AX6646BA
AX6646BA
    AXELITE(亚瑟莱特)
    SOT23-5
    800MV~5.5V 300MA 6V
AX6646BA 数据手册
AX6646/A 300mA LDO Regulator with Enable  GENERAL DESCRIPTION The AX6646/A is a 300mA, low quiescent, high PSRR, low noise and low dropout linear regulator. The Device includes pass element, error amplifier, band-gap, current limit and thermal shutdown circuitry. The characteristics of low dropout voltage and less quiescent current make it good for some critical current application, for example, some battery powered devices. The typical quiescent current is approximately 40µA. In the shutdown mode, the maximum supply current is less than 1uA. The Output voltage is adjustable from 0.8V to 5.5V. Built-in current-limit, Short current protection and thermal-shutdown functions prevent any fault condition from IC damage.  FEATURES - Input voltage range is up to 6V 200mV Dropout at 150mA output current Guaranteed 300mA output current Low quiescent current 40µA (typ.) Adjustable Output voltage form 0.8V to 5.5V Maximum shutdown current
AX6646BA 价格&库存
很抱歉,暂时无法提供与“AX6646BA”相匹配的价格&库存,您可以联系我们找货
