UMW
R
UMW 2SC3265
SOT-23 Plastic-Encapsulate Transistors
2SC3265
SOT-23
TRANSISTOR (NPN)
FEATURES
1. BASE
2. EMITTER
z
z
3. COLLECTOR
High DC current gain
Complementary to KTA1298
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
35
V
VCEO
Collector-Emitter Voltage
30
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current -Continuous
800
mA
PC
Collector Power Dissipation
200
mW
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC= 100μA, IE=0
35
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= 10mA, IB=0
30
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100μA, IC=0
5
V
Collector cut-off current
ICBO
VCB=30 V, IE=0
0.1
μA
IEBO
VEB=5 V, IC=0
0.1
μA
DC current gain
hFE
VCE=1V, IC= 100mA
Collector-emitter saturation voltage
VBE
Transition frequency
fT
Collector output capacitance
VCE=1V,IC=10mA
VCE=5V, IC=10mA
f=100MHz
Cob
320
IC=500mA, IB=20mA
VCE(sat)
base-emitter voltage
100
VCB=10V,IE=0,f=1MHZ
0.5
0.5
V
0.8
V
120
MHz
13
pF
CLASSIFICATION OF hFE
Rank
Range
Marking
www.umw-ic.com
O
Y
100-200
160-320
EO
EY
1
友台半导体有限公司
UMW
R
UMW 2SC3265
Typical Characterisitics
Static Characteristic
160
COMMON
EMITTER
Ta=25℃
450uA
hFE
DC CURRENT GAIN
400uA
350uA
300uA
80
250uA
200uA
150uA
40
IC
Ta=100℃
120
IC
(mA)
500uA
COLLECTOR CURRENT
hFE
400
300
Ta=25℃
200
100
100uA
COMMON EMITTER
VCE=1V
IB=50uA
0.5
1.0
1.5
2.0
COLLECTOR-EMITTER VOLTAGE
VCEsat
1
10
3
IC
VBEsat
1.2
300
100
30
COLLECTOR CURRENT
(V)
IC
Ta=100℃
100
Ta=25℃
30
IC
Ta=25℃
0.8
Ta=100℃
0.4
β=25
β=25
10
0.0
1
10
3
IC
800
300
100
30
COLLECTOR CURRENT
IC
1
800
10
3
(mA)
COLLECTOR CURRENT
—— VBE
Cob/ Cib
100
IC
300
800
(mA)
VCB/ VEB
Cib
(mA)
Ta=100℃
(pF)
30
C
100
30
CAPACITANCE
IC
100
30
300
COLLECTOR CURRENT
800
(mA)
300
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
600
VCE
2.5
Ta=25℃
10
10
Cob
3
f=1MHz
IE=0/IC=0
3
COMMON EMITTER
VCE=1V
1
0.2
0.4
0.6
0.8
1.0
Ta=25℃
1
0.1
1.2
fT
400
1
0.3
—— IC
PC
250
10
3
REVERSE VOLTAGE
BASE-EMMITER VOLTAGE VBE (V)
V
(V)
Ta
VCE=5V
TRANSITION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
PC (mW)
(MHz)
Ta=25℃
200
100
5
200
150
100
50
COLLECTOR CURRENT
www.umw-ic.com
100
30
IC
(mA)
25
50
75
100
AMBIENT TEMPERATURE
2
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW 2SC3265
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“2SC3265”相匹配的价格&库存,您可以联系我们找货
