SMD2920B100TF
SMD2920B100TF
    YAGEO(国巨)
    2920(7351公制)
    聚合物 PTC 自恢复保险丝 33V 1.1 A Ih 表面贴装型 2920(7351 公制),凹陷
SMD2920B100TF 数据手册
DATA SHEET POSITIVE TEMPERATURE COEFFICIENT AC/DC POWER SUPPLY SMD2920 series Product specification– September 01, 2023 V.4 RoHS compliant & Halogen free Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 2 11 SMD2920 Positive Temperature Coefficient (PTC) Data Sheet Description The 2920 series provides surface mount resettable overcurrent protection with holding current from 0.3A to 7.0A. This series offers complete portfolio in terms of holding current and working voltage, and is suitable for wide range of application. Features ■ RoHS compliant and lead-free ■ Fast response to fault current ■ UL/CUL/ TUV/ RoHS/ Halogen Free ■ Low profile ■ Compatible with high temperature solders ■ Compact design saves board space Applications ■ USB hubs, ports and peripherals ■ Set-top-box and HDMI ■ Game console port protection ■ Motherboard USB & IEEE 1394 protection ■ Optical disk drives ■ General electronics Part Number Code and Marking SMD 2920 B TF T / Special Voltage Rating (Optional) Thickness Version (Optional) Lead-Free Holding Current Rating Delimiter Device Dimensions: Length/Width (Unit: 1/100 inch) Surface Mount Device Part Number Marking Part Number Marking Part Number Marking SMD2920B030TF 030 SMD2920B150TF 150 SMD2920B300TF/30 3030 SMD2920B050TF 050 SMD2920B185TF 185 SMD2920B330TF 330 SMD2920B075TF 075 SMD2920B200TF/24 2024 SMD2920B400TF 400 SMD2920B075TF/60 0760 SMD2920B250TF 250 SMD2920B500TF 500 SMD2920B100TF 100 SMD2920B260TF 260 SMD2920B500TF/16 5016 SMD2920B110TF/60 110 SMD2920B260TF/24 2624 SMD2920B600TF/12 6012 SMD2920B125TF 125 SMD2920B300TF/15 3015 SMD2920B700TF/12 7012 www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT 3 Product Specification 11 SMD2920 Dimensions and PAD-SIZE C A BK Logo Marking B Marking Part identification D Part Number A E B C D E Min. Max. Min. Max. Min. Max. Min. Max. Min. Max. SMD2920B030TF 6.73 7.98 4.80 5.44 0.65 1.15 0.30 2.50 0.25 2.00 SMD2920B050TF 6.73 7.98 4.80 5.44 0.65 1.15 0.30 2.50 0.25 2.00 SMD2920B075TF 6.73 7.98 4.80 5.44 0.55 1.05 0.30 2.50 0.25 2.00 SMD2920B075TF/60 6.73 7.98 4.80 5.44 0.55 1.05 0.30 2.50 0.25 2.00 SMD2920B100TF 6.73 7.98 4.80 5.44 0.45 0.95 0.30 2.50 0.25 2.00 SMD2920B110TF/60 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B125TF 6.73 7.98 4.80 5.44 0.35 0.85 0.30 2.50 0.25 2.00 SMD2920B150TF 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B185TF 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B200TF/24 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B250TF 6.73 7.98 4.80 5.44 0.70 1.20 0.30 2.50 0.25 2.00 SMD2920B260TF 6.73 7.98 4.80 5.44 0.70 1.20 0.30 2.50 0.25 2.00 SMD2920B260TF/24 6.73 7.98 4.80 5.44 0.70 1.20 0.30 2.50 0.25 2.00 SMD2920B300TF/15 6.73 7.98 4.80 5.44 0.70 1.20 0.30 2.50 0.25 2.00 SMD2920B300TF/30 6.73 7.98 4.80 5.44 0.75 1.25 0.30 2.50 0.25 2.00 SMD2920B330TF 6.73 7.98 4.80 5.44 1.20 2.00 0.30 2.50 0.25 2.00 SMD2920B400TF 6.73 7.98 4.80 5.44 0.60 1.10 0.30 2.50 0.25 2.00 SMD2920B500TF 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B500TF/16 6.73 7.98 4.80 5.44 0.90 1.40 0.30 2.50 0.25 2.00 SMD2920B600TF/12 6.73 7.98 4.80 5.44 0.80 1.60 0.30 2.50 0.25 2.00 SMD2920B700TF/12 6.73 7.98 4.80 5.44 0.80 1.60 0.30 2.50 0.25 2.00 