UMW
R
UMW MMBT5401
SOT-23 Plastic-Encapsulate Transistors
MMBT5401
TRANSISTOR (PNP)
SOT–23
MARKING: 2L
1. BASE
2. EMITTER
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-160
V
VCEO
Collector-Emitter Voltage
-150
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-0.6
A
PC
Collector Power Dissipation
0.3
W
Thermal Resistance from Junction to Ambient
416
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
3. COLLECTOR
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Collector-base breakdown voltage
Symbol
V(BR)CBO
Collector-emitter breakdown voltage
V(BR)CEO
Emitter-base breakdown voltage
V(BR)EBO
Collector cut-off current
ICBO
Emitter cut-off current
IEBO
hFE(1)
DC current gain
hFE(2) *
hFE(3)
Collector-emitter saturation voltage
Base-emitter saturation voltage
Test
conditions
Min
Typ
Max
Unit
IC=-100µA, IE=0
-160
V
IC=-1mA, IB=0
-150
V
IE=-10µA, IC=0
-5
V
VCB=-120V, IE=0
-0.1
μA
VEB=-4V, IC=0
-0.1
μA
VCE=-5V, IC=-1mA
80
VCE=-5V, IC=-10mA
100
VCE=-5V, IC=-50mA
50
300
VCE(sat)1
IC=-10mA, IB=-1mA
-0.2
V
VCE(sat)2
IC=-50mA, IB=-5mA
-0.5
V
VBE(sat)1
IC=-10mA, IB=-1mA
-1
V
VBE(sat)2
IC=-50mA, IB=-5mA
-1
V
Transition frequency
fT
VCE=-5V,IC=-10mA, f=30MHz
100
MHz
*Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%.
CLASSIFICATION OF hFE (2)
RANK
L
H
RANGE
100-200
200-300
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW MMBT5401
Static Characteristic
-20
-100uA
VCE=-5V
COMMON
EMITTER
Ta=25℃
-90uA
o
hFE
-70uA
200
-12
-60uA
-10
-50uA
-8
-40uA
-6
Ta=100 C
250
-80uA
DC CURRENT GAIN
(mA)
-14
COLLECTOR CURRENT
-16
IC
-18
hFE —— IC
300
150
o
Ta=25 C
100
-30uA
-4
50
-20uA
-2
IB=-10uA
-0
-0
-3
-9
COLLECTOR-EMITTER VOLTAGE
VCE
-1
VBEsat —— IC
-1.0
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
-0.6
Ta=100℃
-0.4
-0.2
-1
-10
COLLECTOR CURRENT
IC
IC
-0.1
Ta=25℃
-1
-10
Cob / Cib
100
IC
(mA)
—— VCB / VEB
VCE=-5V
o
(pF)
o
Ta=100 C
Ta=25℃
-1
-0.2
-0.4
-0.6
-0.8
BASE-EMITTER VOLTAGE
fT
10
Cob
1
-0.5
-1.0
-1
-10
REVERSE VOLTAGE
VBE(V)
—— IC
Pc
0.4
COLLECTOR POWER DISSIPATION
Pc (W)
300
250
fT
(MHz)
Cib
C
-10
CAPACITANCE
COLLECTOR CURRENT
IC (mA)
f=1MHz
IE=0 / IC=0
Ta=25 C
-0.1
-0.0
TRANSITION FREQUENCY
-600
-100
COLLECTOR CURRENT
(mA)
IC —— V
BE
-100
(mA)
Ta=100℃
-0.01
-0.1
-600
-100
IC
β=10
Ta=25℃
-0.0
-0.1
-600
-100
VCEsat ——
-1
β=10
-0.8
-10
COLLECTOR CURRENT
(V)
200
150
100
50
V
(V)
Ta
0.3
0.2
0.1
VCE=-5V
o
Ta=25 C
-0
-5
-10
-15
COLLECTOR CURRENT
www.umw-ic.com
-20
IC
-25
-30
50
75
AMBIENT TEMPERATURE
(mA)
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW MMBT5401
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“MMBT5401”相匹配的价格&库存,您可以联系我们找货
