pulse width). 44 178-Ball, Single-Channel Mobile LPDDR3 SDRAM ACTIVATE Command ACTIVATE Command The ACTIVATE command is issued by holding CS_n LOW, CA0 LOW, and CA1 HIGH at the rising edge of the clock. The bank addresses BA[2:0] are used to select the desired bank. Row addresses are used to determine which row to activate in the selected bank. The ACTIVATE command must be applied before any READ or WRITE operation can be executed. The device can accept a READ or WRITE command at tRCD after the ACTIVATE command is issued. After a bank has been activated, it must be precharged before another ACTIVATE command can be applied to the same bank. The bank active and precharge times are defined as tRAS and tRP, respectively. The minimum time interval between successive ACTIVATE commands to the same bank is determined by the RAS cycle time of the device (tRC). The minimum time interval between ACTIVATE commands to different banks is tRRD. Figure 15: ACTIVATE Command CK_c CK_t CA[9:0] Bank n row addr Row addr Bank m Bank n row addr Row addr col addr Col addr Bank n row addr Row addr Bank n tRRD tRCD tRP tRAS tRC CMD ACTIVATE ACTIVATE NOP Note: READ PRECHARGE NOP NOP ACTIVATE 1. A PRECHARGE ALL command uses tRPab timing, and a single-bank PRECHARGE command uses tRPpb timing. In this figure, tRP denotes either an all-bank PRECHARGE or a single-bank PRECHARGE. 8-Bank Device Operation Certain restrictions must be taken into consideration when operating 8-bank devices; one restricts the number of sequential ACTIVATE commands that can be issued and one provides additional RAS precharge time for a PRECHARGE ALL command. The 8-Bank Device Sequential Bank Activation Restriction: No more than four banks can be activated (or refreshed, in the case of REFpb) in a rolling tFAW window. The number of clocks in a tFAW period depends on the clock frequency, which may vary. If the clock frequency is not changed over this period, convert to clocks by dividing tFAW[ns] by tCK[ns] and then rounding up to the next integer value. As an example of the rolling window, if RU(tFAW/tCK) is 10 clocks, and an ACTIVATE command is issued in clock n, no more than three further ACTIVATE commands can be issued at or between clock n + 1 and n + 9. REFpb also counts as bank activation for purposes of tFAW. If the clock is changed during the tFAW period, the rolling tFAW window may be calculated in clock cycles by adding together the time spent in each clock period. The tFAW requirement is met when the previous n clock cycles exceeds the tFAW time. The 8-Bank Device PRECHARGE ALL Provision: tRP for a PRECHARGE ALL command must equal tRPab, which is greater than tRPpb. 45 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Read and Write Access Modes Figure 16: tFAW Timing Tn Tn+ Tm Tm+ Tx Tx+ Ty Ty + 1 Ty + 2 Tz Tz + 1 Tz + 2 CK_c CK_t CA[9:0] Bank Bank A A Bank Bank B B tRRD CMD ACTIVATE NOP Bank Bank C C tRRD ACTIVATE NOP Bank Bank D D Bank Bank E E tRRD ACTIVATE NOP ACTIVATE NOP NOP NOP ACTIVATE NOP tFAW Read and Write Access Modes After a bank is activated, a READ or WRITE command can be issued with CS_n LOW, CA0 HIGH, and CA1 LOW at the rising edge of the clock. CA2 must also be defined at this time to determine whether the access cycle is a READ operation (CA2 HIGH) or a WRITE operation (CA2 LOW). A single READ or WRITE command initiates a burst READ or burst WRITE operation on successive clock cycles. Burst interrupts are not allowed. 46 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Burst READ Command The burst READ command is initiated with CS_n LOW, CA0 HIGH, CA1 LOW, and CA2 HIGH at the rising edge of the clock. The command address bus inputs, CA5r–CA6r and CA1f–CA9f, determine the starting column address for the burst. The read latency (RL) is defined from the rising edge of the clock on which the READ command is issued to the rising edge of the clock from which the tDQSCK delay is measured. The first valid data is available RL × tCK + tDQSCK + tDQSQ after the rising edge of the clock when the READ command is issued. The data strobe output is driven LOW tRPRE before the first valid rising strobe edge. The first bit of the burst is synchronized with the first rising edge of the data strobe. Each subsequent data-out appears on each DQ pin, edgealigned with the data strobe. The RL is programmed in the mode registers. Pin input timings for the data strobe are measured relative to the crosspoint of DQS_t and its complement, DQS_c. Figure 17: READ Output Timing RL-1 tCH tCL RL RL + BL/ 2 CK_c CK_t tHZ(DQS) tDQSCK tLZ(DQS) tRPST tRPRE DQS_c DQS_t tQH tQH tDQSQmax tDQSQmax DOUT DQ DOUT DOUT DOUT tLZ(DQ) DOUT DOUT DOUT DOUT tHZ(DQ) Transitioning data Note: 1. tDQSCK can span multiple clock periods. Figure 18: Burst READ – RL = 12, BL = 8, tDQSCK > tCK T0 T1 T2 T12 Ta-1 Ta Ta+1 Ta+2 Ta+3 Ta+4 CK_c CK_t RL = 12 CA[9:0] CMD Bank n col addr Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP NOP tDQSCK DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 Transitioning data 47 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Figure 19: Burst READ – RL = 12, BL = 8, tDQSCK < tCK T0 T1 T2 T12 T13 T14 T15 T16 T17 CK_c CK_t RL = 12 CA[9:0] Bank n col addr CMD Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCK DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 Transitioning data Figure 20: Burst READ Followed by Burst WRITE – RL = 12, WL = 6, BL = 8 T0 T1 T2 T12 Ta - 1 Ta Ta + 1 Ta + 2 Ta + 3 Ta + 4 Ta + 9 Ta + 10 CK_c CK_t RL = 12 CA[9:0] CMD Bank n col addr BL/2 WL = 6 Bank n col addr Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP Col addr WRITE tDQSCK NOP NOP NOP tDQSSmin DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 DIN A0 DIN A1 DIN Transitioning Data The minimum time from the burst READ command to the burst WRITE command is defined by the read latency (RL) and the burst length (BL). Minimum READ-to-WRITE latency is RL + RU(tDQSCK(MAX)/tCK) + BL/2 + 1 - WL clock cycles. 48 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Figure 21: Seamless Burst READ – RL = 6, BL = 8, tCCD = 4 T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 T12 T13 T14 T15 CK_c CK_t RL = 6 CA[9:0] tCCD CMD Bank n Col addr b col addr b Bank n Col addr a col addr a READ tCCD =4 NOP NOP NOP READ Bank n Col addr c col addr c Bank n Col addr d col addr d =4 NOP NOP NOP READ NOP NOP NOP READ NOP NOP NOP DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 DOUTB0 DOUTB1 DOUTB2 DOUTB3 DOUTB4 DOUTB5 DOUTB6 DOUTB7 DOUTC0 DOUTC1 Transitioning data The seamless burst READ operation is supported by enabling a READ command at every fourth clock cycle for BL = 8 operation. This operation is supported as long as the banks are activated, whether the accesses read the same or different banks. tDQSCK Delta Timing To allow the system to track variations in tDQSCK output across multiple clock cycles, three parameters are provided: tDQSCKDL (delta long), tDQSCKDM (delta medium), and tDQSCKDS (delta short). Each of these parameters defines the change in tDQSCK over a short, medium, or long rolling window, respectively. The definition for each tDQSCK-delta parameter is shown in the figures below. 49 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Figure 22: tDQSCKDL Timing Tn Tn + 1 Tn + 2 Tn + 9 Tn + 10 Ta Ta + 1 Ta + 12 CK_c CK_t RL = 10 CA [9:0] Bankn Col addr col addr CMD READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKn DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 32ms maximum… 1 Tm Tm + 1 Tm + 2 Tm + 9 Tm + 10 Tb Tb + 1 Tb + 2 CK_c CK_t RL = 10 CA [9:0] Bankn Col addr col addr CMD READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKm DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 …32ms maximum Transitioning data 1 Notes: 1. tDQSCKDL = (tDQSCKn - tDQSCKm). 2. tDQSCKDL (MAX) is defined as the maximum of ABS (tDQSCKn - tDQSCKm) for any (tDQSCKn, tDQSCKm) pair within any 32ms rolling window. 50 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Figure 23: tDQSCKDM Timing Tn Tn + 1 Tn + 2 Tn + 9 Tn + 10 Ta Ta + 1 Ta + 2 CK_c CK_t RL = 10 CA [9:0] Bank n col addr CMD Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKn DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 1.6μs maximum… 1 Tm Tm + 1 Tm + 2 Tm + 9 Tm + 10 Tb Tb + 1 Tb + 2 CK_c CK_t RL = 10 CA [9:0] Bank n col addr CMD Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKm DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 …1.6μs maximum Transitioning data 1 Notes: 1. tDQSCKDM = (tDQSCKn - tDQSCKm). 2. tDQSCKDM (MAX) is defined as the maximum of ABS (tDQSCKn - tDQSCKm) for any (tDQSCKn, tDQSCKm) pair within any 1.6μs rolling window. 51 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst READ Command Figure 24: tDQSCKDS Timing Tn Tn + 1 Tn + 2 Tn + 9 Tn + 10 Ta Ta + 1 Ta + 2 CK_c CK_t RL = 10 CA [9:0] Bank n col addr CMD Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKn DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 160ns maximum… 1 Tm Tm + 1 Tm + 2 Tm + 9 Tm + 10 Tb Tb + 1 Tb + 2 CK_c CK_t RL = 10 CA [9:0] Bank n col addr CMD Col addr READ NOP NOP NOP NOP NOP NOP NOP NOP tDQSCKm DQS_c DQS_t DQ DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 DOUTA0 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 …160ns maximum Transitioning data 1 Notes: 1. tDQSCKDS = (tDQSCKn - tDQSCKm). 2. tDQSCKDS (MAX) is defined as the maximum of ABS (tDQSCKn - tDQSCKm) for any (tDQSCKn, tDQSCKm) pair for READs within a consecutive burst, within any 160ns rolling window. 52 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst WRITE Command Burst WRITE Command The burst WRITE command is initiated with CS_n LOW, CA0 HIGH, CA1 LOW, and CA2 LOW at the rising edge of the clock. The command address bus inputs, CA5r–CA6r and CA1f–CA9f, determine the starting column address for the burst. Write latency (WL) is defined from the rising edge of the clock on which the WRITE command is issued to the rising edge of the clock from which the tDQSS delay is measured. The first valid data must be driven WL × tCK + tDQSS from the rising edge of the clock from which the WRITE command is issued. The data strobe signals (DQS) must be driven as shown in Figure 27 (page 54). The burst cycle data bits must be applied to the DQ pins tDS prior to the associated edge of the DQS and held valid until tDH after that edge. Burst data is sampled on successive edges of the DQS_t until the burst length is completed. After a burst WRITE operation, tWR must be satisfied before a PRECHARGE command to the same bank can be issued. Pin input timings are measured relative to the crosspoint of DQS_t and its complement, DQS_c. Figure 25: Data Input (WRITE) Timing tDQSL tDQSH tDQSL tWPST DQS_c DQS_t tWPRE VIH(AC) DQ VIH(AC) VIH(DC) DIN VIL(AC) tDS tDH DIN VIL(DC) tDH tDS DIN tDS tDH VIH(DC) DIN VIL(AC) tDS VIH(AC) VIH(DC) VIH(AC) VIH(DC) VIL(AC) VIL(DC) VIL(AC) VIL(DC) tDH VIL(DC) DM 53 Don’t Care 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst WRITE Command Figure 26: Burst WRITE T0 Ta Ta + 1 ... Ta + 5 Tx Tx + 1 Ty Ty + 1 CK_c CK_t WL CA[9:0] CMD Bank n col addr Col addr WRITE NOP Case 1: tDQSS (MAX) DQS_c DQS_t NOP tDQSS DIN A0 tDQSS DQ (MIN) NOP tDSS (MAX) DQ Case 2: tDQSS (MIN) DQS_c DQS_t Bank n Row addr row addr Bank n tDSH DIN A0 NOP tDSS DIN A1 DIN A6 PRECHARGE NOP ACTIVATE NOP Completion of burst WRITE tWR tRP tWR tRP DIN A7 tDSH DIN A1 DIN A2 DIN A7 Don’t Care Figure 27: Method for Calculating tWPRE Transitions and Endpoints CK_t VTT CK_c T1 begins tWPRE DQS_t - DQS_c 0V tWPRE T2 Resulting differential signal relevant for tWPRE specification tWPRE 54 ends Transitioning Data 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst WRITE Command Figure 28: Method for Calculating tWPST Transitions and Endpoints CK_t VTT CK_c tWPST DQS_t - DQS_c 0V Resulting differential signal relevant for tWPST specification T1 begins tWPST T2 ends tWPST Figure 29: Burst WRITE Followed by Burst READ T0 Tx Tx + 1 Tx + 2 Tx + 5 Tx + 9 Tx + 10 Tx + 11 CK_c CK_t RL WL CA[9:0] Bank m Col addr a col addr a Bank n Col addr b col addr b tWTR CMD WRITE NOP NOP NOP NOP NOP READ NOP NOP DQS_c DQS_t DQ DIN A0 DIN A1 DIN A7 Don’t Care Notes: Transitioning Data 1. The minimum number of clock cycles from the burst WRITE command to the burst READ command for any bank is [WL + 1 + BL/2 + RU(tWTR/tCK)]. 2. tWTR starts at the rising edge of the clock after the last valid input data. 55 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Burst WRITE Command Figure 30: Seamless Burst WRITE – WL = 4, BL = 8, tCCD = 4 T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 T12 T13 CK_c CK_t WL = 4 CA[9:0] Bankm Col addr a col addr a tCCD CMD WRITE Bankn Col addr b col addr b Bankn Col addr c col addr c Bankn Col addr d col addr d =4 NOP NOP NOP WRITE NOP NOP NOP WRITE NOP NOP NOP WRITE NOP DQS_c DQS_t DQ DIN A0 DIN A1 DIN A2 DIN A3 DIN A4 DIN A5 DIN A6 DIN A7 DIN B0 DIN B1 DIN B2 DIN B3 DIN B4 DIN B5 Don’t Care Note: DIN B6 DIN B7 DIN C0 DIN C1 Transitioning Data 1. The seamless burst WRITE operation is supported by enabling a WRITE command every four clocks for BL = 8 operation. This operation is supported for any activated bank. 56 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Write Data Mask Write Data Mask LPDDR3 devices support one write data mask (DM) pin for each data byte (DQ), which is consistent with LPDDR2 devices. Each DM can mask its respective DQ for any given cycle of the burst. Data mask timings match data bit timing, but are inputs only. Internal data mask loading is identical to data bit loading to ensure matched system timing. Figure 31: Data Mask Timing DQS_c DQS_t DQ tDS VIH(AC) tDH VIH(DC) VIH(AC) tDS tDH VIH(DC) DM VIL(AC) VIL(DC) VIL(AC) VIL(DC) Don’t Care Figure 32: Write Data Mask – Second Data Bit Masked CK_c CK_t tWR tWTR WL CMD WRITE Case 1: t DQSS (MIN) tDQSS (MIN) DQS_t DQS_c DOUT 1 DQ DOUT 0 DOUT 2 DOUT 3 DOUT 4 DOUT 5 DOUT 6 DOUT 7 DM Case 2: t DQSS (MAX) tDQSS (MAX) DQS_t DQS_c DOUT 1 DQ DOUT 0 DOUT 2 DOUT 3 DOUT 4 DOUT 5 DOUT 6 DOUT 7 DM Don’t Care 57 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command PRECHARGE Command The PRECHARGE command is used to precharge or close a bank that has been activated. The PRECHARGE command is initiated with CS_n LOW, CA0 HIGH, CA1 HIGH, CA2 LOW, and CA3 HIGH at the rising edge of the clock. The PRECHARGE command can be used to precharge each bank independently or all banks simultaneously. The AB flag and the bank address bits BA0, BA1, and BA2 are used to determine which bank(s) to precharge. The precharged bank(s) will be available for subsequent row access tRPab after