Recommended Pad Layout (mm) 5.30typ. 4.60typ. 2.00typ. 2.00typ. www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT 4 Product Specification 11 SMD2920 Electrical Characteristics Part Number Maximum Time To Trip Time Current (Sec.) (A) Ihold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ. (W) SMD2920B030TF 0.30 0.60 60 10 1.50 3.0 SMD2920B050TF 0.50 1.00 60 10 1.50 SMD2920B075TF 0.75 1.50 30 40 SMD2920B075TF/60 0.75 1.50 60 SMD2920B100TF 1.10 2.20 SMD2920B110TF/60 1.10 SMD2920B125TF Resistance Rmin (Ω) R1max (Ω) 1.5 0.600 4.800 4.0 2.5 0.180 1.400 1.50 0.3 8.0 0.100 1.000 10 1.50 0.3 8.0 0.100 0.950 33 40 1.50 0.5 8.0 0.065 0.410 2.20 60 20 2.00 0.5 8.0 0.120 0.410 1.25 2.50 15 40 1.50 2.0 8.0 0.050 0.250 SMD2920B150TF 1.50 3.00 33 40 1.50 2.0 8.0 0.035 0.230 SMD2920B185TF 1.85 3.70 33 40 1.50 2.5 8.0 0.030 0.150 SMD2920B200TF/24 2.00 4.00 24 40 1.50 5.0 8.0 0.020 0.125 SMD2920B250TF 2.50 5.00 15 40 1.50 5.0 8.0 0.020 0.085 SMD2920B260TF 2.60 5.0 6 40 1.5 10.0 8.0 0.014 0.075 SMD2920B260TF/24 2.60 5.0 24 40 1.5 5.0 8.0 0.014 0.075 SMD2920B300TF/15 3.00 5.0 15 40 1.5 20.0 8.0 0.012 0.048 SMD2920B300TF/30 3.00 5.0 30 40 1.5 20.0 8.0 0.012 0.048 SMD2920B330TF 3.30 5.50 30 40 2.0 5.0 8.0 0.015 0.055 SMD2920B400TF 4.00 8.0 15 40 1.5 4.0 20.0 0.008 0.040 SMD2920B500TF 5.00 10.0 12 40 1.5 5.0 20.0 0.005 0.031 SMD2920B500TF/16 5.00 10.0 16 40 2.0 5.0 20.0 0.005 0.031 SMD2920B600TF/12 6.00 12.00 12 50 2.0 2.0 30.0 0.004 0.020 SMD2920B700TF/12 7.00 14.00 12 50 2.0 2.0 35.0 0.0035 0.0180 Note on Electrical Characteristics ■ Vocabulary ·Ihold = Hold current: maximum current device will pass without tripping in 23℃ still air. ·Itrip = Trip current: minimum current at which the device will trip in 23℃ still air. ·Vmax = Maximum voltage device can withstand without damage at rated current (Imax) ·Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) ·Pd typ. = Typical power dissipated from device when in the tripped state at 23℃ still air. ·Rmin = Minimum resistance of device in initial (un-soldered) state. ·R1max = Maximum resistance of device at 23℃ measured one hour after tripping or reflow soldering of 260℃ for 20 sec. ■ Value specified is determined by using the PWB with 0.090”*1.5oz copper traces. ■ Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification SMD2920 5 11 Polymeric PTC Selecting Guide ■ Determine the following operating parameters for the circuits: ·Normal operating current (Ihold) ·Maximum interrupt current (Imax) ·Maximum circuit voltage (Vmax) ·Normal operating temperature surrounding device (min℃/max℃) ■ Select the device from factor and dimension suitable for the application ■ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure the circuit’s requirement does not exceed the device rating. ■ Check that PPTC device’s trip time (time-to-trip) will protect the circuit. ■ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range. ■ Verify that performance and suitability of the chosen PPTC device in the application. ! WARNING ■ Mechanical Stress ·PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied. ■ Chemical Pollutants ·Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and shall not be used or applied. ■ Electronic and Thermal Effect ·PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur. ·PPTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in