STK8BA58
STK8BA58
    SENSORTEK(昇佳)
    LGA-12(2x2)
    数字输出三轴MEMS加速度计
STK8BA58 数据手册
STK8BA58 Digital Output 3-axis MEMS Accelerometer Datasheet Version – 1.0 2019/11/26 Hazardous Substance Free RoHS / REACH Compliant STK8BA58 REV 1.0 1. OVERVIEW Description Feature The STK8BA58 is a ±2g/±4g/±8g, 3-axis linear 2 accelerometer, with digital output (I C). It is a low profile capacitive MEMS sensor featuring, compensation for 0g offset and gain errors, and conversion to 12-bit digital values at user configurable samples per second. The device can be arranged for sensor data changes through the interrupt pins. The STK8BA58 is available in a small 2.0mm x 2.0mm x 1.0 mm LGA package and it is guaranteed to operate over an extended temperature range from -40 °C to +85 °C.               Low Voltage Operation: - Supply Internal Domain Voltage: 1.7V~3.6V - I/O Voltage Range: 1.62V~3.6V ±2g/±4g±/8g dynamically selectable full-scale 2 I C digital output interface Low noise 12 bit data output 10000 g high shock survivability 2.0mm x 2.0mm x 1.0 mm LGA Package Configurable Samples from 14 to 2000 samples per second Sleep Feature for Low Power Consumption On-chip interrupt controller, motion-triggered interrupt-signal generation for - New data - Any-motion (slope) detection - Significant motion RoHS Compliant Halogen Free Environmentally Preferred Product Moisture Sensitivity Level 3 Applications        www.sensortek.com.tw 1 Display orientation Gaming and virtual reality input devices Impact recognition and logging Vibration monitoring and compensation Pedometer Activity trackers for fitness apps Smart power management for mobile devices @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 2. PIN DESCRIPTION Pin# Name Dir. Function 1 NC NC 2 SDA B 3 VDDIO PWR 4 Reserved I Recommended tie to GND. 5 INT1 O Interrupt 1 Output. 6 NC NC 7 VS PWR Supply Voltage. 8 GNDIO GND Must be connected to ground. 9 GND GND Must be connected to ground. 10 NC NC Not Internally Connected. 11 NC NC Not Internally Connected. 12 SCL I Not Internally Connected. 2 Serial Data (I C, Open-Drain) Digital Interface Supply Voltage. Not Internally Connected. 2 Serial Communications Clock (I C, Open-Drain) Direction denotation: www.sensortek.com.tw O Output GND Ground I Input B Bi-direction PWR Power NC Not Connected 2 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 www.sensortek.com.tw 3 I2C Interface Digital Engine FUNCTION BLOCK Decimation Filter 3. @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 4. ELECTRICAL SPECIFICATIONS TA = 25°C, VS = 2.6 V, VDDIO = 2.6 V, acceleration = 0 g, CS = CI/O = 10 μF and 0.1 μF Parameter Test Conditions Min Typ Max Unit Operating Voltage Range (VS) 1.7 2.6 3.6 V Interface Voltage Range (VDDIO) 1.62 2.6 3.6 V POWER SUPPLY Current consumption in normal mode Current consumption in suspend mode Current consumption in low-power mode Start-Up Time Sleep duration=25 ms Bandwidth=1k Hz POR Bandwidth=1k Hz Digital high level input voltage (VIH) 110 μA 1 μA 7 uA 3 ms 0.7 x VDDIO V Digital low level input voltage (VIL) 0.3 x VDDIO 1 High level output voltage (VOH) 0.8 x VDDIO V 1 Low level output voltage (VOL) OUTPUT DATA RATE AND BANDWIDTH 0.2 x VDDIO V Each axis Bandwidth (BW) Output data rate (ODR) in normal mode 1. V 7.81 Hz 15.63 Hz 31.25 Hz 62.5 Hz 125 Hz 250 Hz 500 Hz 1000 Hz BW * 2 Hz IOL = 10mA, IOH = -4mA www.sensortek.com.tw 4 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 5. MECHANICAL SPECIFICATIONS TA = 25°C, VS = 2.6 V, VDDIO = 2.6 V, acceleration = 0 g, CS = CI/O = 10 μF and 0.1 μF Parameter SENSOR INPUT Test Conditions Typical Max Unit Each axis Measurement Range User selectable Non-linearity Percentage of full scale Cross-Axis Sensitivity OUTPUT RESOLUTION Min ±2, ±4, ±8 g ±0.5 %FS 1 % Each axis ±2 g Range Full resolution 12 Bits ±4 g Range Full resolution 12 Bits ±8 g Range Full resolution 12 Bits ±2g, 12-bit resolution 1024 LSB/g Sensitivity at XOUT, YOUT, ZOUT ±4g, 12-bit resolution 512 LSB/g Sensitivity Change Due to Temperature X-, Y-, Z-Axes SENSITIVITY Each axis ±8g, 12-bit resolution 0 g OFFSET 1 256 LSB/g ±0.02 %/°C ±100 mg X-, Y-, Z-Axes ±1 mg/°C ±2g, 12-bit resolution Bandwidth = 1k Hz 200 μg/sqrt(Hz) Each axis 0 g Output for XOUT, YOUT, ZOUT 0 g Offset Change Due to Temperature NOISE X-, Y-, Z-Axes 1. These parameters are tested in production at final test, and could slightly change after mounting the sensor onto a printed circuit board or exposing it to extensive mechanical stress. www.sensortek.com.tw 5 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 6. ABSOLUTE MAXIMUM RATINGS Symbol Ratings Maximum value Unit VS VDDIO Vin AUNP TOP TSTG Supply voltage Digital Interface Supply Voltage Input voltage on any control pin Acceleration (any axis, unpowered) Operating temperature range Storage temperature range ESD Electrostatic discharge protection -0.3 to 3.6 -0.3 to 3.6 -0.3 to 3.6 10000 -40 to +85 -40 to +125 2 (HBM) 500 (CDM) 200 (MM) 100 (Latch Up) V V V g °C °C kV V V mA 7. DIGITAL INTERFACE 2 I C digital interface are available in STK8BA53. In the cases, the STK8BA58 operates as a slave device. 