F310R-12LC
F310R-12LC
    NIDEC(尼得科)
    DC风扇 AXIAL 30X10MM 12VDC WIRE
F310R-12LC 数据手册
F310R BRUSHLESS DC FANS ■ FEATURES RoHS compliant ● Low noise, 13 dB (A) ● Light weight (approx. 8 g) ■ STRUCTURE ● Frame and impeller ABS/PBT alloy ● Bearing 1 sleeve bearing ■ PART NUMBER DESIGNATION F310R - 12 L C Series name Bearing 1 sleeve bearing Power supply 05:DC5 V 12:DC12 V Air flow L:0.09 m3/min LL:0.06 m3/min ■ LIST OF PART NUMBERS Power supply 1 sleeve bearing Air flow 0.09 m3/min Air flow 0.06 m3/min DC5 V F310R-05LC F310R-05LLC DC12 V F310R-12LC F310R-12LLC ※ Verify the above part numbers when placing orders. F310R BRUSHLESS DC FANS ■ STANDARD SPECIFICATIONS Item F310R-05LLC F310R-05LC F310R-12LLC F310R-12LC Rated voltage DC5 V DC12 V Voltage range 4.5 ~ 5.7 V 10.2 ~ 13.8 V Rated current 0.06 A 0.09 A 0.04 A 0.05 A Rotating speed 5500 min-1 7000 min-1 5500 min-1 7000 min-1 0.06 m3/min 0.09 m3/min 0.06 m3/min 0.09 m3/min 14 Pa 23 Pa 14 Pa 23 Pa 13 dB (A) 17 dB (A) 13 dB (A) 17 dB (A) Air flow Static pressure Noise Use environment –10 ~ +60 °C (35 ~ 85 %RH) Storage environment –20 ~ +70 °C (35 ~ 85 %RH) Net weight Approx. 8 g ※ The specifications above are typical values measured on the conditions of no-loading running with rated voltage in the circumstances of 25 °C ± 2 °C, 35~ 85 %RH. Please contact us if you would liketo check the specifications in different circumstances. ■ AIR FLOW PERFORMANCE CURVES 30 Static pressure (Pa) 25 F310R-05LC -12LC 20 15 10 F310R-05LLC -12LLC 5 0 0 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1 3 Air flow (m /min) (Unit: mm) Lead wire : UL1061 AWG28 Red : VOLTAGE Black : GND Dimension of mounting hole for recommendation 10 ± 0.5 24 ± 0.5 4 – φ 3.2 Air flow .6 φ 24 ± 0.5 □30 ± 0.5 4 – C2.3 28 24 ± 0.5 24 ± 0.5 150 ± 20 ■ OUTLINE DIMENSIONS 4 – φ 3.2
F310R-12LC 价格&库存
很抱歉,暂时无法提供与“F310R-12LC”相匹配的价格&库存,您可以联系我们找货
