SURFACE MOUNT CERMET TRIMMERS
RoHS compliant
SM-42/43
INTERNAL STRUCTURE
②
③
⑨
①
⑧
④
⑤
⑦
⑥
Part name
■ FEATURES
RoHS compliant
Fine adjustment is possible
Automatic mounting is possible (Taping)
Reflow soldering is possible
Sealed construction (Washable: Refer to page 698.)
Resin material is UL Recognized 94V-0
Material
①
Housing
②
Base element
③
Electrode
Ag-Pd cermet
④
Resistive element
RuO2 cermet
⑤
Adhesive
⑥
Wiper
⑦
Terminal pin
⑧
Rotor gear
⑨
Shaft
Polyphenylenesulphide
Ceramic
Epoxy
Multi metal alloy
Copper alloy, Sn-Cu-plated
Polyamide
Brass, Nickel-plated
■ PART NUMBER DESIGNATION
S M - 4 □ T W 1 0 0Ω ( 1 0 1 )
Series name
Resistance code
Electrical turn
Resistance value
2:11 turns
3:5 turns
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Product shape (Shape of terminal)
A:J-hook (Side adjustment)
B:Gull wing(Side adjustment)
W:J-hook (Top adjustment)
X:Gull wing (Top adjustment)
SM-42/43
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Electrical
turn
Form of packaging
Adjustment
Shape of terminal
position
Top adjustment
11
Side adjustment
Top adjustment
5
Side adjustment
〈Nominal resistance values〉
Taping (reel)
Plastic bag
W (J-hook)
SM-42TW
SM-42W
X (Gull wing)
SM-42TX
SM-42X
A (J-hook)
SM-42TA
SM-42A
B (Gull wing)
SM-42TB
SM-42B
W (J-hook)
SM-43TW
SM-43W
X (Gull wing)
SM-43TX
SM-43X
A (J-hook)
SM-43TA
SM-43A
B (Gull wing)
SM-43TB
SM-43B
TA, TB : 500 pcs./reel
TW, TX : 250 pcs./reel
50 pcs./pack
Pieces in package
■ ELECTRICAL CHARACTERISTICS
→ 10 Ω → 20 Ω
50 Ω
1 kΩ
2 kΩ
10 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
20 kΩ
100 Ω
200 Ω
500 Ω
5 kΩ
Fig. 1
The products indicated by → mark are manufactured upon receipt of order basis.
※ The above part numbers are all available with the respective combination of
(Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping specification is not sold separately and must be purchased in reel units.
■ MECHANICAL CHARACTERISTICS
Operating torque
17.6 mN·m {180 gf·cm} maximum
Mechanical stop
Clutch action
Rotational life
200 cycles [ Δ R/R ≦ ± (3 Ω +3 %)]
Thrust to shaft
5 N {0.51 kgf} minimum
Solderability
245 ± 3 °C, 2 ~ 3 s
± 10 %
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Power ratings
0.25 W (85 °C) 0 W (150 °C)
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Resistance law
Linear law
10 Ω ~ 2 MΩ
Nominal resistance range
Resistance tolerance
Maximum input voltage
DC300 V or power rating, whichever is smaller
Maximum wiper current
100 mA or power rating, whichever is smaller
Effective electrical turn
11 turns (SM-42), 5 turns (SM-43)
1 % or 2 Ω, whichever is greater
End resistance
1 % or 3 Ω, whichever is greater
C.R.V.
