14-507.0250
14-507.0250
    EAO
    开关 工作温度-25℃~+55℃
14-507.0250 数据手册
Series Series 14 Attractive. Compact. Reliable. https://eao.com/14 14 14 Information about the Series Key advantages § Attractive 22.5 mm or 30.5 mm § Up to 4 NO and 4 NC contacts § Low back panel depth § High IP67 protection § Low-level switching possible § Excellent tactile feeback Mounting cut-outs design (flush) Typical application areas § Industrial machinery and process automation § Panel building § Lifting and moving § Public transportation § Construction machinery and special vehicles Functions § Ø § Ø 22.3 mm 30.5 mm Terminal § Soldering terminal § Plug-in terminal § Soldering/plug-in terminal § PCB (with PCB plug-in base) § Cable § Push-in terminal (PIT) Lens Material § Aluminium § Stainless steel § Plastic § Pushbutton § Illuminated pushbutton § Mushroom-head pushbutton § Selector switch § Keylock switch § Indicator § Buzzer § Engraving § Hot stamping § Pad printing § Screen print Design Approvals § Flush § Raised § CB (IEC 61058) § CSA § CQC § ENEC (EN 61058) § DNV GL (previously § UL IP front protection § IP40 § IP65 § IP67 Germanischer Lloyd) Conformities Raitings § 42 VAC (100 mA) § 250 VAC (5 A) 280 Markings ​ § CE § 2014/35/EU § 2011/65/EU § 2014/30/EU (LVD) (RoHS) (EMC) eao.com § 11/2021 Index 14 Flush design Illuminated pushbutton 282 Mushroom-head pushbutton 285 Mushroom-head pushbutton illuminated 288 Selector switch 2 positions 291 Keylock switch 2 positions 294 Indicator 297 Buzzer 299 Raised design Illuminated pushbutton 300 Mushroom-head pushbutton 303 Mushroom-head pushbutton illuminated 306 Selector switch 2 positions 309 Keylock switch 2 positions 312 Indicator compact 315 Indicator full-face illumination 316 Indicator front illumination 318 Buzzer 320 Components 321 Accessories 327 Technical data 335 Marking 339 Application guidelines 343 01 02 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 281 14 Flush design 01 Illuminated pushbutton, IP67 1.5 ... 6 02 Equipment consisting of (schematic overview) B 7.5 56 Ø 35 03 A 52.5 04 3 D 2 Product can differ from the current configuration. 14 Page 323 Lens Page 321 Marking Plate Page 323 Single-LED Page 325 48.5 … 71 60.5 / 68 09 Front bezel C 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm Universal-Solder terminal 17 Actuator 35 min. 35 min. 18 Pressure ring 19 Ø30.5 +0.5 0 Fixing nut 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension Ø 35 mm 51 56 Switching action Terminal Switching system Contacts Part No. Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 57 61 Maintained 70 71 Momentary 82 Maintained 84 92 Momentary 96 Component Layout Wiring diagram Diode 1N4007 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-743.0292 13 5 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-744.0292 15 5 Contacts: NC = Normally closed, NO = Normally open 282 eao.com § 11/2021 Flush design 14 Component Layout 5 Switching action Terminal Switching system Contacts Diode 1N4007 Part No. Wiring diagram Momentary Universal terminal Snap-action switching element 2 NC / 2 NO 2 14-746.0292 23 Maintained Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-747.0292 14 5 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-748.0292 16 5 02 Contacts: NC = Normally closed, NO = Normally open 03 Wiring diagrams 1 b+ 2 a- 01 04 1 b+ 1 3 b+ 1 3 b+ 1 b+ 1 b+ 2 a- 2 4 a- 2 4 a- 2 a- 2 a- 09 14 17 Wiring diagram 5 1 Wiring diagram 6 3 b+ Wiring diagram 7 1 3 Wiring diagram 8 1 b+ 3 b+ Wiring diagram 9 3 1 I 3 b+ Wiring diagram 10 3 1 I 3 b+ 3 1 18 I 19 4 2 Wiring diagram 11 1 3 4 2 a- a- 2 Wiring diagram 12 b+ 3 a- 1 2 1 2 4 Wiring diagram 16 3 3 1 3 b+ 3 1 a- 4 3 2 x1- 1 b+ 3 1 I 4 3 x2+ 1 4 a- 2 3 4 2 x1- Wiring diagram 19 x2+ 1 II a- 2 4 3 3 b+ 41 4 45 a- 51 Wiring diagram 20 1 I 3 22 31 I I Wiring diagram 18 II 2 2 Wiring diagram 15 I 1 1 4 Wiring diagram 14 x2+ Wiring diagram 17 I 2 2 I 4 1 a- Wiring diagram 13 I 2 4 56 x2+ II 57 2 4 2 4 a- 2 2 4 Wiring diagram 23 1 3 1 3 1 II 4 Wiring diagram 26 4 2 x1- Wiring diagram 24 I 2 2 4 2 3 x2+ 4 2 3 1 I 4 x1- 2 2 4 x1- 61 Wiring diagram 25 1 III 4 3 1 II 4 2 3 70 x2+ III 4 2 71 4 82 x1- 84 Wiring diagram 27 92 96 11/2021 § eao.com ​ 283 14 Flush design 01 Wiring diagrams 1 02 3 1 I 3 1 II 3 1 III 3 1 x2+ IV 3 1 I 3 1 II 3 1 III 3 x2+ 4 x1- IV 03 2 2 4 4 2 2 4 4 2 x1- 2 4 4 2 2 4 04 Wiring diagram 28 09 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 14 17 18 19 Wiring diagram 30 Wiring diagram 31 Component layouts 22 A D C 31 5.08 41 2.54 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B 45 a 4 3 B b 2 51 56 10.16 Component layout 5 57 61 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 70 71 82 84 92 96 284 ​ eao.com § 11/2021 Flush design 14 Mushroom-head pushbutton, IP67 01 Equipment consisting of (schematic overview) 1.5 ... 7 7.5 Page 321 Front bezel set Page 323 Marking Plate Page 323 56 A 04 C 11 13.5 03 Ø 35 Lens 02 B 48.5 … 71 52.5 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 mm x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm Actuator 09 Product can differ from the current configuration. 14 17 50 min. Pressure ring 18 50 min. Fixing nut To obtain a complete unit, please select the red components from the pages shown. 19 +0.5 0 Ø30.5 Each Part Number listed below includes all the black components shown in the 3D-drawing. 22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 35 mm Component Layout Switching action Terminal Switching system Contacts Part No. Wiring diagram Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Maintained Momentary Maintained 45 51 56 57 61 70 71 82 84 Contacts: NC = Normally closed, NO = Normally open 92 96 11/2021 § eao.com 285 14 Flush design 01 Wiring diagrams 02 1 b+ 2 a- 1 b+ 1 3 b+ 1 3 b+ 1 b+ 1 b+ 2 a- 2 4 a- 2 4 a- 2 a- 2 a- 03 04 Wiring diagram 5 09 1 Wiring diagram 6 3 b+ Wiring diagram 7 1 3 Wiring diagram 8 1 b+ 3 Wiring diagram 9 x2+ 1 3 Wiring diagram 10 1 b+ I I 3 x2+ 4 x1- I 14 17 18 4 2 Wiring diagram 11 1 19 3 4 2 a- 2 2 Wiring diagram 12 1 b+ I 22 a- a- 2 x1- Wiring diagram 17 3 1 I 4 4 3 2 4 x2+ 1 3 1 I 4 a- 2 Wiring diagram 18 II 2 4 2 x1- Wiring diagram 19 3 x2+ 4 x1- II 2 4 31 Wiring diagram 20 41 1 Wiring diagram 24 3 1 I 3 1 II 3 Wiring diagram 25 x2+ 1 3 1 3 I III 1 II 3 x2+ 4 x1- III 45 2 51 56 4 2 4 2 x1- Wiring diagram 26 1 57 2 3 1 3 1 II 2 4 3 1 III 2 2 4 4 2 3 x2+ 1 IV 2 4 Wiring diagram 28 71 4 Wiring diagram 27 I 61 70 2 4 3 1 I 4 x1- 2 3 1 II 4 2 3 1 III 4 2 3 x2+ 4 x1- IV 4 2 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 82 84 92 Wiring diagram 30 Wiring diagram 31 96 286 ​ eao.com § 11/2021 Flush design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 11/2021 § eao.com 96 ​ 287 14 Flush design 01 Mushroom-head pushbutton illuminated, IP67 Equipment consisting of (schematic overview) 1.5 ... 7 02 7.5 B 03 A 04 09 C 11 13.5 Product can differ from the current configuration. 14 48.5 … 71 52.5 Page 321 Front bezel set Page 323 Marking Plate Page 323 Single-LED Page 325 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 mm x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm 17 Lens Ø 35 56 Actuator 50 min. 50 min. 18 Pressure ring 19 +0.5 Ø30.5 0 Fixing nut 22 Mounting cut-outs [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension Ø 35 mm 51 56 Switching action Terminal Switching system Contacts Part No. Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 57 61 Maintained 70 71 Momentary 82 84 Maintained 92 Momentary 96 Component Layout Wiring diagram Diode 1N4007 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Universal terminal Snap-action switching element 1 NC / 1 NO 14-743.0292 13 5 1 Contacts: NC = Normally closed, NO = Normally open 288 eao.com § 11/2021 Flush design Switching action Terminal Momentary Maintained Switching system Contacts Diode 1N4007 Component Layout Wiring diagram Part No. 14 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-744.0292 15 5 Universal terminal Snap-action switching element 2 NC / 2 NO 2 14-746.0292 23 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-747.0292 14 5 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-748.0292 16 5 02 03 Contacts: NC = Normally closed, NO = Normally open 04 Wiring diagrams 1 01 b+ 1 1 b+ 3 b+ 1 3 1 b+ b+ 1 09 b+ 14 2 2 a- Wiring diagram 5 1 a- Wiring diagram 6 3 b+ 4 2 Wiring diagram 7 1 3 4 2 a- a- 2 Wiring diagram 8 1 b+ 3 b+ Wiring diagram 9 3 1 I 4 2 Wiring diagram 11 1 3 4 2 a- a- b+ 3 4 a- 1 1 3 b+ 3 1 4 a- x2+ 1 3 18 3 2 2 Wiring diagram 14 b+ 3 1 19 4 a- 2 4 1 b+ 3 x2+ 1 3 41 b+ I I 22 31 Wiring diagram 15 I I 17 I 2 2 Wiring diagram 13 I 3 a- Wiring diagram 10 I 2 Wiring diagram 12 2 a- 45 2 4 a- 2 2 4 4 2 x1- 4 a- 2 4 2 x1- 4 a- 51 Wiring diagram 16 1 3 Wiring diagram 17 1 b+ 3 1 1 4 2 4 a- 2 2 4 Wiring diagram 23 1 3 3 1 I II I 2 3 Wiring diagram 18 3 Wiring diagram 19 x2+ 1 II 2 4 1 3 1 II 3 x2+ 4 2 x1- 3 56 x2+ II 4 2 57 4 61 x1- 70 Wiring diagram 25 1 3 1 I III 1 I Wiring diagram 24 I 3 Wiring diagram 20 3 1 II 3 71 x2+ III 82 2 4 2 4 2 4 x1- 2 4 2 4 2 4 x1- 84 Wiring diagram 26 Wiring diagram 27 92 96 11/2021 § eao.com ​ 289 14 Flush design 01 Wiring diagrams 1 02 3 1 I 3 1 II 3 1 III 3 1 x2+ IV 3 1 I 3 1 II 3 1 III 3 x2+ 4 x1- IV 03 2 2 4 4 2 2 4 4 2 x1- 2 4 4 2 2 4 04 Wiring diagram 28 09 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 14 17 18 19 Wiring diagram 30 Wiring diagram 31 Component layouts 22 A D C 31 5.08 41 2.54 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B 45 a 4 3 B b 2 51 56 10.16 Component layout 5 57 61 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 70 71 82 84 92 96 290 ​ eao.com § 11/2021 Flush design 14 Selector switch 2 positions, IP67 01 Equipment consisting of (schematic overview) 1.5 ... 