YC5018
YC5018
    YICHIP(易兆微)
    QFN-32(5x5)
    YC5018 超低功耗NFC IC
YC5018 数据手册
YC5X NFC IC Product Brief Yichip Microelectronics ©2019 1 / 15 Revision History Version Date Author V1.0 2019-6-6 Team Description Initial version datasheet V2.8 Contents 1 2 3 4 5 6 General Description ....................................................................................................................................... 3 1.1 Product Selection ............................................................................................................................... 3 1.2 Product Introduction .......................................................................................................................... 3 1.3 Key Features ...................................................................................................................................... 3 1.4 Block Diagram ................................................................................................................................... 4 1.5 Pin Assignment .................................................................................................................................. 5 1.5.1 QFN32 — YC5118 / YC5018(G) .............................................................................................. 5 1.5.2 QFN32 — YC5018(H) .............................................................................................................. 6 1.5.3 SOP16 — YC5016 / YC5116 .................................................................................................... 8 1.5.4 QFN20—YC5020 ...................................................................................................................... 9 Functional Description ................................................................................................................................ 10 2.1 ISO/IEC14443A Function Support .................................................................................................. 10 2.2 ISO/IEC14443B Function Support ...................................................................................................11 Reset and Clock ............................................................................................................................................11 3.1 Reset .................................................................................................................................................11 3.2 Clock ................................................................................................................................................ 12 Application Block Diagram ........................................................................................................................ 12 4.1 Typical Circuit ................................................................................................................................. 13 Electrical Specifications .............................................................................................................................. 13 5.1 Voltage Parameters .......................................................................................................................... 13 5.2 Current Parameters .......................................................................................................................... 13 5.3 Environmental Parameters ............................................................................................................... 14 Package Information ................................................................................................................................... 