MMBTA42
MMBTA42
    UMW(友台)
    SOT23-3
MMBTA42 数据手册
UMW R UMW MMBTA42 SOT-23 Plastic-Encapsulate Transistors MMBTA42 TRANSISTOR (NPN) SOT-23 FEATURES z High breakdown voltage z Low collector-emitter saturation voltage z Complementary to MMBTA92 (PNP) 1. BASE 2. EMITTER 3. COLLECTOR Marking: 1D MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 300 V VCEO Collector-Emitter Voltage 300 V VEBO Emitter-Base Voltage 5 V IC Collector Current -Continuous 0.3 A ICM Collector Current-Peak 0.5 A PC Collector Power dissipation 0.35 W RӨJA Thermal Resistance, junction to Ambient 357 ℃/W TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Max Unit Collector-base breakdown voltage V(BR)CBO IC= 100μA,IE=0 300 V Collector-emitter breakdown voltage V(BR)CEO IC= 1mA, IB=0 300 V Emitter-base breakdown voltage V(BR)EBO IE= 100μA, IC=0 5 V Collector cut-off current ICBO VCB=200V, IE=0 0.25 μA Emitter cut-off current IEBO VEB= 5V, IC=0 0.1 μA hFE(1) VCE= 10V, IC= 1mA 60 hFE(2) VCE= 10V, IC=10mA 100 hFE(3) VCE=10V, IC=30mA 60 Collector-emitter saturation voltage VCE(sat) IC=20mA, IB= 2mA 0.2 V Base-emitter saturation voltage VBE(sat) IC= 20mA, IB=2mA 0.9 V DC current gain fT Transition frequency www.umw-ic.com 1 VCE= 20V, IC= 10mA, f=30MHz 50 200 MHz 友台半导体有限公司 UMW R UMW MMBTA42 SOT-23 Plastic-Encapsulate Transistors IC 18 VCE —— 90uA —— IC COMMON EMITTER Ta=25℃ hFE 80uA 70uA DC CURRENT GAIN (mA) 12 COLLECTOR CURRENT 14 IC 16 hFE 1000 60uA 50uA 10 40uA 8 30uA 6 Ta=100℃ Ta=25℃ 100 20uA 4 IB=10uA COMMON EMITTER VCE=10V 2 10 0.1 0 0 2 4 6 8 10 12 14 16 COLLECTOR-EMITTER VOLTAGE COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) —— 20 22 IC 10 VBEsat —— 900 Ta=100 ℃ 100 1 COLLECTOR CURRENT BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) VCEsat 500 18 VCE (V) Ta=25℃ 100 IC (mA) IC Ta=25℃ 600 Ta=100 ℃ β=10 β=10 10 0.1 1 10 COLLECTOR CURREMT IC 100 —— IC 300 0.1 100 fT VBE —— IC 100 (mA) IC (MHz) 300 fT 1 300 600 900 COMMON EMITTER VCE=20V Ta=25℃ 0.1 0 100 TRANSITION FREQUENCY T =2 5℃ a T =1 00℃ a 10 COMMON EMITTER VCE=10V 10 0.1 1200 1 Cob/Cib 100 —— VCB/VEB COLLECTOR POWER DISSIPATION PC (mW) Ta=25 ℃ (pF) C 10 Cob 1 0.1 1 REVERSE VOLTAGE www.umw-ic.com 10 V PC 400 f=1MHz IE=0/IC=0 Cib 10 COLLECTOR CURRENT BASE-EMMITER VOLTAGE VBE (mV) CAPACITANCE 10 COLLECTOR CURREMT (mA) (mA) IC COLLECTOR CURRENT 1 —— IC 100 (mA) Ta 300 200 100 0 20 0 (V) 25 50 75 AMBIENT TEMPERATURE 2 100 Ta 125 150 (℃ ) 友台半导体有限公司 UMW R Symbol A A1 A2 b c D E E1 e e1 L L1 θ www.umw-ic.com UMW MMBTA42 SOT-23 Plastic-Encapsulate Transistors Dimensions In Millimeters Min. Max. 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP. 1.800 2.000 0.550 REF. 0.300 0.500 0° 8° 3 Dimensions In Inches Min. Max. 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP. 0.071 0.079 0.022 REF. 0.012 0.020 0° 8° 友台半导体有限公司
MMBTA42
物料型号为 MMBTA42,属于SOT-23塑料封装的NPN型晶体管。
器件简介:MMBTA42晶体管具有高击穿电压和低饱和电压的特性,与MMBTA92(PNP型)互补。
引脚分配:1. 基极(BASE),2. 发射极(EMITTER),3. 集电极(COLLECTOR)。
参数特性: - 集-基击穿电压(VcBO):300V - 集-射击穿电压(VCEO):300V - 发-基击穿电压(VEBO):5V - 集电极连续电流(Ic):0.3A - 集电极峰值电流(IcM):0.5A - 集电极功耗(Pc):0.35W - 热阻(ROJA):357°C/W - 极性温度(TJ):150°C - 存储温度(Tstg):-55°C至+150°C
功能详解:MMBTA42晶体管具有直流电流增益(hFE)的变化范围,以及集-射饱和电压和基-射饱和电压的参数。
应用信息:适用于需要高击穿电压和低饱和电压的电路中。
封装信息:SOT-23封装,具体尺寸包括A、A1、A2、b、C、D、E、E1、e、e1、L、L1、日等参数,详见文档中提供的详细尺寸表。
MMBTA42 价格&库存
很抱歉,暂时无法提供与“MMBTA42”相匹配的价格&库存,您可以联系我们找货
MMBTA42
  • 1+0.58564
  • 200+0.19602
  • 1500+0.12221
  • 3000+0.09680
库存:2490
MMBTA42
  • 1+0.10350
  • 10+0.09930
  • 100+0.09420
  • 500+0.08960
  • 1000+0.08640
库存:2264
MMBTA42
  • 20+0.19268
  • 200+0.14894
  • 600+0.12464
  • 3000+0.11006
  • 9000+0.09742
  • 21000+0.09062
库存:2176