an all-bank PRECHARGE command is issued, or tRPpb after a single-bank PRECHARGE command is issued. To ensure that LPDDR3 devices can meet the instantaneous current demand required to operate, the row precharge time (tRP) for an all bank PRECHARGE (tRPab) will be longer than the row precharge time for a single-bank PRECHARGE (tRPpb). ACTIVATE to PRECHARGE timing is shown in the ACTIVATE Command figure. Table 45: Bank Selection for PRECHARGE by Address Bits AB (CA4r) BA2 (CA9r) BA1 (CA8r) BA0 (CA7r) Precharged Bank(s) 8-Bank Device 0 0 0 0 Bank 0 only 0 0 0 1 Bank 1 only 0 0 1 0 Bank 2 only 0 0 1 1 Bank 3 only 0 1 0 0 Bank 4 only 0 1 0 1 Bank 5 only 0 1 1 0 Bank 6 only 0 1 1 1 Bank 7 only 1 Don’t Care Don’t Care Don’t Care All banks 58 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command Burst READ Operation Followed by PRECHARGE For the earliest possible precharge, the PRECHARGE command can be issued BL/2 clock cycles after a READ command. A new bank ACTIVATE command can be issued to the same bank after the row precharge time (tRP) has elapsed. A PRECHARGE command cannot be issued until after tRAS is satisfied. For LPDDR3 devices, the minimum READ-to-PRECHARGE time (tRTP) must also satisfy a minimum analog time from the rising clock edge that initiates the last 8-bit prefetch of a READ command. tRTP begins BL/2 - 4 clock cycles after the READ command. For LPDDR3 READ-to-PRECHARGE timings, see the PRECHARGE and Auto Precharge Clarification table. Figure 33: Burst READ Followed by PRECHARGE – BL = 8, RU(tRTP(MIN)/tCK) = 2 T0 T1 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 Tx + 5 CK_c CK_t RL CA[9:0] Bank m col addr a Col addr a Bank m Row addr row addr Bank m tRP tRTP CMD READ NOP NOP PRECHARGE NOP NOP NOP ACTIVATE NOP DQS_c DQS_t DQ DOUTA0 DOUTA1 DOUTA2 DOUTA3 DOUTA4 DOUTA5 DOUTA6 DOUTA7 Transitioning Data 59 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command Burst WRITE Followed by PRECHARGE For WRITE cycles, a WRITE recovery time ( tWR) must be provided before a PRECHARGE command can be issued. This delay is referenced from the last valid burst input data to the completion of the burst WRITE. The PRECHARGE command must not be issued prior to the tWR delay. For LPDDR3 WRITE-to-PRECHARGE timings, see the PRECHARGE and Auto Precharge Clarification table. LPDDR3 devices write data to the array in prefetch multiples (prefetch = 8). An internal WRITE operation can begin only after a prefetch group has been completely latched, so tWR starts at prefetch bondaries. The minimum WRITE-to-PRECHARGE time for commands to the same bank is WL + BL/2 + 1 + RU(tWR/tCK) clock cycles. Figure 34: Burst WRITE Followed by PRECHARGE – BL = 8 T0 Tx Tx + 1 Tx + 4 Tx + 5 Ty Ty + 1 Tz Tz + 1 CK_c CK_t WL CA[9:0] Bankn col addr Col addr ≥ tRP tWR CMD WRITE Case 1: t DQSS (MAX) Bankn Row addr row addr Bankn NOP NOP tDQSS NOP NOP (MAX) PRECHARGE NOP ACTIVATE NOP Completion of burst WRITE DQS_c DQS_t DQ Case 2: t DQSS (MIN) tDQSS DIN A0 DIN A5 DIN A6 DIN A1 DIN A6 DIN A7 DIN A7 (MIN) DQS_c DQS_t DQ DIN A0 Don’t Care 60 Transitioning Data 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command Auto Precharge Before a new row can be opened in an active bank, the active bank must be precharged using either the PRECHARGE command or the auto precharge function. When a READ or WRITE command is issued to the device, the AP bit (CA0f) can be set to enable the active bank to automatically begin precharge at the earliest possible moment during the burst READ or WRITE cycle. If AP is LOW when the READ or WRITE command is issued, a normal READ or WRITE burst operation is executed and the bank remains active at the completion of the burst. If AP is HIGH when the READ or WRITE command is issued, the auto precharge function is engaged. This feature enables the PRECHARGE operation to be partially or completely hidden during burst READ cycles (dependent upon READ or WRITE latency), thus improving system performance for random data access. Burst READ with Auto Precharge If AP (CA0f) is HIGH when a READ command is issued, the READ with auto precharge function is engaged. The device starts an auto precharge on the rising edge of the clock, BL/2 or BL/2 - 4 + RU(tRTP/tCK) clock cycles later than the READ with auto precharge command, whichever is greater. For LPDDR3 auto precharge calculations, see the PRECHARGE and Auto Precharge Clarification table. Following an auto precharge operation, an ACTIVATE command can be issued to the same bank if the following two conditions are satisfied simultaneously: • The RAS precharge time (tRP) has been satisfied from the clock at which the auto precharge begins. • The RAS cycle time (tRC) from the previous bank activation has been satisfied. Figure 35: LPDDR3 – Burst READ with Auto Precharge T0 T1 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 Tx + 5 CK_c CK_t RL CA[9:0] Bankm Col addr a col addr a Bankm Row addr row addr ≥ tRPpb tRTP CMD READ w/AP NOP NOP NOP NOP NOP NOP ACTIVATE NOP DQS_c DQS_t DQ DOUT A0 DOUT A1 DOUT A2 DOUT A3 DOUT A4 DOUT A5 DOUT A6 DOUT A7 Transitioning Data 61 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command Burst WRITE with Auto Precharge If AP (CA0f) is HIGH when a WRITE command is issued, the WRITE with auto precharge function is engaged. The device starts an auto precharge at the clock rising edge tWR cycles after the completion of the burst WRITE. Following a WRITE with auto precharge, an ACTIVATE command can be issued to the same bank if the following two conditions are met: • The RAS precharge time (tRP) has been satisfied from the clock at which the auto precharge begins. • The RAS cycle time (tRC) from the previous bank activation has been satisfied. Figure 36: Burst WRITE with Auto Precharge – BL = 8 T0 Tx Tx + 1 ... Tx + 5 Ty Ty + 1 Tz Tz + 1 CK_c CK_t WL CA[9:0] Bankn col addr Bankn Row addr row addr Col addr tWR CMD WRITE NOP NOP NOP NOP ≥ tRPpb NOP NOP ACTIVATE NOP DQS_t DQS_c DQ DIN A0 DIN A1 DIN A6 DIN A7 Don’t Care 62 Transitioning Data 178-Ball, Single-Channel Mobile LPDDR3 SDRAM PRECHARGE Command Table 46: PRECHARGE and Auto Precharge Clarification From Command READ READ w/AP WRITE WRITE w/AP To Command BL/2 + MAX (4, RU(tRTP/tCK)) -4 PRECHARGE ALL BL/2 + MAX (4, RU(tRTP/tCK)) -4 PRECHARGE to same bank as READ w/AP BL/2 + MAX (4, RU(tRTP/tCK)) - 4 PRECHARGE ALL BL/2 + MAX(4, RU(tRTP/tCK)) - 4 PRECHARGE to same bank as READ -4+ Notes CLK 1 CLK 1, 2 1 1 RU(tRPpb/ 1 BL/2 + MAX(4, tCK) WRITE or WRITE w/AP (same bank) Illegal 3 WRITE or WRITE w/AP (different bank) RL + BL/2 + RU(tDQSCKmax/tCK) - WL + 1 3 READ or READ w/AP (same bank) Illegal 3 READ or READ w/AP (different bank) BL/2 3 RU(tWR/tCK) +1 PRECHARGE to same bank as WRITE WL + BL/2 + PRECHARGE ALL WL + BL/2 + RU(tWR/tCK) + 1 CLK WL + BL/2 + RU(tWR/tCK) RU(tWR/tCK) CLK +1 +1+ 1 1 PRECHARGE to same bank as WRITE w/AP WL + BL/2 + RU(tWR/tCK) + 1 1 1 RU(tRPpb/tCK) 1 ACTIVATE to same bank as WRITE w/AP WL + BL/2 + WRITE or WRITE w/AP (same bank) Illegal 3 WRITE or WRITE w/AP (different bank) BL/2 3 READ or READ w/AP (same bank) Illegal READ or READ w/AP (different bank) PRECHARGE ALL RU(tRTP/tCK)) Unit ACTIVATE to same bank as READ w/AP PRECHARGE ALL PRECHARGE Minimum Delay Between Commands WL + BL/2 + PRECHARGE to same bank as PRECHARGE 1 PRECHARGE ALL 1 PRECHARGE 1 PRECHARGE ALL 1 Notes: 3 RU(tWTR/tCK) +1 3 CLK 1 1 CLK 1 1 1. For a given bank, the PRECHARGE period should be counted from the latest PRECHARGE command, which will be either a one-bank PRECHARGE command or a PRECHARGE ALL command, issued to that bank. The PRECHARGE period is satisfied after tRP, depending on the latest PRECHARGE command issued to that bank. 2. Any command issued during the specified minimum delay time is illegal. 3. After a READ with auto precharge command, seamless READ operations to different banks are supported. After a WRITE with auto precharge command, seamless WRITE operations to different banks are supported. READ with auto precharge and WRITE with auto precharge commands must not be interrupted or truncated. 63 178-Ball, Single-Channel Mobile LPDDR3 SDRAM REFRESH Command REFRESH Command The REFRESH command is initiated with CS_n LOW, CA0 LOW, CA1 LOW, and CA2 HIGH at the rising edge of the clock. Per-bank REFRESH is initiated with CA3 LOW at the rising edge of the clock. All-bank REFRESH is initiated with CA3 HIGH at the rising edge of the clock. A per-bank REFRESH command (REFpb) performs a per-bank REFRESH operation to the bank scheduled by the bank counter in the memory device. The bank sequence for per-bank REFRESH is fixed to be a sequential round-robin: 0-1-2-3-4-5-6-7-0-1-.... The bank count is synchronized between the controller and the SDRAM by resetting the bank count to zero. Synchronization can occur upon issuing a RESET command or at every exit from self refresh. A bank must be idle before it can be refreshed. The controller must track the bank being refreshed by the per-bank REFRESH command. The REFpb command must not be issued to the device until the following conditions have been met (see the REFRESH Command Scheduling Separation Requirements table): • • • • tRFCab has been satisfied after the prior REFab command has been satisfied after the prior REFpb command tRP has been satisfied after the prior PRECHARGE command to that bank tRRD has been satisfied after the prior ACTIVATE command (if applicable, for example after activating a row in a different bank than the one affected by the REFpb command) tRFCpb The target bank is inaccessible during per-bank REFRESH cycle time (tRFCpb); however, other banks within the device are accessible and can be addressed during the cycle. During the REFpb operation, any of the banks other than the one being refreshed can be maintained in an active state or accessed by a READ or WRITE command. When the per-bank REFRESH cycle has completed, the affected bank will be in the idle state. After issuing REFpb, the following conditions must be met (see the REFRESH Command Scheduling Separation Requirements table): • • • • tRFCpb must be satisfied before issuing a REFab command must be satisfied before issuing an ACTIVATE command to the same bank tRRD must be satisfied before issuing an ACTIVATE command to a different bank tRFCpb must be satisfied before issuing another REFpb command tRFCpb An all-bank REFRESH command (REFab) issues a REFRESH command to all banks. All banks must be idle when REFab is issued (for instance, by issuing a PRECHARGE ALL command prior to issuing an all-bank REFRESH command). REFab also synchronizes the bank count between the controller and the SDRAM to zero. The REFab command must not be issued to the device until the following conditions have been met (see the REFRESH Command Scheduling Separation Requirements table): • tRFCab has been satisfied following the prior REFab command • tRFCpb has been satisfied following the prior REFpb command • tRP has been satisfied following the prior PRECHARGE commands When an all-bank REFRESH cycle has completed, all banks will be idle. After issuing REFab: 64 178-Ball, Single-Channel Mobile LPDDR3 SDRAM REFRESH Command • tRFCab latency must be satisfied before issuing an ACTIVATE command • tRFCab latency must be satisfied before issuing a REFab or REFpb command Table 47: REFRESH Command Scheduling Separation Requirements Symbol Minimum Delay From tRFCab REFab To Notes REFab ACTIVATE command to any bank REFpb tRFCpb REFpb REFab ACTIVATE command to same bank as REFpb REFpb tRRD REFpb ACTIVATE ACTIVATE command to a different bank than REFpb REFpb 1 ACTIVATE command to a different bank than the prior ACTIVATE command Note: 1. A bank must be in the idle state before it is refreshed, so following an ACTIVATE command REFab is prohibited. REFpb is supported only if it affects a bank that is in the idle state. In general, an all bank REFRESH command needs to be issued to the device regularly every tREFI interval. To allow for improved efficiency in scheduling and switching between tasks, some flexibility in the absolute refresh interval is provided for postponing and pulling in the refresh command. A maximum of eight REFRESH commands can be postponed during operation of the device, but at no point in time are more than a total of eight REFRESH commands allowed to be postponed. In the case where eight REFRESH commands are postponed in a row, the resulting maximum interval between the surrounding REFRESH commands is limited to 9 × tREFI. A maximum of eight additional REFRESH commands can be issued in advance (pulled in), with each one reducing the number of regular REFRESH commands required later by one. Note that pulling in more than eight REFRESH commands in advance does not reduce the number of regular REFRESH commands required later; therefore, the resulting maximum interval between two surrounding REFRESH commands is limited to 9 x tREFI. At any given time, a maximum of 16 REFRESH commands can be issued within 2 x tREFI. For per bank refresh, a maximum of 8 × 8 per bank REFRESH commands can be postponed or pulled in for scheduling efficiency. At any given time, a maximum of 2 × 8 × 8 per bank REFRESH commands may be issued within 2 × tREFI. 65 178-Ball, Single-Channel Mobile LPDDR3 SDRAM REFRESH Command Figure 37: REFRESH Command Timing T0 T1 REF NOP Ta0 Ta1 Tb0 Tb1 Tb2 Tb3 Vaild Vaild Vaild Vaild Tc0 Tc1 Tc2 Tc3 REF Vaild Vaild Vaild CK_c CK_t CMD NOP REF tRFC NOP tRFC NOP Vaild (MIN) tREFI (MAX 9  tREF) DRAM must be idle DRAM must be idle 1. Only NOP commands are allowed after the REFRESH command is registered until tRFC (MIN) expires. 