6 7.5 Page 323 Anti-twist device Page 326 56 A 03 Ø 35 Front bezel 02 B 15.5 04 C 2 46.5 … 69 52.5 3 Actuator Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm 09 Product can differ from the current configuration. 14 Pressure ring 17 35 min. 18 35 min. Fixing nut Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Ø30.5 19 +0.5 0 22 Mounting cut-outs [mm] 31 0 I 0 41 I 45 Actuator, Front dimension Ø 35 mm Switching action Terminal Rest - Momentary Plug-in terminal Rest - Maintained Switching system Contacts Switching angle Lever shape Part No. Wiring diagram Snap-action switching element 1 NC / 1 NO 42° right short 14-501.0220 124 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right short 14-501.02502 124 Soldering terminal Snap-action switching element 2 NC / 2 NO 42° right short 14-502.02502 125 Snap-action switching element 1 NC / 1 NO 90° right short 14-506.0220 117 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right Plug-in terminal short 14-506.02502 117 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right short 14-507.02502 118 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right short 14-508.02502 126 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right short 14-509.02502 127 Component Layout 56 57 61 Rest - Momentary Universal terminal Low-level element 2 NO 42° right short 14-515.0360 122 5 Universal terminal Low-level element 1 NC / 1 NO 42° right short 14-517.0360 119 5 Universal terminal Low-level element 2 NO 90° right short 14-520.0360 123 5 Rest - Maintained 51 Universal terminal Low-level element 2 NC 90° right short 14-521.0360 121 5 Universal terminal Low-level element 1 NC / 1 NO 90° right short 14-522.0360 120 5 70 71 Contacts: NC = Normally closed, NO = Normally open 82 84 92 96 11/2021 § eao.com 291 14 Flush design 01 Wiring diagrams 1 02 3 1 I 3 1 I 3 1 3 4 2 4 II 03 2 2 4 4 2 04 Wiring diagram 117 09 Wiring diagram 118 Wiring diagram 119 1 3 1 3 1 3 1 3 2 4 2 4 2 4 2 4 14 17 18 Wiring diagram 120 Wiring diagram 121 1 19 Wiring diagram 122 3 1 I 3 1 I 3 Wiring diagram 123 1 II 3 1 I 3 1 II 3 III 22 2 2 4 4 2 2 4 4 2 4 2 4 31 Wiring diagram 124 41 Wiring diagram 125 1 3 1 I 3 1 II 3 Wiring diagram 126 1 III 3 IV 45 2 51 56 4 2 4 2 4 2 4 Wiring diagram 127 57 61 70 71 82 84 92 96 292 ​ eao.com § 11/2021 Flush design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 1 3 a b 2 4 B 1 3 a b 4 2 1 7.62 B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 293 14 Flush design 01 Keylock switch 2 positions, IP65 Equipment consisting of (schematic overview) 1.5 ... 6 02 7.5 B 03 A 04 Product can differ from the current configuration. 17 46.5 … 69 52.5 Page 323 Anti-twist device Page 326 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm 14 Front bezel C 2 27 09 Ø 35 56 Actuator General information 35 min. • Lock numbers 1001, lock type KABA • Front plastic black Pressure ring 35 min. 18 Fixing nut 19 Ø30.5 +0.5 0 Each Part Number listed below includes all the black components shown in the 3D-drawing. 22 To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] 31 41 0 0 I I 45 Actuator, Front dimension Ø 35 mm 51 56 Switching action Terminal Switching system Contacts Switching angle Part No. Rest (a) - Maintained (a) Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-135.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-135.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-136.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-137.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-138.025K2 116 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right 14-141.022K 113 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right 14-141.025K2 113 Soldering terminal Snap-action switching element 2 NC / 2 NO 42° right 14-142.025K2 113 Soldering terminal Snap-action switching element 3 NC / 3 NO 42° right 14-143.025K2 114 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-235.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-235.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-236.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-237.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-238.025K2 116 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-335.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-335.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-336.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-337.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-338.025K2 116 Universal terminal Low-level element 2 NO 90° right 14-411.036K 112 5 Universal terminal Low-level element 1 NC / 1 NO 90° right 14-412.036K 111 5 57 61 70 Rest (a) - Momentary Rest (a) - Maintained 71 82 Rest - Maintained (a) 84 92 96 Component Layout Wiring diagram Rest (a) - Maintained (a) Contacts: NC = Normally closed, NO = Normally open a = Key remove 294 eao.com § 11/2021 Flush design Switching action Rest (a) - Maintained Terminal Switching system Contacts Switching angle Wiring diagram Part No. 14 Component Layout Universal terminal Low-level element 2 NO 90° right 14-414.036K 112 5 Universal terminal Low-level element 1 NC / 1 NO 90° right 14-415.036K 111 5 Rest - Maintained (a) Universal terminal Low-level element 2 NO 90° right 14-417.036K 112 5 Universal terminal Low-level element 1 NC / 1 NO 90° right 14-418.036K 111 5 Rest (a) - Momentary Universal terminal Low-level element 2 NO 42° right 14-437.036K 109 5 Universal terminal Low-level element 1 NC / 1 NO 42° right 14-438.036K 110 5 01 02 03 04 Contacts: NC = Normally closed, NO = Normally open a = Key remove 09 Wiring diagrams 1 3 1 I 3 1 I 3 1 14 3 II 17 2 2 4 Wiring diagram 107 4 2 4 Wiring diagram 108 1 18 Wiring diagram 109 1 3 4 2 3 1 19 3 22 4 2 Wiring diagram 110 2 Wiring diagram 111 1 3 1 I 31 4 2 4 41 Wiring diagram 112 3 1 II 3 1 I 3 1 II 45 3 III 51 2 4 2 2 4 4 2 4 2 4 56 Wiring diagram 113 Wiring diagram 114 1 3 1 I 2 Wiring diagram 115 3 1 II 4 2 3 57 1 III 4 2 3 1 I 2 4 3 1 II 4 2 3 1 III 4 2 3 IV 4 2 61 70 4 71 Wiring diagram 116 82 84 92 96 11/2021 § eao.com ​ 295 14 Flush design 01 Component layouts 02 A D C 5.08 03 2.54 Ø1.0 (6x) 04 09 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 3 B b 2 14 10.16 17 18 19 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 22 31 41 45 51 56 57 61 High-intensity illuminated and robust. EAO Series 14 Indicator compact. 70 71 Ideal for safe status indications, such as of production robots – thanks to excellent visibility. . High-intensity illumination . Compact, space-saving design . 180° all-round visibility . Easy mounting with reliable PIT terminal . IP69K protection 82 84 92 www.eao.com/14-compact 96 296 ​ eao.com § 11/2021 Flush design 14 Indicator, IP67 01 Equipment consisting of (schematic overview) 1.5 ... 6 02 B Page 323 Lens Page 321 Marking Plate Page 323 56 A 04 C 2 Single-LED 03 Ø 35 Front bezel 48.5 52.5 3 09 Page 325 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm Actuator Product can differ from the current configuration. 14 17 35 min. 35 min. 18 Pressure ring Ø30.5 19 +0.5 0 Fixing nut 22 Mounting cut-outs [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension Ø 35 mm Terminal Part No. Wiring diagram Plug-in terminal 14-040.002 3 Soldering terminal 14-040.005 3 Universal terminal 14-041.006 3 Component Layout 5 51 56 57 Wiring diagrams 61 b+ 70 71 a- 82 Wiring diagram 3 84 92 96 11/2021 § eao.com 297 14 Flush design 01 Component layouts 02 A D C 5.08 03 2.54 Ø1.0 (6x) 04 09 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 3 B b 2 14 10.16 17 18 19 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 22 31 41 45 51 56 57 61 70 71 82 84 92 96 298 ​ eao.com § 11/2021 Flush design 14 Buzzer, IP40 01 Equipment consisting of (schematic overview) 2 ... 6 02 03 Ø 35 Actuator 04 Fixing nut 46.5 2 Pressure ring Dimensions [mm] 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. 