KNP series
WIRE WOUND RESISTORS, FLAMEPROOF
Features
1. Super heat dissipation small linear temperature
coefficient.
2. Instant overload capability low noise figure and
low annual shift on resistance values.
3. Flameproof, light weight, price is lower than enamel
types.
4. Winding wires are much more durable than enamel
types which are produced in high temperature.
1.
2.
3.
4.
ELECTRICAL AND MECHANICAL PERFORMANCE
Characteristics
Resistance Tolerance
Resistance Temp. Coeff.
Power Rating Load
Short Time Overload
Dielectric Withstanding Voltage
Insulation Resistance
Terminal Strength
Test Methods
Standards
5% ( J ) or
1% ( F )
300 ppm /
-55
Surface temp. 275 Max.
275 , R/R
2%
2%
No evidence of mechanical damage
or insulation breakdown.
~ 200
Rated voltage for 30 minutes
/ 30
10 times of rated wattage
for 5 seconds.
10
/5
Applying suitable voltage listed on
Dimensions for one minute.
1
DC100V or 500V megger
1,000MÙ
No evidence of mechanical damage.
Minimum 95% coverage
95%
Resistance to Soldering Heat
, R/R
1%
Solder-ability
< 1W
> 2W
235 5
1 kg
2.5 kg
for 2 seconds
270 5 for 10 1 seconds
350 10 for 3.5 0.5 seconds
ENVIRONMENTAL CHARACTERISTICS
Characteristics
Standards
Temp. Cycle
R/R
1%
Load Life
R/R
3%
Moisture-proof Load Life
R/R
3%
Nonflammability
Reference Standards
JIS C 5201-1
not flamed
9
Test Methods
-55 ( 30 min.)
Room Temp.( 3 min.)
+200 ( 30 min.)
Room Temp.( 3 min.) / ( 5 cycles)
Rated power load 90 minutes ON
30 minutes OFF
70 1000 hours
30 minutes OFF
40 95% RH 1000 hours
16 times of rated wattage for 5 min.
KNP series
Dimensions
Unit mm
d
H
L
H
D
Dielectric
Withstanding
Voltage
Rated
Wattage
D 1
L 1
H 3
d 0.1
Resistance
Range(Ù)
1/4W
2.6 0.5
6.8
28
0.6
0.1~200
250V
1/2W
3.0
9
28
0.65
0.1~300
350V
1W
4
9
28
0.65
0.1~500
350V
2W
5.0
11
28
0.8
0.1~1K
500V
3W
5.5
13
38
0.8
0.1~1K
500V
3WL
5.5
15
38
0.8
0.1~1.2K
500V
5W
6.5
19
38
0.8
0.1~1.2K
500V
6W
8.5
24
38
0.8
0.1~1.5K
500V
7W
8.5
32
33
0.8
0.1~1.5K
500V
8W
8.5
41
38
0.8
0.1~2.2K
800V
10W
8.5
53
38
0.8
0.1~3.3K
1000V
Note: Too low or too high ohmic values can be supplied only case by case.
Derating Curve
Surface Temperature Rise
For resistors operated in ambient temperatures above 70 ,
power rating must be derated in accordance with the curve
below.
-55
70
(OC)
100
Rated Load
80
60
40
100
150
200
250
300
4W~10W
200
3W(3WL)
2W
100
1/4W~1W
275
Ambient Temp.
(OC)
60
80
Rated Load
How to order
It is composed by Type, Rated Wattage, Nominal Resistance, Tolerance and Package. e.g.
KNP
a.
1W
b.
10R
c.
J
d.
T/B
e.
a. Type(
): Wire Wound Resistors, Flameproof are called "KNP".
b. Rated Wattage(
) : Shown by "W" such as 1/4W, 1/2W, 1W, 2W, 3W,
3WL, 5W, 6W, 7W, 8W, 10W
c. Nominal Resistance(
) : 10Ù.
d. Tolerance(
): F
1% , J
5% .
e. Package (
T/R tape & reel (
); T/B tape in box(
); Nil Bulk(
10
100
很抱歉,暂时无法提供与“KNP 3W 22R J T/B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.63148
- 50+0.50609
- 150+0.44334