7.1 I2C 2 All registers in STK8BA58 can be accessed via the I C bus. All operations can be controlled by the related registers. There are two signals associated with the I2C bus: the serial clock line (SCL) and the serial data line (SDA). The latter is a bidirectional signal used for sending and receiving the data to/from the interface. Both signals are pull-up to VDD I/O through an external resistor. 2 2 A watchdog timer (WDT) is used to prevent the I C bus lock-up by STK8BA53. The I C bus will be reset and return to normal operation state once the WDT is reached. The WDT can be enabled/disabled by I2C_WDT_EN bit and the timer period can be set by I2C_WDT_SEL bit in register INTFCFG (0x34). 2 The STK8BA58 I C command format description for reading and writing operation between the host and STK8BA58 are shown in the following timing chart. Slave Address Slave Address (7-bit) R/W Command Bit 0x18 OPERATION 0 Write Data to STK8BA53 1 Read Data form STK8BA53 Characteristics of the I2C Timing Standard Mode Symbol Fast Mode Parameter Unit Min. Max. Min. Max. fSCLK SCL clock frequency 10 100 10 400 KHz tHDSTA Hold time after (repeated) start condition. After this period, the first clock is generated 4.0 — 0.6 — μs tLOW LOW period of the SCL clock 4.7 — 1.3 — μs www.sensortek.com.tw 6 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 tHIGH HIGH period of the SCL clock 4.0 — 0.6 — μs tSUSTA Set-up time for a repeated START condition 4.7 — 0.6 — μs tHDDAT Data hold time 0 — 0 — ns tSUDAT Data set-up time 250 — 100 — ns tr Rise time of both SDA and SCL signals — 1000 — 300 ns tf Fall time of both SDA and SCL signals — 300 — 300 ns tSUSTO Set-up time for STOP condition 4.0 — 0.6 — μs tBUF Bus free time between a STOP and START condition 4.7 — 1.3 — μs -1 Note: fSCLK is the (tSCLK) . Timing Chart of the I2C Write Command Read Data Sequential Read Data www.sensortek.com.tw 7 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 8. 8.1 PRINPICLE OF OPERATION Mode of Operation STK8BA58 acts as a slave and can communicate with a master (uC or uP). Acceleration data and status information 2 can be accessed with I C interface. The interrupt pin are freely configured by user, depends on different requirements. 8.2 Power Management STK8BA58 has three different power modes, Normal Mode, Low-Power Mode and Suspend Mode. After power-on, it will enter Normal Mode, and user can transfer to Low-Power Mode or Suspend Mode for power-saving purpose. In Normal Mode, all functions are available and data acquisition is performed continuously. In Suspend Mode, whole analog and oscillator are power-down. No data acquisition is performed. Only register reading and writing to SUSPEND bit in register POWMODE (0x11) or register SWRST (0x14) are supported. Suspend mode can be entered by set SUSPEND bit in register POWMODE (0x11) to 1. In the suspend mode, the output data doesn’t clear or update, but keeps the last value before entering into suspend mode. In Low-Power Mode, STK8BA58 will switch between wake-up and sleep phase. In wake-up phase, the device is full functional operation, just like in Normal Mode, and in sleep phase, the analog circuit is power-down except oscillator. During the wake-up phase, enabled interrupts are processed normally. If an interrupt is detected, device will stay in wake-up phase as long as the interrupt condition endures (non-latched interrupt), or until the latch time expires (temporary interrupt), or until the interrupt is reset (latched interrupt). If no interrupt is detected, the device enters the sleep phase automatically. Average current consumption can be effectively reduced by entering low-power mode. Low-power mode can be entered by setting LOWPOWER bit in register POWMODE (0x11) to 1. The duration of sleep phase can be set by SLEEP_DUR [3:0] in register POWMODE (0x11). www.sensortek.com.tw 8 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 SLEEP_DUR[3:0] 4’b0000 ~ 4’b0101 4’b0110 4’b0111 4’b1000 4’b1001 4’b1010 4’b1011 4’b1100 4’b1101 4’b1110 4’b1111 8.3 Duration (ms) 0.5 1 2 4 6 10 25 50 100 500 1000 Actually ODR with 1kHz bandwidth (Hz) 295 255 202 140 110 75 34 18 10 2 1 Data, Range and Bandwidth Acceleration Data The acceleration data of STK8BA58 is 12 bit and is given in two's complement format. The MSB in each axis will be stored in register XOUT2/YOUT2/ZOUT2 (0x03, 0x05, 0x07) individually, and the LSB will be stored in register XOUT1/YOUT1/ZOUT1 (0x02, 0x04, 0x06) individually. The NEW_X/NEW_Y/NEW_Z bit in register XOUT1/YOUT1/ZOUT1 (0x02, 0x04, 0x06) is used for new data flag, and it will be set to 1 if the data is updated, and reset if either the corresponding MSB or LSB is read. Reading the acceleration data registers shall always start with the LSB part due to the data protection function. When data protection function is enabled, the content of an MSB register