14 6.1 QFN32 Package Dimensions ........................................................................................................... 14 6.2 SOP16 Package Dimensions ............................................................................................................ 15 6.3 QFN20 Package Dimensions ........................................................................................................... 15 Rev. 2.8 Yichip Microelectronics Proprietary 2 / 15 1 General Description 1.1 Product Selection NFC IC No. Part Number Package Spec Pin-to-pin Compatibility Recommended Voltage (V) 1 YC5018 QFN5X5 32pin EMV2.6 FM17550、NXP RC523 3.3 2 YC5118 QFN5X5 32pin EMV3.0 FM17550、NXP RC523 3.3 3 YC5016 SOP16 EMV2.6 3.3 4 YC5116 SOP16 EMV3.0 3.3 5 YC5020 QFN3X3 20pin EMV2.6 3.3 1.2 Product Introduction YC5X is a serial of highly integrated ultra-low power NFC ICs. In accordance with EMV2.6 and EMV3.0 respectively, YC50XX and YC51XX support all layer applications for ISO/IEC14443 Type A/MIFARE and Type B. With extremely simplified peripheral circuits, YC5X serials can provide flexible implementations of all kinds of NFC applications. 1.3 Key Features  YC50XX follows EMV2.6 standard while YC51XX follows EMV3.0 standard;  Supporting ISO/IEC 14443 TypeA/MIFARE communication protocol;  Supporting ISO/IEC 14443 TypeB communication protocol;  Supporting ISO 14443 A/B high speed transport communication at 106kbps / 212kbps / 424kbps / 848kbps;  Supporting external clock input (27.12M/12MHz selectable) without external crystal;  Supporting software AGC with high RX sensitivity and effective communication distance up to 12cm;  Supporting TX waveform self-shaping in order to effectively suppress TX overshoots; Rev. 2.8 Yichip Microelectronics Proprietary 3 / 15  Supporting self-calibration for modulation depth so that the modulation depth is complied with EMV3.0 test requirements under different heights and loadings;  Supporting hardware EMD detection to pass all EMV3.0 EMD cases in order to simplify the design of master program;  Supporting low power card detection (LPCD) function;  Package format: QFN32, SOP16 and QFN20;  IO operating voltage range: 1.65V ~ 5V;  Maximum TX power: 1.4W;  Supporting host interface: 10Mbps SPI, or I2C speed mode up to 400Kbps & speed plus mode up to 1MKbps;  Low power mode: Standby mode and RF off mode  Equipped with CRC and Parity functions, embedded with CRC co-processor, complied with ISO/1EC14443 & CCITT protocol;  Programmable timer and flexible interrupt modes. 1.4 Block Diagram YC51xx Series Block Diagram MCU . .. SPI/I2C RegisterBank RXN ISO-14443 Receiver RXP FIFO TXN ISO-14443 Transmitter TXP PWR CLK OSCIN MISC OSCOUT 图 1. YC5X NFC 芯片系列框图 Rev. 2.8 Yichip Microelectronics Proprietary 4 / 15 1.5 Pin Assignment NC SCL/MISO MOSI SCK NC NC NC NC 32 31 30 29 28 27 26 25 QFN32 — YC5118 / YC5018(G) I2C 1 24 SDA/NSS PVDD 2 23 IRQ DVDD 3 22 OSCOUT DVSS 4 21 OSCIN NC 5 20 GPIO3 NRSTPD 6 19 GPIO2 GPIO0 7 18 AVSS GPIO1 8 17 RX YC5118 9 10 11 12 13 14 15 16 TVSS TX1 TVDD TX2 TVSS AVDD VMID /YC5018(G) NC 1.5.1 QFN32 Figure 2. YC5118 / YC5018(G) package pin Assignment Table 1. QFN32 Pin Assignment —— YC5118 / YC5018(G) 序号 符号 类型 描述 1 I2C I Low level: SPI, High Level: I2C 2 PVDD PWR IO Power supply 3 DVDD PWR Digital Power supply 4 DVSS PWR Digital Ground 5 NC — — 6 NRSTPD I Low enable: Reset or lost power, High for normal operation 7 GPIO0 O GPIO0 control pin 0: low level & 1: Hi-Z 8 GPIO1 O GPIO1 control pin 0: low level & 1: Hi-Z 9 NC — — 10 TVSS PWR TX Ground 11 TX1 O TX output for 13.56MHz modulation on Energy carrier signal 12 TVDD PWR TX Power supply 13 TX2 O TX output for 13.56MHz modulation on Energy carrier signal 14 TVSS PWR TX Ground 15 AVDD PWR Analog Power supply Rev. 2.8 Yichip Microelectronics