2. The time interval between two REFRESH commands may be extended to a maximum of 9 ×tREFI. Notes: Figure 38: Postponing REFRESH Commands tREFI 9 tREFI t 8 REFRESH commands postponed Figure 39: Pulling In REFRESH Commands tREFI 9 tREFI t 8 REFRESH commands pulled-in 66 178-Ball, Single-Channel Mobile LPDDR3 SDRAM REFRESH Command REFRESH Requirements Minimum REFRESH Commands LPDDR3 requires a minimum number, R, of REFRESH (REFab) commands within any rolling refresh window (tREFW = 32ms @ MR4[2:0] = 011 or T C ≤ 85˚C). For actual values per density and the resulting average refresh interval (tREFI), see the Refresh Requirement Parameters (Per Density) table. For tREFW and tREFI refresh multipliers at different MR4 settings, see the MR4 Device Temperature (MA[7:0] = 04h) and the MR4 Op-Code Bit Definitions tables. When using per-bank REFRESH, a REFab command can be replaced by a full cycle of eight REFpb commands. REFRESH Requirements and Self Refresh Self refresh mode may be entered with a maximum of eight REFRESH commands being postponed. After exiting self refresh mode with one or more REFRESH commands postponed, additional REFRESH commands may be postponed, but the total number of postponed refresh commands (before and after the self refresh) must never exceed eight. During self refresh mode, the number of postponed or pulled-in REFRESH commands does not change. An internally timed refresh event can be missed when CKE is raised for exit from self refresh mode. After exiting self refresh, the device requires a minimum of one extra REFRESH command before it is put back into self refresh mode. 67 178-Ball, Single-Channel Mobile LPDDR3 SDRAM REFRESH Command Figure 40: All-Bank REFRESH Operation T0 T1 T2 T3 T4 Tx Tx + 1 Ty Ty + 1 CK_c CK_t CA[9:0] CMD AB PRECHARGE NOP NOP REFab NOP ≥ tRFCab ≥ tRPab NOP REFab Any ≥ tRFCab Figure 41: Per-Bank REFRESH Operation T0 T1 Tx Tx + 1 Tx + 2 Ty Ty + 1 Tz Tz + 1 CK_c CK_t CA[9:0] CMD Bank 1 Row A AB PRECHARGE NOP NOP ≥tRPab REFpb REFRESH to bank 0 Notes: ACTIVATE REFpb ≥tRFCpb Row A ≥tRFCpb REFRESH to bank 1 ACTIVATE command to bank 1 1. In the beginning of this example, the REFpb bank counter points to bank 0. 2. Operations to banks other than the bank being refreshed are supported during the tRFCpb period. 68 178-Ball, Single-Channel Mobile LPDDR3 SDRAM SELF REFRESH Operation SELF REFRESH Operation The SELF REFRESH command can be used to retain data in the array, even if the rest of the system is powered-down. When in the self refresh mode, the device retains data without external clocking. The device has a built-in timer to accommodate SELF REFRESH operation. The SELF REFRESH command is executed by taking CKE LOW, CS_n LOW, CA0 LOW, CA1 LOW, and CA2 HIGH at the rising edge of the clock. CKE must be HIGH during the clock cycle preceding a SELF REFRESH command. CKE must not go LOW while MRR, MRW, READ, or WRITE operations are in progress. To ensure that there is enough time to account for internal delay on the CKE signal path, two NOP commands are required after CKE is driven LOW; this timing period is defined as tCPDED. CKE LOW will result in deactivation of input receivers after tCPDED has expired. After the power-down command is registered, CKE must be held LOW to keep the device in self refresh mode. Mobile LPDDR3 devices can operate in self refresh mode in both the standard and extended temperature ranges. These devices also manage self refresh power consumption when the operating temperature changes, resulting in the lowest possible power consumption across the operating temperature range. See the IDD Specification Parameters and Operating Conditions table for details. After the device has entered self refresh mode, all external signals other than CKE are “Don’t Care.” For proper SELF REFRESH operation, power supply pins (VDD1, V DD2, VDDQ, and V DDCA) must be at valid levels. V DDQ can be turned off during self refresh. If VDDQ is turned off, V REFDQ must also be turned off. Prior to exiting self refresh, both VDDQ and V REFDQ must be within their respective minimum/maximum operating ranges (see AC and DC Operating Conditions). V REFDQ can be at any level between 0 and VDDQ; V REFCA can be at any level between 0 and V DDCA during self refresh. Before exiting self refresh, V REFDQ and V REFCA must be within specified limits (see the AC and DC Logic Input Measurement Levels for Single-Ended Signals section). After entering self refresh mode, the device initiates at least one all-bank REFRESH command internally during tCKESR. The clock is internally disabled during SELF REFRESH operation to save power. The device must remain in self refresh mode for at least tCKESR. The user can change the external clock frequency or halt the external clock one clock after self refresh entry is registered; however, the clock must be restarted and stable before the device can exit SELF REFRESH operation. Exiting self refresh requires a series of commands. First, the clock must be stable prior to CKE returning HIGH. After the self refresh exit is registered, a minimum delay, at least equal to the self refresh exit interval (tXSR), must be satisfied before a valid command can be issued to the device. This provides completion time for any internal refresh in progress. For proper operation, CKE must remain HIGH throughout tXSR. NOP commands must be registered on each rising clock edge during tXSR. For the description of ODT operation and specifications during self-refresh entry and exit, see "On Die Termination" section. Using self refresh mode introduces the possibility that an internally timed refresh event could be missed when CKE is driven HIGH for exit from self refresh mode. Upon exiting self refresh, at least one REFRESH command (one all-bank command or eight per-bank commands) must be issued before issuing a subsequent SELF REFRESH command. 69 178-Ball, Single-Channel Mobile LPDDR3 SDRAM SELF REFRESH Operation Figure 42: SELF REFRESH Operation 2 tCK (MIN) CK tCPDED tIHCKE Input clock frequency can be changed or clock can be stopped during self refresh. tIHCKE CKE tISCKE tISCKE CS_n tCKESR (MIN) CMD Valid Enter SR tXSR (MIN) Exit SR NOP NOP Enter self refresh mode NOP NOP Valid Exit self refresh mode Don’t Care Notes: 1. Input clock frequency can be changed or stopped during self refresh, provided that upon exiting self-refresh, a minimum of two cycles of stable clocks are provided, and the clock frequency is between the minimum and maximum frequencies for the particular speed grade. 2. The device must be in the all-banks-idle state prior to entering self refresh mode. 3. tXSR begins at the rising edge of the clock after CKE is driven HIGH. 4. A valid command can be issued only after tXSR is satisfied. NOPs must be issued during tXSR. Partial-Array Self Refresh (PASR) – Bank Masking LPDDR3 SDRAMs comprise eight banks. Each bank can be configured independently whether or not a SELF REFRESH operation will occur in that bank. One 8-bit mode register (accessible via the MRW command) is assigned to program the bank-masking status of each bank up to eight banks. For bank-masking bit assignments, see the MR16 PASR Bank Mask (MA[7:0] = 010h) and MR16 Op-Code Bit Definitions tables. The mask bit to the bank enables or disables a refresh operation of the entire memory space within the bank. If a bank is masked using the bank-mask register, a REFRESH operation to the entire bank is blocked, and bank data retention is not guaranteed in self refresh mode. To enable a REFRESH operation to a bank, the corresponding bank mask bit must be programmed as “unmasked.” When a bank mask bit is unmasked, the array space being refreshed within that bank is determined by the programmed status of the segment mask bits. Partial-Array Self Refresh – Segment Masking Programming segment-mask bits is similar to programming bank-mask bits. Eight segments are used for masking (see the MR17 PASR Segment Mask (MA[7:0] = 011h) and MR17 PASR Segment Mask Definitions tables). A mode register is used for programming segment-mask bits up to eight bits. 70 178-Ball, Single-Channel Mobile LPDDR3 SDRAM SELF REFRESH Operation When the mask bit to an address range (represented as a segment) is programmed as “masked,” a REFRESH operation to that segment is blocked. Conversely, when a segment mask bit to an address range is unmasked, refresh to that segment is enabled. A segment-masking scheme can be used in place of or in combination with a bankmasking scheme. Each segment mask bit setting is applied across all banks. For segment-masking bit assignments, see the MR17 PASR Segment Mask (MA[7:0] = 011h) and MR17 PASR Segment Mask Definitions tables. Table 48: Bank- and Segment-Masking Example Segment Mask (MR17) Bank 0 Bank 1 Bank 2 Bank 3 Bank 4 Bank 5 Bank 6 Bank 7 Bank Mask (MR16) 0 1 0 0 0 0 0 1 Segment 0 0 – M – – – – – M Segment 1 0 – M – – – – – M Segment 2 1 M M M M M M M M Segment 3 0 – M – – – – – M Segment 4 0 – M – – – – – M Segment 5 0 – M – – – – – M Segment 6 0 – M – – – – – M Segment 7 1 M M M M M M M M Note: 1. This table provides values for an eight-bank device with REFRESH operations masked to banks 1 and 7 and to segments 2 and 7. 71 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER READ MODE REGISTER READ The MODE REGISTER READ (MRR) command is used to read configuration and status data from SDRAM mode registers. The MRR command is initiated with CS_n LOW, CA0 LOW, CA1 LOW, CA2 LOW, and CA3 HIGH at the rising edge of the clock. The mode register is selected by CA1f–CA0f and CA9r–CA4r. The mode register contents are available on the first data beat of DQ[7:0] after RL × tCK + tDQSCK + tDQSQ and following the rising edge of the clock where MRR is issued. Subsequent data beats contain valid but undefined content, except in the case of the DQ calibration function, where subsequent data beats contain valid content as described in the Data Calibration Pattern Description table. All DQS are toggled for the duration of the mode register READ burst. The MRR command has a burst length of eight. MRR operation (consisting of the MRR command and the corresponding data traffic) must not be interrupted. The MRR command period is tMRR. Figure 43: MRR Timing T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 T12 T13 T14 CK_c CK_t RL = 8 CA[9:0] Register A Register A Register B Register B tMRR CMD MRR1 NOP2 tMRR NOP2 NOP2 MRR1 NOP2 NOP2 NOP2 Valid Valid Valid Valid Valid Valid Valid DQS_c DQS_t DQ[7:0]3 DOUTA DOUTB DQ[MAX:8] Transitioning data Notes: Undefined 1. MRRs to DQ calibration registers MR32 and MR40 are described in the DQ Calibration section. 2. Only the NOP command is supported during tMRR. 3. Mode register data is valid only on DQ[7:0] on the first beat. Subsequent beats contain valid but undefined data. DQ[MAX:8] contain valid but undefined data for the duration of the MRR burst. 4. Minimum MRR to write latency is RL + RU(tDQSCK (MAX)/tCK) + 8/2 + 1 - WL clock cycles. 5. Minimum MRR to MRW latency is RL + RU(tDQSCK (MAX)/tCK) + 8/2 + 1 clock cycles. 6. In this example, RL = 8 for illustration purposes only. After a prior READ command, the MRR command must not be issued before BL/2 clock cycles have completed. Following a WRITE command, the MRR command must not be issued before WL + 1 + BL/2 + RU( tWTR/tCK) clock cycles have completed, as READ bursts and WRITE bursts must not be truncated my MRR. 72 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER READ Figure 44: READ to MRR Timing T0 T1 Tx Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Tx+7 Tx+8 Tx+9 CK_c CK_t RL CA[9:0] Bankm Col addr col addr a a Register B Register B tMRR CMD READ NOP1 NOP1 NOP1 NOP1 MRR NOP1 NOP1 Valid DQS_c DQS_t DQ[7:0] DOUT A0 DOUT A1 DOUT A2 DOUT A3 DOUT A0 DOUT A1 DOUT A2 DOUT A3 DQ[MAX:8] DOUT A0 DOUT A1 DOUT A2 DOUT A3 DOUT A0 DOUT A1 DOUT A2 DOUT A3 DOUT B Transitioning data Notes: Undefined 1. The minimum number of clock cycles from the burst READ command to the MRR command is BL/2. 2. Only the NOP command is supported during tMRR. Figure 45: Burst WRITE Followed by MRR T0 Tx Tx+1 Tx+2 Tx+3 Tx+4 Tx+5 Tx+6 Ty Ty+1 Ty+2 CK_c CK_t WL CA[9:0] Bankn col addr a RL Col addr a Register B Register B t WTR CMD Valid WRITE tMRR MRR1 NOP2 NOP2 DQS_c DQS_t DQ DIN A0 DIN A1 DIN A2 DIN A3 DIN A4 DIN A5 DIN A6 DIN A7 Transitioning data Notes: 1. The minimum number of clock cycles from the burst WRITE command to the MRR command is [WL + 1 + BL/2 + RU(tWTR/tCK)]. 2. Only the NOP command is supported during tMRR. MRR Following Idle Power-Down State Following the idle power-down state, an additional time, tMRRI, is required prior to issuing the MODE REGISTER READ (MRR) command. This additional time (equivalent to tRCD) is required in order to maximize power-down current savings by allowing more power-up time for the MRR data path after exit from the idle power-down state. 73 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER READ Figure 46: MRR After Idle Power-Down Exit CK tIHCKE tCKE (MIN) CKE tISCKE CS_n tXP(MIN) CMD Exit PD tMRRI NOP NOP Valid1 Valid1 Valid1 tMRR MRR Valid Valid Don’t Care Exit power-down mode 1. Any valid command except MRR. Note: Temperature Sensor LPDDR3 devices feature a temperature sensor whose status can be read from MR4. This sensor can be used to determine an appropriate refresh rate, determine whether AC timing derating is required in the extended temperature range, and/or monitor the operating temperature. Either the temperature sensor or the device operating temperature can be used to determine whether operating temperature requirements are being met (see the Operating Temperature Range table). Temperature sensor data can be read from MR4 using the mode register read protocol. Upon exiting self-refresh or power-down, the device temperature status bits will be no older than tTSI. When using the temperature sensor, the actual device case temperature may be higher than the operating temperature specification that applies for the standard or extended temperature ranges (see the Operating Temperature Range table). For example, T CASE could be above 85°C when MR4[2:0] equals 011b. To ensure proper operation using the temperature sensor, applications must accommodate the following table. Table 49: Temperature Sensor Definitions and Operating Conditions Parameter Description Symbol Min/Max Value Unit System temperature gradient Maximum temperature gradient experienced by the memory device at the temperature of interest over a range of 2°C TempGradient MAX System-dependent °C/s MR4 READ interval Time period between MR4 READs from the system ReadInterval MAX System-dependent ms Temperature sensor interval Maximum delay between internal updates of MR4 tTSI MAX 32 ms System response delay Maximum response time from an MR4 READ to the system response SysRespDelay MAX System-dependent ms 74 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER READ Table 49: Temperature Sensor Definitions and Operating Conditions (Continued) Parameter Description Device temperature margin Margin above maximum temperature to support controller response Symbol Min/Max Value Unit TempMargin MAX 2 °C These devices accommodate the temperature margin between the point at which the device temperature enters the extended temperature range and the point at which the controller reconfigures the system accordingly. To determine the required MR4 polling frequency, the system must use the maximum TempGradient and the maximum response time of the system according to the following equation: TempGradient × (ReadInterval + tTSI + SysRespDelay) ≤ 2°C For example, if TempGradient