35 min. 35 min. • For PCB application use adaptor Part-No. 31942 Ø30.5 • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.5 0 19 Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 35 mm Terminal Operating voltage Front cap colour Front cap material Front cap surface Part No. Wiring diagram Plug-in terminal 24 V DC Black Aluminium anodised 14-810.910 71 24 V DC Nature Aluminium anodised 14-810.918 71 41 45 51 Wiring diagrams 56 x1+ 57 x2- 61 70 Wiring diagram 71 71 82 84 92 96 11/2021 § eao.com 299 14 Raised design 01 Illuminated pushbutton, IP67 1.5 ... 7 02 Equipment consisting of (schematic overview) B 7.5 45.5 A 30 03 41.5 04 3 D 14 Lens Page 321 Marking Plate Page 323 Single-LED Page 325 3 49.5/ 57 Product can differ from the current configuration. Page 323 37.5 … 60 13.5 09 Front bezel C Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm D = Universal-Solder terminal 17 Actuator NJO     NJO 18    Fixing nut 19   ±  ±  22 To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 Actuator, Front dimension Ø 29 mm 45 51 Switching action Terminal Switching system Contacts Part No. Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 56 57 Maintained 61 70 Momentary 71 Maintained 82 84 Momentary 92 Maintained 96 Component Layout Wiring diagram Diode 1N4007 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-743.0292 13 5 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-744.0292 15 5 Universal terminal Snap-action switching element 2 NC / 2 NO 2 14-746.0292 23 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-747.0292 14 5 Contacts: NC = Normally closed, NO = Normally open 300 eao.com § 11/2021 Raised design Switching action Terminal Switching system Contacts Diode 1N4007 Part No. Wiring diagram Maintained Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-748.0292 16 14 Component Layout 5 02 Contacts: NC = Normally closed, NO = Normally open 03 Wiring diagrams 1 01 b+ 1 b+ 2 a- 1 3 b+ 1 3 1 b+ b+ 1 04 b+ 09 2 a- Wiring diagram 5 1 4 2 a- a- 2 b+ Wiring diagram 7 1 3 Wiring diagram 8 1 b+ 3 b+ Wiring diagram 9 3 1 I 4 2 3 4 2 a- Wiring diagram 11 1 2 a- a- 14 Wiring diagram 6 3 4 2 a- b+ 3 4 a- 1 1 3 3 1 4 a- 2 2 Wiring diagram 14 x2+ 1 3 b+ 3 1 18 4 a- 2 4 1 b+ 3 x2+ 1 3 31 b+ I I 19 22 Wiring diagram 15 I I 17 3 I 2 2 Wiring diagram 13 I b+ I 2 Wiring diagram 12 3 Wiring diagram 10 41 2 4 a- 2 2 4 4 2 x1- 4 a- 2 4 2 x1- 4 a- 45 Wiring diagram 16 Wiring diagram 17 Wiring diagram 18 Wiring diagram 19 Wiring diagram 20 51 1 3 1 I 2 3 b+ 3 1 1 2 4 a- 2 2 4 Wiring diagram 23 1 3 1 I II 4 3 3 x2+ 1 II 2 4 1 3 1 II 3 x2+ 4 2 x1- 3 x2+ II 4 2 56 4 57 x1- 61 Wiring diagram 25 1 3 1 I III 1 I Wiring diagram 24 I 3 3 1 II 3 x2+ 4 x1- 70 III 71 2 4 2 4 2 4 x1- 2 4 2 4 2 82 Wiring diagram 26 Wiring diagram 27 84 92 96 11/2021 § eao.com ​ 301 14 Raised design 01 Wiring diagrams 1 02 3 1 I 3 1 II 3 1 III 3 1 x2+ IV 3 1 I 3 1 II 3 1 III 3 x2+ 4 x1- IV 03 2 2 4 4 2 2 4 4 2 x1- 2 4 4 2 2 4 04 Wiring diagram 28 09 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 14 17 18 19 Wiring diagram 30 Wiring diagram 31 Component layouts 22 A D C 31 5.08 41 2.54 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B 45 a 4 3 B b 2 51 56 10.16 Component layout 5 57 61 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 70 71 82 84 92 96 302 ​ eao.com § 11/2021 Raised design 14 Mushroom-head pushbutton, IP67 01 Equipment consisting of (schematic overview) Page 321 Front bezel Page 323 Marking Plate Page 323 02 B 7.5 45.5 A 03 30 Lens 1.5 ... 7 C 13.5 28 41.5 37.5 … 60 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm Actuator 04 3 09 Product can differ from the current configuration. 14 17 NJO Fixing nut 18 NJO Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 19  ± 22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 40 mm Component Layout Switching action Terminal Switching system Contacts Part No. Wiring diagram Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Maintained Momentary Maintained 45 51 56 57 61 70 71 82 84 Contacts: NC = Normally closed, NO = Normally open 92 96 11/2021 § eao.com 303 14 Raised design 01 Wiring diagrams 02 1 b+ 2 a- 1 b+ 1 3 b+ 1 3 b+ 1 b+ 1 b+ 2 a- 2 4 a- 2 4 a- 2 a- 2 a- 03 04 Wiring diagram 5 09 1 Wiring diagram 6 3 b+ Wiring diagram 7 1 3 Wiring diagram 8 1 b+ 3 Wiring diagram 9 x2+ 1 3 Wiring diagram 10 1 b+ I I 3 x2+ 4 x1- I 14 17 18 4 2 Wiring diagram 11 1 19 3 4 2 a- 2 2 Wiring diagram 12 1 b+ I 22 a- a- 2 x1- Wiring diagram 17 3 1 I 4 4 3 2 4 x2+ 1 3 1 I 4 a- 2 Wiring diagram 18 II 2 4 2 x1- Wiring diagram 19 3 x2+ 4 x1- II 2 4 31 Wiring diagram 20 41 1 Wiring diagram 24 3 1 I 3 1 II 3 Wiring diagram 25 x2+ 1 3 1 3 I III 1 II 3 x2+ 4 x1- III 45 2 51 56 4 2 4 2 x1- Wiring diagram 26 1 57 2 3 1 3 1 II 2 4 3 1 III 2 2 4 4 2 3 x2+ 1 IV 2 4 Wiring diagram 28 71 4 Wiring diagram 27 I 61 70 2 4 3 1 I 4 x1- 2 3 1 II 4 2 3 1 III 4 2 3 x2+ 4 x1- IV 4 2 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 82 84 92 Wiring diagram 30 Wiring diagram 31 96 304 ​ eao.com § 11/2021 Raised design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 11/2021 § eao.com 96 ​ 305 14 Raised design Mushroom-head pushbutton illuminated, IP67 1.5 ... 7 02 Equipment consisting of (schematic overview) B 7.5 45.5 03 A 41.5 04 09 Product can differ from the current configuration. 14 3 D 13.5 28 Lens Page 321 Front bezel Page 323 Marking Plate Page 323 Single-LED Page 325 C 30 01 37.5 … 60 49.5/ 57 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm D = Universal-Solder terminal 17 Actuator NJO NJO 18 Fixing nut 19  ± Each Part Number listed below includes all the black components shown in the 3D-drawing. 22 To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 40 mm 45 51 Switching action Terminal Switching system Contacts Part No. Momentary Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-131.022 18 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-131.0252 17 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-132.0252 24 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-133.0252 26 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-134.0252 28 Plug-in terminal Snap-action switching element 1 NC / 1 NO 14-271.022 20 Soldering terminal Snap-action switching element 1 NC / 1 NO 14-271.0252 19 Soldering terminal Snap-action switching element 2 NC / 2 NO 14-272.0252 25 Soldering terminal Snap-action switching element 3 NC / 3 NO 14-273.0252 27 Soldering terminal Snap-action switching element 4 NC / 4 NO 14-274.0252 29 Universal terminal Low-level element 2 NO 14-431.036 11 5 Universal terminal Low-level element 2 NC 14-432.036 30 5 56 57 Maintained 61 70 Momentary 71 82 Maintained 84 Momentary 92 Maintained 96 Component Layout Wiring diagram Diode 1N4007 Universal terminal Low-level element 1 NC / 1 NO 14-433.036 7 5 Universal terminal Low-level element 1 NO 14-435.036 9 5 Universal terminal Low-level element 1 NC 14-436.036 5 5 Universal terminal Low-level element 2 NO 14-471.036 12 5 Universal terminal Low-level element 2 NC 14-472.036 31 5 Universal terminal Low-level element 1 NC / 1 NO 14-473.036 8 5 Universal terminal Low-level element 1 NO 14-475.036 10 5 Universal terminal Low-level element 1 NC 14-476.036 6 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-743.0292 13 5 Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-744.0292 15 5 Universal terminal Snap-action switching element 2 NC / 2 NO 2 14-746.0292 23 5 Universal terminal Snap-action switching element 1 NC / 1 NO 1 14-747.0292 14 5 Contacts: NC = Normally closed, NO = Normally open 306 eao.com § 11/2021 Raised design Switching action Terminal Switching system Contacts Diode 1N4007 Part No. Wiring diagram Maintained Universal terminal Snap-action switching element 1 NC / 1 NO 2 14-748.0292 16 14 Component Layout 5 02 Contacts: NC = Normally closed, NO = Normally open 03 Wiring diagrams 1 01 b+ 1 b+ 2 a- 1 3 b+ 1 3 1 b+ b+ 1 04 b+ 09 2 a- Wiring diagram 5 1 4 2 a- a- 2 b+ Wiring diagram 7 1 3 Wiring diagram 8 1 b+ 3 b+ Wiring diagram 9 3 1 I 4 2 3 4 2 a- Wiring diagram 11 1 2 a- a- 14 Wiring diagram 6 3 4 2 a- b+ 3 4 a- 1 1 3 3 1 4 a- 2 2 Wiring diagram 14 x2+ 1 3 b+ 3 1 18 4 a- 2 4 1 b+ 3 x2+ 1 3 31 b+ I I 19 22 Wiring diagram 15 I I 17 3 I 2 2 Wiring diagram 13 I b+ I 2 Wiring diagram 12 3 Wiring diagram 10 41 2 4 a- 2 2 4 4 2 x1- 4 a- 2 4 2 x1- 4 a- 45 Wiring diagram 16 Wiring diagram 17 Wiring diagram 18 Wiring diagram 19 Wiring diagram 20 51 1 3 1 I 2 3 b+ 3 1 1 2 4 a- 2 2 4 Wiring diagram 23 1 3 1 I II 4 3 3 x2+ 1 II 2 4 1 3 1 II 3 x2+ 4 2 x1- 3 x2+ II 4 2 56 4 57 x1- 61 Wiring diagram 25 1 3 1 I III 1 I Wiring diagram 24 I 3 3 1 II 3 x2+ 4 x1- 70 III 71 2 4 2 4 2 4 x1- 2 4 2 4 2 82 Wiring diagram 26 Wiring diagram 27 84 92 96 11/2021 § eao.com ​ 307 14 Raised design 01 Wiring diagrams 1 02 3 1 I 3 1 II 3 1 III 3 1 x2+ IV 3 1 I 3 1 II 3 1 III 3 x2+ 4 x1- IV 03 2 2 4 4 2 2 4 4 2 x1- 2 4 4 2 2 4 04 Wiring diagram 28 09 Wiring diagram 29 1 3 b+ 1 3 b+ 2 4 a- 2 4 a- 14 17 18 19 Wiring diagram 30 Wiring diagram 31 Component layouts 22 A D C 31 5.08 41 2.54 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B 45 a 4 3 B b 2 51 56 10.16 Component layout 5 57 61 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 70 71 82 84 92 96 308 ​ eao.com § 11/2021 Raised design 14 Selector switch 2 positions, IP67 01 Equipment consisting of (schematic overview) 1.5 ... 