− 65 ~ 150 °C
Operating temp. range
± 100 10 /°C maximum
Temp. coefficient
-6
Insulation resistance
100 MΩ minimum (DC500 V)
Dielectric strength
AC600 V, 60 s
Net weight
Approx. 0.17 g
Temperature
〈Reflow profile for soldering heat evaluation〉
250
Peak : 250 ℃
200
Pre Heating Zone
150
100
50
Pull-off strength
5 N {0.51 kgf} 10 s
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Thermal shock
Humidity
Shock
Test conditions
Specifications
− 65 ~ 150 °C (0.5 h),
5 cycles
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
85 °C, 0.25 W, 1000 h
Low temp. operation
− 65 °C, 2 h
High temp. exposure
150 °C, 250 h
Immersion seal
85 °C, 60 s
[ Δ R/R ≦ 2 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 % or 3 Ω ]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
No leaks (No continuous bubbles)
+5
Over 230 ℃
180 ℃
150 ℃
90±30 s
30±10 s
Heating time
Soldering Zone
Reflow : two times maximum
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
Soldering heat
Manual soldering:350 ± 10
°C, 3 ~ 4 s
[ Δ R/R ≦ 1 %]
Δ R/R:Change in total resistance
S.S. :Setting stability
SM-42/43
■ MAXIMUM INPUT RATINGS
Resistance
code
Nominal resistance
values ( Ω )
Maximum input Maximum wiper
voltage (V)
current (mA)
→ 10
→ 20
50
100
200
500
100
200
500
101
201
501
1.00
2.00
3.53
5.00
7.07
11.2
100
100
70.7
50.0
35.4
22.4
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
15.8
22.4
35.4
50.0
70.7
112
15.8
11.2
7.07
5.00
3.54
2.24
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
158
223
300
300
300
1.58
1.12
0.60
0.30
0.15
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● SM-42/43B
● SM-42/43X
2
2
2.3
5.1
1.3
2.54
1.3
1.9
1.3
1.3
2.9
5.2
1.6
2
1.9
2
2
● SM-42/43W
1.3
● SM-42/43A
(Unit: mm)
2.54
1.3
Note) The zero point is the center of mounting.
SM-42/43
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
3.9
①
● SM-42/43W
3.5
Resistance code & Production date code
①
②
1.3
②
Note the terminal position.
3 – 0.9
1.2
4.8
2.54
2 – 0.8
③
CW rotation
Φ 1.5, Slot
③
0.56W × 0.5D
5.1
2.6
3–1
5.3
● SM-42/43X
5.7
3.5
②
2 – 0.8
1.2
4.8
2.54
1.3
①
Φ 1.5, Slot
③
0.56W × 0.5D
5.1
3–1
5.3
● SM-42/43A
3.7
3 – 0.8
①
2 – 0.9
4.8
1.2
1.3
2.3
3–1
②
③
Φ 1.5, Slot
0.56W× 0.5D
2.6
4.6
5
● SM-42/43B
①
1.2
2.3
1.3
4.8
②
2 – 0.9
Φ 1.5, Slot
0.56W × 0.5D
2.8
4.6
6
③
3 – 0.6
3.9
SM-42/43
■ PACKAGING SPECIFICATIONS
● Taping version (SM-42/43TA, TB) is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
SM-42/43TW, TX is packaged in 250 pcs. per reel.
Orders will be accepted for units of 250 pcs., i.e., 500, 750 pcs., etc.
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the dia-grams below.
● EMBOSSED TAPE DIMENSIONS
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
(TA/TB type : In accordance with EIAJ ET-7200A)
Empty
Filled
(Unit: mm)
Empty
+1
Head
40 mm min.
21±0.8
20 pitches min.
2±0.5
60
Leader
+1
End
13 0 (TA/TB)
170.3 (TW, TX)
400 mm min.
Direction of feed
13±0.2
15.4±1 (TA/TB)
19.5±1 (TW/TX)
180 –1.5 (TA/TB)
180 –3 (TW, TX)
12±0.1
5.75
Cross section A-A
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
2
1.75±0.1
0.4±0.1
Installation
example
(SM-42A)
12
7.5±0.1
1
2±0.1
3
.1
+0 0
A
1
A
5
1.
2
Installation
example
(SM-42W)
φ
.1
+0 0
5
1.
3
4±0.1
0.5±0.1
5.5±0.05
2±0.1
+0.3
φ
A
16 –0.1
4±0.1
● SM-42/43TA/TB
1.75±0.1
● SM-42/43TW/TX
4.5
A
8±0.1
Cross section A-A
很抱歉,暂时无法提供与“SM-43TW103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+18.78177250+2.34998
- 500+17.80362500+2.22759
- 750+17.25422750+2.15885
- 1250+16.584921250+2.07511
- 1750+16.157751750+2.02166
- 2500+15.716422500+1.96644
- 3000+15.495503000+1.93880
- 国内价格 香港价格
- 1+28.536241+3.57045
- 10+24.0105710+3.00420
- 25+22.4005225+2.80275
- 50+21.2486750+2.65863
- 100+20.15213100+2.52143
- 国内价格
- 2+23.06665
- 10+22.07213
- 100+21.36399
- 国内价格
- 10+22.07213
- 100+21.36399
- 国内价格
- 1+22.08600
- 10+18.91080
- 30+17.02080