will be updated by reading the corresponding LSB register. The data protection function can be disabled (enabled) by writing '1' (‘0’) to the PROTECT_DIS bit in register DATASETUP (0x13). With disabled data protection, the content of both MSB and LSB registers is updated by a new value immediately. Range The STK8BA58 supports four different acceleration measurement ranges. A measurement range can be selected by RANGE[3:0] bits in register RANGESEL (0x0F). RANGE[3:0] 4’b0011 4’b0101 4’b1000 others Sensing Range ±2g ±4g ±8g undefined Resolution 0.98 mg/LSB 1.95 mg/LSB 3.91 mg/LSB undefined Bandwidth There are two different data stream of STK8BA53, unfiltered data and filtered data. Unfiltered data is sampled as 2 kHz, and the sample rate of filtered data depends on the selected bandwidth; it is twice of the bandwidth. If the DATA_SEL bit in register DATASETUP (0x13) is set to '0' ('1'), the filtered (unfiltered) data will be stored in the XOUT/YOUT/ZOUT data register. Each of the data stream can be separately offset-compensated, and also can be the data source of interrupts controller. The actual bandwidth for the filtered data can be selected by BW [4:0] bits in register BWSEL (0x10). BW[4:0] 5’b00xxx 5’b01000 5’b01001 5’b01010 5’b01011 5’b01100 5’b01101 5’b01110 5’b01111 5’b1xxxx www.sensortek.com.tw Actual Bandwidth (Hz) 7.81 7.81 15.63 31.25 62.5 125 250 500 1000 1000 9 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 8.4 Motion Algorithm Status and Interrupt Event Detection The following table shows the interrupt events offered by STK8BA53. Two interrupt engines and one INT pins are integrated for conveniently motion detection. Each interrupt could be enabled independently, and mapped into the INT pin. If the condition of enabled interrupt is fulfilled, the corresponding status is set to ‘1’ and the INT pin is asserted. The INT pin state is logical ‘or’ combination of all mapped interrupts. The INT pin state is logical ‘or’ combination of all mapped interrupts. If an interrupt is disabled, all active pins and status are reset immediately. Two motion algorithms, any-motion and significant motion, used for detecting user movement can flexibly choose three independent axes as the data source via register INTEN1 (0x16), and the event signal is triggered by an “OR” combination of the enabled axes. Interrupt Event New Data Any-Motion (Slope) Significant Motion Control Bit DATA_EN in INTEN2 (0x17) SLP_EN_Z in INTEN1 (0x16) SLP_EN_Y in INTEN1 (0x16) SLP_EN_X in INTEN1 (0x16) ANY_MOT_EN in SIGMOT2 (0x2A) SIG_MOT_EN in SIGMOT2 (0x2A) Status Bit in Register INTSTS1/2 (0x09, 0x0A) DATA_STS ANY_MOT_STS SIG_MOT_STS ANY_MOT_STS SIG_MOT_STS Note: Motion algorithm engine follows the logic shown below. Interrupt Latch Mode There are three different interrupt latch modes of Any-Motion (Slope) and Significant Motion: non-latched, temporary, and latched. The modes can be selected by the INT_LATCH [3:0] bits in register INTCFG2 (0x21). The following table shows the different configurations of interrupt modes in INT_LATCH [3:0]. Note: Interrupt latched mode INT_LATCH [3:0] in register INTCFG2 (0x21) can not be default setting after motion algorithms enabled. Interrupt latched mode must be set in the initial configuration. INT_LATCH[3:0] 4’b0000 4’b0001 4’b0010 4’b0011 4’b0100 4’b0101 4’b0110 4’b0111 4’b1000 4’b1001 4’b1010 4’b1011 4’b1100 4’b1101 4’b1110 4’b1111 www.sensortek.com.tw Output Mode non-latched temporary, 250ms temporary, 500ms temporary, 1s temporary, 2s temporary, 4s temporary, 8s latched non-latched temporary, 250us temporary, 500us temporary, 1ms temporary, 12.5ms temporary, 25ms temporary, 50ms latched 10 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 In the non-latched mode, the corresponding status and mapped INT pin are clear as soon as the activation condition is no more valid. In the latched mode, the status and mapped INT pins are cleared only by setting ‘1’ to the INT_RST bit in register INTCFG2 (0x21). If the activation condition still holds when it is cleared, the interrupt pin and status will be both asserted again. In the temporary mode, an asserted interrupt and selected pin are cleared after a defined period of time. The following figure shows the behavior of three interrupt modes. Both filtered and unfiltered data could be the data source of the interrupt events. Setting the corresponding bit in register DATASETUP (0x13) to ‘0’(‘1’) will select the filtered(unfiltered) data as the data source for interrupt events. Interrupt latch mode control bits only apply to Any-Motion (Slope) and Significant Motion. Other interrupt events are fixed to their own latch mode, which are shown in the following table. Interrupt Event New data Any-Motion (Slope) Significant Motion Type Status Programmable Programmable Latch mode Non-latch Programmable Programmable Clear Auto clear after 250us Based on configuration Based on configuration Interrupt Pin Mapping The mapping of interrupts to the INT1 is controlled by registers INTMAP2 (0x1A). Setting the corresponding bit to ‘1’(‘0’) maps(un-maps) the related interrupt to the INT1 pin. INT Pin Output Type and Active Level INT1 could be configured as Push-Pull/Open-Drain output and the active level could also be set as active-high/activelow. The related bits in register INTCFG1 (0x20) are used to select the INT1 output type and active level. 