ES 115D-Z
ES 115D-Z
    NIDEC(尼得科)
    插件
    滑动开关 插件
ES 115D-Z 数据手册
ES Miniature Slide Switches RoHS Compliant ■Part Numbering ES 1 15 ●Series code A 12 − Z ●Current ●Number of poles 1 1 pole 2 2 poles ●Switching function 1 pole 2 poles Switching function A D E − N P OFF − ON ON − ON ●Terminal styles None ON−OFF−ON #250 Tab terminal 10 Screw terminal 12 Solder terminal ■Terminal Styles TAB#250 (Style:−) ■Panel Cut-Out Dimensions Screw (Style:10) M4.5 ●ES115・125 type Solder (Style:12) ●ES215・225 type ES125 Type (25A Type) ES115 1−pole Dimension L Switches with switching function “A” do not have terminal No. 2. Part No. Terminal style ES115A■−Z ES115D■−Z ES115E■−Z Switching function TAB Screw Solder 25.2±1 − 22.3±1 25.7±1 − 22.8±1 Viewed from part No. marking side Part No. Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ES115A■−Z AC125V 15A ES115D■−Z AC250V 15A Initial contact resistance 20mΩ Max. AC125V 15A (DC2〜4V 100mA) ES115E■−Z AC250V 7A Dielectric strength Insulation resistance AC1500V minute 100MΩ Min. (DC500V) Electrical life 20,000 cycles ES115A■−Z OFF − ON Connecting terminals − − 1−3 ES115D■−Z ES115E■−Z ON ON − OFF ON ON Connecting terminals 2−1 − 2−3 To check the full part number of the products marked with the ■, please refer to “Table of Part Numbers”. ES ES125 Dimension L 1−pole Switches with switching function “A” do not have terminal No. 2. Part No. Terminal style ES125A■−Z ES125D■−Z TAB Screw Solder 25.2±1 26.4±1 22.3±1 Switching function Viewed from part No. marking side Part No. Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance 20mΩ Max. ES125A■−Z AC125V 25A ES125D■−Z AC250V 25A (DC2〜4V 100mA) ES215 Dielectric strength Insulation resistance AC1500V minute Electrical life 100MΩ Min. (DC500V) ES125A■−Z OFF − ON Connecting terminals − − 1−3 ES125D■−Z ON − ON Connecting terminals 2−1 − 2−3 To check the full part number of the products marked with the ■, please refer to “Table of Part Numbers”. 20,000 cycles Dimension L 2−poles Part No. Terminal style ES215N■−Z ES215P■−Z TAB Screw Solder 29.3±1 27.1±1 − 26.4±1 Switching function Viewed from part No. marking side Part No. ES215N■−Z ES215P■−Z ■Specifications Rating Connecting terminals Terminal numbers are shown on the bottom of the switch. Initial contact resistance Dielectric strength Insulation resistance ON ON 2−1 5−4 Electrical life − OFF − ON ON 2−3 5−6 To check the full part number of the products marked with the ■, please refer to “Table of Part Numbers”. AC125V 15A ES215N■−Z AC250V 15A ES215P■−Z ES225 20mΩ Max. AC125V 15A (DC2〜4V 100mA) AC250V 7A AC1500V minute 100MΩ Min. (DC500V) 20,000 cycles Dimension L 2−poles Part No. Terminal style ES225N■−Z Switching function TAB Screw Solder 29.3±1 30.6±1 26.4±1 Viewed from part No. marking side Part No. ES225N■−Z Connecting terminals ■Specifications AC125V 25A Initial contact resistance 20mΩ Max. ES225N■−Z AC250V 25A (DC2〜4V 100mA) Dielectric strength Insulation resistance AC1500V minute ■ indicates the terminal style number (“None”, “10”, or “12.”). 100MΩ Min. (DC500V) − − ON 2−3 5−6 To check the full part number of the products marked with the ■, please refer to “Table of Part Numbers”. Terminal numbers are shown on the bottom of the switch. Rating ON 2−1 5−4 Electrical life 20,000 cycles ES ■Table of Part Numbers Series ES (15A用) ES (25A用) Switching function OFF −  ON ON  −  ON ON−OFF−ON OFF −  ON ON  −  ON ★:Made to order products. TAB terminals 1−pole ★ ES115A−Z ★ ES115D−Z ★ ES115E−Z − − 2−poles −   ES215N−Z ★ ES215P−Z − − Screw terminls 1−pole − − − ★ ES125A10−Z − Solder terminals 1−pole ★ ES115A12−Z ★ ES115D12−Z − ★ ES125A12−Z ★ ES125D12−Z 2−poles − − − − ★ ES225N12−Z ■Shorting (Make-Before-Break) A switch which momentarily connects both circuits when the actuator is moved from Point A to B in the below figure. All switches which are not marked as “Shorting” are “Non-shorting” (Break-Before-Make). Shorting Non-shorting 〔Fig.1〕
ES 115D-Z 价格&库存
很抱歉,暂时无法提供与“ES 115D-Z”相匹配的价格&库存,您可以联系我们找货
ES 115D-Z
    • 1+86.05440
    • 200+33.30720
    • 500+32.14080
    • 1000+31.55760
