ES
Miniature Slide Switches
RoHS Compliant
■Part Numbering
ES
1
15
●Series code
A
12
Z
●Current
●Number of poles
1
1 pole
2
2 poles
●Switching function
1 pole 2 poles Switching function
A
D
E
N
P
OFF
ON
ON
ON
●Terminal styles
None
ON−OFF−ON
#250
Tab terminal
10
Screw terminal
12
Solder terminal
■Terminal Styles
TAB#250
(Style:−)
■Panel Cut-Out Dimensions
Screw
(Style:10)
M4.5
●ES115・125 type
Solder
(Style:12)
●ES215・225 type
ES125 Type
(25A Type)
ES115
1−pole
Dimension L
Switches with switching function “A” do not have terminal No. 2.
Part No.
Terminal
style
ES115A■−Z
ES115D■−Z
ES115E■−Z
Switching function
TAB
Screw
Solder
25.2±1
22.3±1
25.7±1
22.8±1
Viewed from part No. marking side
Part No.
Terminal numbers are shown on the bottom of the switch.
■Specifications
Rating
ES115A■−Z AC125V 15A
ES115D■−Z AC250V 15A
Initial contact resistance
20mΩ Max.
AC125V 15A (DC2〜4V 100mA)
ES115E■−Z AC250V 7A
Dielectric strength Insulation resistance
AC1500V
minute
100MΩ Min.
(DC500V)
Electrical life
20,000
cycles
ES115A■−Z
OFF
ON
Connecting terminals
1−3
ES115D■−Z
ES115E■−Z
ON
ON
OFF
ON
ON
2−1
2−3
To check the full part number of the products marked with
the ■, please refer to “Table of Part Numbers”.
ES
ES125
Dimension L
1−pole
Part No.
Terminal
style
ES125A■−Z
ES125D■−Z
TAB
Screw
Solder
25.2±1
26.4±1
22.3±1
Switching function
Part No.
■Specifications
Rating
20mΩ Max.
ES125A■−Z AC125V 25A
ES125D■−Z AC250V 25A (DC2〜4V 100mA)
ES215
AC1500V
minute
Electrical life
100MΩ Min.
(DC500V)
ES125A■−Z
OFF
ON
1−3
ES125D■−Z
ON
ON
2−1
2−3
20,000
cycles
Dimension L
2−poles
Part No.
Terminal
style
ES215N■−Z
ES215P■−Z
TAB
Screw
Solder
29.3±1
27.1±1
26.4±1
Switching function
Part No.
ES215N■−Z
ES215P■−Z
■Specifications
Rating
ON
ON
2−1
5−4
Electrical life
OFF
ON
ON
2−3
5−6
AC125V 15A
ES215N■−Z AC250V 15A
ES215P■−Z
ES225
20mΩ Max.
AC250V 7A
AC1500V
minute
100MΩ Min.
(DC500V)
20,000
cycles
Dimension L
2−poles
Part No.
Terminal
style
ES225N■−Z
Switching function
TAB
Screw
Solder
29.3±1
30.6±1
26.4±1
Part No.
ES225N■−Z
■Specifications
AC125V 25A
20mΩ Max.
ES225N■−Z AC250V 25A
(DC2〜4V 100mA)
AC1500V
minute
■ indicates the terminal style number (“None”, “10”, or “12.”).
100MΩ Min.
(DC500V)
ON
2−3
5−6
Rating
ON
2−1
5−4
Electrical life
20,000
cycles
ES
■Table of Part Numbers
Series
ES
(15A用)
ES
(25A用)
Switching function
OFF − ON
ON − ON
ON−OFF−ON
OFF − ON
ON − ON
★:Made to order products.
TAB terminals
1−pole
★ ES115A−Z
★ ES115D−Z
★ ES115E−Z
2−poles
ES215N−Z
★ ES215P−Z
Screw terminls
1−pole
★ ES125A10−Z
Solder terminals
1−pole
★ ES115A12−Z
★ ES115D12−Z
★ ES125A12−Z
★ ES125D12−Z
2−poles
★ ES225N12−Z
■Shorting (Make-Before-Break)
A switch which momentarily connects both circuits
when the actuator is moved from Point A to B in the
below figure.
All switches which are not marked as “Shorting” are
“Non-shorting” (Break-Before-Make).
Shorting
Non-shorting
〔Fig.1〕
很抱歉,暂时无法提供与“ES 115D12-Z”相匹配的价格&库存,您可以联系我们找货