7 7.5 02 B 45.5 03 25 A 30 Front bezel Actuator 04 C 13.5 35.5 … 58 27 41.5 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm 14 Fixing nut NJO Each Part Number listed below includes all the black components shown in the 3D-drawing. NJO 09 Product can differ from the current configuration. General information A • The colour of anodised aluminium parts can vary due to technical production reasons B • Non-illuminative  18 NJO 19    NJO      ±  ±  22 Mounting cut-outs [mm] A = Long lever B = Short lever 0 I 31 0 41 I 45 Actuator, Front dimension Ø 29 mm Switching action Terminal Rest - Momentary Plug-in terminal Rest - Maintained Switching system Contacts Switching angle Lever shape Part No. Wiring diagram Snap-action switching element 1 NC / 1 NO 42° right short 14-501.0220 124 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right short 14-501.02502 124 Soldering terminal Snap-action switching element 2 NC / 2 NO 42° right short 14-502.02502 125 Plug-in terminal Snap-action switching element 1 NC / 1 NO 90° right short 14-506.0220 117 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right short 14-506.02502 117 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right short 14-507.02502 118 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right short 14-508.02502 126 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right short 14-509.02502 127 Component Layout 57 61 Low-level element 2 NO 42° right short 14-515.0360 122 5 Universal terminal Low-level element 1 NC / 1 NO 42° right short 14-517.0360 119 5 Universal terminal Low-level element 2 NO 90° right short 14-520.0360 123 5 Universal terminal Low-level element 2 NC 90° right short 14-521.0360 121 5 Universal terminal Low-level element 1 NC / 1 NO 90° right short 14-522.0360 120 5 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right long 14-556.0220 117 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right long 14-556.02502 117 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right long 14-557.02502 118 51 56 Rest - Momentary Universal terminal Rest - Maintained 17 70 71 82 Universal terminal Low-level element 2 NO 90° right long 14-570.0360 123 1 Universal terminal Low-level element 1 NC / 1 NO 90° right long 14-572.0360 120 1 84 Contacts: NC = Normally closed, NO = Normally open 92 96 11/2021 § eao.com 309 14 Raised design 01 Wiring diagrams 1 02 3 1 I 3 1 I 3 1 3 4 2 4 II 03 2 2 4 2 4 04 Wiring diagram 117 09 Wiring diagram 118 Wiring diagram 119 1 3 1 3 1 3 1 3 2 4 2 4 2 4 2 4 14 17 18 Wiring diagram 120 Wiring diagram 121 1 19 Wiring diagram 122 3 1 I 3 1 I Wiring diagram 123 3 1 II 3 1 I 3 1 II 3 III 22 2 2 4 4 2 2 4 2 4 2 4 4 31 Wiring diagram 124 41 Wiring diagram 125 1 3 1 I 3 1 3 II Wiring diagram 126 1 III 3 IV 45 2 51 56 57 4 2 4 2 4 2 4 Wiring diagram 127 Component layouts 61 A D 70 71 92 96 b 4 3 2 4 1 3 a b 2 4 1 3 a b 4 2 1 3 a b 2 4 1 3 a b C 82 84 7.62 18 x 24 mm 2 a 1 5.08 18 x 18 mm 10.16 B Ø18 mm Ø1.0 (6x) Component layout 1 Dimensions [mm] A = Terminals (rear side) B = Diode block C = Anti twist device only 18 x 24 mm D = Drilling plan (component side) 310 ​ eao.com § 11/2021 Raised design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 1 3 a b 2 4 B 1 3 a b 4 2 1 7.62 B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 311 14 Raised design 01 Keylock switch 2 positions, IP65 Equipment consisting of (schematic overview) 1.5 ... 7 02 B 7.5 45.5 03 04 35.5 … 58 41.5 3 Actuator Product can differ from the current configuration. Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 mm x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm 14 General information Fixing nut NJO • Lock numbers 1001, lock type KABA     • Front plastic black NJO 18 Each Part Number listed below includes all the black components shown in the 3D-drawing.    17 C 13.5 38 09 30 A Front bezel 19  ±   ±  22 Mounting cut-outs [mm] 31 0 0 41 45 51 I I Actuator, Front dimension Ø 29 mm Switching action Terminal Switching system Contacts Switching angle Part No. Rest (a) - Maintained (a) Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-135.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-135.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-136.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-137.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-138.025K2 116 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right 14-141.022K 113 Soldering terminal Snap-action switching element 1 NC / 1 NO 42° right 14-141.025K2 113 Soldering terminal Snap-action switching element 2 NC / 2 NO 42° right 14-142.025K2 113 Soldering terminal Snap-action switching element 3 NC / 3 NO 42° right 14-143.025K2 114 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-235.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-235.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-236.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-237.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-238.025K2 116 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-335.022K 107 Soldering terminal Snap-action switching element 1 NC / 1 NO 90° right 14-335.025K2 107 Soldering terminal Snap-action switching element 2 NC / 2 NO 90° right 14-336.025K2 108 Soldering terminal Snap-action switching element 3 NC / 3 NO 90° right 14-337.025K2 115 Soldering terminal Snap-action switching element 4 NC / 4 NO 90° right 14-338.025K2 116 Universal terminal Low-level element 2 NO 90° right 14-411.036K 112 5 Universal terminal Low-level element 1 NC / 1 NO 90° right 14-412.036K 111 5 Universal terminal Low-level element 2 NO 90° right 14-414.036K 112 5 56 57 Rest (a) - Momentary 61 70 Rest (a) - Maintained 71 82 Rest - Maintained (a) 84 Rest (a) - Maintained (a) 92 96 Component Layout Wiring diagram Rest (a) - Maintained Contacts: NC = Normally closed, NO = Normally open a = Key remove 312 eao.com § 11/2021 Raised design Switching action Terminal Switching system Contacts Switching angle Wiring diagram Part No. 14 Component Layout Rest (a) - Maintained Universal terminal Low-level element 1 NC / 1 NO 90° right 14-415.036K 111 5 Rest - Maintained (a) Universal terminal Low-level element 2 NO 90° right 14-417.036K 112 5 Universal terminal Low-level element 1 NC / 1 NO 90° right 14-418.036K 111 5 Rest (a) - Momentary Universal terminal Low-level element 2 NO 42° right 14-437.036K 109 5 Universal terminal Low-level element 1 NC / 1 NO 42° right 14-438.036K 110 5 01 02 03 Contacts: NC = Normally closed, NO = Normally open a = Key remove 04 Wiring diagrams 09 1 3 1 I 3 1 I 3 1 3 4 2 4 14 II 17 2 2 4 4 2 18 Wiring diagram 107 Wiring diagram 108 1 Wiring diagram 109 1 3 3 1 19 3 22 4 2 Wiring diagram 110 2 Wiring diagram 111 1 3 1 I 2 4 3 2 1 3 1 I 2 4 Wiring diagram 113 31 Wiring diagram 112 II 4 4 2 41 3 1 II 4 2 3 45 III 4 2 51 4 56 Wiring diagram 114 1 3 1 I 3 1 II 3 1 III 3 1 I 3 1 II 3 1 III 57 3 IV 61 2 Wiring diagram 115 4 2 4 2 2 4 4 2 4 2 4 2 4 70 Wiring diagram 116 71 82 84 92 96 11/2021 § eao.com ​ 313 14 Raised design 01 Component layouts 02 A D C 5.08 03 2.54 Ø1.0 (6x) 04 09 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 3 B b 2 14 10.16 17 18 19 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 22 31 41 45 51 56 57 61 High-intensity illuminated and robust. EAO Series 14 Indicator compact. 70 71 Ideal for safe status indications – thanks to excellent visibility. . High-intensity illumination . Compact, space-saving design . 180° all-round visibility . Easy mounting with reliable PIT terminal . IP69K protection 82 84 92 www.eao.com/de/14-compact 96 314 ​ eao.com § 11/2021 Raised design 14 Indicator compact, IP65, IP67, IP69K 01 Equipment consisting of (schematic overview) Indicator  .Y 02 03  Fixing nut  04  Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] 09 Product can differ from the current configuration. 14 General information NJO • Low back panel depth NJO 17 18  ± 19 Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 34 mm 41 Terminal Illuminative colour Operating voltage Part No. Wiring diagram Push-in terminal Red 24 V AC/DC 14-060.207 4 Orange 24 V AC/DC 14-060.307 4 Green 24 V AC/DC 14-060.507 4 Blue 24 V AC/DC 14-060.607 4 White 24 V AC/DC 14-060.907 4 45 51 56 Wiring diagrams 57 x2+ 61 70 x1- 71 Wiring diagram 4 82 84 92 96 11/2021 § eao.com 315 14 Raised design 01 Indicator full-face illumination, IP67 Equipment consisting of (schematic overview) 1.5 ... 7 02 B 34 03 30 A 3 Marking cap Page 323 Single-LED Page 325 D 13.5 09 Page 322 C 41.5 04 Lens cap Product can differ from the current configuration. 