8.5 Offset Compensation Manual Compensation STK8BA58 offers the manual digital offset-compensation method. It is done by adding a compensation value to the acceleration data coming from the ADC. The registers OFSTX/Y/Z (0x38, 0x39, 0x3A) are used to for the offset compensation purpose and are given in two's complement format. 1 LSB of OFSTX/Y/Z represents 7.81mg in any sensing range. By writing '1' to the OFST_RST bit in register OFSTCOMP1 (0x36), all offset compensation registers are reset to zero. It is recommended to write into these registers immediately after a new data interrupt in order not to disturb running offset computations. www.sensortek.com.tw 11 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 9. 9.1 REGISTER DEFINATION Register Map ADDR REG NAME 00h CHIP_ID 01h RESERVED 02h XOUT1 03h XOUT2 04h YOUT1 05h YOUT2 06h ZOUT1 07h ZOUT2 08h RESERVED 09h INTSTS1 BIT 7 BWSEL POWMODE 12h RESERVED 13h DATASETUP SLPSIGN_X 1Bh-1Fh RESERVED 20h INTCFG1 21h INTCFG2 22h-26h RESERVED 27h SLOPEDLY 28h SLOPETHD 29h SIGMOT1 2Ah SIGMOT2 2Bh SIGMOT3 2Ch-33h RESERVED 34h INTFCFG 35h RESERVED 36h OFSTCOMP1 www.sensortek.com.tw SIG_MOT_STS SLP_1ST_Z SLP_1ST_Y SLP_1ST_X DATA_SEL PROTECT_DIS 03h 1Fh reserved SLEEP_DUR[3:0] 00h reserved reserved 00h 00h SLP_EN_Z SLP_EN_Y SLP_EN_X reserved 00h ANYMOT2INT1 reserved reserved SIGMOT2INT1 00h reserved INT1_OD reserved INT1_LV 00h reserved SLP_DUR[1:0] 96h SKIP_TIME[7:0] ANY_MOT_EN SIG_MOT_EN SKIP_TIME[8] 00h I2C_WDT_EN reserved reserved 12 02h 32h PROOF_TIME[6:0] reserved reserved 00h 14h SLP_THD[7:0] reserved 01h 00h INT_LATCH[3:0] reserved OFST_RST 00h DATA2INT1 reserved reserved 00h 00h reserved DATA_EN reserved INT_RST 00h 00h reserved reserved 00h 00h BW[4:0] reserved 00h 00h reserved INTEN1 INTMAP2 reserved RANGE[3:0] 16h INTMAP1 ANY_MOT_STS reserved LOWPOWER 00h 00h reserved reserved 19h NEW_Z 00h reserved SUSPEND 00h 00h reserved SLPSIGN_Y SWRST[7:0] 1Ah NEW_Y reserved SWRST INTEN2 reserved 00h 00h reserved RESERVED RESERVED NEW_X reserved 15h 18h reserved ZOUT[11:4] SLPSIGN_Z Default 00h ZOUT[3:0] 14h 17h 0 YOUT[11:4] reserved 11h 1 87h YOUT[3:0] DATA_STS 10h 2 XOUT[11:4] INTSTS2 RESERVED 3 reserved EVENTINFO1 RANGESEL 4 XOUT[3:0] 0Bh 0Fh 5 CHIP_ID[7:0] 0Ah 0Ch-0Eh 6 I2C_WDT_SEL reserved 00h 00h 00h @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 37h RESERVED reserved 00h 38h OFSTX OFST_X[7:0] 00h 39h OFSTY OFST_Y[7:0] 00h 3Ah OFSTZ OFST_Z[7:0] 00h 9.2 Register Description CHIP_ID Register (00h) b7 b6 b5 b4 b3 b2 b1 b0 b3 b2 reserved 3’b000 RO b1 b0 NEW_X 0 RO CHIP_ID[7:0] 8’b10000111 RO The register contains the chip identification code. XOUT1 Register (02h) b7 b6 b5 b4 XOUT[3:0] 4’b0000 RO XOUT1/XOUT2 register contain the x-axis acceleration data and the new data flag for the x-axis. XOUT2 Register (03h) b7 b6 b5 b4 b3 b2 b1 b0 b3 b2 reserved 3’b000 RO b1 b0 NEW_Y 0 RO XOUT[11:4] 8’b00000000 RO YOUT1 Register (04h) b7 b6 b5 b4 YOUT[3:0] 4’b0000 RO YOUT1/YOUT2 register contain the y-axis acceleration data and the new data flag for the y-axis. YOUT2 Register (05h) b7 b6 b5 b4 b3 b2 b1 b0 b3 b2 reserved 3’b000 RO b1 b0 NEW_Z 0 RO b1 b0 YOUT[11:4] 8’b00000000 RO ZOUT1 Register (06h) b7 b6 b5 b4 ZOUT[3:0] 4’b0000 RO ZOUT1/ZOUT2 register contain the z-axis acceleration data and the new data flag for the z-axis. ZOUT2 Register (07h) b7 b6 b5 b4 b3 b2 ZOUT[11:4] 8’b00000000 RO www.sensortek.com.tw 13 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 INTSTS1 Register (09h) b7 b6 b5 reserved 5’b00000 RO b4 b3 b2 ANY_MOT_STS 0 RO b1 reserved 0 RO b0 SIG_MOT_STS 0 RO This register contains the interrupts status in STK8BA53. BIT 0 2 BIT NAME SIG_MOT_STS ANY_MOT_STS Description Significant motion interrupt status. ‘1’ : event triggered, ‘0’ : no event. Any-motion (slope) detection interrupt status. ‘1’ : event triggered, ‘0’ : no event. INTSTS2 Register (0Ah) b7 DATA_STS 0 RO b6 b5 b4 b3 reserved 7’b0000000 RO b2 b1 b0 b1 SLP_1ST_Y 0 RO b0 SLP_1ST_X 0 RO This register contains the new data interrupt status in STK8BA53. BIT 7 BIT NAME DATA_STS Description New data interrupt status. ‘1’ : event triggered, ‘0’ : no event. EVENTINFO1 Register (0Bh) b7 reserved 0 RO b6 SLPSIGN_Z 0 RO b5 SLPSIGN_Y 0 RO b4 SLPSIGN_X 0 RO b3 reserved 0 RO b2 SLP_1ST_Z 0 RO This register contains any-motion (slope) detection information. BIT 0 1 2 BIT NAME SLP_1ST_X SLP_1ST_Y SLP_1ST_Z 4 SLPSIGN_X 5 SLPSIGN_Y 6 SLPSIGN_Z Description 1 : Motion on the X-axis cause SLOPE interrupt asserted. 1 : Motion on the Y-axis cause SLOPE interrupt asserted. 