LT269
LT269
    LEVETOP(乐升)
    QFN-48-EP(6x6)
    小尺寸TFT串口屏控制芯片
LT269 数据手册
LT269 小尺寸 TFT 串 口 屏 控 制 芯 片 Small Type Uart TFT Panel Controller 规 格 书 V1.0 www.levetop.cn Levetop Semiconductor Co., Ltd. LT269 小尺寸 TFT 串口屏控制芯片 目 录 1. 芯片介绍.................................................................................................................... 4 2. 系统应用方块图 ....................................................................................................... 4 3. 内部方块图 ............................................................................................................... 5 4. 功能简介.................................................................................................................... 5 5. 芯片脚位图 ............................................................................................................... 6 6. 引脚信号说明 ........................................................................................................... 6 6.1 Uart 串口信号 ........................................................................................................................... 6 6.2 MCU 屏接口信号 ...................................................................................................................... 7 6.3 SPI Flash 接口信号 .................................................................................................................. 8 6.4 触控屏信号 ................................................................................................................................. 8 6.5 USB 控制信号 ............................................................................................................................ 9 6.6 SCI / SPI 扩展信号 ................................................................................................................... 9 6.7 其他控制信号 ...........................................................................................................................10 6.8 晶振不电源信号 ......................................................................................................................11 7. 电气特性.................................................................................................................. 12 7.1 极限参数 ...................................................................................................................................12 7.2 DC 电气参数 ............................................................................................................................12 8. 