is 10˚C/s, and the SysRespDelay is 1ms: 10°C × (ReadInterval + 32ms + 1ms) ≤ 2°C s In this case, ReadInterval must not exceed 167ms. Figure 47: Temperature Sensor Timing Temp < (tTSI + ReadInterval + SysRespDelay) Device Temp Margin ient Grad Temp 2°C MR4 Trip Level tTSI MR4 = 0x03 MR4 = 0x86 MR4 = 0x86 MR4 = 0x86 MR4 = 0x06 Time Temperature sensor update ReadInterval Host MR4 READ MRR MR4 = 0x03 SysRespDelay MRR MR4 = 0x86 DQ Calibration LPDDR3 devices feature a DQ calibration function that outputs one of two predefined system timing calibration patterns. An MRR operation to MR32 (pattern A) or and MRR 75 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER READ operation to MR40 (pattern B) will return the specified pattern on DQ0 and DQ8—for x32 devices, on DQ0, DQ8, DQ16 and DQ24. For x16 devices, DQ[7:1] and DQ[15:9] drive the same information as DQ0 during the MRR burst. For x32 devices, DQ[7:1], DQ[15:9], DQ[23:17], and DQ[31:25] drive the same information as DQ0 during the MRR burst. MRR DQ calibration commands can occur only in the idle state. Figure 48: MR32 and MR40 DQ Calibration Timing T0 T1 T6 T7 T8 T9 T10 T11 T12 T13 T14 T15 CK_c CK_t RL = 6 CA[9:0] Reg 32 Reg 32 Reg 40 Reg 40 tMRR CMD MRR tMRR =4 NOP1 NOP1 NOP1 =4 NOP1 NOP MRR NOP1 NOP1 DQS_c DQS_t Pattern A Pattern B DQ0 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 DQ[7:1] 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 x16 DQ8 1 0 1 0 0 0 1 1 0 0 1 1 0 0 1 1 DQ[15:9] 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 DQ16 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 DQ[23:17] 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 DQ24 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 DQ[31:25] 1 0 1 0 1 0 1 0 0 0 1 1 0 0 1 1 x32 Transitioning data Optionally driven the same as DQ0 or 0b Table 50: Data Calibration Pattern Description Pattern MR# Bit Time 0 Bit Time 1 Bit Time 2 Bit Time 3 Bit Time 4 Bit Time 5 Bit Time 6 Bit Time 7 Pattern A MR32 1 0 1 0 1 0 1 0 Reads to MR32 return DQ calibration pattern A Pattern B MR40 0 0 1 1 0 0 1 1 Reads to MR40 return DQ calibration pattern B 76 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE MODE REGISTER WRITE The MRW command is used to write configuration data to the mode registers. The MRW command is initiated with CS_n LOW, CA0 LOW, CA1 LOW, CA2 LOW, and CA3 LOW at the rising edge of the clock. The mode register is selected by CA1f–CA0f, CA9r– CA4r. The data to be written to the mode register is contained in CA9f–CA2f. The MRW command period is defined by tMRW. Mode register writes to read-only registers have no impact on the functionality of the device. Figure 49: MODE REGISTER WRITE Timing T0 T1 T2 Tx Tx + 1 Tx + 2 Ty 1 Ty + 1 Ty + 2 CK_c CK_t tMRW CA[9:0] CMD tMRW MR addr MR data MRW MR addr MR data NOP2 Notes: NOP2 NOP2 MRW NOP2 Valid 1. At time Ty, the device is in the idle state. 2. Only the NOP command is supported during tMRW. MRW can be issued only when all banks are in the idle precharge state. One method of ensuring that the banks are in this state is to issue a PRECHARGE ALL command. MRW RESET Command The MRW RESET command brings the device to the device auto initialization (resetting) state in the power-on initialization sequence (see the Voltage Ramp and Device Initialization section). The MRW RESET command can be issued from the idle state. This command resets all mode registers to their default values. After MRW RESET, boot timings must be observed until the device initialization sequence is complete, and the device is in the idle state. Array data is undefined after the MRW RESET command. If the initialization is to be performed at-speed (greater than the recommended boot clock frequency), then CA training may be necessary to ensure setup and hold timings. As the MRW RESET command is required prior to CA Training, an alternate MRW RESET command with an op-code of 0xFCh should be used. This encoding ensures that no transitions occur on the CA bus. Prior to CA training, it is recommended to hold the CA bus stable for one cycle prior to, and one cycle after, the issuance of the MRW RESET command to ensure setup and hold timings on the CA bus. For MRW RESET timing, see the figure below and see the Voltage Ramp and Initialization Sequence figure. 77 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE Table 51: Truth Table for MRR and MRW Current State Command Intermediate State Next State MRR Reading mode register, all banks idle All banks idle MRW Writing mode register, all banks idle All banks idle MRW (RESET) Resetting, device auto initialization All banks idle All banks idle Bank(s) active MRR Reading mode register, bank(s) active Bank(s) active MRW Not allowed Not allowed MRW (RESET) Not allowed Not allowed Figure 50: MODE REGISTER WRITE Timing for MRW RESET Td Td’ Te CK_t CK_c CKE CA[9:0] FCh CMD FCh FCh Reg B FCh MRW (Optional) MRW Reg B MRR tINIT3 tINIT4 CS_n Optional CA/CMD CMD not allowed Note: Optional CS_n 1. Optional MRW RESET command and optional CS_n assertion are allowed. When the optional MRW RESET command is used, tINIT4 starts at Td'. MRW ZQ Calibration Commands The MRW command is used to initiate a ZQ calibration command that calibrates output driver impedance across process, temperature, and voltage. LPDDR3 devices support ZQ calibration. There are four ZQ calibration commands and related timings: tZQINIT, tZQRESET, tZQCL, and tZQCS. tZQINIT is used for initialization calibration; tZQRESET is used for resetting ZQ to the default output impedance; tZQCL is used for long calibration(s); and 78 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE tZQCS is used for short calibration(s). See the MR10 Calibration (MA[7:0] = 0Ah) table for ZQ calibration command code definitions. The initialization ZQ calibration (ZQINIT) must be performed for LPDDR3. ZQINIT provides an output impedance accuracy of ±15%. After initialization, the ZQ calibration long (ZQCL) can be used to recalibrate the system to an output impedance accuracy of ±15%. A ZQ calibration short (ZQCS) can be used periodically to compensate for temperature and voltage drift in the system. ZQRESET resets the output impedance calibration to a default accuracy of ±30% across process, voltage, and temperature. This command is used to ensure output impedance accuracy to ±30% when ZQCS and ZQCL commands are not used. One ZQCS command can effectively correct at least 1.5% (ZQ correction) of output impedance errors within tZQCS for all speed bins, assuming the maximum sensitivities specified in the Output Driver Sensitivity Definition and Output Driver Temperature and Voltage Sensitivity tables are met. The appropriate interval between ZQCS commands can be determined using these tables and system-specific parameters. LPDDR3 devices are subject to temperature drift rate (Tdriftrate) and voltage drift rate (Vdriftrate) in various applications. To accommodate drift rates and calculate the necessary interval between ZQCS commands, apply the following formula: ZQcorrection (Tsens × Tdriftrate ) + (Vsens × Vdriftrate ) Where T sens = MAX (dRONdT) and V sens = MAX (dRONdV) define temperature and voltage sensitivities. For example, if T sens = 0.75%/˚C, V sens = 0.20%/mV, T driftrate = 1˚C/sec, and V driftrate = 15 mV/sec, then the interval between ZQCS commands is calculated as: 1.5 = 0.4s (0.75 × 1) + (0.20 × 15) A ZQ calibration command can be issued only when the device is in the idle state with all banks precharged. No other activities can be performed on the data bus during calibration periods (tZQINIT, tZQCL, or tZQCS). The quiet time on the data bus helps to accurately calibrate output impedance. There is no required quiet time after the ZQRESET command. If multiple devices share a single ZQ resistor, only one device can be calibrating at any given time. After calibration is complete, the ZQ ball circuitry is disabled to reduce power consumption. In systems sharing a ZQ resistor among devices, the controller must prevent tZQINIT, and tZQCL overlap between the devices. ZQRESET overlap is acceptable. If the ZQ resistor is absent from the system, ZQ must be connected to V DDCA. In this situation, the device must ignore ZQ calibration commands, and the device will use the default calibration settings. tZQCS, 79 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE Figure 51: ZQ Timings T0 T1 T2 T3 T4 T5 Tx Tx + 1 Tx + 2 CK_c CK_t CA[9:0] MR addr MR data ZQINIT tZQINIT CMD MRW NOP NOP NOP NOP NOP Valid NOP NOP Valid NOP NOP Valid NOP NOP Valid ZQCS tZQCS CMD MRW NOP NOP NOP ZQCL tZQCL CMD MRW NOP NOP NOP ZQRESET tZQRESET CMD MRW NOP Notes: NOP NOP 1. Only the NOP command is supported during ZQ calibration. 2. CKE must be registered HIGH continuously during the calibration period. 3. All devices connected to the DQ bus should be High-Z during the calibration process. 80 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE ZQ External Resistor Value, Tolerance, and Capacitive Loading To use the ZQ calibration function, a 240Ω (±1% tolerance) external resistor must be connected between the ZQ pin and ground. A single resistor can be used for each device, or one resistor can be shared among multiple devices if the ZQ calibration timings for each device do not overlap. The total capacitive loading on the ZQ pin must be limited (see the Input/Output Capacitance table). MRW – CA Training Mode Because CA inputs operate as double data rate, it may be difficult for the memory controller to satisfy CA input setup/hold timings at higher frequency. A CA training mechanism is provided. CA Training Sequence 1. CA training mode entry: MODE REGISTER WRITE command to MR41 2. CA training session: Calibrate CA0, CA1, CA2, CA3, CA5, CA6, CA7 and CA8 (see the CA Training Mode Enable [MR41] table) 3. CA to DQ mapping change: MODE REGISTER WRITE command to MR48 4. Additional CA training session: Calibrate remaining CA pins (CA4 and CA9) (see the CA Training Mode Enable [MR48] table) 5. CA training mode exit: MODE REGISTER WRITE command to MR42 Figure 52: CA Training Timing CK_t CK_c MRW#41, #48 MRW#41, #48 MRW#41, #48 (optional)4 (CA cal.Entry) (optional)4 MRW#42 (optional)4 CAx CAx CAx CAx R R# R R# CA[9:0] MRW#42 (CA cal.Exit) MRW#42 (optional)4 CAy CAy CAx CAx R R# R R# CS_n CKE tCACKEL tCAMRD tCAENT tCACD tADR tADR tCACKEH tCAEXT tMRZ Even DQ CAx R CAy R Odd DQ CAx R# CAy R# Optional CA Notes: Optional CS_n Don’t Care 1. Unused DQ must be valid HIGH or LOW during data output period. Unused DQ may transition at the same time as the active DQ. DQS must remain static and not transition. 2. CA to DQ mapping change via MR 48 omitted here for clarity of the timing diagram. Both MR41 and MR48 training sequences must be completed before exiting the training mode (MR42). To enable a CA to DQ mapping change, CKE must be driven HIGH prior to issuance of the MRW 48 command. (See the steps in the CA Training Sequence section for details.) 3. Because data-out control is asynchronous and will be an analog delay from when all the CA data is available, tADR and tMRZ are defined from the falling edge of CK. 81 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE 4. It is recommended to hold the CA bus stable for one cycle prior to and one cycle after the issuance of the MRW CA TRAINING ENTRY command to ensure setup and hold timings on the CA bus. 5. Optional MRW 41, 48, 42 commands and the CA CALIBRATION command are allowed. To complement these optional commands, optional CS_n assertions are also allowed. All timing must comprehend these optional CS_n assertions: a) tADR starts at the falling clock edge after the last registered CS_n assertion; b) tCACD, tCACKEL, and tCAMRD start with the rising clock edge of the last CS_n assertion; c) tCAENT and tCAEXT need to be met by the first CS_n assertion; and d) tMRZ will be met after the falling clock edge following the first CS_n assertion with exit (MRW42) command. 6. Clock phase may be adjusted in CA training mode while CS_n is HIGH and CKE is LOW, resulting in an irregular clock with shorter/longer periods and pulse widths. The device may not properly recognize a MODE REGISTER WRITE command at normal operation frequency before CA training is finished. Special encodings are provided for CA training mode enable/disable. MR41 and MR42 encodings are selected so that rising-edge and falling-edge values are the same. The device will recognize MR41 and MR42 at normal operation frequency even before CA timing adjustments have been made. Calibration data will be output through DQ pins. CA to DQ mapping is described in the CA to DQ mapping (CA training mode enabled with MR41) table. After timing calibration with MR41 is finished, issue MRW to MR48 and calibrate the remaining CA pins (CA4 and CA9) using (DQ0/DQ1and DQ8/DQ9) as calibration data output pins (see the CA to DQ mapping (CA training mode enabled with MR48) table). Table 52: CA Training Mode Enable (MR41 (29H, 0010 1001b), OP = A4H (1010 0100b)) Clock Edge CA0 CA1 CA2 CA3 CA4 CA5 CA6 CA7 CA8 CA9 CK rising edge L L L L H L L H L H CK falling edge L L L L H L L H L H Table 53: CA Training Mode Disable (MR42 (2AH, 0010 1010b), OP = A8H(1010 1000b)) Clock Edge CA0 CA1 CA2 CA3 CA4 CA5 CA6 CA7 CA8 CA9 CK rising edge L L L L L H L H L H CK falling edge L L L L L H L H L H Table 54: CA to DQ Mapping (CA Training Mode Enabled with MR41) Clock Edge CA0 CA1 CA2 CA3 CA5 CA6 CA7 CA8 CK rising edge DQ0 DQ2 DQ4 DQ6 DQ8 DQ10 DQ12 DQ14 CK falling edge DQ1 DQ3 DQ5 DQ7 DQ9 DQ11 DQ13 DQ15 Note: 1. Other DQs must have valid output (either HIGH or LOW). 