1 : Motion on the Z-axis cause SLOPE interrupt asserted. Sign of acceleration slope on the X-axis that triggered the SLOPE interrupt. 0 : positive. 1 : negative. Sign of acceleration slope on the Y-axis that triggered the SLOPE interrupt. 0 : positive. 1 : negative. Sign of acceleration slope on the Z-axis that triggered the SLOPE interrupt. 0 : positive. 1 : negative. RANGESEL Register (0Fh) b7 b6 b5 b4 b3 reserved 4’b0000 RO b2 b1 b0 RANGE[3:0] 4’b0011 R/W This register contains the acceleration sensing range. RANGE[3:0] 4’b0011 4’b0101 4’b1000 others www.sensortek.com.tw Sensing Range ±2g ±4g ±8g undefined 14 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 BWSEL Register (10h) b7 b6 reserved 3’b000 RO b5 b4 b3 b2 BW[4:0] 5’b11111 R/W b1 b0 b1 b0 reserved 0 RO b1 b0 This register contains the output data bandwidth selection. BW[4:0] 5’b00xxx 5’b01000 5’b01001 5’b01010 5’b01011 5’b01100 5’b01101 5’b01110 5’b01111 5’b1xxxx Actual Bandwidth (Hz) 7.81 7.81 15.63 31.25 62.5 125 250 500 1000 1000 POWMODE Register (11h) b7 SUSPEND 0 R/W b6 LOWPOWER 0 R/W b5 reserved 0 RO b4 b3 b2 SLEEP_DUR[3:0] 4’b0000 R/W This register contains the power mode selection and the sleep time duration setting. BIT BIT NAME [4:1] SLEEP_DUR[3:0] 6 LOWPOWER 7 SUSPEND Description Sleep time duration. SLEEP_DUR[3:0] 4’b0000 ~ 4’b0101 4’b0110 4’b0111 4’b1000 4’b1001 4’b1010 4’b1011 4’b1100 4’b1101 4’b1110 4’b1111 Duration (ms) 0.5 1 2 4 6 10 25 50 100 500 1000 0 : low-power mode disable. 1 : low-power mode enable. 0 : suspend mode disable. 1 : suspend mode enable. DATASETUP Register (13h) b7 DATA_SEL 0 R/W b6 PROTECT_DIS 0 R/W b5 b4 b3 b2 reserved 6’b000000 RO This register is used to select if the output data is filtered or unfiltered and how the output data contained in the register XOUT1/XOUT2, YOUT1/YOUT2, ZOUT1/ZOUT2 are updated. www.sensortek.com.tw 15 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 BIT BIT NAME 6 PROTECT_DIS 7 DATA_SEL Description 0 : Enable the data protection function. 1 : Disable the data protection function. 0 : Data output filtered. 1 : Data output unfiltered. SWRST Register (14h) b7 b6 b5 b4 b3 b2 b1 b0 SWRST[7:0] 8’b00000000 W This register is used to software reset. Write 0xB6 into SWRST to reset all the registers to default value. INTEN1 Register (16h) b7 b6 b5 reserved 5’b00000 RO b4 b3 b2 SLP_EN_Z 0 R/W b1 SLP_EN_Y 0 R/W b0 SLP_EN_X 0 R/W b1 b0 b1 reserved 0 RO b0 SIGMOT2INT1 0 R/W This register contains the several interrupt enable bit. BIT BIT NAME 0 SLP_EN_X 1 SLP_EN_Y 2 SLP_EN_Z Description 0 : Disable X-axis any-motion (slope) interrupt. 1 : Enable X-axis any-motion (slope) interrupt. 0 : Disable Y-axis any-motion (slope) interrupt. 1 : Enable Y-axis any-motion (slope) interrupt. 0 : Disable Z-axis any-motion (slope) interrupt. 1 : Enable Z-axis any-motion (slope) interrupt. INTEN2 Register (17h) b7 b6 Reserved 3’b000 RO b5 b4 DATA_EN 0 R/W b3 b2 reserved 4’b0000 RO This register contains the several interrupt enable bit. BIT BIT NAME 4 DATA_EN Description 0 : Disable new data interrupt. 1 : Enable new data interrupt. INTMAP1 Register (19h) b7 b6 b5 Reserved 5’b00000 RO b4 b3 b2 ANYMOT2INT1 0 R/W This register is used to map the related interrupt to the desired INT pin. BIT BIT NAME 0 SIGMOT2INT1 2 ANYMOT2INT1 www.sensortek.com.tw Description 0 : Do not map significant motion interrupt to INT1. 1 : Map significant motion interrupt to INT1. 0 : Do not map any-motion (slope) interrupt to INT1. 1 : Map any-motion (slope) interrupt to INT1. 16 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 INTMAP2 Register (1Ah) b7 b6 b5 b4 reserved 7’b0000000 RO b3 b2 b1 b0 DATA2INT1 0 R/W b2 b1 INT1_OD 0 R/W b0 INT1_LV 1 R/W This register is used to map the related interrupt to the desired INT pin. BIT BIT NAME 0 DATA2INT1 Description 0 : Do not map new data interrupt to INT1. 1 : Map new data interrupt to INT1. INTCFG1 Register (20h) b7 b6 b5 b4 b3 reserved 6’b000000 RO This register is used to define the INT1 pin output type and active level. Open-drain or Push-pull output type and active high or active low can be selected. BIT BIT NAME 0 INT1_LV 1 INT1_OD Description INT1 active level selection. 0 : Active low. 1 : Active high. INT1 output type selection. 0 : Push-pull output type. 1 : Open-drain output type. INTCFG2 Register (21h) b7 INT_RST 0 R/W b6 b5 reserved 3’b000 RO b4 b3 b2 b1 INT_LATCH[3:0] 4’b0000 R/W b0 This register is used to reset latched interrupt pin and select the interrupt mode. BIT BIT NAME [3:0] INT_LATCH[3:0] 7 INT_RST www.sensortek.com.tw Description INT pin output mode selection. INT_LATCH[3:0] Output Mode 4’b0000 non-latched 4’b0001 temporary, 250ms 4’b0010 temporary, 500ms 4’b0011 temporary, 1s 4’b0100 temporary, 2s 4’b0101 temporary, 4s 4’b0110 temporary, 8s 4’b0111 latched 4’b1000 non-latched 4’b1001 temporary, 250us 4’b1010 temporary, 500us 4’b1011 temporary, 1ms 4’b1100 temporary, 12.5ms 4’b1101 temporary, 25ms 4’b1110 temporary, 50ms 4’b1111 latched 1 : Reset any latched interrupt pin. 17 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 