which case the voltage at such PPTC devices may reach a hazardous level. ·Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC devices. ·Conductive material contamination, such as metal particle, may induce shortage, flame or arcing. ·Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which shall not be used under such circumstances. ■ General ·Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications will be met. ·The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer. ·Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection To avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices. ·Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with. www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 6 11 SMD2920 Thermal Derating Curve Percentage of Rated Current 200.00 150.00 100.00 50.00 0.00 -40.00 0.00 40.00 80.00 120.00 Device Ambient Temperature (℃) Thermal Derating Chart Recommended Hold Current (A) at Ambient Temperature (℃) Part Number Ambient Operation Temperature -40℃ -20℃ 0℃ 23℃ 40℃ 50℃ 60℃ 70℃ 85℃ SMD2920B030TF 0.45 0.40 0.35 0.30 0.25 0.23 0.20 0.17 0.14 SMD2920B050TF 0.76 0.67 0.59 0.50 0.42 0.38 0.33 0.29 0.23 SMD2920B075TF 1.13 1.01 0.88 0.75 0.62 0.56 0.50 0.44 0.34 SMD2920B075TF/60 1.13 1.01 0.88 0.75 0.62 0.56 0.50 0.44 0.34 SMD2920B100TF 1.66 1.47 1.29 1.10 0.91 0.83 0.73 0.64 0.50 SMD2920B110TF/60 1.66 1.47 1.29 1.10 0.91 0.83 0.73 0.64 0.50 SMD2920B125TF 1.89 1.68 1.46 1.25 1.04 0.94 0.83 0.73 0.56 SMD2920B150TF 2.27 2.01 1.76 1.50 1.25 1.13 1.00 0.87 0.74 SMD2920B185TF 2.80 2.47 2.17 1.85 1.54 1.39 1.22 1.07 0.85 SMD2920B200TF/24 3.14 2.77 2.42 2.00 1.73 1.56 1.38 1.20 0.98 SMD2920B250TF 3.78 3.35 2.93 2.50 2.08 1.88 1.65 1.45 1.13 SMD2920B260TF 3.64 3.25 2.91 2.60 2.26 2.08 1.95 1.74 1.48 SMD2920B260TF/24 3.64 3.25 2.91 2.60 2.26 2.08 1.95 1.74 1.48 SMD2920B300TF/15 4.20 3.85 3.44 3.00 2.69 2.50 2.31 2.12 1.83 SMD2920B300TF/30 4.20 3.85 3.44 3.00 2.69 2.50 2.31 2.12 1.83 SMD2920B330TF 4.60 4.20 3.75 3.30 2.95 2.75 2.50 2.25 1.70 SMD2920B400TF 5.50 5.00 4.50 4.00 3.40 3.10 2.80 2.50 2.10 SMD2920B500TF 7.55 6.70 5.85 5.00 4.15 3.75 3.30 2.90 2.25 SMD2920B500TF/16 7.55 6.70 5.85 5.00 4.15 3.75 3.30 2.90 2.25 SMD2920B600TF/12 8.58 7.83 7.05 6.00 5.27 4.87 4.48 4.05 3.38 SMD2920B700TF/12 9.48 8.73 7.92 7.00 6.36 5.88 5.41 4.83 3.94 www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 7 11 SMD2920 Average Time-Current Curve 100 A B C A-SMD2920B030TF D E B-SMD2920B050TF F C-SMD2920B075TF 10 Time to Trip (s) SMD2920B075TF/60 D-SMD2920B100TF SMD2920B110TF 1 E-SMD2920B150TF F-SMD2920B185TF 0.1 0.01 0.1 1 10 100 Fault Current (A) 100 C A B D EF G A-SMD2920B125TF H B-SMD2920B200TF/24 I C-SMD2920B250TF 10 D-SMD2920B260TF Time to Trip (s) SMD2920B260TF/24 E-SMD2920B300TF/15 F- SMD2920B330TF 1 G-SMD2920B400TF H-SMD2920B500TF SMD2920B500TF/16 0.1 I- SMD2920B600TF/12 SMD2920B700TF/12 0.01 1 10 100 Fault Current (A) www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 8 11 SMD2920 Soldering Parameters Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Profile Feature Pb-Free Assembly Average ramp-up rate (TS max to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (TS min to TS max) 150℃ 200℃ 60-180 seconds Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature Storage Condition 20-40 seconds 6℃/second max. 8 minutes max. 0℃~35℃, ≤70%RH ·Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free ·Recommended maximum paste thickness is 0.25mm (0.010 inch) ·Device can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 9 11 SMD2920 Environmental Specifications Operating / Storage temperature -40℃ to +85℃ Maximum Device Surface Temperature in Tripped State 125℃ Passive Aging +85℃, 1000 hours ±50% typical resistance change Humidity Aging +85℃, 85%RH, 1000 hours ±50% typical resistance change Thermal Shock MIL-STD-202, Method 107G +85℃/-40℃ 20 times -50% typical resistance change Solvent Resistance MIL-STD-202, Method 215 No change Vibration MIL-STD-883C, Method 2007.1, Condition A No change Moisture Level Sensitivity Level 1, J-STD-020C Physical Specifications Terminal Material Solder-Plated Copper (Solder Material: Matte Tin (Sn)) Terminal Solderability Meets EIA Specification RS186-9E, ANSI/J-STD-002 Category 3. Packaging Part Number Quantity Part Number Quantity Part Number Quantity SMD2920B030TF 1500 SMD2920B150TF 1500 SMD2920B300TF/30 1500 SMD2920B050TF 1500 SMD2920B185TF 1500 SMD2920B330TF 1000 SMD2920B075TF 1500 SMD2920B200TF/24 1500 SMD2920B400TF 1000 SMD2920B075TF/60 1000 SMD2920B250TF 1500 SMD2920B500TF 1000 SMD2920B100TF 2000 SMD2920B260TF 2000 SMD2920B500TF/16 1000 SMD2920B110TF/60 1500 SMD2920B260TF/24 1500 SMD2920B600TF/12 1000 SMD2920B125TF 2000 SMD2920B300TF/15 1500 SMD2920B700TF/12 1000 ◎ 8mm tape on 7 inch reel per EIA-481 (equivalent to IEC286, part 3) www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 10 11 SMD2920 Tape Dimensions (mm) B030TF, B110TF/60 B050TF B075TF, B150TF B185TF, B250TF B200TF/24 B260TF/24 B300TF/15 B300TF/30 B100TF B125TF B260TF W 16.00±0.30 16.00±0.30 16.00±0.30 F 7.50±0.10 7.50±0.10 7.50±0.10 E1 1.75±0.10 1.75±0.10 1.75±0.10 D0 1.55±0.05 1.55±0.05 1.50±0.10 D1 1.50±0.10 1.50±0.10 1.50(MIN) P0 4.00±0.10 4.00±0.10 4.00±0.10 P1 8.00±0.10 8.00±0.10 8.00±0.10 P2 2.00±0.10 2.00±0.10 2.00±0.10 A0 5.74±0.10 5.74±0.10 5.74±0.10 B0 8.02±0.10 8.02±0.10 8.02±0.10 T 0.30±0.10 0.30±0.10 0.30±0.10 K0 1.30±0.10 0.91±0.10 2.00±0.10 Leader min. 390 390 390 Trailer min. 160 160 160 Symbol P2 P1 D0 T B0 D1 W F E P0 K0 A0 Reel C Φ180.0±3.0 D Φ60.0±0.5 H 19.5±1.0 W 17.0±0.2 B075TF/60 B330TF B400TF B500TF B500TF/16 B600TF/12 B700TF/12 www.yageo.com Sep. 01, 2023 V.4 Circuit Protection POSITIVE TEMPERATURE COEFFICIENT Product Specification 11 11 SMD2920 Legal Disclaimer YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any part icular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applicatio ns under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Ae rospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure o f YAGEO products could result in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Sep. 01, 2023 V.4
SMD2920B100TF 价格&库存
很抱歉,暂时无法提供与“SMD2920B100TF”相匹配的价格&库存,您可以联系我们找货
SMD2920B100TF
    SMD2920B100TF
    • 1+2.998431+0.38966
    • 5+2.471315+0.32116
    • 10+2.2675010+0.29467
    • 50+1.8848550+0.24495
    • 100+1.73920100+0.22602
    • 250+1.56363250+0.20320
    • 500+1.44239500+0.18745
    • 1000+1.330411000+0.17289
    库存:3
    SMD2920B100TF
    • 2000+1.226642000+0.15941
    • 4000+1.130524000+0.14692
    • 6000+1.077586000+0.14004
    • 10000+1.0141010000+0.13179
    • 14000+0.9741514000+0.12660
    • 20000+0.9333620000+0.12130
    库存:3
    SMD2920B100TF
      SMD2920B100TF