30 3 41.5 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm D = Universal-Solder terminal 14 Actuator 17 NJO     NJO 18  19   Fixing nut  ±  22  ±  Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 29 mm 45 Part No. Plug-in terminal 14-030.002 3 Soldering terminal 14-030.005 3 Universal terminal 14-031.006 3 5 1 14-741.006 1 5 2 14-742.006 2 5 Terminal 51 Diode 1N4007 56 57 Component Layout Wiring diagram Wiring diagrams 61 b+ 3 b+ 3 1 a- 2 a- 2 4 b+ 70 a- 71 82 Wiring diagram 1 Wiring diagram 2 Wiring diagram 3 84 92 96 316 eao.com § 11/2021 Raised design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 1 3 a b 2 4 B 1 3 a b 4 2 1 7.62 B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 317 14 Raised design Indicator front illumination, IP67 Equipment consisting of (schematic overview) 1.5 ... 7 02 B 45.5 03 A Page 323 Lens Page 321 Marking Plate Page 323 Single-LED Page 325 C 04 13.5 09 Front bezel 30 01 Product can differ from the current configuration. 14 17 37.5 41.5 3 Dimensions [mm] A = Solder terminal B = Plug-in terminal 2.8 x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm Actuator NJO        NJO 18 19  ±   ±  Fixing nut Each Part Number listed below includes all the black components shown in the 3D-drawing. 22 Mounting cut-outs [mm] To obtain a complete unit, please select the red components from the pages shown. 31 41 Actuator, Front dimension Ø 29 mm 45 51 56 57 Terminal Part No. Wiring diagram Plug-in terminal 14-040.002 3 Soldering terminal 14-040.005 3 Universal terminal 14-041.006 3 Component Layout 5 Wiring diagrams b+ 61 70 a- 71 Wiring diagram 3 82 84 92 96 318 eao.com § 11/2021 Raised design 14 Component layouts A 01 02 D C 5.08 2.54 03 Ø1.0 (6x) 2 4 B 1 3 a b 4 2 1 7.62 1 3 a b B a 4 04 3 B b 09 2 14 10.16 17 Component layout 5 Dimensions [mm] A = Terminals (rear side) B = Anti twist device C = Diode block D = Drilling plan (component side) 18 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 11/2021 § eao.com 96 ​ 319 14 Raised design 01 Buzzer, IP65 Equipment consisting of (schematic overview) 2 ... 6 02 Actuator 30 03 04 13.5 17 Product can differ from the current configuration. Dimensions [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. General information NJO • For PCB application use adaptor Part-No. 31942      18   14 Fixing nut NJO 09 35.5   ±  19 ±  Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 29 mm 41 45 51 Terminal Operating voltage Front cap colour Front cap material Plug-in terminal 24 V DC Black Plastic 24 V DC Nature Aluminium Front cap surface anodised Part No. Wiring diagram 14-810.002 71 14-810.902 71 Wiring diagrams 56 x1+ 57 x2- 61 70 Wiring diagram 71 71 82 84 92 96 320 eao.com § 11/2021 Components 14 01 02 Lens plastic Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Black opaque flush non illuminative Symbol Ø 23.7 mm 704.602.0 Red transparent flush illuminative Ø 23,7 mm 704.602.2 Yellow transparent flush illuminative Ø 23,7 mm 704.602.4 Green transparent flush illuminative Ø 23,7 mm 704.602.5 Blue transparent flush illuminative Ø 23,7 mm 704.602.6 Colourless transparent flush illuminative Ø 23,7 mm 704.602.7 Silver transparent flush illuminative Ø 23,7 mm 704.602.7A01 Ring 03 04 09 Additional information 14 • To obtain IP67, use marking plate Part No. 704.609.9 • To obtain IP67 use marking plate Part No. 704.609.9A01 (ring illumination) 17 18 Lens plastic encreased Lens material Lens colour Plastic Lens optics Lens shape Lens illumination Dimensions 19 Part No. Red transparent flush illuminative Ø 23,7 mm 704.611.2 Yellow transparent flush illuminative Ø 23,7 mm 704.611.4 Green transparent flush illuminative Ø 23,7 mm 704.611.5 Blue transparent flush illuminative Ø 23,7 mm 704.611.6 Colourless transparent flush illuminative Ø 23,7 mm 704.611.7 22 31 Additional information 41 • To obtain IP67, use marking plate Part Nr. 704.610.X 45 51 Lens metal Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Aluminium Black opaque flush non illuminative Ø 23,7 mm 704.601.0 Stainless steel Red opaque flush non illuminative Ø 23,7 mm 704.601.2 Gold opaque flush non illuminative Ø 23,7 mm 704.601.4 Olive green opaque flush non illuminative Ø 23,7 mm 704.601.5 Blue opaque flush non illuminative Ø 23,7 mm 704.601.6 Nature opaque flush non illuminative Ø 23,7 mm 704.601.8 Nature opaque flush non illuminative Ø 23,7 mm 704.601.9 56 57 61 70 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 71 • To obtain IP65, it is necessary to use marking plate Part No.. 704.609.X 82 84 92 96 11/2021 § eao.com 321 14 Components 01 Lens metal round spot round 02 03 Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Aluminium Black opaque flush illuminative Ø 23,7 mm 704.601.01 04 09 14 Stainless steel Red opaque flush illuminative Ø 23,7 mm 704.601.21 Gold opaque flush illuminative Ø 23,7 mm 704.601.41 Olive green opaque flush illuminative Ø 23,7 mm 704.601.51 Blue opaque flush illuminative Ø 23,7 mm 704.601.61 Nature opaque flush illuminative Ø 23,7 mm 704.601.81 Nature opaque flush illuminative Ø 23,7 mm 704.601.91 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons • To obtain IP65, it is necessary to use marking plate Part No.. 704.609.X 17 18 19 22 Mushroom-head cap Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Black opaque mushroom-head non illuminative Ø 40 mm 704.604.0 31 41 Red opaque mushroom-head non illuminative Ø 40 mm 704.604.2 Yellow opaque mushroom-head non illuminative Ø 40 mm 704.604.4 Green opaque mushroom-head non illuminative Ø 40 mm 704.604.5 Additional information • To obtain IP67, use marking plate Part No. 704.609.9 45 51 56 Mushroom-head cap illuminated Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Red transparent mushroom-head illuminative Ø 40 mm 704.614.2 57 61 70 Yellow transparent mushroom-head illuminative Ø 40 mm 704.614.4 Green transparent mushroom-head illuminative Ø 40 mm 704.614.5 Blue transparent mushroom-head illuminative Ø 40 mm 704.614.6 Colourless transparent mushroom-head illuminative Ø 40 mm 704.614.7 Additional information • To obtain IP67, use marking plate Part No. 704.609.9 71 82 84 Lens cap round for full face indicator Lens cap material Lens cap colour Lens cap optical effect Diameter Part No. Plastic Red transparent 29 mm 704.603.2 Yellow transparent 29 mm 704.603.4 Green transparent 29 mm 704.603.5 Blue transparent 29 mm 704.603.6 Colourless transparent 29 mm 704.603.7 92 96 Additional information • To obtain IP67, use marking plate Part Nr. 704.608.X 322 eao.com § 11/2021 Components 14 01 Marking cap for front illumination 02 Marking cap material Marking cap colour Marking cap optics Dimensions Marking cap surface Part No. Plastic Colourless transparent Ø 29 mm ribbed 704.610.7 White translucent Ø 29 mm 03 704.610.9 04 09 Marking cap for full face illumination Marking cap material Marking cap colour Marking cap optics Dimensions Marking cap surface Part No. Plastic Colourless transparent Ø 29 mm ribbed 704.608.7 White translucent Ø 29 mm 14 704.608.9 17 18 Marking plate Marking plate material Marking plate colour Marking plate optics Marking plate illumination Diameter Part No. Plastic Black opaque non illuminative 20 mm 704.609.0 Colourless transparent illuminative 20 mm 704.609.7 White translucent illuminative 20 mm 704.609.9 White translucent ring illumination 20 mm 704.609.9A01 19 22 31 Additional information • For front bezel set 24 mm x 30 mm, flush design 41 45 Front bezel round, raised design Front bezel material Front bezel colour Plastic Front bezel surface Dimensions Part No. Black Ø 29 mm 704.600.0 Grey Ø 29 mm 704.600.6 Ø 29 mm 704.600.1 Aluminium Nature anodised Black anodised Stainless steel Nature Ø 29 mm 704.600.1A Ø 29 mm 704.600.9 51 56 57 Additional information 61 • The colour of anodised aluminium parts can vary due to technical production reasons 70 71 Front bezel set Front bezel material Front bezel colour Front bezel surface Mounting cut-out Dimensions Part No. Aluminium Black anodised Ø 30.5 mm Ø 35 mm 14-955.0 Nature anodised Ø 30.5 mm Ø 35 mm 14-955.1 Ø 30.5 mm Ø 35 mm 14-955.9 Stainless steel Nature 82 84 Additional information 92 • The colour of anodised aluminium parts can vary due to technical production reasons 96 11/2021 § eao.com 323 14 Components 01 Front bezel set protective membrane 02 03 Product attributes Front bezel material Front bezel colour Front bezel surface Mounting cut-out Dimensions Part No. With transparent silicone membrane Aluminium Nature anodised Ø 30.5 mm Ø 35 mm 14-955.3 Aluminium Black anodised 04 With transparent silicone membrane, resistant to sea water Stainless steel Nature 09 Ø 30.5 mm Ø 35 mm 14-955.4 Ø 30.5 mm Ø 35 mm 14-955.9E Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 14 17 18 Front bezel set mushroom head pushbutton Product attributes Front bezel material Front bezel colour Front bezel surface Mounting cut-out Part No. For front bezel set 24 mm x 30 mm, flush design Aluminium Nature anodised Ø 