82 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE Table 55: CA Training Mode Enable (MR48 (30H, 0011 0000b), OP = C0H (1100 0000b)) Clock Edge CA0 CA1 CA2 CA3 CA4 CA5 CA6 CA7 CA8 CA9 CK rising edge L L L L L L L L H H CK falling edge L L L L L L L L H H Table 56: CA to DQ Mapping (CA Training Mode Enabled with MR48) Clock Edge CA4 CA9 CK rising edge DQ0 DQ8 CK falling edge DQ1 DQ9 Note: 1. Other DQs must have valid output (either HIGH or LOW). MRW - Write Leveling Mode To improve signal integrity performance, the device provides a write-leveling feature to compensate for timing skew, which affects timing parameters such as tDQSS, tDSS, and tDSH. The memory controller uses the write-leveling feature to receive feedback from the device, enabling it to adjust the clock-to-data strobe signal relationship for each DQS signal pair. The memory controller performing the leveling must have an adjustable delay setting on the DQS signal pair to align the rising edge of DQS_t signals with that of the clock signal at the DRAM pin. The device asynchronously feeds back CLK, sampled with the rising edge of DQS_t signals. The controller repeatedly delays DQS_t signals until a transition from 0 to 1 is detected. The DQS_t signal delay established through this exercise ensures the tDQSS specification can be met. All data bits carry the leveling feedback to the controller (DQ[15:0] for x16 configuration, DQ[31:0] for x32 configuration). All DQS_t signals must be leveled independently. The device enters write-leveling mode when mode register MR2[7] is set HIGH. When entering write-leveling mode, the state of the DQ pins is undefined. During write-leveling mode, only NOP commands are allowed, or a MRW command to exit the write-leveling operation. Upon completion of the write-leveling operation, the device exits from write-leveling mode when MR2[7] is reset LOW. The controller drives DQS_t LOW and DQS_c HIGH after a delay of tWLDQSEN. After time tWLMRD, the controller provides DQS_t signal input, which is used by the DRAM to sample the clock signal driven from the controller. The delay time tWLMRD (MAX) is controller-dependent. The DRAM samples the clock input with the rising edge of DQS_t and provides asynchronous feedback on all the DQ bits after time tWLO. The controller samples this information and either increments or decrements the DQS_t and/or DQS_c delay settings and launches the next DQS_t/DQS_c pulse. The sample time and trigger time are controller-dependent. After the following DQS_t/DQS_c transition is sampled, the controller locks the strobe delay settings, and write leveling is achieved for the device. 83 178-Ball, Single-Channel Mobile LPDDR3 SDRAM MODE REGISTER WRITE Figure 53: Write-Leveling Timing tWLS tWLH tWLS tWLH CK_t CK_c CAs CMD CA CA MRW CA NOP NOP NOP NOP NOP NOP NOP NOP NOP NOP CA MRW NOP NOP tWLDQSEN DQS_t DQS_c DQ tWLMRD tWLO tDQSL tWLO tDQSH 84 tMRD NOP Valid 178-Ball, Single-Channel Mobile LPDDR3 SDRAM On-Die Termination (ODT) On-Die Termination (ODT) On-die termination (ODT) is a feature that enables the device to enable/disable and turn on/off termination resistance for each DQ, DQS, and DM signal via the ODT control pin. ODT is designed to improve signal integrity of the memory channel by enabling the DRAM controller to independently turn on/off the internal termination resistance for any or all DRAM devices. The ODT pin directly controls ODT operation and is not sampled by the clock. ODT is turned off and not supported in self refresh and deep power-down modes. The device will also disable termination during READ operations. ODT operation can be enabled optionally during power-down mode via a mode register. Note that if ODT is enabled during power-down mode, V DDQ may not be turned off during power down. The DRAM will also disable termination during READ operations. A simple functional representation of the ODT feature is shown below. Figure 54: Functional Representation of On-Die Termination ODT To other circuitry such as RCV, ... VDDQ RTT Switch DQ, DQS, DM The switch is enabled by the internal ODT control logic, which uses the external ODT pin and other control information. The value of R TT (ODT termination resistance value) is determined by the settings of several mode register bits. The ODT pin will be ignored if MR11 is programmed to disable ODT in self refresh, in deep power-down, in CKE power-down (mode register option), and during READ operations. ODT Mode Register ODT mode is enabled if MR11[1:0] are non-zero. In this case, the value of RTT is determined by the settings of those bits. ODT mode is disabled if MR11[1:0] are zero. MR11[2] determines whether ODT will operate during power-down mode if enabled through MR11[1:0]. Asychronous ODT When enabled, the ODT feature is controlled asynchronously based on the status of the ODT pin. ODT is off under any of the following conditions: • • • • • ODT is disabled through MR11[1:0] Device is performing a READ operation (READ or MRR) Device is in power-down mode and MR11[2] is zero Device is in self refresh or deep power-down mode Device is in CA training mode In asynchronous ODT mode, the following timing parameters apply when ODT operation is controlled by the ODT pin tODToff, tODTon. 85 178-Ball, Single-Channel Mobile LPDDR3 SDRAM On-Die Termination (ODT) Minimum RTT turn-on time (tODTon [MIN]) is the point in time when the device termination circuit leaves High-Z state and ODT resistance begins to turn on. Maximum RTT turn-on time (tODTon,max) is the point in time when ODT resistance is fully on. tODTon (MIN) and tODTon (MAX) are measured from ODT pin HIGH. Minimum RTT turn-off time (tODToff [MIN]) is the point in time when the device termination circuit starts to turn off the ODT resistance. Maximum ODT turn off time (tODToff [MAX]) is the point in time when the on-die termination has reached High-Z. tODToff,min and tODToff (MAX) are measured from ODT pin LOW. ODT During READ Operations (READ or MRR) During READ operations, the device will disable termination and disable ODT control through the ODT pin. After READ operations are completed, ODT control is resumed through the ODT pin (if ODT mode is enabled). ODT During Power-Down When MR11[2] is zero, termination control through the ODT pin will be disabled when the DRAM enters power-down. After a power-down entry is registered, termination will be disabled within a time window specified by tODTd (MIN) (MAX). ODT pin control is resumed when power-down is exited (if ODT mode is enabled). Between the POWERDOWN EXIT command and until tXP is satisfied, termination will transition from disabled to control by the ODT pin. When tXP is satisfied, the ODT pin is used to control termination. Minimum RTT disable time (tODTd [MIN]) is the point in time when the device termination circuit is no longer controlled by the ODT pin. Maximum ODT disable time (tODTd [MAX]) is the point in time when ODT will be in High-Z. When MR11[2] is enabled and MR11[1:0] are non-zero, ODT operation is supported during CKE power-down with ODT control through the ODT pin. ODT During Self Refresh The device disables the ODT function during self refresh. After a SELF REFRESH command is registered, termination will be disabled within a time window specified by tODTd (MIN) (MAX). During self refresh exit, ODT control through the ODT pin is resumed (if ODT mode is enabled). Between the SELF REFRESH EXIT command and until tXSR is satisfied, termination will transition from disabled to control by the ODT pin. When tXSR is satisfied, the ODT pin is used to control termination. ODT During Deep Power-Down The device disables the ODT function during deep power-down. After a DEEP POWERDOWN command is registered, termination will be disabled within a time window specified by tODTd (MIN) (MAX). ODT During CA Training and Write Leveling During CA training mode, the device will disable ODT and ignore the state of the ODT control pin. For ODT operation during write leveling mode, refer to the DRAM Termination Function in Write-Leveling Mode table for termination activation and deactivation for DQ and DQS_t/DQS_c. If ODT is enabled, the ODT pin must be HIGH in write leveling mode. 86 178-Ball, Single-Channel Mobile LPDDR3 SDRAM On-Die Termination (ODT) Table 57: DRAM Termination Function in Write-Leveling Mode ODT Pin DQS Termination DQ Termination De-asserted OFF OFF Asserted ON OFF Table 58: ODT States Truth Table Write Read/DQ Calibration ZQ Calibration CA Training Write Leveling DQ termination Enabled Disabled Disabled Disabled Disabled DQS termination Enabled Disabled Disabled Disabled Enabled Figure 55: Asynchronous ODT Timing – RL = 12 T0 T1 T9 T10 T11 T12 T13 T14 T15 T16 T17 T18 T19 T20 T21 CK_t, CK_c Col add CA[9:0] Bank n Col add CMD READ RL = 12 DQS_t, DQS_c DO 0 DQ DO 1 DO 2 DO 3 DO 4 DO 5 DO 6 DO 7 tDQSCK ODT DRAM_RTT ODTon ODToff tODToff tODTon (MIN) tODToff (MIN) tODTon (MIN) (MAX) Don’t Care 87 178-Ball, Single-Channel Mobile LPDDR3 SDRAM On-Die Termination (ODT) Figure 56: Automatic ODT Timing During READ Operation – RL = m T0 T1 Tm-3 Tm-2 Tm-1 Tm Tm+1 Tm+2 Tm+3 Tm+4 Tm+5 Tm+6 Tm+7 Tm+8 Tm+9 CK_t, CK_c Col add CA[9:0] Bank n Col add CMD READ RL = m tHZ(DQS) BL/2 DQS_t, DQS_c DO 0 DQ DO 1 DO 2 DO 3 DO 4 DO 5 DO 6 DO 7 tDQSCK ODT ODTon DRAM_RTT ODToff tAODToff ODTon tAODTon Don’t Care Notes: 1. The automatic RTT turn-off delay, tAODToff, is referenced from the rising edge of RL - 2 clock at Tm-2. 2. The automatic RTT turn-on delay, tAODTon, is referenced from the rising edge of RL + BL/2 clock at Tm+4. Figure 57: ODT Timing During Power-Down, Self Refresh, Deep Power-Down Entry/Exit T0 T1 T2 T3 Tm-1 Tm-2 Tm Tm+1 Tm+2 Tn CK_t, CK_c CKE ODT DRAM_RTT ODTon ODToff tODTd ODTon tODTe Don’t Care Note: 1. Upon exiting of deep power-down mode, a complete power-up initialization sequence is required. 88 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Power-Down Power-down is entered synchronously when CKE is registered LOW and CS_n is HIGH at the rising edge of clock. A NOP command must be driven in the clock cycle following the POWER-DOWN command. CKE must not go LOW while MRR, MRW, READ, or WRITE operations are in progress. CKE can go LOW while any other operations, such as ROW ACTIVATION, PRECHARGE, AUTO PRECHARGE, or REFRESH are in progress, but the power-down IDD specification is not applied until such operations are complete. Entering power-down deactivates the input and output buffers, excluding CKE. To ensure enough time to account for internal delay on the CKE signal path, two NOP commands are required after CKE is driven LOW. this timing period is defined as tCPDED. CKE LOW results in deactivation of input receivers after tCPDED has expired. In powerdown mode, CKE must be held LOW; all other input signals are “Don’t Care.” CKE LOW must be maintained until tCKE is satisfied, and V REFCA must be maintained at a valid level during power-down. VDDQ can be turned off during power-down. If V DDQ is turned off, V REFDQ must also be turned off. Prior to exiting power-down, both V DDQ and V REFDQ must be within their respective minimum/maximum operating ranges (see the AC and DC Operating Conditions section). No refresh operations are performed in power-down mode. The maximum duration in power-down mode is only limited by the refresh requirements outlined in the REFRESH Command section. The power-down state is exited when CKE is registered HIGH. The controller must drive CS_n HIGH in conjunction with CKE HIGH when exiting the power-down state. CKE HIGH must be maintained until tCKE is satisfied. A valid, executable command can be applied with power-down exit latency tXP after CKE goes HIGH. Power-down exit latency is defined in the AC Timing table. If power-down occurs when all banks are idle, this mode is referred to as idle powerdown; if power-down occurs when a row is active in any bank, this mode is referred to as active power-down. For the description of ODT operation and specifications during power-down entry and exit, see the On-Die Termination section. 89 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Figure 58: Power-Down Entry and Exit Timing 2 tCK (MIN) CK tCPDED Input clock frequency can be changed 1 or the input clock can be stopped during power-down. tIHCKE tIHCKE tCKE (MIN) CKE tISCKE tISCKE CS_n tCKE tXP (MIN) Exit PD CMD Valid Enter NOP NOP PD Enter power-down mode (MIN) NOP NOP Valid Exit power-down mode Don’t Care Note: 1. Input clock frequency can be changed or the input clock stopped during power-down, provided that the clock frequency is between the minimum and maximum specified frequencies for the speed grade in use and that prior to power-down exit, a minimum of two stable clocks complete. Figure 59: CKE Intensive Environment CK_c CK_t tCKE tCKE CKE 90 tCKE tCKE 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Figure 60: REFRESH to REFRESH Timing in CKE Intensive Environments CK_c CK_t tCKE tCKE tCKE tCKE CKE tXP tXP tREFI CMD REFRESH Note: REFRESH 1. The pattern shown can repeat over an extended period of time. With this pattern, all AC and DC timing and voltage specifications with temperature and voltage drift are ensured. Figure 61: READ to Power-Down Entry T0 T1 T2 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 Tx + 5 Tx + 6 Tx + 7 Tx + 8 Tx + 9 CK_c CK_t RL tISCKE CKE1, 2 CMD READ DOUT DOUT DOUT DOUT DOUT DOUT DOUT DOUT DQ DQS_c DQS_t Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. CKE can be registered LOW at {RL + RU[tDQSCK(MAX)/tCK] + BL/2 + 1} clock cycles after the clock on which the READ command is registered. 91 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Figure 62: READ with Auto Precharge to Power-Down Entry T0 T1 T2 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 Tx + 5 Tx + 6 Tx + 7 Tx + 8 Tx + 9 CK_c CK_t tISCKE BL/23 RL CKE1, 2 CMD PRE4 READ w/AP DOUT DOUT DOUT DOUT DOUT DOUT DOUT DOUT DQ DQS_c DQS_t Notes: 1. CKE must be held HIGH until the end of the burst operation. 2. CKE can be registered LOW at [RL + RU(tDQSCK/tCK) + BL/2 + 1] clock cycles after the clock on which the READ command is registered. 3. BL/2 with tRTP = 7.5ns and tRAS (MIN) is satisfied. 4. Start internal PRECHARGE. Figure 63: WRITE to Power-Down Entry T0 T1 Tm Tm + 1 Tm + 2 Tm + 3 Tm + 4 Tm + 5 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 CK_c CK_t WL tISCKE BL/2 CKE1 tWR CMD WRITE DIN DQ DIN DIN DIN DIN DIN DIN DIN DQS_c DQS_t Note: 1. CKE can be registered LOW at [WL + 1 + BL/2 + RU(tWR/tCK)] clock cycles after the clock on which the WRITE command is registered. 92 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Figure 64: WRITE with Auto Precharge to Power-Down Entry T0 T1 Tm Tm + 1 Tm + 2 Tm + 3 Tm + 4 Tm + 5 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 CK_c CK_t WL tISCKE BL/2 CKE1 tWR CMD PRE2 WRITE w/AP DQ DIN DIN DIN DIN DIN DIN DIN DIN DQS_c DQS_t Notes: 1. CKE can be registered LOW at [WL + 1 + BL/2 + RU(tWR/tCK) + 1] clock cycles after the WRITE command is registered. 2. Start internal PRECHARGE. Figure 65: REFRESH Command to Power-Down Entry T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 CK_c CK_t tISCKE CKE1 tIHCKE CMD REFRESH Note: 1. CKE can go LOW tIHCKE after the clock on which the REFRESH command is registered. 93 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Power-Down Figure 66: ACTIVATE Command to Power-Down Entry T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 CK_c CK_t tISCKE CKE1 tIHCKE CMD ACTIVATE Note: 1. CKE can go LOW at tIHCKE after the clock on which the ACTIVATE command is registered. Figure 67: PRECHARGE Command to Power-Down Entry T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 CK_c CK_t tISCKE CKE1 tIHCKE CMD PRE Note: 1. CKE can go LOW tIHCKE after the clock on which the PRECHARGE command is registered. 