UMW
R
UMW MMBTA92
SOT-23 Plastic-Encapsulate Transistors
SOT-23
MMBTA92
TRANSISTOR (PNP)
FEATURES
1. BASE
2. EMITTER
High voltage transistor
3. COLLECTOR
MARKING:2D
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Value
Unit
VCBO
Symbol
Collector-Base Voltage
Parameter
-300
V
VCEO
Collector-Emitter Voltage
-300
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-200
mA
ICM
Collector Current -Pulsed
-500
mA
PC
Collector Power Dissipation
300
mW
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
RӨJA
Thermal Resistance from Junction to Ambient
417
℃/W
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC= -100μA, IE=0
-300
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= -1mA, IB=0
-300
V
Emitter-base breakdown voltage
V(BR)EBO
IE= -100μA, IC=0
-5
V
Collector cut-off current
ICBO
VCB=-200V, IE=0
-0.25
μA
Emitter cut-off current
IEBO
VEB= -5V, IC=0
-0.1
μA
hFE(1)
VCE= -10V, IC= -1mA
60
hFE(2)
VCE= -10V, IC=-10mA
100
hFE(3)
VCE= -10V, IC=-30mA
60
DC current gain
200
Collector-emitter saturation voltage
VCE(sat)
IC=-20mA, IB= -2mA
-0.2
Base-emitter saturation voltage
VBE(sat)
IC= -20mA, IB= -2mA
-0.9
Transition frequency
www.umw-ic.com
fT
VCE=-20V, IC= -10mA
f=30MHz
1
50
V
V
MHz
友台半导体有限公司
UMW
R
UMW MMBTA92
IC
70
(mA)
IC
hFE
DC CURRENT GAIN
IC
-350uA
-300uA
40
-250uA
-200uA
30
-150uA
Ta=100℃
Ta=25℃
100
-100uA
10
IB=-50uA
COMMON EMITTER
VCE= -10V
8
12
16
COLLECTOR-EMITTER VOLTAGE
VCEsat
-0.1
24
-1
VCE (V)
-10
-100
COLLECTOR CURRENT
IC
VBEsat ——
-900
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
-500
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
COMMON
EMITTER
Ta=25℃
-400uA
50
hFE
1000
-450uA
60
COLLECTOR CURRENT
VCE
-500uA
Ta=100 ℃
-100
Ta=25℃
IC
IC
Ta=25℃
-600
Ta=100 ℃
β=10
β=10
-50
-10
-0.1
-1
-10
COLLECTOR CURREMT
IC
-100
IC
-300
-0.1
-50
-10
COLLECTOR CURREMT
(mA)
fT
VBE
-100
IC
(mA)
IC
(MHz)
300
fT
(mA)
T =2
5℃
a
TRANSITION FREQUENCY
-10
T =1
00℃
a
IC
COLLECTOR CURRENT
-1
-1
100
COMMON EMITTER
VCE=-20V
COMMON EMITTER
VCE= -10V
Ta=25℃
10
-0.1
-0.1
-0
-300
-600
-900
-1200
-1
Cob/Cib
100
VCB/VEB
(pF)
COLLECTOR POWER DISSIPATION
PC (mW)
Ta=25 ℃
C
10
Cob
1
-0.1
-1
REVERSE VOLTAGE
www.umw-ic.com
-10
V
PC
350
f=1MHz
IE=0/IC=0
Cib
-10
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (mV)
CAPACITANCE
-300
(mA)
IC
-100
(mA)
Ta
300
250
200
150
100
50
(V)
25
50
75
AMBIENT TEMPERATURE
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW MMBTA92
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“MMBTA92”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19829
- 200+0.15574
- 600+0.13220
- 3000+0.10692
- 9000+0.09461
- 21000+0.08802
- 国内价格
- 1+0.56979
- 200+0.19071
- 1500+0.11817
- 3000+0.09419