SLOPEDLY Register (27h) b7 b6 b5 b4 b3 b2 reserved 6’b000000 RO b1 b0 SLP_DUR[1:0] 2’b00 R/W This register is used to set the number of samples needed in slope detection. The actual number of samples will be equal to SLP_DUR[1:0] + 1. SLOPETHD Register (28h) b7 b6 b5 b4 b3 SLP_THD[7:0] 8’b00010100 R/W b2 b1 b0 This register is used to set the threshold value for the slope detection. The actual slope threshold will depend on sensing range. The default value of SLP_THD[7:0] is 0x14. RANGE[3:0] 4’b0011 4’b0101 4’b1000 Sensing Range ±2g ±4g ±8g Actual Slope Threshold (mg) SLP_THD[7:0] * 3.91 SLP_THD[7:0] * 7.81 SLP_THD[7:0] * 15.63 SIGMOT1 Register (29h) b7 b6 b5 b4 b3 SKIP_TIME[7:0] 8’b10010110 R/W b2 b1 b0 This register is used to set the skip time for the significant motion. Holding the duration for skip, for which the motion is checked for re-detection. 1 LSB=20 ms. Range is 0 to 10sec. The default value of SKIP_TIME[8:0] is 0x96 correspond to 3 seconds. SIGMOT2 Register (2Ah) b7 b6 b5 reserved 5’b00000 RO b4 b3 b2 b1 ANY_MOT_EN SIG_MOT_EN 0 1 R/W R/W b0 SKIP_TIME[8] 0 R/W This register contains MSB of SKIP_TIME[8:0] for the significant motion, and significant motion interrupt enable bit. BIT BIT NAME 1 SIG_MOT_EN 2 ANY_MOT_EN Description 0 : Disable significant motion. 1 : Enable significant motion. 0 : Disable any-motion. 1 : Enable any-motion. SIGMOT3 Register (2Bh) b7 reserved 0 RO b6 b5 b4 b3 PROOF_TIME[7:0] 7’b0110010 R/W b2 b1 b0 This register is used to set the proof time for the significant motion. Holding the duration for proof, for which the motion is re-checked after. 1 LSB=20 ms. Range is 0 to 2.5sec. The default value of PROOF_TIME[8:0] is 0x32 correspond to 1 seconds. www.sensortek.com.tw 18 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 INTFCFG Register (34h) b7 b6 b5 reserved 5’b00000 RO b4 b3 b2 b1 I2C_WDT_EN I2C_WDT_SEL 0 0 R/W R/W b0 reserved 0 RO 2 This register contains the digital interface parameters for the I C interface. BIT BIT NAME Description 2 1 I2C_WDT_SEL 2 I2C_WDT_EN I C watchdog timer period selection. 0 : Watchdog timer period 1ms. 1 : Watchdog timer period 50ms. 2 I C watchdog timer enable bit. 0 : Disable I2C watchdog timer. 1 : Enable I2C watchdog timer. OFSTCOMP1 Register (36h) b7 OFST_RST 0 W b6 b5 b4 b3 reserved 2’b0000000 R b2 b1 b0 This register is used to define the setting for the offset compensation. BIT 7 BIT NAME OFST_RST Description 1 : Reset all the offset compensation register (register 0x38 ~ 0x3A) to zero. OFSTX Register (38h) B7 b6 b5 b4 b3 b2 b1 b0 b2 b1 b0 b2 b1 b0 OFST_X[7:0] 8’b00000000 R/W This register contains the offset compensation value for the x-axis data output. OFSTY Register (39h) B7 b6 b5 b4 b3 OFST_Y[7:0] 8’b00000000 R/W This register contains the offset compensation value for the y-axis data output. OFSTZ Register (3Ah) b7 b6 b5 b4 b3 OFST_Z[7:0] 8’b00000000 R/W This register contains the offset compensation value for the z-axis data output. Register 0x38 to 0x3A can be modified manually set by user. The value in these register will be added to the actual acceleration data sensing by STK8BA58 and store the new value to XOUT/YOUT/ZOUT register. www.sensortek.com.tw 19 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 10. APPLICATION INFORMATION 10.1 New Data Interrupt This interrupt serves for synchronous reading of acceleration data. It is generated after storing a new value of z-axis acceleration data in the data register. The interrupt is cleared automatically when the next cycle of data acquisition starts. The interrupt status is ’0’ for at least 50μs. The interrupt mode of the new data interrupt is fixed to non-latched for at least 250 us. Control Register INTEN2[4] INTSTS[7] INTMAP2 DATASETUP[5] Bit Name DATA_EN DATA_STS DATA2INT1 DATA_SEL Function ‘1’: enabled, ‘0’: disabled, and the interrupt mode is fixed to non-latched. The interrupt status. New data interrupt maps to INT1. ‘1’: unfiltered data, ‘0’: filtered data, as the input of the new data interrupt. 10.2 Any-motion (Slope) Detection Any-motion (slope) detection is to detect the change of motion. By monitoring the slop of acceleration, user can estimate the variation of acceleration. STK8BA58 use the slop between successive acceleration data to detect it, and would active the interrupt when the slop exceeds a preset threshold. Moreover, a duration setting has to be configured to suppress failure signals. The following figure shows the relationship between acceleration data, acceleration slop, and INT status. If a certain number N of consecutive slope data points is larger (smaller) than the slope threshold, the INT would be trigger (clear). One LSB of SLP_THD [7:0] represents 1 LSB of acceleration data, and it depends on which sensing range is set. For Example, 3.91mg in 2g-range, 7.81 mg in 4g-range, 15.6 mg in 8g-range and 31.3 mg in 16g-range. The consecutive slope data points are set by SLP_DUR [1:0], and is equal to (SLP_DUR [1:0] + 1). The time