94 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Deep Power-Down Figure 68: MRR Power-Down Entry CK_c T0 T1 T2 Tx Tx + 1 Tx + 2 Tx + 3 Tx + 4 Tx + 5 CK_t Tx + 6 Tx + 7 Tx + 8 Tx + 9 tISCKE RL CKE1 CMD MRR DOUT DOUT DOUT DOUT DOUT DOUT DOUT DOUT DQ DQS_c DQS_t Note: 1. CKE can be registered LOW at [RL + RU(tDQSCK/tCK)+ BL/2 + 1] clock cycles after the clock on which the MRR command is registered. Figure 69: MRW Command to Power-Down Entry T0 T1 T2 T3 T4 T5 T6 T7 T8 T9 T10 T11 CK_c CK_t tISCKE CKE1 tMRW CMD MRW Note: 1. CKE can be registered LOW tMRW after the clock on which the MRW command is registered. Deep Power-Down Deep power-down (DPD) is entered when CKE is registered LOW with CS_n LOW, CA0 HIGH, CA1 HIGH, and CA2 LOW at the rising edge of the clock. All banks must be in the idle state with no activity on the data bus prior to entering DPD mode. During DPD, CKE must be held LOW. The contents of the device will be lost upon entering DPD mode. In DPD mode, all input buffers except CKE, all output buffers, and the power supply to internal circuitry are disabled within the device. To ensure that there is enough time to account for internal delay on the CKE signal path, two NOP commands are required after CKE is driven LOW; this timing period is defined as tCPDED. CKE LOW will result in deactivation of command and address receivers after tCPDED has expired. V REFDQ can be at any level between 0 and V DDQ, and V REFCA can be at any level between 0 and V DDCA during DPD. All power supplies, including V REF, must be within the specified limits prior to exiting DPD (see AC and DC Operating Conditions). 95 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Input Clock Frequency Changes and Stop Events DPD mode is exited when CKE is registered HIGH while meeting tISCKE, and the clock must be stable. The device must be fully reinitialized using the power-up initialization sequence. For a description of ODT operation and specifications during DPD entry and exit, see the ODT During Deep Power-Down section. Figure 70: Deep Power-Down Entry and Exit Timing CK tIHCKE tCPDED Input clock frequency can be changed or the input clock can be stopped during DPD. 2 tCK (MIN) tINIT31, 2 CKE tISCKE tISCKE CS_n tRP CMD tDPD NOP Enter DPD NOP Exit DPD NOP Enter DPD mode Notes: Exit DPD mode NOP RESET Don’t Care 1. The initialization sequence can start at any time after Tx + 1. 2. tINIT3 and Tx + 1 refer to timings in the initialization sequence. For details, see the Mode Register Definition section. Input Clock Frequency Changes and Stop Events Input Clock Frequency Changes and Clock Stop with CKE LOW During CKE LOW, the device supports input clock frequency changes and clock stop under the following conditions: • Refresh requirements are met • Only REFab or REFpb commands can be in process • Any ACTIVATE or PRECHARGE commands have completed prior to changing the frequency • Related timing conditions, tRCD and tRP, have been met prior to changing the frequency • The initial clock frequency must be maintained for a minimum of two clock cycles after CKE goes LOW • The clock satisfies tCH(abs) and tCL(abs) for a minimum of two clock cycles prior to CKE going HIGH For input clock frequency changes, tCK (MIN) and tCK (MAX) must be met for each clock cycle. After the input clock frequency changes and CKE is held HIGH, additional MRW commands may be required to set the WR, RL, and so on. These settings may require adjustment to meet minimum timing requirements at the target clock frequency. 96 178-Ball, Single-Channel Mobile LPDDR3 SDRAM NO OPERATION Command For clock stop, CK_t is held LOW and CK_c is held HIGH. Input Clock Frequency Changes and Clock Stop with CKE HIGH During CKE HIGH, the device supports input clock frequency changes and clock stop under the following conditions: • Refresh requirements are met • Any ACTIVATE, READ, WRITE, PRECHARGE, MRW, or MRR commands have completed, including any associated data bursts, prior to changing the frequency • Related timing conditions, tRCD, tWR, tWRA, tRP, tMRW, tMRR, and so on, are met • CS_n must be held HIGH • Only REFab or REFpb commands can be in process The device is ready for normal operation after the clock satisfies tCH(abs) and tCL(abs) for a minimum of 2 × tCK + tXP. After the input clock frequency changes, tCK (MIN) and tCK (MAX) must be met for each clock cycle. After the input clock frequency changes, additional MRW commands may be required to set the WR, RL, and so on. These settings may require adjustment to meet minimum timing requirements at the target clock frequency. For clock stop, CK_t is held LOW and CK_c is held HIGH. NO OPERATION Command The NO OPERATION (NOP) command prevents the device from registering any unwanted commands issued between operations. A NOP command can be issued only at clock cycle n when the CKE level is constant for clock cycle n - 1 and clock cycle n. A NOP command has two possible encodings: 1. CS_n HIGH at the clock rising edge n. 2. CS_n LOW with CA0, CA1, CA2 HIGH at the clock rising edge n. The NOP command does not terminate a previous operation that is still in process, such as a READ burst or WRITE burst cycle. 97 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables Truth Tables Truth tables provide complementary information to the state diagram. They also clarify device behavior and applicable restrictions when considering the actual state of the banks. Unspecified operations and timings are illegal. To ensure proper operation after an illegal event, the device must be powered down and then restarted using the specified initialization sequence before normal operation can continue. Table 59: Command Truth Table Notes 1–13 apply to entire table Command Pins CKE Command MRW MRR CK(n-1) CK(n) CS_ n CA0 CA1 CA2 CA3 CA4 CA5 CA6 CA7 CA8 CA9 H H L L L L L MA0 MA1 MA2 MA3 MA4 MA5 X MA6 MA7 OP0 OP1 OP2 OP3 OP4 OP5 OP6 OP7 L L L L H MA0 MA1 MA2 MA3 MA4 MA5 X MA6 MA7 L L L H REFRESH (per bank) H REFRESH (all banks) H Enter self refresh H ACTIVATE (bank) H WRITE (bank) H READ (bank) H H X H L X X H L X L L H H X X L X H PRECHARGE (per bank, all banks) H ENTER DPD H L X L L H H H H H X L L H R8 R9 R10 R11 R12 BA0 BA1 BA2 X R0 R1 R2 R3 R4 R5 R6 R7 R13 R14 L H L L RFU RFU C1 C2 BA0 BA1 BA2 X AP C3 C4 C5 C6 C7 C8 C9 C10 C11 L H L H RFU RFU C1 C2 BA0 BA1 BA2 X AP C3 C4 C5 C6 C7 C8 C9 C10 C11 L H H L H AB X X BA0 BA1 BA2 X H L L X H H L X H L L NOP H L H L X X H H H X MAINTAIN PD, SREF, DPD (NOP) X X X NOP CA Pins X X H H H X X X H X X X 98 CK Edge 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables Table 59: Command Truth Table (Continued) Notes 1–13 apply to entire table Command Pins CKE CA Pins CK(n-1) CK(n) CS_ n MAINTAIN PD, SREF, DPD L L X X X X ENTER POWER-DOWN H H X X X Exit PD, SREF, DPD L H X X X Command L X H X Notes: CA0 CA1 CA2 CA3 CA4 CA5 CA6 CA7 CA8 CA9 CK Edge 1. All commands are defined by the current state of CS_n, CA0, CA1, CA2, CA3, and CKE at the rising edge of the clock. 2. Bank addresses (BA) determine which bank will be operated upon. 3. AP HIGH during a READ or WRITE command indicates that an auto precharge will occur to the bank associated with the READ or WRITE command. 4. X indicates a “Don’t Care” state, with a defined logic level, either HIGH (H) or LOW (L). For PD, SREF and DPD, CS_n, CK can be floated after tCPDED has been met and until the required exit procedure is initiated as described in their respective entry/exit procedures. 5. Self refresh exit and DPD exit are asynchronous. 6. VREF must be between 0 and VDDQ during SREF and DPD operation. 7. CAxr refers to command/address bit “x” on the rising edge of clock. 8. CAxf refers to command/address bit “x” on the falling edge of clock. 9. CS_n and CKE are sampled on the rising edge of the clock. 10. The least significant column address C0 is not transmitted on the CA bus, and is inferred to be zero. 11. AB HIGH during a PRECHARGE command indicates that an all-bank precharge will occur. In this case, bank address is a "Don't Care." 12. RFU needs to input H or L (defined logic level). 13. When CS_n is HIGH, the CA bus can be floated. Table 60: CKE Truth Table Notes 1–5 apply to entire table; L = LOW; H = HIGH; X = “Don’t Care” Command n Current State CKEn-1 CKEn CS_n Active power-down Idle power-down Resetting idle power-down L L X X L H H NOP L L X X L H H NOP L L X X L H H NOP Operation n Maintain active power-down Exit active power-down Maintain idle power-down Exit idle power-down Maintain resetting power-down Exit resetting power-down 99 Next State Notes Active power-down Active 6, 7 Idle power-down Idle 6, 7 Resetting power-down Idle or resetting 6, 7, 8 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables Table 60: CKE Truth Table (Continued) Notes 1–5 apply to entire table; L = LOW; H = HIGH; X = “Don’t Care” Command n Current State CKEn-1 CKEn CS_n Deep powerdown Self refresh L L X X L H H NOP Operation n Next State Maintain deep power-down Exit deep power-down Deep power-down Power-on 9 L L X X L H H NOP Exit self refresh Bank(s) active H L H NOP Enter active power-down Active power-down All banks idle H L H NOP Enter idle power-down Idle power-down 12 H L L Self refresh 12 H L L DPD Enter deep power-down Deep power-down 12 Resetting H L H NOP Enter resetting power-down Resetting power-down Other states H H Notes: Maintain self refresh Notes Self refresh Idle ENTER SELF Enter self refresh REFRESH 10, 11 Refer to the command truth table 1. Current state is the state of the device immediately prior to clock edge n. 2. All states and sequences not shown are illegal or reserved unless explicitly described elsewhere in this document. 3. CKEn is the logic state of CKE at clock rising edge n; CKEn-1 was the state of CKE at the previous clock edge. 4. CS_n is the logic state of CS_n at the clock rising edge n. 5. Command n is the command registered at clock edge n, and operation n is a result of command n. 6. Power-down exit time (tXP) must elapse before any command other than NOP is issued. 7. The clock must toggle at least twice prior to the tXP period. 8. Upon exiting the resetting power-down state, the device will return to the idle state if tINIT5 has expired. 9. The DPD exit procedure must be followed as described in Deep Power-Down. 10. Self refresh exit time (tXSR) must elapse before any command other than NOP is issued. 11. The clock must toggle at least twice prior to the tXSR time. 12. In the case of ODT disabled, all DQ output must be High-Z. In the case of ODT enabled, all DQ must be terminated to VDDQ. Table 61: Current State Bank n to Command to Bank n Truth Table Notes 1–5 apply to entire table Current State Command Any NOP Operation Continue previous operation 100 Next State Current state Notes 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables Table 61: Current State Bank n to Command to Bank n Truth Table (Continued) Notes 1–5 apply to entire table Current State Command Idle ACTIVATE REFRESH (all banks) Active Begin to refresh Refreshing (per bank) 6 Begin to refresh Refreshing (all banks) 7 MR writing 7 Load value to mode register MRR Read value from mode register Idle, MR reading RESET Begin device auto initialization Resetting 7, 8 9, 10 PRECHARGE Deactivate row(s) in bank or banks Precharging READ Select column and start read burst Reading WRITE Select column and start write burst Writing Read value from mode register PRECHARGE Writing Notes MRW MRR Reading Next State Select and activate row REFRESH (per bank) Row active Operation Active MR reading Precharging 9 READ Deactivate row(s) in bank or banks Select column and start new read burst Reading 11, 12 WRITE Select column and start write burst Writing 11, 12, 13 WRITE Select column and start new write burst Writing 11, 12 READ Select column and start read burst Reading 11, 12, 14 Power-on MRW RESET Begin device auto initialization Resetting 7, 9 Resetting MRR Read value from mode register Resetting MR reading Notes: 1. Values in this table apply when both CKEn -1 and CKEn are HIGH, and after tXSR or tXP has been met, if the previous state was power-down. 2. All states and sequences not shown are illegal or reserved. 3. Current state definitions: State Definition Idle The bank or banks have been precharged, and tRP has been met. Active A row in the bank has been activated, and tRCD has been met. No data bursts or accesses, and no register accesses, are in progress. Reading A READ burst has been initiated with auto precharge disabled, and has not yet terminated. Writing A WRITE burst has been initiated with auto precharge disabled, and has not yet terminated. 4. The states listed below must not be interrupted by a command issued to the same bank. NOP commands or supported commands to the other bank should be issued on any clock edge occurring during these states. Supported commands to the other banks are determined by that bank’s current state, and the definitions given in the table: Current State Bank n to Command to Bank m. State Starts with... Ends when... tRP is met Precharging Registration of a PRECHARGE command Row activating Registration of an ACTIVATE tRCD is met command 101 Notes After tRP is met, the bank is in the idle state. After tRCD is met, the bank is in the active state. 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables State Starts with... Ends when... READ with AP enabled Registration of a READ command with auto precharge enabled tRP WRITE with AP enabled Registration of a WRITE command with auto precharge enabled tRP Notes is met After tRP is met, the bank is in the idle state. is met After tRP is met, the bank is in the idle state. 5. The states listed below must not be interrupted by any executable command. NOP commands must be applied to each positive clock edge during these states. 6. 7. 8. 9. 10. 11. 12. 13. 