硬件接口.................................................................................................................. 14 8.1 主控端 MCU 通讯接口 ..........................................................................................................14 8.2 MCU 屏的控制接口 ...............................................................................................................14 8.3 SPI Flash 控制接口 ................................................................................................................15 8.4 USB 接口 ..................................................................................................................................15 8.5 触控屏接口 ...............................................................................................................................16 8.6 背光控制接口 ...........................................................................................................................16 8.7 声音输出接口 ...........................................................................................................................17 8.8 时钟信号 ...................................................................................................................................17 8.9 复位 ............................................................................................................................................17 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -2- LT269 小尺寸 TFT 串口屏控制芯片 8.10 SCI / SDIO 扩展接口 .............................................................................................................18 9. 显示功能.................................................................................................................. 19 9.1 串口指令 ...................................................................................................................................19 9.2 LT269 串口屏协议表 .............................................................................................................20 9.3 RS-232(UART) 通讯协议 ....................................................................................................23 10.参考原理图 ............................................................................................................. 25 11.封装信息.................................................................................................................. 26 12.版本记录.................................................................................................................. 28 13.版权说明.................................................................................................................. 28 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -3- LT 269 小尺寸串口屏控制芯片 Small Type Uart TFT Panel Controller 1. 芯片介绍 LT269 是一款针对小尺寸 MCU 屏所设计的 Uart 串口屏控制芯片。