difference between the successive acceleration signals depends on the selected bandwidth and equates to 1/(2*bandwidth). Any-motion (slope) detection can be enabled by writing ‘1’ to ANY_MOT_EN bit in the register SIGMOT2 (0x2A). Furthermore, user must select which axes are enabled independently by writing ‘1’ to the bit SLP_EN_X, SLP_EN_Y, and SLP_EN_Z in the register INTEN1 (0x16). If slope of any axis fulfills the specified condition, INT pin would be triggered, interrupt status would be updated to ANY_MOT_STS, and the sign of slop would be shown in SLPSIGN_X, SLPSIGN_Y, SLPSIGN_Z. Moreover, SLP_1ST_X, SLP_1ST_Y, and SLP_1ST_Z would indicate which axis is the first axis triggering the interrupt of slop detection. Control Register INTEN1 [0] INTEN1 [1] INTEN1 [2] SIGMOT2[2] SLOPETHD [7:0] SLOPEDLY [1:0] INTMAP1 INTSTS1 [2] DATASETUP [7] EVENTINFO1 [0] EVENTINFO1 [1] EVENTINFO1 [2] EVENTINFO1 [4] EVENTINFO1 [5] EVENTINFO1 [6] www.sensortek.com.tw Bit Name SLP_EN_X SLP_EN_Y SLP_EN_Z ANY_MOT_EN SLP_THD SLP_DUR ANTMOT2INT1 ANT_MOT _STS DATA_SEL SLP_1ST_X SLP_1ST_Y SLP_1ST_Z SLPSIGN_X SLPSIGN_Y SLPSIGN_Z Function Slope detection enable for X-axis, ‘1’: enabled, ‘0’: disabled for Y-axis, ‘1’: enabled, ‘0’: disabled for Z-axis, ‘1’: enabled, ‘0’: disabled Any-motion enable bit. 0: Disabled. 1: Enabled. Slope threshold, 1LSB=1LSB of XOUT/YOUT/ZOUT Slope duration, 1LSB=1/(2*bandwidth) Slope detection interrupt maps to INT1 Slope detection status which is synchronized with INT1 activity ‘1’: unfiltered data, ‘0’: filtered data, as the input of the slop detection ‘1’: triggered axis, ‘0’: not triggered Sign of slope when interrupt is triggered, ‘0’: Positive, ‘1’: Negative 20 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 Note1: In order to ensure motion algorithm working normally, interrupt latched mode must be set before motion algorithms enabled. Note2: It’s not recommended that motion algorithm working in the low-power mode and set BW less than 1k Hz simultaneously. 10.3 Significant Motion The significant motion is defined as some activities that might lead to a change in a user's location. Examples of significant motions are walking or biking, sitting in a moving car, coach or train, etc. Examples of situations that should not trigger significant motion include phone in pocket and person is not moving, phone is on a table and the table shakes a bit due to nearby traffic or washing machine. For more information, please refer to Android Sensor types: https://source.android.com/devices/sensors/sensor-types.html#significant_motion. Significant motion function would be triggered by means of monitoring the slope of acceleration over a period of time. The algorithm will be started when a motion is detected, and generates a signal if another motion is detected after the SKIP_TIME[8:0] (0x29-0x2A) and within the PROOF_TIME[7:0] (0x2B). Both 1 LSB of skip time and proof time correspond to 20ms. The significant motion and slope detection share event-triggered settings including independent XYZ-axes slope enable bit INTEN1 [2:0] (0x16), threshold SLOPETHD [7:0] (0x28), duration SLOPEDLY [1:0] (0x27). User should be noticed that the slope detection has to be enabled before enabling significant motion due to a sharing algorithm engine. Then enable significant motion by writing ‘1’ to SIG_MOT_EN bit in register SIGMOT2 (0x2A). www.sensortek.com.tw 21 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 Follow the steps below to enable significant motion: Step1. (MUST) Set interrupt configurations INTCFG1 (0x20) and INTCFG2 (0x21). Step2. Set configuration settings include SKIP_TIME[8:0] (0x29-0x2A), PROOF_TIME[7:0] (0x2B), SLOPEDLY[1:0] (0x27) and SLOPETHD[7:0] (0x28). Step3. Set XYZ-axes slope detection enabled by INTEN1[2:0] (0x16). Step4. Set significant motion enabled by SIGMOT2[1] (0x2A). Step5. Mapping significant motion to physical interrupt pin by INTMAP1[0] (0x19). Step6. Wait for INT triggered or monitor SIG_MOT_STS bit in INTSTS1[0] (0x09) Significant Motion algorithm flow chart 10.4 Application Circuit I2C Interface Note: A 22 ohm resistor is recommended to filter out the system power noise. www.sensortek.com.tw 22 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 10.5 Sensing Axes Orientation By measuring the acceleration components respect to g field, the position and orientation information could be recognized. It could be used for such applications as Portrait/Landscape in Mobile phone/PDA/PMP. This enables a product to set its display orientation appropriately to either portrait/landscape mode, or to turn off the display if the product is placed upside down. The sensor provides positive or negative directions of X/Y/Z axes. The relationship between directions and six different positions: Left, Right, Up, Down, Back, and Front, is shown in the following figure. If the sensor is at rest and the force of gravity is acting along the indicated directions, the output of the corresponding channel will be