MSNP10065G1
MSNP10065G1
650V Silicon Carbide Schottky Diode
Features
Benefits
-650-Volt Schottky Rectifier
-Shorter recovery time
-High-speed switching possible
-High-Frequency Operation
-Temperature-Independent Switching Behavior
-Extremely Fast Switching
-Positive Temperature Coefficient on VF
-Higher safety margin against overvoltage
-Improved efficiency all load conditions
-Increased efficiency compared to Silicon Diode alternatives
-Reduction of Heat Sink Requirements
-Parallel Devices Without Thermal Runaway
-Essentialy No Switching Losses
Applications
Package
-Switch Mode Power Supplies
-Power Factor Correction
-Motor Drives
-HID Lighting
Type : TO-220 -2lead
1、Cathode 2、Anode
1
Absolute Maximum Ratings
2
TC = 25℃ unless otherwise noted
Symbol
Parameter
MSNP10065G1
Units
VRRM
Repetitive Peak Reverse Voltage
650
V
VRSM
Surge Peak Reverse Voltage
650
V
VDC
DC Blocking Voltage
650
V
IF
Continuous Forward Current
@Tc=135℃
10
A
IFRM
Repetitive Peak Forward Surge Current @TC=25 ̊C
tp = 10 ms, Half Sine Wave
80
A
IFSM
Non-Repetitive Peak Forward Surge Current @TC=25 ̊C
tp= 10 ms, Half Sine Wave
90
A
IFSM
@TC=25 ̊C, tp= 10 us,pulse
840
A
71
31
W
Ptot
Power Dissipation
@Tc=25℃
@Tc=110℃
TJ , Tstg
Operating Junction and Storage Temperature
-55 to +175
̊C
VI
Isolation Blocking Voltage (leg to case)
3000
V
Meipusen Co.,Ltd
http://www.meipusen.com
page1
Rev1.0 Sep . 2019
MSNP10065G1
Electrical Characteristics
TC = 25°C unless otherwise noted
Symbol
Test Conditions
Test Conditions
Min
Typ
Max
Unit
VF
Forward Voltage
IF=10 A, TC=25°C
IF= 10 A, TC=175°C
1.45
1.75
1.7
2.00
V
IR
Reverse Current
VR=650V, TC=25°C
VR=650V, TC=175°C
2
40
μA
QC
Total Capacitive Charge
VR =400V, TJ = 25°C
Vr
Qc= 0 C ( V ) dv
28
C
Total Capacitance
VR =0V, TJ = 25°C, f=1MHz
VR =200V, TJ = 25°C, f=1MHz
VR =400V, TJ = 25°C, f=1MHz
550
53
48
pF
EC
Capacitance Stored Energy
VR=400V
7.0
μJ
nC
Thermal Characteristics
Symbol
Parameter
Typ
Unit
RθJC
Thermal Resistance from Junction to Case
2.1
℃/W
Typical Characteristics
100
16
14
O
Tj=75 C
O
Tj=25 C
60
O
Tj=125 C
12
O
Tj=75 C
O
O
Tj=175 C
10
IR (A)
IF (A)
80
O
Tj=25 C
8
Tj=125 C
O
Tj=175 C
40
6
2
0.5
1.0
1.5
VF (V)
2.0
2.5
3.0
Figure 1.Forward Characteristics
Meipusen Co.,Ltd
200
300
400
500
VR (V)
600
700
800
Figure 2. Reverse Characteristics
page2
Rev1.0 Sep . 2019
900
MSNP10065G1
600
40
35
500
30
Qc (nC)
C (pF)
400
300
25
200
10
100
5
0.1
1
10
100
VR (V)
1000
Figure 3. Capacitance vs. Reverse Voltage
200
300
VR (V)
400
500
600
Figure 4. Total Capacitance Charge vs. Reverse Voltage
80
14
12
60
8
Ptot (W)
Ec (J)
10
6
40
2
200
300
VR (V)
400
500
600
25
Figure 5. Capacitance Stored Energy
50
75
100
125
150
175
0.01
0.1
1
TC(C )
Figure 6. Power Derating
70
10% Duty
20% Duty
30% Duty
50% Duty
70% Duty
DC
IF(peak) (A)
50
1
Thermal Resistance (C /W)
60
40
30
50
75
TC (C)
100
125
150
175
Figure 7.Current Derating
Meipusen Co.,Ltd
0.5
0.3
0.1
0.1
0.05
0.02
0.01
SinglePulse
0.01
1E-6
1E-5
1E-4
1E-3
T (sec)
Figure 8. Transient Thermal Impedance
page3
Rev1.0 Sep . 2019
很抱歉,暂时无法提供与“MSNP10065G1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.14560
- 10+10.89720
- 30+10.72440
- 100+10.56240