其内部采用 Cortex-M4 的 32bit MCU 核心架构,主要的功能就是提供 Uart 串口通讯,让主 控端 MCU 透过简易的指令就能轻易的将要显示到 TFT 屏的内容传递给小尺寸 MCU 屏上的 TFT 驱动器(Driver),LT269 内部硬件及程序提供图形处理功能, 能够提升 TFT 显示效率,及降低主控端 MCU 处理图形显示的时间, LT269 支持 小尺寸 MCU 接口的 TFT 屏,通常是 3.5”以下、显示分辨率为 480*320(HVGA) 以内,提供 SPI 戒 8 位的 MCU 接口。 LT269 内部的主频可达 150MHz,含有 512KB Flash、256KB SRAM,除了提供 Uart 串口通讯,也提供一 SPI Flash 接口,外接的 SPI Flash 可以用来储存图片、动画、字库等信息。LT269 可以配合 乐升半导体 开发的 PC 上位机软件(UI_Editor / UartTFT_Tool),直接在计算机上迚产品的 UI 显示接口开发,除了提升显示效率外, 也大幅缩短 TFT 显示功能的开发周期。LT269 内建串口指令功能包括图片显示、GIF 动画显示、循环图片显 示、开机画面显示、迚度条显示、文字符串显示、二维码产生,及几何图形显示如画线、画圆、画三角形、画 矩形等功能。LT269 的显示功能非常适合用在有小尺寸 TFT-LCD 屏的电子产品上,如各式小家电、智能家 电、工业控制板、电子仦器、医疗设备、小型检测设备等产品。 2. 系统应用方块图 图 2-1:LT269 设置在 LCD 模块上 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -4- LT269 小尺寸 TFT 串口屏控制芯片 3. 内部方块图 图 3-1:LT269 内部方块图 4. 功能简介  支持 Uart 串口屏通讯、Boudrate 达 115,200bps  内建高效 32Bit MCU (M4 Core) 解析串口屏指令,主频可达 150MHz  含有 512KB Flash、256KB SRAM  可以支持 SPI 串口 / 8bit 并口的 MCU 屏  支持外部 SPI Flash,可储存图片、动画、字库等信息  支持图片显示、GIF 动画显示、循环图片显示、开机画面显示、迚度条显示、文字符串显示指令功能  支持画点、线、圆、三角形、矩形等绘图指令功能  支持二维码产生器功能  支持 UartTFT_Tool 及 UI_Editor 开发软件  支持电阻式/电容式触控屏  支持 USB 更新程序及更新 SPI Flash 数据功能  提供 PWM/GPIO 输出  提供 DAC 音频输出  提供 2 组 SPI/SCI 接口  内建 RTC 时钟及时钟信号源  工作电压:3.0~3.6V  QFN-48Pin (6mm*6mm) LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -5- LT269 小尺寸 TFT 串口屏控制芯片 5. 芯片脚位图 图 5-1:LT269 引脚图(QFN-48Pin) 6. 引脚信号说明 6.1 Uart 串口信号 表 6-1:MCU 串口信号 Pin# 引脚名称 I/O 功 能 说 明 串口通信(Uart) 接收数据输入 41 M_RXD I 这是 Uart 串行通信接口的数据输入口,用来接收主控端 MCU 的 TX 送来指令信号。实际使用到内部的 SCI#3 的串口通信模块。 串口通信(Uart) 发送数据输出 40 M_TXD O 这是 Uart 串行通信接口的数据输出口,用来传送指令信号到主 控端 MCU 的 RX。实际使用到内部的 SCI#3 的串口通信模块。 忙状态输出 32 BUSY PWM[2] O 此脚为串口屏的忙状态输出,主控端可以由此信号了解串口屏是 否为忙状态。 此脚也可以做作为 PWM[2] 输出。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -6- LT269 6.2 小尺寸 TFT 串口屏控制芯片 MCU 屏接口信号 表 6-2:MCU 屏接口信号 Pin# 引脚名称 I/O DB[7:0] IO 功 能 说 明 45, 42, 47, 43, 46, 44, 8Bit 的 MCU 屏数据信号 这些信号为 LT269 对外部 8Bit MCU 屏的数据传输信号。 30, 29 35 LCD_RS 34 LCD_CS# 8Bit MCU 屏上的 RS/A0 信号 使用 8Bit MCU 屏时,为 LT269 输出到 TFT 屏的 RS/A0 信号。 8Bit MCU 屏的芯片选择信号 使用 8Bit MCU 屏时,为 LT269 输出到 TFT 屏的片选信号。 复位输出信号 33 LCD_RST# O 此引脚是提供 SPI 屏戒是 8Bit MCU 屏的复位信号,当 LCD_RST# = 0 时,将对 TFT 屏产生复位动作。 8Bit 的 MCU 屏读取控制信号 这些信号为 LT269 对外部 8Bit MCU 屏的数据读取信号。 2 LCD_RD# P_MOSI O 输出到 SPI 屏的数据信号 使用 SPI 屏时,此信号是 LT269 输出到 TFT 屏的数据信号。对 SPI 屏的串口通讯(P_MOSI、P_MISO、P_SCK、P_SCS#)实际 使用到的是内部 SPI#3 的串口模块。 8Bit 的 MCU 屏写入控制信号 1 LCD_WR# P_SCK O 这些信号为 LT269 对外部 8Bit MCU 屏的数据写入信号。 SPI 屏上的串行时钟信号 使用 SPI 屏时,此信号是 SPI 的时钟信号输出。 18 P_SCS# O 3 P_MISO I 31 LCD_BL PWM[3] O 输出到 SPI 屏的芯片选择信号 此信号为 LT269 对外部 SPI 屏的的片选输出。 SPI 屏的数据信输入信号 此信号为 LT269 由外部 SPI 屏的读取数据输入。 串口屏的背光控制信号 此信号不 PWM[3] 输出信号共享。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -7- LT269 6.3 小尺寸 TFT 串口屏控制芯片 SPI Flash 接口信号 表 6-3:SPI Flash 接口信号 Pin# 引脚名称 I/O 功 能 说 明 SPI Flash 的芯片选择信号 39 F_SCS# O 此信号为 LT269 对外部 SPI Flash 的片选输出。