negative (static acceleration). Example: If the sensor is at rest or at uniform motion in a gravity field according to the figure given below, the output signals are: ± 0g for the X-axis ± 0g for the Y-axis + 1g for the Z-axis Gravity Vector Front (+Z) Up (+X) Right (+Y) Left (-Y) Down (-X) Back (-Z) Sensing axes orientation The following table lists all corresponding output signals on X, Y, and Z while the sensor is at rest or at uniform motion in a gravity field under assumption of a ±2g range setting, a 12 bit resolution, and a top down gravity vector as shown above. Sensor Orientation & X-axis Output Y-axis Output Z-axis Output www.sensortek.com.tw Top View Top View Top View Top View +1g/1024LSB 0g / 0 LSB 0g / 0 LSB 0g / 0 LSB +1g/1024LSB 0g / 0 LSB -1g/1024LSB 0g / 0 LSB 0g / 0 LSB 0g / 0 LSB -1g/1024LSB 0g / 0 LSB 23 Side View Side View 0g / 0 LSB 0g / 0 LSB +1g/1024LSB 0g / 0 LSB 0g / 0 LSB -1g/1024LSB @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 11. PACKAGE OUTLINE 11.1 Package Outline Drawing SYMBOLS A A1 A2 D D1 D2 D3 D4 D5 E E1 E2 E3 E4 E5 e y www.sensortek.com.tw DIMENSIONS IN MILLIMETERS MIN. NOM. MAX 0.95 1.00 1.05 0.16 0.19 0.22 0.80 REF. 1.95 2.00 2.05 1.51 REF. 0.24 0.29 0.34 0.23 0.28 0.33 0.325 0.375 0.425 0.10 REF. 1.95 2.00 2.05 1.50 REF. 0.23 0.28 0.33 0.24 0.29 0.34 0.10 REF. 0.11 REF. 0.50 REF. 0.00 --0.10 24 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 11.2 Recommended PCB Layout The PCB layout should use NSMD (Non Solder mask Defined) pad definitions for all pads. The solder mask opening must be defined at least 0.05 mm larger than the metal pad on all sides. 11.3 Marking Rule Marking YYYY XXXX ● www.sensortek.com.tw Symbol Name YYYY Order number XXXX Product serial number ● Pin1 dot 25 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 11.4 Tape and Reel Information 1. Carrier Tape Specification 2. Reel Specification 3. Unit Orientation www.sensortek.com.tw 26 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 11.5 Soldering Condition 1. Pb-free solder temperature profile Max. temperature 265+0/-5°C/10sec. 255°C 200°C Ramp-down rate 6°C/sec. max. Ramp-up rate 3°C/sec. max. 217°C Ramp-up rate 3°C/sec. max. Soldering Zone 60~150 sec. 150°C Pre-heating Time 60~180 sec. 2. Reflow soldering should not be done more than three times. 3. When soldering, do not put stress on the ICs during heating. 4. After soldering, do not warp the circuit board. 11.6 Soldering Iron Each terminal is to go to the tip of soldering iron temperature less than 350℃ for 3 seconds within once in less than the soldering iron capacity 25W. Leave two seconds and more intervals, and do soldering of each terminal. Be careful because the damage of the product is often started at the time of the hand solder. 11.7 Repairing Repair should not be done after the ICs have been soldered. When repairing is unavoidable, a double-head soldering iron should be used (as below figure). It should be confirmed beforehand whether the characteristics of the ICs will or will not be damaged by repairing. www.sensortek.com.tw 27 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 12. STORAGE INFORMATION 12.1 Storage Condition 1. Devices are packed in moisture barrier bags (MBB) to prevent the products from moisture absorption during transportation and storage. Each bag contains a desiccant. 2. The delivery product should be stored with the conditions shown below: Storage Temperature Relatively Humidity 10 to 30℃ below 60%RH 12.2 Treatment After Unsealed 1. Floor life (time between soldering and removing from MBB) must not exceed the time shown below: Floor Life Storage Temperature Relatively Humidity 168 Hours 10 to 30℃ below 60%RH 2. When the floor life limits have been exceeded or the devices are not stored in dry conditions, they must be rebaked before reflow to prevent damage to the devices. The recommended conditions are shown below Temperature Re-Baking Time www.sensortek.com.tw 60℃ 12 Hours 28 @copyright 2019 Sensortek Technology Corp. STK8BA58 REV 1.0 Revision History Date 2019/11/26 Version 1.0 Modified Items Initial release. Important Notice This document contains information that is proprietary to Sensortek Technology Corp. (“sensortek”), and is subject to change without notice. Any part of this document may not be used, reproduced, duplicated or disclosed in any form or any means without the prior written permission of sensortek. Sensortek does not warrant or represent that any license, either express or implied, is granted under any sensortek‘s patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which sensortek‘s products or services are used. In addition, Sensortek does not assume any liability for the occurrence of infringing on any patent or other intellectual property rights of a third party. Sensortek reserves the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. www.sensortek.com.tw 29 @copyright 2019 Sensortek Technology Corp.
STK8BA58 价格&库存
很抱歉,暂时无法提供与“STK8BA58”相匹配的价格&库存,您可以联系我们找货
