F310R
BRUSHLESS DC FANS
■ FEATURES
RoHS compliant
● Low noise, 13 dB (A)
● Light weight (approx. 8 g)
■ STRUCTURE
● Frame and impeller
ABS/PBT alloy
● Bearing
1 sleeve bearing
■ PART NUMBER DESIGNATION
F310R - 12 L C
Series name
Bearing
1 sleeve bearing
Power supply
05:DC5 V
12:DC12 V
Air flow
L:0.09 m3/min
LL:0.06 m3/min
■ LIST OF PART NUMBERS
Power supply
1 sleeve bearing
Air flow 0.09 m3/min
Air flow 0.06 m3/min
DC5 V
F310R-05LC
F310R-05LLC
DC12 V
F310R-12LC
F310R-12LLC
※ Verify the above part numbers when placing orders.
F310R
BRUSHLESS DC FANS
■ STANDARD SPECIFICATIONS
Item
F310R-05LLC
F310R-05LC
F310R-12LLC
F310R-12LC
Rated voltage
DC5 V
DC12 V
Voltage range
4.5 ~ 5.7 V
10.2 ~ 13.8 V
Rated current
0.06 A
0.09 A
0.04 A
0.05 A
Rotating speed
5500 min-1
7000 min-1
5500 min-1
7000 min-1
0.06 m3/min
0.09 m3/min
0.06 m3/min
0.09 m3/min
14 Pa
23 Pa
14 Pa
23 Pa
13 dB (A)
17 dB (A)
13 dB (A)
17 dB (A)
Air flow
Static pressure
Noise
Use environment
–10 ~ +60 °C (35 ~ 85 %RH)
Storage environment
–20 ~ +70 °C (35 ~ 85 %RH)
Net weight
Approx. 8 g
※ The specifications above are typical values measured on the
conditions of no-loading running with rated voltage in the
circumstances of 25 °C ± 2 °C, 35~ 85 %RH. Please contact us if you
would liketo check the specifications in different circumstances.
■ AIR FLOW PERFORMANCE CURVES
30
Static pressure (Pa)
25
F310R-05LC
-12LC
10
F310R-05LLC
-12LLC
5
0.02
0.03
0.04
0.05
0.06
0.07
0.08
0.09
0.1
3
Air flow (m /min)
(Unit: mm)
Lead wire : UL1061 AWG28
Red : VOLTAGE
Black : GND
Dimension of mounting hole for recommendation
10 ± 0.5
24 ± 0.5
4 – φ 3.2
Air flow
.6
φ
24 ± 0.5
□30 ± 0.5
4 – C2.3
28
24 ± 0.5
24 ± 0.5
150 ± 20
■ OUTLINE DIMENSIONS
4 – φ 3.2
很抱歉,暂时无法提供与“F310R-12LLC”相匹配的价格&库存,您可以联系我们找货