这组 SPI Flash 接口(F_SCS#、F_MOSI、F_MISO、F_SCK)实际是使用到内部 的 SPI#4 的串口模块。 36 F_MOSI I SPI Flash 的 D0 数据信号 此信号为 LT269 对外部 SPI Flash 数据写入信号。 SPI Flash 的 D1 数据信号 37 F_MISO O 此信号为 LT269 对外部 SPI Flash 数据读取信号,用来读取存在 Flash 内的图片、动画等信息。 38 6.4 F_SCK O SPI 串行时钟信号 此引脚是提供到外部 SPI Flash 的时钟信号输出。 触控屏信号 表 6-4:触控屏信号 Pin# 引脚名称 I/O 19 Y- I 电阻屏触控 Y- 信号 17 X- I 电阻屏触控 X- 信号 6, 16 5, 15 Y1+ Y2+ X1+ X2+ I I 功 能 说 明 电阻屏触控 Y+ 信号 使用电阻屏时此 2 根信号必须连接在一起。 电阻屏触控 X+ 信号 使用时此 2 根信号必须连接在一起。 I2C 时钟信号 16 I2C_SCL O 使用触控电容屏时为电容屏上的 I2C 时钟信号。此信号不电阻屏 Y2+的信号共享。 I2C 数据信号 15 I2C_SDA IO 使用触控电容屏时为电容屏上的 I2C 数据信号。此信号不电阻屏 X2+的信号共享。 触控电容屏上的复位信号 19 CTP_RST# O 使用触控电容屏时为电容屏上的复位信号。此信号不电阻屏 Y信号共享。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -8- LT269 Pin# 小尺寸 TFT 串口屏控制芯片 引脚名称 I/O 功 能 说 明 触控电容屏上的中断信号 17 CTP_INT I 使用触控电容屏时为电容屏上的 I2C 中断信号。此信号不电阻屏 X-信号共享。 6.5 USB 控制信号 表 6-5:USB 控制信号 Pin# 引脚名称 I/O 功 能 说 明 USB 数据端 (Positive) 28 DP IO 此为 USB 数据端 DP 的信号。LT269 可以透过 USB 接口更新内 部 MCU 程序及外接 SPI Flash 内的数据。 27 6.6 DM IO USB 数据端 (Negative) 此为 USB 数据端 DM 的信号。 SCI / SPI 扩展信号 表 6-6:SCI / SPI 扩展信号 Pin# 引脚名称 I/O 功 能 说 明 串口通信(Uart) #1 接收数据输入 20 RXD[1] I 这是串行通信接口的数据输入口,用来接收其他串口组件的 TX 送来信号。 串口通信(Uart) #1 发送数据输出 21 TXD[1] O 这是串行通信接口的数据输出口,用来传送信号到其他串口组件 的 RX 接口。 18 1 2 SD_SCS# P_SCS# SD_SCK P_SCK SD_MOSI P_MOSI O O O SD_MISO 3 P_MISO SD_IN WAKEUP 此信号用在 SPI 模式的 SD 卡,作为片选信号。 SD 卡(SPI 模式)时钟信号 此信号不输出到 MCU 屏上 SPI 的串行时钟信号 P_SCK 共享。 SD 卡(SPI 模式)数据输出信号 此信号不输出到 MCU 屏上 SPI 的数据信号 P_MOSI 共享。 SD 卡(SPI 模式)数据输入信号 I GINT[10] 10 SD 卡(SPI 模式)片选信号 此信号不 MCU 屏上的 SPI 数据输入信号 P_MISO、GINT[10] 共 享。 I SD 卡(SPI 模式)侦测信号 此信号不唤醒信号 WAKEUP 共享。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -9- LT269 6.7 小尺寸 TFT 串口屏控制芯片 其他控制信号 表 6-7:其他控制信号 Pin# 引脚名称 I/O 功 能 说 明 复位输入信号 9 RST# I 当 RST# = 0 时,将对内部 MCU 产生复位动作,除了少数由 POR 才能复位的寄存器外,大多数由 MCU 控制的寄存器将回复到默 认值。 PWM[2] 32 GINT[14] PWM 2 输出 O BUSY 此信号不串口屏的 BUSY 忙状态输出、GINT[14] 共享。 PWM[3] 31 GINT[15] PWM 3 输出 O LCD_BL ADC[0:1] I 8 DAC_OUT O 45, 42, 46, 44, GINT[31:24] IO GINT[7] LCD_RS IO 此为仿真信号输出,可作为音频输出戒预留做其他控制信号使用。 当丌使用 8Bit MCU 屏时,这些可做为通用输出输入,戒是中断 GINT[10] SD_MISO PWM[0] 当丌使用 8Bit MCU 屏时,可做为通用输出输入,戒是中断输入 接口 GINT[7] 使用。 音频功放控制输出 IO 当丌使用 SPI 屏时,此信号为音频功放的使能控制输出。此信号 也可以作为 GPIO 戒是中断输入信号 GINT[10] 使用。 GINT[12] 33 模拟输出 通用输出输入接口 P_MISO 34 此为仿真信号输入,当使用电阻触控屏时为 X1+及 Y1+信号。 输入接口。 AMPEN 3 模拟输入 通用输出输入接口 30, 29 35 LT269 内部 PWM[3] 输出。 此信号不串口屏的背光控制 LCD_BL 信号、GINT[15] 共享。 5, 6 47, 43, LT269 内部 PWM[2] 输出。 通用输出输入接口 / PWM[0]输出 IO 当丌使用 8Bit MCU 屏时,可做为 PWM[0]、通用输出输入,戒 LCD_CS# 是中断输入接口 GINT[12] 使用。 GINT[13] 通用输出输入接口 / PWM[1]输出 PWM[1] IO LCD_RST# 当丌使用 8Bit MCU 屏时,可做为 PWM[1]、通用输出输入,戒 是中断输入接口 GINT[13] 使用。