OR-355-TP-G
OR-355-TP-G
    ORIENT(奥伦德)
    SOP-4-2.54mm
    消费级 OR-355-TP-G
OR-355-TP-G 数据手册
Shenzhen Orient Components Co ., Ltd OR-355 ORIENT Photo coupler Product Data Sheet 、 Part Number: OR-355 Customer: Date: SHENZHEN ORIENT COMPONENTS CO.,LTD. Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2020 Orient .All rights Reserved 1 V2 Shenzhen Orient Components Co ., Ltd OR-355 1. Features (1) Current transfer ratio(( CTR : MIN. 600% at IF = 1mA, VCE = 2V,Ta=25℃) (2) High input -output isolation voltage (VISO=3,750Vrms) (3) High collector-emitter voltage (VCEO = 80V) (4) Working Temperature -55 ℃ to 110 ℃ (5) SOP-4 package (6) Safety approval UL approved(No.E323844) VDE approved(No.40029733) CQC approved (No.CQC19001231254) (7) In compliance with RoHS, REACH standards (8) MSL Class Ⅰ 2. Instructions  The OR-355 series device contains an infrared emitting diodes, optically to a photo Darington detector.They are encapsulated in a 4 pin SOP encapsulation.  Pin pitch of OR-355 is 2.54mm 3. Application Range  Hybrid substrates that require high density mounting.  Programmable controllers  System appliance, measuring instruments Copyright© 2020 Orient .All rights Reserved 2 V2 Shenzhen Orient Components Co ., Ltd OR-355 4. Max Absolute rated Value (Normal Temperature=25℃) Parameter Input Output Symbol Rated Value Unit Forward Current IF 50 mA Junction Temperature TJ 125 ℃ Reverse Voltage VR 6 V Consume Power P 100 mW Collector and emitter Voltage VCEO 80 Emitter and collector Voltage VECO 7 Collector Current IC 90 mA Consume Power PC 150 mW Total Consume Power Ptot 200 mW *1 Insulation Voltage Viso 3750 Vrm s Working Temperature Topr -55 to + 110 V ℃ Deposit Temperature Tstg -55 to + 125 *2 Soldering Temperature Tsol 260 *1. AC Test, 1 minute, humidity = 40~60% Insulation test method as below: (1) Short circuit both terminals of photo coupler. (2) No Current when testing insulationvoltage. (3) Adding sine wave voltage when testing. *2. soldering time is 10 seconds. Copyright© 2020 Orient .All rights Reserved 3 V2 Shenzhen Orient Components Co ., Ltd OR-355 5. Opto-electronic Characteristics Parameter Input Output Transforming Characteristics  Condition Symbol Min Typ.* Max Unit Forward Voltage VF --- 1.1 1.4 V IF=20mA Reverse Current IR --- --- 5 µA VR =5V Terminal Capacitance Ct --- 30 250 pF Collector Dark Current ICEO --- --- 400 nA V=0, f=1KHz VCE=40V, IF=0 Collector-Emitter Breakdown Voltage BV CEO 40 --- --- V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BV ECO 7 --- --- V IE=0.1mA, IF=0 1.Current Transfer Ratio CTR 600 --- 7500 % Collector Current IC 6 --- 75 mA VCE(sat) --- --- 1 V IF=1mA, IC= 2mA Insulation Impedance Riso 5×1010 1×1011 --- Ω DC500V 40~60%R.H. Floating Capacitance Cf --- 0.6 1 pF V=0, f=1MHz Response Time(Rise) tr --- 200 --- μs Descend Time(fall) tf --- 200 --- μs VCC=5V, IC=2mA, RL=100Ω Collector-Emitter Saturation Voltage IF=1mA, VCE=2V Current Conversion Ratio = IC / IF × 100% Copyright© 2020 Orient .All rights Reserved 4 V2 Shenzhen Orient Components Co ., Ltd OR-355 6. Rank table of current transfer ratio CTR(tolerance:±3%) MODEL NO. OR-355 CTR Rank NO mark Min. 600 Max. --- Unit Condition % IF=1mA, VCE=2V, Ta=25℃ 7. Order Information Part Number OR-355-X-Y-Z Note X = Tape and reel option (TP or TP1). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free. * VDE Code can be selected. Option Description Packing quantity TP Surface mount lead form (low profile) + TP tape & reel option 3000 units per reel TP1 Surface mount lead form (low profile) + TP1 tape & reel option 3000 units per reel Copyright© 2020 Orient .All rights Reserved 5 V2 Shenzhen Orient Components Co ., Ltd OR-355 8. Naming Rule 1. Manufacturer : ORIENT. 2. Part Number : 355. 3. Year Code 4. Week Code 5. VDE Code 6. HF Code ‘G’: Halogen Free. 7. Anode. : '21' means '2021' and so on. : 01 means the first week, 02 means the second week and so on. . * VDE Code can be selected. Copyright© 2020 Orient .All rights Reserved 6 V2 Shenzhen Orient Components Co ., Ltd OR-355 9. Outer Dimension 10. Recommended Foot Print Patterns (Mount Pad) unit:mm Copyright© 2020 Orient .All rights Reserved 7 V2 Shenzhen Orient Components Co ., Ltd OR-355 11. Taping Dimensions (1)OR-355-TP 2.54±0.1 (2)OR-355-TP1 Description Symbol Dimension in mm(inch) Tape wide W 12±0.3(0.472) Pitch of sprocket holes P0 4±0.1(0.157) F 5.5±0.1(0.217) P2 2±0.1(0.079) P1 8±0.1(0.315) Distance of compartment Distance of compartment to compartment Package Type TP/TP1 Quantities(pcs) 3000 Copyright© 2020 Orient .All rights Reserved 8 V2 Shenzhen Orient Components Co ., Ltd OR-355 12. Package Dimension (1) package dimension Packing Information Packing type Reel type Tape Width 12mm Qty per Reel 3,000pcs Small box (inner) Dimension 345*345*45mm Large box (Outer) Dimension 480x360x360mm Max qty per small box 6,000pcs Max qty per large box 60,000pcs (2)Packing Label Sample Note: 1. P/N :Contents with "Order Information" in the specification. 2. LOT NO : The production lot. 3. BATCH : The Electrical rank. 4. Quantity :Packaging quantity. 5. Product Data :Date of manufacture. Copyright© 2020 Orient .All rights Reserved 9 V2 Shenzhen Orient Components Co ., Ltd OR-355 13. Reliability Test NO. 1 ITEMS RSH 耐焊接热 Reliability Testing QTY. (Pcs) 22 Condition 260±5℃ Process 10s/3 次 Device Standard 锡炉 JESD22-A106 高温烤箱 测试仪 JESD22-A103 低温箱 测试仪 JESD22-A119 168 hrs 2 HTSL 高温存储 77 125℃ 500 hrs 1000 hrs 168 hrs 3 LTSL 低温存储 77 -55℃ 500 hrs 1000 hrs 4 5 TC 温度循环 TS 温度冲击 77 H:125℃ 15min ∫5min L:-55℃ 15min 300 cycle 冷热冲击机 JESD22-A104 77 H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle 冷热冲击机 JESD22-A106 高温烤箱 测试仪、老 化电路板 JESD22-A108 ESD静电测 试仪 JESD22-A114 锡炉 JESD22-B102 高温烤箱 ,测试仪 JESD22-A103 恒温恒湿 机,测试仪 JESD22-A101 压力锅 JESD22-A102 168 hrs 6 7 8 9 10 11 HTOL 高温操作 ESD-HBM 人体模式 SD 可焊性 HTRB 高温反向偏压 H3TRB 温湿度反向偏 压,寿命试验 Autoclave 压力锅 110°C IF=10mA Vce=5V 500 hrs 22 ≥8KV 1Cycle 1次 22 Pb-free 245±5℃ 5S/1次 77 HTRB @125℃ Vce=80v 77 77 77 H3TRB 85℃,85%RH Vce=80v Ta=121 ℃,100%RH,2atm Copyright© 2020 Orient .All rights Reserved 1000 hrs 168 hrs 500 hrs 1000 hrs 168 hrs 500 hrs 1000 hrs 96hrs 10 V2 Shenzhen Orient Components Co ., Ltd OR-355 14. Temperature Profile Of Soldering (1) IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (T Smin ) 150˚C - Temperature Max (T Smax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2020 Orient .All rights Reserved 11 V2 Shenzhen Orient Components Co ., Ltd OR-355 (2) Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C Preheat time 30 to 80 sec (3) Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2020 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 12 V2 Shenzhen Orient Components Co ., Ltd OR-355 15. Characteristics Curve Copyright© 2020 Orient .All rights Reserved 13 V2 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 14 OR-355 V2
OR-355-TP-G 价格&库存
很抱歉,暂时无法提供与“OR-355-TP-G”相匹配的价格&库存,您可以联系我们找货
