Pb
RoHS
MSF08065G1
650V Silicon Carbide Diode
Features
Benefits
-650-Volt Schottky Rectifier
-Shorter recovery time
-High-speed switching possible
-High-Frequency Operation
-Temperature-Independent Switching Behavior
-Extremely Fast Switching
-Positive Temperature Coefficient on VF
-Higher safety margin against overvoltage
-Improved efficiency all load conditions
-Increased efficiency compared to Silicon Diode alternatives
-Reduction of Heat Sink Requirements
-Parallel Devices Without Thermal Runaway
-Essentialy No Switching Losses
Applications
Package
-Switch Mode Power Supplies
-Power Factor Correction
-Motor Drives
-HID Lighting
Type : TO-220F -2lead
1、Cathode 2、Anode
PIN 1
CASE
1
Absolute Maximum Ratings
2
1
2
PIN 2
TC = 25 ℃ unless otherwise noted
Symbol
Parameter
MSF08065G1
Units
VRRM
Repetitive Peak Reverse Voltage
650
V
VRSM
Surge Peak Reverse Voltage
650
V
VDC
DC Blocking Voltage
650
V
8
A
IF
Continuous Forward Current
Tc=120℃
IFRM
Repetitive Peak Forward Surge Current
tp = 10 ms, Half Sine Wave @TC=25 ̊C
45
A
IFSM
Non-Repetitive Peak Forward Surge Current
tp= 10 ms, Half Sine Wave @TC=25 ̊C
60
A
IFSM
@TC=25 ̊C, tp= 10 us,pulse
250
A
50
22
W
-55 to +175
̊C
Ptot
TJ , Tstg
Power Dissipation
@Tc=25 ℃
@Tc=110 ℃
Operating Junction and Storage Temperature
MAPLESEMI CONDUCTOR Co.,Ltd
http://www.Maplesemi.com
page1
Rev1.0 Oct . 2019
MSF08065G1
LEAD FREE
TC = 25°C unless otherwise noted
Symbol
Test Conditions
Test Conditions
Min
Typ
Max
Unit
VF
Forward Voltage
IF=8A, TC=25°C
IF=8A, TC=175°C
1.45
1.75
1.7
2.0
V
IR
Reverse Current
VR=650V, TC=25°C
VR=650V, TC=175°C
2
40
μA
QC
Total Capacitive Charge
VR =400V, IF =8A
TJ = 25°C
Vr
Qc= C ( V ) dv
22
MSF08065G1
Electrical Characteristics
nC
C
Total Capacitance
VR =0V, TJ = 25°C, f=1MHz
VR =200V, TJ = 25°C, f=1MHz
VR =400V, TJ = 25°C, f=1MHz
440
44
38
pF
EC
Capacitance Stored Energy
VR=400V
5.8
μJ
Thermal Characteristics
Symbol
Parameter
Typ
Unit
RθJC
Thermal Resistance from Junction to Case
2.95
℃/W
Typical Characteristics
16
100
14
O
Tj=25 C
12
80
O
Tj=25 C
O
Tj=75 C
O
Tj=75 C
O
Tj=125 C
O
Tj=125 C
60
O
Tj=175 C
IR (A)
IF (A)
10
8
6
4
O
Tj=175 C
40
0.5
1.0
1.5
VF (V)
2.0
2.5
3.0
300
400
500
600
700
800
VR (V)
Figure 1.Forward Characteristics
100
Figure 2. Reverse Characteristics
page2
Rev1.0 Oct . 2019
900
MSF08065G1
500
35
30
400
25
Qc (nC)
C (pF)
300
200
10
100
5
0.1
1
VR (V)
10
100
1000
Figure 3. Capacitance vs. Reverse Voltage
50
8
40
Ptot (W)
10
Ec (J)
60
6
10
200
300
400
VR (V)
Figure 5. Capacitance Stored Energy
500
200
300
VR (V)
400
500
600
25
50
75
TC (C)
100
125
150
Figure 6. Power Derating
60
10% Duty
20% Duty
30% Duty
50% Duty
70% Duty
DC
50
40
IF(peak) (A)
30
50
75
100
125
150
175
TC ( °C )
Figure 7.Current Derating
600
30
4
Figure 4. Total Capacitance Charge vs. Reverse Voltage
12
Figure 8. Transient Thermal Impedance
page3
Rev1.0 Oct . 2019
175
很抱歉,暂时无法提供与“MSF08065G1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.57120
- 10+10.62720
- 50+9.40680