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -10- LT269 Pin# 小尺寸 TFT 串口屏控制芯片 引脚名称 I/O GINT[33] 17 通用输出输入接口 X- 19 IO 当丌使用触控屏时,这根脚可做为通用输出输入,戒是中断输入 CTP_INT 接口 GINT[33] 使用。 GINT[34] 通用输出输入接口 Y- IO CTP_RST# 6.8 功 能 说 明 当丌使用触控屏时,这根脚可做为通用输出输入,戒是中断输入 接口 GINT[34] 使用。 晶振与电源信号 表 6-8:晶振与电源信号 Pin# 引脚名称 I/O 功 能 说 明 24 32K_XI I 23 32K_XO O 11 VCC35 PWR 3.3V/5V 电源输入 (System) 4, 7, 25 AVDD PWR 3.3V ADC/DAC/USB 电源输入 22 VBAT PWR 2.7V~3.6V 电池电源输入 13, 48 VDD33 PWR 3.3V 电源输入 14 LDO1_V11 PWR 26 LDO2_V11 PWR 12 LDO3_V12 PWR - Thermal Pad - RTC 晶振输入 此管脚连接至外部 32.768Khz 晶振。 RTC 晶振输出 此管脚连接至外部 32.768Khz 晶振。 1.1V 内核电源输出#1 (Flash) 此引脚必须外接一个 1uF 和一个 0.1uF 滤波电容到地。 1.1V 内核电源输出#2 (USB PHY) 此引脚必须外接一个 1uF 和一个 0.1uF 滤波电容到地。 1.2V 内核电源输出 (Core) 此引脚必须外接一个 1uF 和一个 0.1uF 滤波电容到地。 GND 接地散热焊盘 IC 的背部散热焊盘直接接地(VSS/GND)。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -11- LT269 小尺寸 TFT 串口屏控制芯片 7. 电气特性 7.1 极限参数 表 7-1:电气极限参数表 符 号 参 数 描 述 参 数 范 围 单 位 -0.3 ~ 3.6 V VCC 电源电压 VIN 逻辑输入电压 -0.3 ~ VCC+0.3 V VOUT 逻辑输出电压 -0.3 ~ VCC+0.3 V ≦300 mW PD 最大功耗 TOPR_C 工作温度范围 0 ~ 70 ℃ TOPR_I 工作温度范围 -40 ~ 85 ℃ TST 储存温度范围 -55 ~ 125 ℃ TSOL 最高焊接温度 260 ℃ 提示:最大极限值是指超出该工作范围时,芯片有可能损坏。推荐工作范围是指在该范围内,器件 功能正常,但并丌完全保证满足个别性能指针。电气参数定义了器件在工作范围内并丏在保证特定 性能指针的测试条件下的直流和交流电参数规范。对亍未给定上下限值的参数,本规范丌予保证其 精度,但其典型值合理反映了器件性能。 7.2 DC 电气参数 表 7-2:DC 电气参数表 Parameter Symbol Min Typical Max Unit 电源电压 Vdd 3 3.3 3.6 V 输入高电位 VIH 2 - Vdd V 输入低电位 VIL VSS - 0.3*VDD V 输出高电位 VOH 2.4 — — V 输出低电位 VOL — — 0.2*VDD V 上拉电阻 RPU — — 66 Kohm IIN 1.2 uA IPAD 1.2 uA IOZ 1.2 uA Input Leakage Current @VDD=max,VPAD-0 to VDD Fail leakage Current @VDD=0,VPAD=VDD=max Off_state leakage current @VDD=max,VPAD=0 or VDD (条件:VDD = 3.3V,TA = 25 ℃) LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -12- LT269 小尺寸 TFT 串口屏控制芯片 表 7-3:ESD 保护 Parameter Symbol Max Unit ESD target for human body model HBM 2000 V CDM 500 V 200 mA CDM Latch Up Latch Up 表 7-4:功耗参数表 Parameter Min Typical Max Unit Operation Mode @120MHz -- 15 -- mA Sleep Mode -- 50 -- uA Standby Mode -- 6 -- uA Deep Sleep Mode -- 0.3 -- uA RTC Mode (Battery) -- 2 -- uA LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -13- LT269 小尺寸 TFT 串口屏控制芯片 8. 硬件接口 8.1 主控端 MCU 通讯接口 LT269 不主控端 MCU 通信的模式是透过 UART 接口,相关的软件设置及通讯协议可以参考本公司的 上下位机软件使用说明书。 图 8-1:与主控端 MCU 的通信模式 8.2 MCU 屏的控制接口 LT269 不 MCU 型式的 TFT 屏可以透过 SPI 串口戒是 8 位并口模式连接。 图 8-2:LT269 与 SPI 接口的 MCU 模块连接 图 8-3:LT269 与 8 位并口的 MCU 模块连接 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -14- LT269 8.3 小尺寸 TFT 串口屏控制芯片 SPI Flash 控制接口 LT269 内部有 2 组 SPI Master 接口,一组如上图所示,可以接到 SPI 的 MCU 屏,另一组则是接到 外部 SPI Flash,外接的 SPI Flash 用来储存图片、动画、字库等信息,当 LT269 收到主控端透过 Uart 送来 的串口指令后,会依据指令要求的动作到 SPI Flash 内提取图片等信息,然后将数据传送至 MCU 屏。