Proprietary 5 / 15 16 VMID PWR Internal reference voltage 17 RX I RX input 18 AVSS PWR Analog Ground 19 GPIO2 O GPIO2 control pin 0: low level & 1: Hi-Z 20 GPIO3 O GPIO3 control pin 0: low level & 1: Hi-Z 21 OSCIN I Connect to external 27.12MHz Crystal, and optionally to external 27.12MHz or 12MHz clock signal 22 OSCOUT O Connect to external 27.12MHz Crystal 23 IRQ O Output interrupt signal 24 NSS/ SDA/ I/O SPI CS / I2C SDA 25 NC — — 26 NC — — 27 NC — — 28 NC — — 29 SCK I/O SPI SCK 30 MOSI I/O SPI MOSI 31 MISO/SCL I/O SPI MISO / I2C SCL 32 NC — — NC SCL/MISO MOSI SCK GPIO4 GPIO3 GPIO2 GPIO1 32 31 30 29 28 27 26 25 QFN32 — YC5018(H) I2C 1 24 SDA/NSS PVDD 2 23 IRQ DVDD 3 22 OSCOUT DVSS 4 21 OSCIN NC 5 20 NC NRSTPD 6 19 NC 7 18 AVSS 8 17 RX 10 11 12 13 14 15 16 TVSS TX1 TVDD TX2 TVSS AVDD VMID GPIO0 9 NC YC5018(H) NC 1.5.2 QFN32 Figure 3. YC5018(H) Package Pin Assignment Rev. 2.8 Yichip Microelectronics Proprietary 6 / 15 Table 2. QFN32 Pin Assignment —— YC5018(H) 序号 符号 类型 描述 1 I2C I Low level: SPI, High Level: I2C 2 PVDD PWR IO Power supply 3 DVDD PWR Digital Power supply 4 DVSS PWR Digital Ground 5 NC — — 6 NRSTPD I Low enable: Reset or lost power, High for normal operation 7 NC — — 8 GPIO0 O GPIO0 control pin 0: low level & 1: Hi-Z 9 NC — — 10 TVSS PWR TX Ground 11 TX1 O TX output for 13.56MHz modulation on Energy carrier signal 12 TVDD PWR TX Power supply 13 TX2 O TX output for 13.56MHz modulation on Energy carrier signal 14 TVSS PWR TX Ground 15 AVDD PWR Analog Power supply 16 VMID PWR Internal reference voltage 17 RX I RX input 18 AVSS PWR Analog Ground 19 NC — — 20 NC — — 21 OSCIN I Connect to external 27.12MHz Crystal, and optionally to external 27.12MHz or 12MHz clock signal 22 OSCOUT O Connect to external 27.12MHz Crystal 23 IRQ O Output interrupt signal 24 NSS/ SDA/ I/O SPI CS / I2C SDA 25 GPIO1 O GPIO1 control pin 0: low level & 1: Hi-Z 26 GPIO2 O GPIO2 control pin 0: low level & 1: Hi-Z 27 GPIO3 O GPIO3 control pin 0: low level & 1: Hi-Z 28 GPIO4 O GPIO4 control pin 0: low level & 1: Hi-Z 29 SCK I/O SPI SCK 30 MOSI I/O SPI MOSI 31 MISO/SCL I/O SPI MISO / I2C SCL 32 NC — — Rev. 2.8 Yichip Microelectronics Proprietary 7 / 15 1.5.3 SOP16 — YC5016 / YC5116 MOSI 1 16 SCK MISO 2 15 NSS DVDD 3 14 OSCOUT DVSS 4 13 OSCIN NRSTP D 5 12 RX TVSS 6 11 VMID TX1 7 10 AVDD TVDD 8 9 TX2 YC5016 /YC5116 SOP16 Figure 4. YC5016/YC5116 Package Pin Assignment Table 3. SOP16 Pin Assignment —— YC5016 / YC5116 序号 符号 类型 描述 1 MOSI I SPI MOSI 2 MISO O SPI MISO 3 DVDD PWR Digital Power supply 4 DVSS PWR Digital Ground 5 NRSTPD I Low enable: Reset or lost power, High for normal operation 6 TVSS PWR TX Ground 7 TX1 O TX output for 13.56MHz modulation on Energy carrier signal 8 TVDD PWR TX Power supply 9 TX2 O TX output for 13.56MHz modulation on Energy carrier signal 10 AVDD PWR Analog Power supply 11 VMID PWR Internal reference voltage 12 RX I RX input 13 OSCIN I Connect to external 27.12MHz Crystal, and optionally to external 27.12MHz or 12MHz clock signal 14 OSCOUT O Connect to external 27.12MHz Crystal 15 NSS I SPI NSS 16 SCK I SPI SCK Rev. 2.8 Yichip Microelectronics Proprietary 8 / 15 MISO MOSI SCK NSS IRQ 20 19 18 17 16 QFN20—YC5020 PVDD 1 15 OSCOUT DVDD 2 14 OSCIN NRSTPD 3 13 RXP NC 4 12 RXN NC 5 11 VMID 7 8 9 10 TVDD TX2 AVDD NC TX1 YC5020 6 1.5.4 QFN20 Figure 5. YC5020 Package Pin Assignment Table 4. QFN20 Pin Assignment —— YC5020 序号 符号 类型 描述 1 VIO PWR IO Power supply 2 DVDD PWR Digital Power supply 3 NRSTPD I Low enable: Reset or lost power, High for normal operation 4 NC — — 5 NC — — 6 NC — — 7 TX1 O TX output for 13.56MHz modulation on Energy carrier signal 8 TVDD PWR TX Power supply 9 TX2 O TX output for 13.56MHz modulation on Energy carrier signal 10 AVDD PWR Analog Power supply 11 