SI2301CDS-T1-GE3-HXY
    HXY(华轩阳)
    SOT-23
    MOSFETs 1个P沟道 耐压:20V 电流:2.3A SOT-23
SI2301CDS-T1-GE3-HXY 数据手册
HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET HUAXUANYANG Description The SI2301CDS-T1-GE3 uses advanced trench technology to provide excellent R DS(ON), low gate D chargeand operation with gate voltages as low as S 1.8V. This device is suitable for use as a load switch G or in PWM applications. SOT-23 General Features VDS = -20V,ID = - 2.3A RDS(ON) < 140m Ω @ VGS=-4.5V D RDS(ON) < 170m Ω @ VGS=-2.5V G Application PWM applications S Load switch P-Channel MOSFET Package Marking and Ordering Information Product ID Pack Brand Qty(PCS) SI2301CDS-T1-GE3 SOT-23 HXY MOSFET 3000 Absolute Maximum Ratings (TA=25℃unless otherwise noted) Symbol Parameter Limit Unit VDS Drain-Source Voltage -20 V VGS Gate-Source Voltage ±12 V ID Drain Current-Continuous -2.3 A IDM Drain Current-Pulsed (Note 1) -9 A PD Maximum Power Dissipation 0.65 W -55 To 150 ℃ 178 ℃/W TJ,TSTG RθJA Operating Junction and Storage Temperature Range Thermal Resistance,Junction-to-Ambient (Note 2) Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET HUAXUANYANG Electrical Characteristics (TA=25℃unless otherwise noted) Parameter Symbol Condition Min Drain-Source Breakdown Voltage BVDSS VGS=0V ID=-250μA -20 Zero Gate Voltage Drain Current IDSS VDS=-20V,VGS=0V - Gate-Body Leakage Current IGSS VGS=±12V,VDS=0V Gate Threshold Voltage VGS(th) VDS=VGS,ID=-250μA Drain-Source On-State Resistance RDS(ON) Typ Max Unit - V - -1 μA - - ±100 nA -0.4 -0.7 -1 V VGS=-4.5V, ID=-2A 130 140 mΩ VGS=-2.5V, ID=-1.8A 152 170 mΩ 4 - - S - 285 - PF - 58 - PF - 32 - PF - 9.8 - nS Off Characteristics On Characteristics (Note 3) Forward Transconductance Dynamic Characteristics gFS VDS=-5V,ID=-2A (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Switching Characteristics Crss VDS=-10V,VGS=0V, F=1.0MHz (Note 4) Turn-on Delay Time td(on) Turn-on Rise Time tr VDD=-10V, RL=5Ω - 4.9 - nS td(off) VGS=-4.5V,RGEN=3Ω - 20.5 - nS - 7 - nS - 2.9 - nC - 0.45 - nC - 0.75 - nC - - -1.2 V - - -2.0 A Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=-10V,ID=-2A, VGS=-4.5V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS VGS=0V,IS=-2A Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET HUAXUANYANG Typical Electrical and Thermal Characteristics ton tr td(on) toff tf td(off) 90% VOUT 10% 10% 90% VIN 50% 10% 50% PULSE WIDTH Figure 2:Switching Waveforms PD Power(W) -ID- Drain Current (A) Figure 1:Switching Test Circuit 90% INVERTED TJ-Junction Temperature(℃) TJ-Junction Temperature(℃) Figure 4 Drain Current ID- Drain Current (A) Rdson On-Resistance(Ω) Figure 3 Power Dissipation -Vds Drain-Source Voltage (V) Figure 5 Output Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD -ID- Drain Current (A) Figure 6 Drain-Source On-Resistance www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET ID- Drain Current (A) Normalized On-Resistance HUAXUANYANG TJ-Junction Temperature(℃) -Vgs Gate-Source Voltage (V) Figure 8 Drain-Source On-Resistance C Capacitance (pF) Rdson On-Resistance(Ω) Figure 7 Transfer Characteristics -Vgs Gate-Source Voltage (V) -Vds Drain-Source Voltage (V) Figure 10 Capacitance vs Vds -Vgs Gate-Source Voltage (V) -Is- Reverse Drain Current (A) Figure 9 Rdson vs Vgs Qg Gate Charge (nC) Figure 11 Gate Charge Shenzhen HuaXuanYang Electronics CO.,LTD -Vsd Source-Drain Voltage (V) Figure 12 Source- Drain Diode Forward www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET ID- Drain Current (A) HUAXUANYANG Vds Drain-Source Voltage (V) r(t),Normalized Effective Transient Thermal Impedance Figure 13 Safe Operation Area Square Wave Pluse Duration(sec) Figure 14 Normalized Maximum Transient Thermal Impedance Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET HUAXUANYANG SOT-23 Package Outline Dimensions Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° SOT-23 Suggested Pad Layout Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HXY SI2301CDS-T1-GE3 ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET HUAXUANYANG Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