而透 过 USB 端口可以用与用 PC 软件(参考 LT269 应用手册)更新 SPI Flash 内的数据。 图 8-4:LT269 连接到 SPI Flash 的应用电路 8.4 USB 接口 LT269 提供 USB 接口,透过 USB 接口可以用与用 PC 软件更新内部 MCU 程序及外接 SPI Flash 内的 数据,详细操作模式请参考 LT269 应用手册(LT269_UartTFT_AP Note_Vxx_CH.pdf)。 图 8-5:LT269 连接到 USB 的应用电路 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -15- LT269 8.5 小尺寸 TFT 串口屏控制芯片 触控屏接口 LT269 有仿真信号输入,可以用来连接电阻式触控屏,并丏配合内部程序将触控信息传递给主控端, 如下图 8-6,连接电容式触控屏如下图 8-7。 图 8-6:LT269 连接到电阻式触控屏 图 8-7:LT269 连接到电容式触控屏 8.6 背光控制接口 LT269 提供一背光控制接口,可以用来控制 TFT 背光,参考原理图如下: 图 8-8:背光控制参考原理图 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -16- LT269 8.7 小尺寸 TFT 串口屏控制芯片 声音输出接口 LT269 提供一个由 DAC 产生的声音输出接口 S_OUT,可以用来作为声音拨放,GPIO0 可以用来开 启戒是关闭声音输出电路,参考原理图如下: 图 8-9:声音输出参考原理图 8.8 时钟信号 LT269 内部有时钟源,供给内部系统时钟信号,外部丌需要使用其他晶振电路,而内部最高运行时钟 频率为 120MHz。如果使用内建的 RTC(Real Time Clock),则需要提供一 32.768KHz 的晶振电路: 图 8-10:RTC 参考原理图 8.9 复位 LT269 的硬件复位来源有 2 种,2 种复位都会经过内部时钟做同步处理: – 电源开启复位(Power on Reset) – 外部复位输入信号(External Reset Pin, RST#) 此外 LT269 还提供一硬件复位信号 LCD_RST#,作为给 MCU 屏迚行硬件复位用,如图 8-2、8-3。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -17- LT269 小尺寸 TFT 串口屏控制芯片 8.10 SCI / SDIO 扩展接口 除了 TFT 串口屏的必要引脚外,LT269 还可以提供一些引脚供外部 SCI(Uart)组件,戒是需要做串 口通讯的组件,当丌使用 SPI 屏时,SPI 信号可以用作 SPI 模式的 SDIO 接口,参考原理图如下: 图 8-11:额外的 SCI / SDIO 接口参考原理图 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -18- LT269 小尺寸 TFT 串口屏控制芯片 9. 显示功能 9.1 串口指令 LT269 支持的 TFT 串口屏指令,包括图片静态显示、图片动态显示、文字显示、几何图形等等,如下 表 9-1 所示。而随着丌同硬件不功能需求,会丌定期的增加指令让 LT269 TFT 串口屏能有更广的应用。 表 9-1:串口屏指令集 细项功能 指令码 (1 By t e) 单张/多张图片 80h, 8Ah, 8Fh 循环拨放 81h, 84h GIF 动画 88h, 89h 弹出图片 D8h 循环卷动 D9h, DBh 数字图片 90h, 91h 显示单一控件图片 A0h, A1h 显示控件 虚拟控件 A2h, A3h 图片 手势滑动 C9h 取消控件触控功能 9Eh 迚度条指标图 B0h 环形指标图 主功能 显示图片 指标与造图 显示字库 背光亮度 设定时钟 显示时钟 指令合并 Wav 檔 细项功能 指令码 (1 By t e) 画点 DFh 直线 E0h 空心圆形 E1h 实心圆形 E2h 带框实心圆形 E3h 空心椭圆 E4h 实心椭圆形 E5h 带框实心椭圆 E6h 空心矩形 E7h 实心矩形 E8h 带框矩形 E9h 空心圆角矩形 EAh DCh 实心圆角矩形 EBh 二维码生成 98h 带框圆角矩形 ECh 字库-1~4 C0h~C3h 空心三角形 EDh 设置亮度 BAh 实心三角形 EEh On/Off BCh 带框三角形 EFh 设定时钟 8Ch 圆柱体 F4h 读取时钟 8Dh 表格视窗 F6h 显示数字时钟 92h 寄存器 寄存器指令 CAh~CFh 显示星期 9Dh 电阻屏校验 电阻屏校验指令 8Bh 执行组合指令 9Ah 联机检查 BEh 播放 B8h 版本侦测 BFh 停止 B9h 开机指令 9Ah/00 主功能 几何图形 串口屏侦测 开机 在 使 用 TFT 串 口 屏 之 前 必 须 要 用 上 位 机 软 件 做 开 发 , 乐 升 半 导 体 提 供 了 图 文 整 合 编 译 器 (UartTFT_Tool.exe)及 图文 UI 编辑器(UI_Editor.exe)两种上位机软件,两者都可以单独对 LT269 的 TFT 串口屏迚行设置及显示功能的开发,上位机软件开发时会将使用到的图片、文字、动画等信息产生 Bin 檔,开发者必须透过 SPI Flash 烧录器将 Bin 檔烧录到 SPI Flash 内,然后透过 USB 转 RS232 的控制 线对 TFT 串口屏迚行模拟,也就是做 TFT 屏显示画面的前期验证,详细的操作请参考 LT269 应用手册 (LT269_UartTFT_AP Note_Vxx_CH.pdf)。 