30.5 mm 14-958.8 Aluminium Black anodised Ø 30.5 mm 14-958.0 19 Additional information 22 • The colour of anodised aluminium parts can vary due to technical production reasons 31 41 45 51 56 57 61 70 71 82 84 92 96 324 eao.com § 11/2021 Components 14 01 Single-LED, T5.7 Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 6 V DC +10% 15 mA ±15 % 350 mcd 630 nm 10-2106.3142 33 12 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2109.1062 33 24 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2112.1062 33 28 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2113.1062 33 48 V AC/DC +10% 4 - 8 mA ±15 % 200 mcd 630 nm 10-2119.1042 33 6 V DC +10% 15 mA ±15 % 300 mcd 587 nm 10-2106.3144 33 12 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2109.1064 33 24 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2112.1064 33 28 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2113.1064 33 48 V AC/DC +10% 4 - 8 mA ±15 % 180 mcd 587 nm 10-2119.1044 33 6 V DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2106.3145 33 12 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2109.1065 33 24 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2112.1065 33 28 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2113.1065 33 48 V AC/DC +10% 2 - 4 mA ±15 % 600 mcd 525 nm 10-2119.1045 33 6 V DC +10% 15 mA ±15 % 680 mcd 470 nm 10-2106.3146 33 12 V AC/DC +10% 4 - 14 mA ±15 % 650 mcd 470 nm 10-2109.1066 33 24 V AC/DC +10% 7 - 14 mA ±15 % 650 mcd 470 nm 10-2112.1066 33 28 V AC/DC +10% 7 - 14 mA ±15 % 650 mcd 470 nm 10-2113.1066 33 48 V AC/DC +10% 4 - 8 mA ±15 % 400 mcd 470 nm 10-2119.1046 33 6 V DC +10% 6 mA ±15 % 900 mcd x: 0.31 / y: 0.32 nm 10-2106.3149 33 12 V AC/DC +10% 3 - 6 mA ±15 % 900 mcd x: 0.31 / y: 0.32 nm 10-2109.1069 33 24 V AC/DC +10% 2,5 - 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2112.1069 33 28 V AC/DC +10% 2,5 - 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2113.1069 33 48 V AC/DC +10% 2 - 4 mA ±15 % 600 mcd x: 0.31 / y: 0.32 nm 10-2119.1049 33 Yellow Green Blue White 02 03 04 09 14 17 18 19 22 31 41 Additional information • For LED element fitting information see Application guidelines, LED polarity • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) 45 • When using AC/DC types with AC operation, slight flickering can occur 51 • The luminous intensity stated is for when used with DC • Electrical and optical data are measured at 25 °C • The specified versions are built with a protection diode (halve wave rectifier) in series and the LED 56 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 57 • Where supply voltages are over 48 V, a voltage-reduction element (external protective series resistor) must be used. 61 30 max. 70 Ø6 max. + 71 82 84 Dimensions [mm] 92 96 11/2021 § eao.com 325 14 Components 01 Wiring diagrams 02 03 04 Wiring diagram 33 09 14 17 18 19 22 Filament lamp Operating voltage Operation current Part No. Wiring diagram 6 V AC/DC 200 mA 10-1106.1369 34 12 V AC/DC 100 mA 10-1109.1329 34 24 V AC/DC 50 mA 10-1112.1279 34 28 V AC/DC 40 mA 10-1113.1249 34 30 V AC/DC 40 mA 10-1114.1249 34 36 V AC/DC 35 mA 10-1116.1229 34 48 V AC/DC 25 mA 10-1119.1199 34 31max. Ø 5.4 max. 31 41 6.5max. 22max. 45 51 56 Dimensions [mm] Wiring diagrams 57 61 70 71 Wiring diagram 34 82 84 92 96 Anti-twist ring Material Mounting cut-out Part No. steel plate Ø 30 mm 704.954.0 326 eao.com § 11/2021 Accessories 14 Front side 01 02 03 04 Legend frame Product attributes Dimensions Material Colour Surface Mounting type Part No. For raised design 30 mm x 0.75 mm x 50 mm aluminium Black anodised adhesive 704.968.2 For flush design 35 mm x 0.75 mm x 57.5 mm aluminium Black anodised adhesive 704.968.3 09 14 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 0.75 4 14.5 18 0.75 19 Ø 30.6 40 57.5 4 14.5 23.5 Ø22.6 50 35 23.5 17 22 30 35 31 Dimensions [mm] for Part No. 704.968.2 Dimensions [mm] for Part No. 704.968.3 41 45 Legend plate 51 Dimensions Material Colour Surface Mounting type Part No. 14.5 mm x 23.5 mm aluminium Nature anodised adhesive 704.968.0 aluminium Black anodised adhesive 704.968.1 56 Additional information 57 • For legend frame Part No.704.968.2 and 704.968.3 • The colour of anodised aluminium parts can vary due to technical production reasons 61 70 71 82 84 92 96 11/2021 § eao.com 327 14 Accessories 01 Material Colour Mounting cut-out Part No. plastic Black Ø 22.3 mm 704.960.4 Ø 36 mm plastic Black Ø 30.5 mm 704.964.8 Additional information • Please note that bigger minimum distances are necessary 09 4.8 Ø 28 14 2.6 20 17 2.5 ... 6 14 Ø 35.6 04 Dimensions Ø 28 mm Ø 36.2 03 Blind plug Ø 30 02 2…6 18 19 Dimensions [mm] for Part No. 704.960.4 22 31 Dimensions [mm] for Part No. 704.964.8 Spare key Product attributes Part No. Standard lock KABA 1001 14-987.1001 41 45 51 56 57 Protective cap Product attributes Material Colour Optics Part No. Only together with lenses Part No. 704.602.X, 704.601.X and front rings Part No. 704.600.X silicone Colourless transparent 704.953.0 Additional information • For Indicator and Illuminated pushbutton for IP68 protection 61 70 71 Protective ring Product attributes With transparent Pebax membrane, temperature resistance -40 °C … +85 °C 82 84 Material With transparent silicone membrane (resistant to sea brass water), temperature resistance -40 °C … +85 °C aluminium aluminium Colour Surface Part No. chrome 704.600.2 Nature anodised 704.600.3 Nature anodised 704.600.5/A Additional information • For Illuminated pushbutton for front protection IP 67 • The colour of anodised aluminium parts can vary due to technical production reasons 92 96 328 eao.com § 11/2021 Accessories 14 01 Protective cover raised design Product attributes Material Optics 02 Part No. For pushbutton plastic transparent 704.925.0 For pushbutton, with spring fitted plastic transparent 704.925.3 For selector switch plastic transparent 704.925.2 03 04 Additional information • Hinged, with means for sealing 44 09 30 44 14 18 37 1.5 17 3 20 18 Dimensions [mm] 19 22 Protective cover flush design 31 Product attributes Dimensions Material Colour With means for sealing, for pushbutton with mounting cut-outs Ø 30.5 mm 37 mm x 44.5 mm plastic Colourless Surface Part No. Without cover locking hole, with spring fitted, with win-dow, for pushbuttonwith mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.18 Without cover locking hole, for pushbutton and selector switch short lever with mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.28 With means for sealing, for pushbutton and selector switch short lever with mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.38 704.925.7 41 45 51 56 Additional information 57 • Hinged • Front panel thickness reduces by 2 mm • Please note that bigger minimum distances are necessary 61 • The colour of anodised aluminium parts can vary due to technical production reasons 44.5 52 37 38 58 70 38 9.5 50 82 24.5 24.5 54 50 44 44.5 22.5 71 9 19 84 Dimensions [mm] for Part No. 704.925.7 Dimensions [mm] for Part No. 704.928.18 92 Dimensions [mm] for Part No. 704.928.28, 704.928.38 96 11/2021 § eao.com 329 14 Accessories 01 Rear side 02 03 04 Flat receptacle Product attributes Material Part No. 2.0 x 0.5 mm plug-in terminal metal 31-945 2.8 x 0.8 mm plug-in terminal metal 31-946 Product attributes Material Part No. For flat receptacle 2.0 mm plastic 31-928 For flat receptacle 2.8 mm plastic 31-929 Cover plug-in terminals for snap-action switching element 2.8 mm plastic 01-928 Product attributes Material Part No. For snap-action switching element plastic 01-929 Product attributes Dimensions Part No. 5 spaces 62.5 mm x 15 mm x 60 mm 02-912.1 10 spaces 125 mm x 15 mm x 60 mm 02-912.2 15 spaces 187.6 mm x 15 mm x 60 mm 02-912.3 20 spaces 250 mm x 15 mm x 60 mm 02-912.4 09 Insulation sleeve 14 17 18 Terminal cover 19 22 31 41 45 Side terminal plate empty 51 56 57 61 70 PCB plug-in base Component Layout Product attributes Terminal Pins Part No. For low level switching element PCB terminal Axial 31-940 3 PCB terminal 90° angled 31-941 2 PCB terminal Axial 31-942 4 For snap-action switching element 2.8 mm Additional information • PCB plug-in base pins right-angle: With the extendable mounting the distance between plug-in base and PCB can be varied up to 3 mm 71 9.8 2 9.6 3 4 9.8 1.5 17.8 17.9 82 84 Ø16.4 4 6.2 17.9 12.9 4 92 96 Dimensions [mm] for Part No. 31-940 330 Dimensions [mm] for Part No. 31-941 Dimensions [mm] for Part No. 31-942 eao.com § 11/2021 Accessories 14 Component layouts 01 02 A B C 03 17.9 31 31 a b a 24 14 4 9 42 09 9 b 04 17.9 17.9 17.9 9.6 17 3 b F 4 3 1 2 a b 2 3 1 4 a 18 D Ø1.0 (4x) 19 15.24 Ø1.0 (6x) 1.27 5 x 2.54 1.27 1.27 0.85 1.27 22 7.62 E 31 Component layout 2 41 Dimensions [mm] A = Socket 90° angled B = Occupancy plan (component side) C = Diode block D = Drilling plan (component side) E = Non-metallic F = Extendable mounting pins 45 51 A 56 B C 57 