14. Ends when... State Starts with... Refreshing (per bank) Registration of a REFRESH (per bank) command tRFCpb is met After tRFCpb is met, the bank is in the idle state. Notes Refreshing (all banks) Registration of a REFRESH (all banks) command tRFCab is met After tRFCab is met, the device is in the all banks idle state. Idle MR read- Registration of the MRR ing command tMRR is met After tMRR is met, the device is in the all banks idle state. Resetting MR Registration of the MRR reading command tMRR is met After tMRR is met, the device is in the all banks idle state. Active MR reading Registration of the MRR command tMRR is met After tMRR is met, the bank is in the active state. MR writing Registration of the MRW command tMRW Precharging all Registration of a PRECHARGE ALL command tRP is met After tMRW is met, the device is in the all banks idle state. is met After tRP is met, the device is in the all banks idle state. Bank-specific; requires that the bank is idle and no bursts are in progress. Not bank-specific; requires that all banks are idle and no bursts are in progress. Not bank-specific. This command may or may not be bank-specific. If all banks are being precharged, they must be in a valid state for precharging. If a PRECHARGE command is issued to a bank in the idle state, tRP still applies. A command other than NOP should not be issued to the same bank while a READ or WRITE with auto precharge is enabled. The new READ or WRITE command could be auto precharge enabled or auto precharge disabled. A WRITE command can be issued only after the completion of the READ burst. A READ command can be issued only after completion of the WRITE burst. Table 62: Current State Bank n to Command to Bank m Truth Table Notes 1–6 apply to entire table Current State of Bank n Command to Bank m Any NOP Operation Continue previous operation 102 Next State for Bank m Current state of bank m Notes 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables Table 62: Current State Bank n to Command to Bank m Truth Table (Continued) Notes 1–6 apply to entire table Current State of Bank n Command to Bank m Idle Row activating, active, or precharging Any Writing (auto precharge disabled) Reading with auto precharge Writing with auto precharge Next State for Bank m Any command supported to bank m ACTIVATE Notes – Select and activate row in bank m Active 6 READ Select column and start READ burst from bank m Reading 7 WRITE Select column and start WRITE burst to bank m Writing 7 Precharging 8 Idle MR reading or active MR reading 9, 10, 11 PRECHARGE Reading (auto precharge disabled) Operation Deactivate row(s) in bank or banks MRR READ value from mode register READ Select column and start READ burst from bank m Reading 7 WRITE Select column and start WRITE burst to bank m Writing 7, 12 ACTIVATE Select and activate row in bank m Active PRECHARGE Deactivate row(s) in bank or banks Precharging 8 READ Select column and start READ burst from bank m Reading 7, 13 WRITE Select column and start WRITE burst to bank m Writing 7 ACTIVATE Select and activate row in bank m Active PRECHARGE Deactivate row(s) in bank or banks Precharging 8 READ Select column and start READ burst from bank m Reading 7, 14 WRITE Select column and start WRITE burst to bank m Writing 7, 12, 14 ACTIVATE Select and activate row in bank m Active PRECHARGE Deactivate row(s) in bank or banks Precharging 8 READ Select column and start READ burst from bank m Reading 7, 13, 14 WRITE Select column and start WRITE burst to bank m Writing 7, 14 ACTIVATE Select and activate row in bank m Active PRECHARGE Deactivate row(s) in bank or banks Precharging 8 15, 16 Power-on MRW RESET Begin device auto initialization Resetting Resetting MRR Read value from mode register Resetting MR reading Notes: 1. This table applies when: • The previous state was self refresh or power-down; • After tXSR or tXP has been met; and 103 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Truth Tables • When both CKEn -1 and CKEn are HIGH. 2. All states and sequences not shown are illegal or reserved. 3. Current state definitions: State Condition And… Idle The bank has been precharged tRP And… Active A row in the bank has been activated tRCD Reading A READ burst has been initi- The READ ated with auto precharge has not yet disabled terminated Writing A WRITE burst has been ini- The WRITE tiated with auto precharge has not yet disabled terminated is met is met No data bursts/accesses and no register accesses are in progress. 4. Refresh, self refresh, and MRW commands can only be issued when all banks are idle. 5. The states listed below must not be interrupted by any executable command. NOP commands must be applied during each clock cycle while in these states: State Starts with... Ends when... Notes Idle MR read- Registration of the MRR ing command tMRR is met After tMRR is met, the device is in the all banks idle state. Resetting MR Registration of the MRR reading command tMRR is met After tMRR is met, the device is in the all banks reset state. Active MR reading Registration of the MRR command tMRR is met After tMRR is met, the bank is in the active state. MR writing Registration of the MRW command tMRW is met After tMRW is met, the device is in the all banks idle state. 6. tRRD must be met between the ACTIVATE command to bank n and any subsequent ACTIVATE command to bank m. 7. READs or WRITEs listed in the command column include READs and WRITEs with or without auto precharge enabled. 8. This command may or may not be bank-specific. If all banks are being precharged, they must be in a valid state for precharging. 9. MRR is supported in the row-activating state. 10. MRR is supported in the precharging state. 11. The next state for bank m depends on the current state of bank m (idle, row-activating, precharging, or active). 12. A WRITE command can be issued only after the completion of the READ burst. 13. A READ command can be issued only after the completion of the WRITE burst. 14. A READ with auto precharge enabled or a WRITE with auto precharge enabled can be followed by any valid command to other banks, provided that the timing restrictions in the PRECHARGE and Auto Precharge Clarification table are met. 15. Not bank-specific; requires that all banks are idle and no bursts are in progress. 16. RESET command is achieved through the MODE REGISTER WRITE command. 104 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Absolute Maximum Ratings Table 63: DM Truth Table DM DQ Notes Write enable Functional Name L Valid 1 Write inhibit H X 1 Note: 1. Used to mask write data; provided simultaneously with the corresponding input data. Absolute Maximum Ratings Stresses greater than those listed may cause permanent damage to the device. This is a stress rating only, and functional operation of the device at these conditions, or any other conditions outside those indicated in the operational sections of this document, is not implied. Exposure to absolute maximum rating conditions for extended periods may adversely affect reliability. Table 64: Absolute Maximum DC Ratings Parameter Symbol Min Max Unit Notes VDD1 supply voltage relative to VSS VDD1 –0.4 2.3 V 1 VDD2 supply voltage relative to VSS VDD2 –0.4 1.6 V 1 VDDCA supply voltage relative to VSSCA VDDCA –0.4 1.6 V 1, 2 VDDQ supply voltage relative to VSSQ VDDQ –0.4 1.6 V 1, 3 VIN, VOUT –0.4 1.6 V TSTG –55 125 ˚C Voltage on any ball relative to VSS Storage temperature Notes: 4 1. For information about relationships between power supplies, see the Power-Up and Initialization section. 2. VREFCA ≤ 0.6 × VDDCA; however, VREFCA may be ≥ VDDCA, provided that VREFCA ≤ 300mV. 3. VREFDQ ≤ 0.7 × VDDQ; however, VREFDQ may be ≥ VDDQ, provided that VREFDQ ≤ 300mV. 4. Storage temperature is the case surface temperature on the center/top side of the device. For measurement conditions, refer to the JESD51-2 standard. 105 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Electrical Specifications – IDD Measurements and Conditions Electrical Specifications – IDD Measurements and Conditions The following definitions and conditions are used in the IDD measurement tables unless stated otherwise: • • • • LOW: V IN ≤ V IL(DC)max HIGH: V IN ≥ V IH(DC)min STABLE: Inputs are stable at a HIGH or LOW level SWITCHING: See the following three tables Table 65: Switching for CA Input Signals CK_t (Rising)/ CK_c (Falling) CK_t (Falling)/ CK_c (Rising) CK_t (Rising)/ CK_c (Falling) CK_t (Falling)/ CK_c (Rising) CK_t (Rising)/ CK_c (Falling) CK_t (Falling)/ CK_c (Rising) CK_t (Rising)/ CK_c (Falling) CK_t (Falling)/ CK_c (Rising) Cycle N N+1 N+2 N+3 CS_n HIGH HIGH HIGH HIGH CA0 H L L L L CA1 H H H L L CA2 H L L L L CA3 H H H L L CA4 H L L L L CA5 H H H L L CA6 H L L L L CA7 H H H L L CA8 H L L L CA9 H H H L Notes: H H H L L H H H H L L H H H H L L H H H H L L H L H H H L L L H 1. CS_n must always be driven HIGH. 2. For each clock cycle, 50% of the CA bus is changing between HIGH and LOW. 3. The noted pattern (N, N + 1, N + 2, N + 3...) is used continuously during IDD measurement for IDD values that require switching on the CA bus. Table 66: Switching for IDD4R Clock CKE CS_n Clock Cycle Number Command CA[2:0] CA[9:3] All DQ Rising H L N Read_Rising HLH LHLHLHL L Falling H L N Read_Falling LLL LLLLLLL L Rising H H N+1 NOP LLL LLLLLLL H Falling H H N+1 NOP LLL LLLLLLL L Rising H H N+2 NOP LLL LLLLLLL H Falling H H N+2 NOP LLL LLLLLLL H Rising H H N+3 NOP LLL LLLLLLL H Falling H H N+3 NOP HLH LHLLHLH L 106 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Electrical Specifications – IDD Measurements and Conditions Table 66: Switching for IDD4R (Continued) Clock CKE CS_n Clock Cycle Number Command CA[2:0] CA[9:3] All DQ Rising H L N+4 Read_Rising HLH LHLLHLH H Falling H L N+4 Read_Falling HHL HHHHHHH H Rising H H N+5 NOP HHH HHHHHHH H Falling H H N+5 NOP HHH HHHHHHH L Rising H H N+6 NOP HHH HHHHHHH L Falling H H N+6 NOP HHH HHHHHHH L Rising H H N+7 NOP HHH HHHHHHH H Falling H H N+7 NOP HLH LHLHLHL L Notes: 1. Data strobe (DQS_t) is changing between HIGH and LOW with every clock cycle. 2. The noted pattern (N, N + 1...) is used continuously during IDD measurement for IDD4R. Table 67: Switching for IDD4W Clock CKE CS_n Clock Cycle Number Command CA[2:0] CA[9:3] All DQ Rising H L N Write_Rising LLH LHLHLHL L Falling H L N Write_Falling LLL LLLLLLL L Rising H H N+1 NOP LLL LLLLLLL H Falling H H N+1 NOP LLL LLLLLLL L Rising H H N+2 NOP LLL LLLLLLL H Falling H H N+2 NOP LLL LLLLLLL H Rising H H N+3 NOP LLL LLLLLLL H Falling H H N+3 NOP LLH LHLLHLH L Rising H L N+4 Write_Rising LLH LHLLHLH H Falling H L N+4 Write_Falling HHL HHHHHHH H Rising H H N+5 NOP HHH HHHHHHH H Falling H H N+5 NOP HHH HHHHHHH L Rising H H N+6 NOP HHH HHHHHHH L Falling H H N+6 NOP HHH HHHHHHH L Rising H H N+7 NOP HHH HHHHHHH H Falling H H N+7 NOP LLH LHLHLHL L Notes: 1. Data strobe (DQS_t) is changing between HIGH and LOW with every clock cycle. 2. Data masking (DM) must always be driven LOW. 3. The noted pattern (N, N + 1...) is used continuously during IDD measurement for IDD4W. 107 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Electrical Specifications – IDD Measurements and Conditions IDD Specifications IDD values are for the entire operating voltage range, and all of them are for the entire standard range, with the exception of IDD6ET, which is for the entire extended temperature range. Table 68: IDD Specification Parameters and Operating Conditions VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V Notes 1, 2, 3, and 5 apply to entire table; Note 4 applies to all "in" values Parameter/Condition Operating one bank active-precharge current: tCK = tCK (MIN); tRC = tRC (MIN); CKE is HIGH; CS_n is HIGH between valid commands; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle power-down standby current: tCK = tCK (MIN); CKE is LOW; CS_n is HIGH; All banks are idle; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle power-down standby current with clock stop: CK_t = LOW, CK_c = HIGH; CKE is LOW; CS_n is HIGH; All banks are idle; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Idle non-power-down standby current: tCK = tCK (MIN); CKE is HIGH; CS_n is HIGH; All banks are idle; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Idle non-power-down standby current with clock stopped: CK_t = LOW; CK_c = HIGH; CKE is HIGH; CS_n is HIGH; All banks are idle; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Active power-down standby current: tCK = tCK (MIN); CKE is LOW; CS_n is HIGH; One bank is active; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Active power-down standby current with clock stop: CK_t = LOW, CK_c = HIGH; CKE is LOW; CS_n is HIGH; One bank is active; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Active non-power-down standby current: tCK = tCK (MIN); CKE is HIGH; CS_n is HIGH; One bank is active; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Active non-power-down standby current with clock stopped: CK_t = LOW, CK_c = HIGH; CKE is HIGH; CS_n is HIGH; One bank is active; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled 108 Symbol Power Supply IDD01 VDD1 IDD02 VDD2 IDD0,in VDDCA, VDDQ IDD2P1 VDD1 IDD2P2 VDD2 IDD2P,in VDDCA, VDDQ IDD2PS1 VDD1 IDD2PS2 VDD2 IDD2PS,in VDDCA, VDDQ IDD2N1 VDD1 IDD2N2 VDD2 IDD2N,in VDDCA, VDDQ IDD2NS1 VDD1 IDD2NS2 VDD2 IDD2NS,in VDDCA, VDDQ IDD3P1 VDD1 IDD3P2 VDD2 IDD3P,in VDDCA, VDDQ IDD3PS1 VDD1 IDD3PS22 VDD2 IDD3PS,in VDDCA, VDDQ IDD3N1 VDD1 IDD3N2 VDD2 IDD3N,in VDDCA, VDDQ IDD3NS1 VDD1 IDD3NS2 VDD2 IDD3NS,in VDDCA, VDDQ Notes 2 2 2 2 2 2 3 3 3 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Electrical Specifications – IDD Measurements and Conditions Table 68: IDD Specification Parameters and Operating Conditions (Continued) VDD2, VDDQ, VDDCA = 1.14–1.30V; VDD1 = 1.70–1.95V Notes 1, 2, 3, and 5 apply to entire table; Note 4 applies to all "in" values Parameter/Condition tCK tCK = (MIN); CS_n is HIGH Operating burst READ current: between valid commands; One bank is active; BL = 8; RL = RL (MIN); CA bus inputs are switching; 50% data change each burst transfer; ODT is disabled Operating burst WRITE current: tCK = tCK (MIN); CS_n is HIGH between valid commands; One bank is active; BL = 8; WL = WL (MIN); CA bus inputs are switching; 50% data change each burst transfer; ODT is disabled All-bank REFRESH burst current: tCK = tCK (MIN); CKE is HIGH between valid commands; tRC = tRFCab (MIN); Burst refresh; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled All-bank REFRESH average current: tCK = tCK (MIN); CKE is HIGH between valid commands; tRC = tREFI; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Per-bank REFRESH average current: tCK = tCK (MIN); CKE is HIGH between valid commands; tRC = tREFI/8; CA bus inputs are switching; Data bus inputs are stable; ODT is disabled Self refresh current (0˚C to +85˚C): CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are stable; Data bus inputs are stable; Maximum 1x self refresh rate; ODT is disabled Self refresh current (+85˚C to +105˚C): CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Deep power-down current: CK_t = LOW, CK_c = HIGH; CKE is LOW; CA bus inputs are stable; Data bus inputs are stable; ODT is disabled Notes: Symbol Power Supply IDD4R1 VDD1 Notes IDD4R2 VDD2 IDD4R,in VDDCA IDD4W1 VDD1 IDD4W2 VDD2 IDD4W,in VDDCA, VDDQ IDD51 VDD1 IDD52 VDD2 IDD5,in VDDCA, VDDQ IDD5AB1 VDD1 IDD5AB2 VDD2 IDD5AB,in VDDCA, VDDQ IDD5PB1 VDD1 IDD5PB2 VDD2 IDD5PB,in VDDCA, VDDQ 3 3 3 3 IDD61 VDD1 4, 5 IDD62 VDD2 4, 5 IDD6,in VDDCA, VDDQ 3, 4 IDD6ET1 VDD1 5, 6 IDD6ET2 VDD2 5, 6 IDD6ET,in VDDCA, VDDQ 3, 5, 6 IDD81 VDD1 IDD82 VDD2 IDD8,in VDDCA, VDDQ 3 ODT disabled: MR11[2:0] = 000b. IDD current specifications are tested after the device is properly initialized. Measured currents are the summation of VDDQ and VDDCA. The 1x self refresh rate is the rate at which the device is refreshed internally during self refresh before going into the elevated temperature range. 