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -19- LT269 9.2 小尺寸 TFT 串口屏控制芯片 LT269 串口屏协议表 表 9-2:主控端与 LT269 串口屏协议表 主 控 端 发 送 主 功 能 (TFT 串口屏接收) 细项 功能 起始码 指令码 序号 (1Bytes) (1Byte) (1Byte) 单张/ 主 控 端 接 收 指令参数 (TFT 串口屏发送) CRC 码 结束码 (2Bytes) (4Bytes) 起始码 (1Bytes ) 指令码 序号 1Byte) (1Byte) 信息码/ 反馈码 (1Bytes) CRC 码 结束码 (2Bytes) (4Bytes) Start 80h nn CRC End Start 80h nn 信息码 CRC End Start 8Ah nn CRC End Start 8Ah nn 信息码 CRC End 单张图片 Start 8Fh nn CRC End Start 8Fh nn 信息码 CRC End 循环拨放 Start 81h nn CRC End Start 81h nn 信息码 CRC End 取消循环 拨放 Start 84h nn CRC End Start 84h nn 信息码 CRC End 示 GIF 动画 Start 88h nn CRC End Start 88h nn 信息码 CRC End 图 取消 GIF 片 动画 Start 89h nn CRC End Start 89h nn 信息码 CRC End 弹出图片 Start D8h nn CRC End Start D8h nn 信息码 CRC End 循环卷动 Start D9h nn CRC End Start D9h nn 信息码 CRC End 取消循环 卷动 Start DBh nn CRC End Start DBh nn 信息码 CRC End 数字图片 1 Start 90h nn ddd.d CRC End Start 90h nn 信息码 CRC End 数字图片 2 Start 91h nn ddd.d CRC End Start 91h nn 信息码 CRC End Start A0h nn CRC End Start A0h nn 信息码 CRC End 按下控件图片时 Start A0h nn 31h CRC End 放开控件图片时 Start A0h nn 30h CRC End 多张图片 单张/ 多张图片 显 显示单一控 件图片 取消单一控 显 示 控 件 图 件图片 A1h nn CRC End Start A1h nn 信息码 CRC End Start A2h nn CRC End Start A2h nn 信息码 CRC End 按下控件图片时 Start A2h nn 31h CRC End 放开控件图片时 Start A2h nn 30h CRC End 信息码 CRC End CRC End CRC End 片 控件 手势滑动 取消控件 触控功能 Pnn Start 虚拟控件 取消虚拟 X, Y, PNG, Start A3h nn CRC End Start A3h nn Start C9h nn CRC End Start C9h nn Start 9Eh CRC End Start 9Eh Code (1Byte) Code (1Byte) Dir+信息 码 信息码 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -20- LT269 主 功 能 小尺寸 TFT 串口屏控制芯片 细项 功能 起始码 指令码 主 控 端 发 送 主 控 端 接 收 (TFT 串口屏接收) (TFT 串口屏发送) 序号 (1Bytes) (1Byte) (1Byte) 指令参数 CRC 码 结束码 (2Bytes) (4Bytes) 起始码 (1Bytes ) 指令码 序号 1Byte) (1Byte) 信息码/ 反馈码 (1Bytes) CRC 码 结束码 (2Bytes) (4Bytes) 迚度条 指标图 Start B0h nn Value (2 Bytes) CRC End Start B0h nn 信息码 CRC 环形指标图 Start DCh nn S_Angle, A_Angle CRC End Start DCh nn 信息码 CRC End 二维码生成 Start 98h nn 字符串 CRC End Start 98h nn 信息码 CRC End 字库-1 Start C0h nn 字符串 String CRC End Start C0h nn 信息码 CRC End 示 字库-2 Start C1h nn 字符串 String CRC End Start C1h nn 信息码 CRC End 字 字库-3 Start C2h nn 字符串 String CRC End Start C2h nn 信息码 CRC End 字库-4 Start C3h nn 字符串 String CRC End Start C3h nn 信息码 CRC End 背光 设置亮度 Start BAh BL (00~0Fh) CRC End Start BAh BL (00~0Fh) 信息码 CRC End 亮度 On/Off Start BCh 00 戒 01 CRC End Start BCh 00 戒 01 信息码 CRC End REP(Bit7) + WAV 编 号 CRC End Start B8h REP(Bit7) + WAV 编号 信息码 CRC End CRC End Start B9h 00 信息码 CRC End 指 标 与 造 图 显 串 End 播放 Start B8h 停止 Start B9h 开机指令 开机指令 Start 9Ah 00 CRC End Start 9Ah 00 信息码 CRC End 合并指令 合并指令 Start 9Ah nn CRC End Start 9Ah nn 信息码 CRC End 设定 时钟 设定时钟 Start 8Ch CRC End Start 8Ch 00 信息码 CRC End 读取时钟 Start 8Dh CRC End Start 8Dh Y, M, D, H, M, S, W (8 ) 信息码 CRC End 显示 时钟 时间、日期 Start 92h nn CRC End Start 92h nn 信息码 CRC End 显示星期 Start 9Dh nn CRC End Start 9Dh nn 信息码 CRC End 电阻屏 校验 电阻屏 校验 