7.62 7.62 Ø1.0 (6x) 12.7 2 4 a D b E Ø2.1 (1x) 3 1 5.08 1 10.16 3 5.08 4 2 Ø2.1 (1x) Ø1.0 (1x) b E 70 10.16 Ø1.0 (1x) 61 Ø1.0 (6x) a 71 12.7 82 D Component layout 3 84 Dimensions [mm] A = Axial socket B = Drilling-/occupancy plan (component side) C = Diode block D = For central mounting with M2 screw, if desired E = Non-metallic 92 96 11/2021 § eao.com ​ 331 14 Accessories 01 02 Component layouts A B 03 7.62 Ø1.0 04 3 4 7.62 2 1 10.16 7.62 09 C b a 14 Ø1.0 (6x) Ø2.1 D 17 18 Component layout 4 Dimensions [mm] A = Axial socket B = Drilling-/occupancy plan (component side) C = Non-metallic D = For central mounting with M2 screw, if desired 19 22 31 41 45 51 Series resistor Operating voltage Resistance Part No. 110 V AC 2.7 kOhm 02-904.0 125 V AC 3.3 kOhm 02-904.1 145 V AC 4.7 kOhm 02-904.3 240 V AC 10 kOhm 02-904.7 Additional information • Only for filament lamp 48 VAC, 25 mA • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) 56 57 61 70 71 82 84 92 96 332 eao.com § 11/2021 Accessories 14 Mounting 01 02 03 Enclosure Product attributes Dimensions Material Colour IP Protection Part No. With mounting cut-out 1 x Ø 22.5 mm, with anti-twist device 94 mm x 81 mm x 94 mm plastic Grey IP66 704.945.1 With mounting cut-out 2 x Ø 22.3 mm, with anti-twist device 130 mm x 81 mm x 94 mm plastic Grey IP66 704.945.2 With mounting cut-out 3 x Ø 22.3 mm, with anti-twist device 180 mm x 81 mm x 94 mm plastic Grey IP66 704.945.3 With mounting cut-out 4 x Ø 22.3 mm, with anti-twist device 180 mm x 110 mm x 182 mm plastic Grey IP66 704.945.4 With mounting cut-out 6 x Ø 22.3 mm, with anti-twist device 180 mm x 110 mm x 182 mm plastic Grey IP66 704.945.5 09 14 17 B 2.5 18 L H 04 19 22 31 Dimensions [mm] 41 45 Cable gland Product attributes Material Colour IP Protection Thread Part No. With traction relief plastic Grey IP68 M16 x 1.5 mm 61-9481.6 plastic Grey IP68 M20 x 1.5 mm 704.945.6 51 56 Lens plug Product attributes Material Part No. For mounting and dismantling of the round lens, flush design plastic 700.006.0 57 61 70 Lamp remover Material Part No. Plastic 02-906 71 82 Additional information • A switching action may occur when replacing the lamp 84 92 Positioning insert for anti-twist ring Material Part No. Plastic 14-910 11/2021 § eao.com 96 333 14 Accessories 01 02 Reducing ring Material Colour Surface Part No. 03 Aluminium Black anodised 704.960.0 Nature anodised 704.960.8 04 Additional information • Devices Ø 22.3 mm in mounting cut-out Ø 30.5 mm • The colour of anodised aluminium parts can vary due to technical production reasons 14 Ø 30.4 17 Ø22.6 2 Ø 35 09 18 2.8 19 Dimensions [mm] 22 31 41 45 51 56 57 61 70 71 82 84 92 96 334 eao.com § 11/2021 Technical data 14 Actuator with snap-action switching element Switching system 01 02 Actuating travel Illuminated pushbutton approx. 3 mm Self-cleaning, double-break, snap action switching system (with contact gap 2 mm x 0.5 mm). 1 normally closed or 1 normally open contact per element. Snap-action switching elements with soldering terminals at the sides: up to 4 switching element can be on a pushbutton (max. 4 normally closed and 4 normally open contacts). Snap-action switching element with axial plug-in terminals 2.8 mm stackable, only 1 switching element can be on a pushbutton. 03 Switch actuator 2 positions Momentary action 1 x ca. 42° deflection Maintained action 1 x ca. 90° deflection 04 Mechanical lifetime Momentary action Maintained action 09 2 million cycles of operation 1 million cycles of operation 14 Electrical characteristics 17 Standards Material The devices comply with EN IEC 61058-1 Material of contact Rated voltage Gold plated silver 250 VAC as per EN IEC 61058-1 Switch housing Rated current Plug-in-/soldering terminal Plastic Heat-resistant and self-extinguishing Soldering terminal Plastic 5A 18 19 22 Electrostatic discharge (ESD) 31 Keylock switch 15 kV Actuator housing Plastic Thermal current Ith 41 5A Mechanical characteristics Terminals Snap-action switching element with tinned soldering terminals at the sides: Max. wire diameter 2 wires à 1.2 mm Max. wire cross-section of stranded cable 1 x 1 mm² Switching voltage and switching current 45 250 VAC, 5 A (ohmic) 250 VAC, 2 A (inductive, cos(phi) = 0.7) 220 VDC, 0.1 A (inductive, L:R = 30 ms) 110 VDC, 0.2 A (inductive, L:R = 30 ms) 60 VDC, 0.7 A (inductive, L:R = 30 ms) 24 VDC, 2 A (inductive, L:R = 30 ms) Snap-action switching element with axial plug-in terminals, which can also be used as soldering terminals: Plug-in terminal 2.8 mm x 0.5 mm Electric strength Soldering terminal: Max. wire diameter 2 wires of 1 mm Max. wire cross-section of stranded cable 2 x 0.75 mm² or 1 x 1.0 mm² Protection class 51 56 57 3000 VAC, 50 Hz, 1 minute between all terminals and earth, as per EN IEC 61058-1 61 II 70 Electrical life 50 000 cycles of operation 71 Tightening torque For fixing nut max. 0.25 Nm Ambient conditions 82 Actuating torque 0.025 Nm … 0.055 Nm, depending on the number of switching elements, measured at the key or lever of the keylock- or selector switch Actuating force Maintain 5 N … 8 N Momentary 3 N … 6 N depending on the number of switching elements 11/2021 § eao.com Storage temperature – 40 °C … + 85 °C 84 Service temperature 92 – 25 °C … +55 °C For indicators and illuminated pushbuttons mounted as a block, make sure the heat can escape freely. ​ 96 335 14 Technical data 01 02 03 04 09 14 Protection degree Climate resistance As per DIN EN 60529 IP67 front side, Indicator IP67 front side, Illuminated pushbutton IP67 front side, Mushroom-head pushbutton IP67 front side, Selector switch IP65 front side, Keylock switch Damp heat state as per DIN EN 60068-2-78 Damp heat cyclic as per DIN EN 60068-2-30 Approvals Approbations Vibration resistance CB (IEC 61058-1) CSA CQC ENEC (EN 61058-1) DNV GL (previously Germanischer Lloyd) UL (sinusoidal) Max. 100 m / s² at 10 Hz … 500 Hz, as per DIN EN 60068-2-6 Conformities Shock resistance (semi-sinusoidal) Max. 150 m /s², pulse width 11 ms, 3-axis, as per DIN EN 60068-2-27 CE 2014 / 35 / EC (LVD) 2011 / 65 / EC (RoHS) 17 18 19 Actuator with low level switching element 22 Switching system 31 This low level switching element was designed for switching low powers in electronic circuits. The mechanism assures reliable switching of loads ranging from a few μA/μV up to 100 mA/ 42 VAC/DC. 41 45 51 Single-break momentary contact, as normally open or normally closed with 4 independent points of contact. 2 momentary contacts per switching element; combination of normally open and normally closed is possible. Special features are the long life, extremely short rebound time and stable contact resistance. For these terminals we can also supply a plug-in base which, when soldered on to the board, enables the switch to be plugged in. Soldering terminal Max. wire diameter 2 wires of 1 mm Max. wire cross-section of stranded cable 2 x 0.75 mm² Plug-in terminal 2.0 mm x 0.5 mm Tightening torque For fixing nut max. 0.25 Nm Actuating torque 56 57 Material Material of contact 0.025 Nm … 0.055 Nm, depending on the number of switching elements, measured at the key or lever of the keylock- or selector switch Gold plated Actuating force 61 Switch housing 70 Actuator housing 3 … 4 N, depending on the number of switching elements Plastic, heat-resistant and self-extinguishing Actuating travel 71 82 84 Illuminated pushbutton: approx. 3 mm Plastic Mechanical characteristics Switch actuator 2 positions Momentary action 1 x ca. 42° deflection momentary action Maintained action 1 x ca. 90° deflection maintained action Terminals Mechanical lifetime The universal terminals permit these units to be mounted on printed circuit boards (PCB). These terminals can also be used as soldering or plug-in terminals. Momentary action 5 million cycles of operation Maintained action 1 million cycles of operation 92 96 336 ​ eao.com § 11/2021 Technical data Electrical characteristics Protection degree 100 mA at 42 VAC / VDC As per EN IEC 60529 IP67 front side, Indicator IP67 front side, Illuminated pushbutton IP67 front side, Mushroom-head pushbutton IP67 front side, Selector switch IP65 front side, Keylock switch Electric strength Shock resistance 3000 VAC, 50 Hz, 1 min. between all terminals and earth, as per EN IEC 61058-1-15 (semi-sinusoidal) Max. 150 m /s², pulse width 11 ms, 3-axis, as per DIN EN 60068-2-27 Electrostatic discharge (ESD) Keylock switch 15 kV Switching voltage and switching current 14 01 02 03 04 09 Protection class II 14 Approvals Ambient conditions Conformities Storage temperature 2014 / 35 / EC (LVD) 2011 / 65 / EC (RoHS) 17 – 40 °C … + 85 °C 18 Service temperature 19 – 25 °C … + 55 °C For indicators and illuminated pushbuttons mounted as a block, make sure the heat can escape freely. 22 31 Buzzer Buzzer Acoustic characteristics System Frequency (tone) Piezo disc Approx. 