VMID PWR Internal reference voltage 12 RXN I RX- input 13 RXP I RX+ input 14 OSCIN I Connect to external 27.12MHz Crystal, and optionally to external 27.12MHz or 12MHz clock signal 15 OSCOUT O Connect to external 27.12MHz Crystal Rev. 2.8 Yichip Microelectronics Proprietary 9 / 15 16 IRQ O Output interrupt signal 17 NSS I/O SPI NSS 18 SCK I/O SPI SCK 19 MOSI I/O SPI MOSI 20 MISO I/O SPI MISO 21 GND PWR Soldering pad ground 2 Functional Description 2.1 ISO/IEC14443A Function Support Table 5. YC5X ISO/IEC A Communication Overview Communication Direction PCD→PICC PICC→PCD Signal Type Transmission Rate 106kBd 212kBd 424kBd 848kBd PCD Modulation 100%ASK 100%ASK 100%ASK 100%ASK Bit Coding Modified Miller Modified Miller Modified Miller Modified Miller Bit Length (128/13.56)us (64/13.56)us (32/13.56)us (16/13.56)us PICC Modulation Subcarrier load modulation Subcarrier load modulation Subcarrier load modulation Subcarrier load modulation Subcarrier Frequency 13.56MHz/16 13.56MHz/16 13.56MHz/16 13.56MHz/16 Bit Coding Manchester BPSK BPSK BPSK The communication between YC5X and RFID card follows ISO14443 Type A protocol. Figure 3 provides the frame format correlated between PCD and PICC. Figure 4 provides the PICC Standard frame format. Figure 3. Type A PCD → PICC Standard Frame Format Rev. 2.8 Yichip Microelectronics Proprietary 10 / 15 Figure 4. Type A PICC Standard Frame Format 106Kbps According to Section 3 of ISO/IEC14443A, CRC co-processor calculates CRC value and controls the generation of internal verification per transmission rate. 2.2 ISO/IEC14443B Function Support YC5Xsupports ISO/IEC14443 Type B protocol. Figure 5 provides the Type B Standard frame format. Figure 5. Type B Standard Frame Format 3 Reset and Clock 3.1 Reset YC5X works normally when reset pin RST at high level, while is under reset status when RST at low level. The reset and startup procedure needs RST low for at least 5ms and then high for at least 20ms. In some application, Rev. 2.8 Yichip Microelectronics Proprietary 11 / 15 if the startup time is sensitive, after RST is pull high from low, powerup_irq or pmu_state register can be periodically visited to judge whether the chip is started up by checking internal interrupt or state machine. 3.2 Clock YC5X supports clock operation mode with or without external crystal. Mode with crystal supports frequency of 27.12MHz or 13.56MHz. Mode without crystal can reduce BOM cost, but needs external clock with frequency of 27.12Mhz or 12MHz. In this mode, before the chip is powered up, make sure external clock to start up for recommended over 200us. The routine for external clock should be as short as possible and wrapped by ground isolation during PCB layout. 。 4 Application Block Diagram MCU connects YC5X through bus and SPI or I2C to implement 14443 contactless communication. Also through GPIO, MCU can provide reset to YC5X receive interrupt from YC5X. Therefore, all kinds of contactless applications can be developed flexibly. YC5X implements 14443 Type A/MIFARE/Type B protocol for physical and link layers, including modulation/demodulation, framing/Un-framing, CRC verification and etc. YC5X provides AGC adjust for receiving software, detection for low power card and other abundant contactless applications. Figure 6. YC5X Application Block Diagram Example Rev. 2.8 Yichip Microelectronics Proprietary 12 / 15 4.1 Typical Circuit Figure 7. YC5X Typical Circuit 5 Electrical Specifications 5.1 Voltage Parameters Table 12. Voltage Parameters Symbol Parameter DVDD Digital Power Supply Voltage AVDD Analog Power Supply Voltage TVDD TX Power Supply Voltage PVDD IO Power Supply Voltage Conditions PVSS=DVSS=AVSS=TVSS=0V PVDD
YC5018 价格&库存
很抱歉,暂时无法提供与“YC5018”相匹配的价格&库存,您可以联系我们找货