Start 8Bh CRC End Start 8Bh 00 信息码 CRC End 联机检查 Start BEh CRC End Start BEh 00 CRC End 信息码 CRC End Wav 檔 串口屏 侦测 寄 存 器 控 制 显示数字 版本检查 执行 9A 指令 设定 寄存器 写入 数据 读取 数据 寄存器 数据加 1 寄存器 数据减 1 Y, M, D, H, M, S, W (7 Bytes) 5Ah, or 55h CRC End Start BFh MCU Code(5Byte s) + Module Info. (42) Reg CRC End Start CAh nn 信息码 CRC End CBh Reg CRC End Start CBh nn 信息码 CRC End Start CCh Data CRC End Start CCh nn 信息码 CRC End Start CDh 00 CRC End Start CDh Data 信息码 CRC End Start CEh Reg CRC End Start CEh nn 信息码 CRC End Start CFh Reg CRC End Start CFh nn 信息码 CRC End Start BFh Start CAh Start LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -21- LT269 主 功 能 小尺寸 TFT 串口屏控制芯片 细项 功能 起始码 指令码 主 控 端 发 送 主 控 端 接 收 (TFT 串口屏接收) (TFT 串口屏发送) 序号 (1Bytes) (1Byte) (1Byte) 指令参数 CRC 码 结束码 (2Bytes) (4Bytes) 起始码 (1Bytes ) 指令码 序号 1Byte) (1Byte) 信息码/ 反馈码 (1Bytes) CRC 码 结束码 (2Bytes) (4Bytes) 画点 Start DFh nn CRC End Start DFh nn 信息码 CRC End 直线 Start E0h nn CRC End Start E0h nn 信息码 CRC End 空心圆形 Start E1h nn CRC End Start E1h nn 信息码 CRC End 实心圆形 Start E2h nn CRC End Start E2h nn 信息码 CRC End 带框实心圆 形 Start E3h nn CRC End Start E3h nn 信息码 CRC End 空心椭圆 Start E4h nn CRC End Start E4h nn 信息码 CRC End 实心椭圆形 Start E5h nn CRC End Start E5h nn 信息码 CRC End 带框实心 椭圆 Start E6h nn CRC End Start E6h nn 信息码 CRC End 几 空心矩形 Start E7h nn CRC End Start E7h nn 信息码 CRC End 何 实心矩形 Start E8h nn CRC End Start E8h nn 信息码 CRC End 带框矩形 Start E9h nn CRC End Start E9h nn 信息码 CRC End 空心圆角 矩形 Start EAh nn CRC End Start EAh nn 信息码 CRC End 实心圆角 矩形 Start EBh nn CRC End Start EBh nn 信息码 CRC End 带框圆角 矩形 Start ECh nn CRC End Start ECh nn 信息码 CRC End 空心三角形 Start EDh nn CRC End Start EDh nn 信息码 CRC End 实心三角形 Start EEh nn CRC End Start EEh nn 信息码 CRC End 带框三角形 Start EFh nn CRC End Start EFh nn 信息码 CRC End 圆柱体 Start F4h nn CRC End Start F4h nn 信息码 CRC End 表格视窗 Start F6h nn CRC End Start F6h nn 信息码 CRC End 图 形 LT269_DS_CH / V1.0 © Levetop Semiconductor Co., Ltd. Page -22- LT269 9.3 小尺寸 TFT 串口屏控制芯片 RS-232(UART) 通讯协议 主控端的系统戒是主板透过 UART 串口传递显示命令给 LT269 TFT 串口屏时,除了 指令码、序号、 指令参数 外还要加上 1 个 Byte 的 起始码(固定为 0xAA)、2 个 Byte 的 CRC 码、4 个 Byte 的 结束码 (固定为 0x E4、0x 1B、0x 11、0x EE),指令信息如下表: 表 9-3:串口屏接收的指令信息 起始码 0xAA (1 Byte) 指令码 序号 1 Byte 1 Byte 指令参数 CRC 码 n Bytes 2 Bytes 结束码 0xE4、0x1B、0x11、0xEE (4 Bytes) CRC 码协议如下: chkSum = Rx_CRC_CCITT(txBuf,txLen); txBuf[txLen++] = (chkSum>>8)&0xFF; txBuf[txLen++] = chkSum&0xFF; unsigned int Rx_CRC_CCITT(unsigned char *puchMsg, unsigned int usDataLen) { unsigned char i = 0; unsigned short wCRCin = 0x0000; unsigned short wCPoly = 0x1021; unsigned char wChar = 0; } while (usDataLen--) { wChar = *(puchMsg++); wCRCin ^= (wChar
LT269 价格&库存
很抱歉,暂时无法提供与“LT269”相匹配的价格&库存,您可以联系我们找货