3.2 kHz continuous tone only 41 45 51 Sound pressure Material 95 db (A) ± 8 dB at a distance of 0.1 m 56 Buzzer case Plastic Electrical characteristics Front cap Operation Voltage/Current Flush design Aluminium black anodised Aluminium natural anodised Operation Voltage Operation Current Raised design Plastic Metal = nickel-plated brass (sea-water proof) Ambient conditions 57 24 VDC ±10 % ≤ 25 mA 61 70 71 Storage temperature – 40 °C … + 85 °C Mechanical characteristics 82 Operating temperature – 25 °C … + 55 °C 84 Terminals Plug-in terminal 2.8 mm x 0. 5 mm Protection degree Tightening torque As per EN IEC 60529 IP65 front side, Buzzer 92 For fixing nut max. 0.25 Nm 96 11/2021 § eao.com ​ 337 14 Technical data 01 Approvals Approbations 02 CQC EMC 03 Conformities 04 CE 2014 / 30 / EC (EMC) 2011 / 65 / EC (RoHS) 09 14 17 18 Indicator compact Material Electrical characteristics Lens cap Operation Voltage Plastic 24 VAC / DC (14…32 VAC / DC) Housing Operating current 19 Plastic < 50 mA 22 Mechanical characteristics 31 Iifetime 50 000 h Terminals PIT push-in terminal Skinning 8 mm Wire cross-section: Wire 0.2 to 1.0 mm² Stranded wire 0.2 to 1.0 mm² without core and sleeve Stranded wire 0.2 to 0.75 mm² with core and sleeve Ambient conditions 51 Tightening torque For fixing nut min. 0.8 Nm Rapid temperature changes 5 cycles, – 40 °C to + 85 °C, as per EN 60068-2-14 56 Protection degree Operating temperature As per EN IEC 60529 IP65, IP67, IP69K front side IP20 rear side – 25 °C … + 60 °C 41 45 57 Climatic conditions Damp heat, constant 56 days, + 40 °C / 93 % relative humidity as per EN 60068-2-78 Storage temperature – 40 °C … + 85 °C 61 70 71 Shock resistance (semi-sinusoidal) Max. 300 m / s², puls width 18 ms, as per EN IEC 60068-2-27 Approvals Vibration resistance Approbations (sinusoidal) Max. 100 m / s² at 10 Hz … 500 Hz, as per EN IEC 60068-2-6 UL Declaration of conformity CE 82 84 EAO reserves the right to alter specifications without further notice. 92 96 338 ​ eao.com § 11/2021 Marking 14 General notes 01 1. Engraving 2. Hot stamping In addition to the most commonly used world languages, in DIN1451-3 close spacing, other typefaces are available as Scandinavian, Slavic, Greek, Russian and Polish. Red, blue and black lenses are filled with white colour. Other colour lenses are filled in black. Standard height of letters is 3 mm. If the height is not specified, we will supply 3 mm engraved letters. For larger series it is worth considering markings by means of hot stamping. We will pleased to advise you. For letters and figures, typefaces with 2.5 mm, 3 mm and 4 mm are available. 09 14 All dimensions in mm Height of letters h Text cap (Ø 23) B1 03 04 Engraving marking cap for Indicator round, full face illumination Height of text cap 02 Number of lines Number of capital letters per line (guide value) Number of lowercase letters per line (guide value) 3 3 8-9 9-10 B1 4 3 5-7 6-8 B1 8 3 – – B1 3 2 8 9 B2 4 2 5 6 B2 8 2 2 2 B2 3 1 9 10 B3 4 1 7 8 B3 8 1 3 3-4 B3 B2 17 Picture 18 19 22 31 41 B3 23 h 45 h h 51 56 The gap between two words results in each case a letter less. 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 339 14 Marking 01 Engraving marking plate for Indicator and illuminated Pushbutton round, front illumination All dimensions in mm 02 03 Height of marking plate Height of letters h Marking plate (Ø 20) Number of lines Number of capital letters per line (guide value) Number of lowercase letters per line (guide value) Picture 3 3 6-8 7-9 B1 4 3 5-6 6-7 B1 04 8 3 – – B1 3 2 6 7 B2 09 4 2 5 6 B2 8 2 1 2 B2 3 1 8 9 B3 14 4 1 6 7 B3 8 1 3 3 B3 Number of lowercase letters per line (guide value) Picture 11 B1 17 B1 18 B2 B3 20 22 h h h 19 The gap between two words results in each case a letter less. 31 41 Engraving diffusor cap for Indicator square, full face illumination All dimensions in mm 45 Dimension style Height of letters Number of lines Number of capital letters per line (guide value) 51 30 x 50 round, raised 3 2 10 30 x 50 round, raised 4 1 7 8 B1 56 30 x 50 round, raised 8 1 3 4 B1 Devices mounting 57 35 x 57.5 round, flush 3 2 10 11 B2 35 x 57.5 round, flush 4 1 7 8 B2 35 x 57.5 round, flush 8 1 3 4 B2 B1 B2 h 61 71 35 30 82 84 Ø30.5 Ø25 50 57.5 70 The gap between two words results in each case a letter less. 92 96 340 ​ eao.com § 11/2021 Marking 14 Standard texts for marking plates and marking caps for Indicator and Illuminated Pushbutton 01 Height of letters 6 mm I Part No. 704.609.912001 II Part No. 704.609.912002 III Part No. 704.609.912003 O Part No. 704.609.912004 02 03 EIN Part No. 704.609.912005 AUS Part No. 704.609.912006 AUF Part No. 704.609.912007 AB Part No. 704.609.912008 04 START Part No. 704.609.912009 STOP Part No. 704.609.912010 HAND Part No. 704.609.912011 AUTO Part No. 704.609.912012 ZU Part No. 704.609.912013 ON Part No. 704.609.912014 OFF Part No. 704.609.912015 ARRET Part No. 704.609.912016 MARCHE Part No. 704.609.912017 RESET 09 14 17 Part No. 704.609.912018 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 11/2021 § eao.com ​ 341 14 Marking 01 Symbols for marking plates and marking caps for Indicator and Illuminated Pushbutton All marking plates with the printed article-numbers are available for flat lenses, marking cap only on request. 02 03 04 Part No. 704.609.910001 Direction of linear rectilinear motion (also for ) Part No. 704.609.910002 Linear motion in 2 directions (also for ) Part No. 704.609.910004 Limited linear motion (also for ) Part No. 704.609.910007 Direction of continuous rotation (right) Part No. 704.609.9100071 Direction of continuous rotation (left) Part No. 704.609.910008 Rotation in 2 directions Part No. 704.609.910009 Direction of interrupted rotation (right) Part No. 704.609.910010 Limited rotation (right) Part No. 704.609.9100101 Limited rotation (left) Part No. 704.609.910013 Direction of spindle rotation Part No. 704.609.910026 Rapid traverse Part No. 704.609.910028 Increase of value (speed, for instance) Part No. 704.609.910029 Decrease of value (speed, for instance) Part No. 704.609.910041 Electric motor Part No. 704.609.910048 Pump (general symbol) Part No. 704.609.9100631 Lock or tighten Part No. 704.609.9100632 Lock or tighten Part No. 704.609.9100641 Unlock, unclamp Part No. 704.609.9100642 Unlock, unclamp Part No. 704.609.910065 Brake on Part No. 704.609.910066 Brake off Part No. 704.609.910067 Automatic (or semi-automatic) cycle Part No. 704.609.910068 Hand control Part No. 704.609.910069 Start, on Part No. 704.609.910070 Stop, off Part No. 704.609.910071 Start and stop with same button Part No. 704.609.910072 In action as long as button is operated Part No. 704.609.910074 Engaging (mechanical start) Part No. 704.609.910075 Disengaging (mechanical stop) Part No. 704.609.910092 Danger (high voltage)! Part No. 704.609.910093 Caution! Part No. 704.609.910101 Coolant fluid Part No. 704.609.910102 Machine lighting Part No. 704.609.910108 Blast 09 14 17 18 19 22 31 41 45 51 56 ! 57 61 70 71 82 84 92 96 342 ​ eao.com § 11/2021 Application guidelines 14 Suppressor circuits 01 When switching inductive loads such as relays, DC motors, and DC solenoids, it is always important to absorb surges (e. g. with a diode) to protect the contacts. When these inductive loads are switched off, a counter emf can severely damage switch contacts and greatly shorten lifetime. Fig. 1 shows an inductive load with a free-wheeling diode connected in parallel. This free-wheeling diode provides a path for the inductor current to flow when the current is interrupted by the switch. Without this free-wheeling diode, the voltage across the coil will be limited only by dielectric breakdown voltages of the circuit or parasitic elements of the coil. This voltage can be kilo- volts in amplitude even when nominal circuit voltages are low (e. g. 12 VDC) see Fig. 2. The free-wheeling diode should be chosen so that the reverse breakdown voltage is greater than the voltage driving the inductive load. The DC blocking voltage (VR) of the free-wheeling diode can be found in the datasheet of a diode. The forward current should be equal or greater than the maximum current flowing through the load. To get an efficient protection, the free-wheeling diode must be connected as close as possible to the inductive load! Counter EMF over load without free-wheeling diode Fig. 2 Switching with inductive load Fig. 1 02 03 04 09 14 17 18 Switch ON OFF 19 0 VDC + _ Free-wheeling diode Inductive load Several hundred to several thousend volts 22 di __ e = L dt 31 41 LED polarity 45 When fitting the LED element the polarity has to correspond with the respective terminal, (+) goes to +. 51 56 + (x2 +) ( b+) (b+) (b+) 57 A B C D 61 A = Solder terminal B = Plug-in terminal 2.8 mm x 0.5 mm C = Universal terminal 2.0 mm x 0.5 mm D = Universal/Solder terminal 70 71 82 84 92 96 11/2021 § eao.com ​ 343
14-507.0250 价格&库存
很抱歉,暂时无法提供与“14-507.0250”相匹配的价格&库存,您可以联系我们找货