5. This is the general definition that applies to full-array self-refresh. 6. IDD6ET is a typical value, is sampled only, and is not tested. 7. For all IDD measurements, VIHCKE = 0.8 × VDDCA; VILCKE = 0.2 × VDDCA. 1. 2. 3. 4. 109 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Operating Conditions AC and DC Operating Conditions Operation or timing that is not specified is illegal. To ensure proper operation, the device must be initialized properly. Table 69: Recommended DC Operating Conditions Note 1 applies to entire table Symbol Min Typ Max DRAM Unit Notes 2 VDD1 1.70 1.80 1.95 Core power 1 V VDD2 1.14 1.20 1.30 Core power 2 V VDDCA 1.14 1.20 1.30 Input buffer power V VDDQ 1.14 1.20 1.30 I/O buffer power V Notes: 1. The voltage range is for DC voltage only. DC is defined as the voltage supplied at the DRAM and is inclusive of all noise up to 1 MHz at the DRAM package ball. 2. VDD1 uses significantly less power than VDD2. Table 70: Input Leakage Current Symbol Min Max Unit Notes Input leakage current: For CA, CKE, CS_n, CK; Any input 0V ≤ VIN ≤ VDDCA; (All other pins not under test = 0V) Parameter/Condition II –2 2 μA 1 VREF supply leakage current: VREFDQ = VDDQ/2, or VREFCA = VDDCA/2; (All other pins not under test = 0V) IVREF –1 1 μA 2 Notes: 1. Although DM is for input only, the DM leakage must match the DQ and DQS output leakage specification. 2. The minimum limit requirement is for testing purposes. The leakage current on VREFCA and VREFDQ pins should be minimal. Table 71: Operating Temperature Range Notes 1 and 2 apply to entire table Parameter/Condition Standard (WT) temperature range Symbol TCASE 1 Wide temperature range Notes: Min Max Unit -25 85 ˚C 0 105 ˚C 1. Operating temperature is the case surface temperature at the center of the top side of the device. For measurement conditions, refer to the JESD51-2 standard. 2. Either the device operating temperature or the temperature sensor can be used to set an appropriate refresh rate, determine the need for AC timing derating, and/or monitor the operating temperature (see Temperature Sensor). When using the temperature sensor, the actual device case temperature may be higher than the TCASE rating that applies for the operating temperature range. For example, TCASE could be above +85˚C when the temperature sensor indicates a temperature of less than +85˚C. 110 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Single-Ended Signals AC and DC Logic Input Measurement Levels for Single-Ended Signals Table 72: Single-Ended AC and DC Input Levels for CA and CS_n Inputs Parameter Symbol 1333/1600 Min 1866/2133 Max Min Max Unit Notes AC input logic HIGH VIHCA(AC) VREF + 0.150 Note 2 VREF + 0.135 Note 2 V 1, 2 AC input logic LOW VILCA(AC) Note 2 VREF - 0.150 Note 2 VREF - 0.135 V 1, 2 DC input logic HIGH VIHCA(DC) VREF + 0.100 VDDCA VREF + 0.100 VDDCA V 1 DC input logic LOW VILCA(DC) VSSCA VREF - 0.100 VSSCA VREF - 0.100 V 1 VREFCA(DC) 0.49 × VDDCA 0.51 × VDDCA 0.49 × VDDCA 0.51 × VDDCA V 3, 4 Reference voltage for CA and CS_n inputs Notes: 1. For CA and CS_n input-only pins. VREF = VREFCA(DC). 2. See figure: Overshoot and Undershoot Definition. 3. The AC peak noise on VREFCA could prevent VREFCA from deviating more than ±1% VDDCA from VREFCA(DC) (for reference, approximately ±12mV). 4. For reference, approximately VDDCA/2 ±12mV. Table 73: Single-Ended AC and DC Input Levels for CKE Parameter Symbol Min Max Unit Notes CKE input HIGH level VIHCKE 0.65 × VDDCA Note 1 V 1 CKE input LOW level VILCKE Note 1 0.35 × VDDCA V 1 Note: 1. See figure: Overshoot and Undershoot Definition. Table 74: Single-Ended AC and DC Input Levels for DQ and DM Parameter Symbol AC input logic HIGH VIHDQ(AC) 1333/1600 1866/2133 Min Max Min Max Unit Notes VREF + 0.150 Note 2 VREF + 0.135 Note 2 V 1, 2, 5 AC input logic LOW VILDQ(AC) Note 2 VREF - 0.150 Note 2 VREF - 0.135 V 1, 2, 5 DC input logic HIGH VIHDQ(DC) VREF + 0.100 VDDQ VREF + 0.100 VDDQ V 1 DC input logic LOW VILDQ(DC) VSSQ VREF - 0.100 VSSQ VREF - 0.100 V 1 Reference voltage for DQ and DM inputs VREFDQ(DC) 0.49 × VDDQ 0.51 × VDDQ 0.49 × VDDQ 0.51 × VDDQ V 3, 4 VODTR/2 - 0.01 × VDDQ VODTR/2 + 0.01 × VDDQ VODTR/2 - 0.01 × VDDQ VODTR/2 + 0.01 × VDDQ V 3, 5, 6 Reference voltage for DQ and DM inputs (DQ ODT enabled) VREFDQ(DC) DQODT,enabled Notes: 1. For DQ input-only pins. VREF = VREFDQ(DC). 2. See figure: Overshoot and Undershoot Definition. 3. The AC peak noise on VREFDQ could prevent VREFDQ from deviating more than ±1% VDDQ from VREFDQ(DC) (for reference, approximately ±12mV). 111 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Single-Ended Signals 4. For reference, approximately VDDQ/2 ±12mV. 5. For reference, approximately VODTR/2 ±12mV. 6. The nominal mode register programmed values for RODT and the nominal controller output impedance RON are used for the calculation of VODTR. For testing purposes, a controller RON value of 50Ω is used. VODTR= 2RON + RTT × VDDQ RON + RTT VREF Tolerances The DC tolerance limits and AC noise limits for the reference voltages V REFCA and VREFDQ are shown below. This figure shows a valid reference voltage V REF(t) as a function of time. V DD is used in place of V DDCA for V REFCA, and V DDQ for V REFDQ. V REF(DC) is the linear average of V REF(t) over a very long period of time (for example, 1 second), and is specified as a fraction of the linear average of V DDQ or V DDCA, also over a very long period of time (for example, 1 second). This average must meet the MIN/MAX requirements in the table: Single-Ended AC and DC Input Levels for CA and CS_n Inputs. Additionally, VREF(t) can temporarily deviate from V REF(DC) by no more than ±1% V DD. V REF(t) cannot track noise on V DDQ or V DDCA if doing so would force V REF outside these specifications. Figure 71: VREF DC Tolerance and VREF AC Noise Limits VDD Voltage VREF(AC) noise VREF(t) VREF(DC)max VREF(DC) VREF(DC)nom VREF(DC)min VSS Time The voltage levels for setup and hold time measurements V IH(AC), V IH(DC), V IL(AC), and VIL(DC) are dependent on V REF. V REF shall be understood as V REF(DC), as defined in the Single-Ended Requirements for Differential Signals figure. VREF DC variations affect the absolute voltage a signal must reach to achieve a valid HIGH or LOW, as well as the time from which setup and hold times are measured. System timing and voltage budgets must account for V REF deviations outside this range. The setup/hold specification and derating values must include time and voltage associated with V REF AC noise. Timing and voltage effects due to AC noise on V REF up to the specified limit (±1% V DD) are included in device timings and associated deratings. 112 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Single-Ended Signals Input Signal Figure 72: LPDDR3-1600 to LPDDR3-1333 Input Signal VIL and VIH levels with ringback 1.550V VDD + 0.35V narrow pulse width 1.200V VDD 0.750V VIH(AC) 0.700V VIH(DC) 0.624V 0.612V 0.600V 0.588V 0.576V VREF + AC noise VREF + DC error VREF - DC error VREF - AC noise 0.500V VIL(DC) 0.450V VIL(AC) 0.000V VSS Minimum VIL and VIH levels 0.750V 0.700V VIH(AC) VIH(DC) 0.624V 0.612V 0.600V 0.588V 0.576V 0.500V VIL(DC) 0.450V VIL(AC) VSS - 0.35V narrow pulse width –0.350V Notes: 1. Numbers reflect typical values. 2. For CA[9:0], CK, and CS_n, VDD stands for VDDCA. For DQ, DM, DQS, and ODT, VDD stands for VDDQ. 3. For CA[9:0], CK, and CS_n, VSS stands for VSSCA. For DQ, DM, DQS, and ODT, VSS stands for VSSQ. 113 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Single-Ended Signals Figure 73: LPDDR3-2133 to LPDDR3-1866 Input Signal VIL and VIH levels with ringback 1.550V VDD + 0.35V narrow pulse width 1.200V VDD 0.735V VIH(AC) 0.700V VIH(DC) 0.624V 0.612V 0.600V 0.588V 0.576V VREF + AC noise VREF + DC error VREF - DC error VREF - AC noise 0.500V VIL(DC) 0.565V VIL(AC) 0.000V VSS Minimum VIL and VIH levels 0.735V 0.700V VIH(AC) VIH(DC) 0.624V 0.612V 0.600V 0.588V 0.576V 0.500V VIL(DC) 0.565V VIL(AC) VSS - 0.35V narrow pulse width –0.350V Notes: 1. Numbers reflect typical values. 2. For CA[9:0], CK, and CS_n, VDD stands for VDDCA. For DQ, DM, DQS, and ODT, VDD stands for VDDQ. 3. For CA[9:0], CK, and CS_n, VSS stands for VSSCA. For DQ, DM, DQS, and ODT, VSS stands for VSSQ. 114 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Differential Signals AC and DC Logic Input Measurement Levels for Differential Signals Figure 74: Differential AC Swing Time and tDVAC tDVAC Differential Voltage VIH,diff(AC)min VIH,diff(DC)min CK DQS 0.0 VIL,diff(DC)max tDVAC 1/2 cycle VIL,diff(AC)max Time Table 75: Differential AC and DC Input Levels For CK, VREF = VREFCA(DC); For DQS, VREF = VREFDQ(DC) LPDDR3 Parameter Symbol Min Max Unit Notes Differential input HIGH AC VIH,diff(AC) 2 × (VIH(AC) - VREF) Note 1 V 2 Differential input LOW AC VIL,diff(AC) Note 1 2 × (VIL(AC) - VREF) V 2 Differential input HIGH DC VIH,diff(DC) 2 × (VIH(DC) - VREF) Note 1 V 3 Differential input LOW DC VIL,diff(DC) Note 1 2 × (VIL(DC) - VREF) V 3 Notes: 1. These values are not defined; however, the single-ended signals CK and DQS must be within the respective limits (VIH(DC)max, VIL(DC)min) for single-ended signals, and must comply with the specified limitations for overshoot and undershoot (see figure: Overshoot and Undershoot Definition). 2. For CK, use VIH/VIL(AC) of CA and VREFCA; for DQS, use VIH/VIL(AC) of DQ and VREFDQ. If a reduced AC HIGH or AC LOW is used for a signal group, the reduced voltage level also applies. 3. Used to define a differential signal slew rate. 115 178-Ball, Single-Channel Mobile LPDDR3 SDRAM AC and DC Logic Input Measurement Levels for Differential Signals Table 76: CK and DQS Time Requirements Before Ringback (tDVAC) tDVAC (ps) @ VIH/ VIL,diff(AC) = 300mV1333 Mb/s Slew Rate (V/ns) tDVAC (ps) @ VIH/ VIL,diff(AC) = 300mV1600 Mb/s tDVAC (ps) @ VIH/VIL,diff(AC) = 270mV1866 Mb/s tDVAC (ps) @ VIH/VIL,diff(AC) = 270mV2133 Mb/s Min Max Min Max Min Max Min Max >8.0 58 – 48 – 40 – 34 – 8.0 58 – 48 – 40 – 34 – 7.0 56 – 46 – 39 – 33 – 6.0 53 – 43 – 36 – 30 – 5.0 50 – 40 – 33 – 27 – 4.0 45 – 35 – 29 – 23 – 3.0 37 – 27 – 21 – 15 – VIH(ac) = VREF(dc)+135mV, VIL(ac) = VREF(dc) - 135mV DC100 Threshold -> VIH(dc) = VREF(dc) + 100mV, VIL(dc) = VREF(dc) - 100mV CK_t, CK_c Differential Slew Rate 8.0 V/ns CA, CS_n slew rate V/ns 4.0 3.0 7.0 V/ns 6.0 V/ns 4.0 V/ns 3.0 V/ns ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH 34 25 34 25 34 25 34 25 34 25 23 17 23 17 23 17 23 17 34 29 0 0 0 0 0 0 11 13 –23 –17 –23 –17 –12 –4 2.0 1.5 Note: 5.0 V/ns ΔtIS 1. Shaded cells are not supported. 145 ΔtIS ΔtIH 178-Ball, Single-Channel Mobile LPDDR3 SDRAM CA and CS_n Setup, Hold, and Derating Table 101: Required Time for Valid Transition – tVAC > VIH(AC) and < VIL(AC) Slew Rate (V/ns) tVAC at 150mV (ps) 1333 Mb/s tVAC at 150mV (ps) 1600 Mb/s tVAC at 135mV (ps) 1866 Mb/s tVAC at 135mV (ps) 2133 Mb/s Min Max Min Max Min Max Min Max >4.0 58 – 48 – 40 – 34 – 4.0 58 – 48 – 40 – 34 – 3.5 56 – 46 – 39 – 33 – 3.0 53 – 43 – 36 – 30 – 2.5 50 – 40 – 33 – 27 – 2.0 45 – 35 – 29 – 23 – 1.5 37 – 27 – 21 – 15 – V IH(AC) or < VIL(AC) table). The total setup time for slow slew rates could be negative (that is, a valid input signal may not have reached V IH/VIL(AC) at the time of the rising clock transition). A valid input signal is still required to complete the transition and reach V IH/VIL(AC). For slew rates between the values listed in the following table, the derating values can be obtained using linear interpolation. Slew rate values are not typically subject to production testing. They are verified by design and characterization. 151 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Data Setup, Hold, and Slew Rate Derating Table 102: Data Setup and Hold Base Values Data Rate Parameter 1333 1600 (base) 100 75 – – VIH/VIL(AC) = VREF(DC) ±150mV (base) – – 62.5 47.5 VIH/VIL(AC) = VREF(DC) ±135mV 125 100 80 65 VIH/VIL(DC) = VREF(DC) ±100mV tDS tDS tDH (base) Note: 1866 2133 Reference 1. AC/DC referenced for 2 V/ns DQ, DM slew rate, and 4 V/ns differential DQS slew rate and nominal VIX . Table 103: Derating Values for AC/DC-Based tDS/tDH (AC150) ΔtDS, ΔtDH derating in ps ΔtDS, ΔtDH Derating in [ps] AC/DC-based AC150 Threshold -> VIH(ac) = VREF(dc) + 150mV, VIL(ac) = VREF(dc) - 150mV DC100 Threshold -> VIH(dc) = VREF(dc) + 100mV, VIL(dc) = VREF(dc) - 100mV DQS_t, DQS_c Differential Slew Rate 8.0 V/ns DQ, DM slew rate V/ns 4.0 7.0 V/ns 6.0 V/ns 4.0 V/ns ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH 38 25 38 25 38 25 38 25 38 25 25 17 25 17 25 17 25 17 0 0 3.0 2.0 1.5 Note: 5.0 V/ns ΔtIS 3.0 V/ns ΔtIS ΔtIH 38 29 0 0 0 0 13 13 –25 –17 –25 –17 –12 –4 1. Shaded cells are not supported. Table 104: Derating Values for AC/DC-Based tDS/tDH (AC135) ΔtDS, ΔtDH derating in ps ΔtDS, ΔtDH Derating in [ps] AC/DC-based AC135 Threshold -> VIH(ac) = VREF(dc) + 135mV, VIL(ac) = VREF(dc) - 135mV DC100 Threshold -> VIH(dc) = VREF(dc) + 100mV, VIL(dc) = VREF(dc) - 100mV DQS_t, DQS_c Differential Slew Rate 8.0 V/ns DQ, DM slew rate V/ns 4.0 3.0 7.0 V/ns 6.0 V/ns 4.0 V/ns 3.0 V/ns ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH ΔtIS ΔtIH 34 25 34 25 34 25 34 25 34 25 23 17 23 17 23 17 23 17 34 29 0 0 0 0 0 0 11 13 –23 –17 –23 –17 –12 –4 2.0 1.5 Note: 5.0 V/ns ΔtIS 1. Shaded cells are not supported. 152 ΔtIS ΔtIH 178-Ball, Single-Channel Mobile LPDDR3 SDRAM Data Setup, Hold, and Slew Rate Derating Table 105: Required Time for Valid Transition – tVAC > VIH(AC) or < VIL(AC) Slew Rate (V/ns) tVAC at 150mV (ps) 1333 Mb/s tVAC at 150mV (ps) 1600 Mb/s tVAC at 135mV (ps) 1866 Mb/s tVAC at 135mV (ps) 2133 Mb/s Min Max Min Max Min Max Min Max >4.0 58 – 48 – 40 – 34 – 4.0 58 – 48 – 40 – 34 – 3.5 56 – 46 – 39 – 33 – 3.0 53 – 43 – 36 – 30 – 2.5 50 – 40 – 33 – 27 – 2.0 45 – 35 – 29 – 23 – 1.5 37 – 27 – 21 – 15 –
RS256M32LD3D1LMZ-125BT 价格&库存
很抱歉,暂时无法提供与“RS256M32LD3D1LMZ-125BT”相匹配的价格&库存,您可以联系我们找货
