ZD25WQ16CTIGT
ZD25WQ16CTIGT
    ZETTA(澜智)
    SOP-8
    SPI NOR FLASH,16Mbit,1.65~3.6V,SOP-8-150mil,Tape&Reel
ZD25WQ16CTIGT 数据手册
ZD25WQ16C ZD25WQ16C Ultra Low Power, 16M-bit Serial Multi I/O Flash Memory Datasheet Performance Highlight       Wide supply range from 1.65V to 3.6V for Read, Erase and Program Ultra-Low Power consumption for Read, Erase and Program x1, x2 and x4 Multi I/O, QPI Support High reliability with 100K cycling endurance and 20-year data retention Page/Sector/Block Erase Fast Chip Erase time 12ms 1 Contents 1. 2. 3. 4. ZD25WQ16C OVERVIEW...................................................................................................................................................................4 1.1 Performance..................................................................................................................................................... 4 1.2 Pin Definition.....................................................................................................................................................5 DESCRIPTION.............................................................................................................................................................4 2.1 Block Diagram.................................................................................................................................................. 5 2.2 Memory Organization......................................................................................................................................6 DEVICE OPERATION................................................................................................................................................ 7 3.1 Mode0 and Mode3...........................................................................................................................................7 3.2 Status Register (SR)....................................................................................................................................... 9 3.3 Configuration Register (CR).........................................................................................................................11 3.4 Data Protection...............................................................................................................................................12 COMMAND DESCRIPTION.................................................................................................................................... 14 4.1 Write Enable (WREN) (06H)........................................................................................................................19 4.2 4.3 Write Disable (WRDI) (04H)........................................................................................................................ 20 Write Enable for Volatile Status Register (50H)....................................................................................... 21 4.4 4.5 Read Status Register (RDSR) (05H, 35H)................................................................................................22 Active Status Interrupt (ASI) (25H)............................................................................................................. 23 4.6 4.7 Write Status Register (WRSR) (01H or 31H)............................................................................................23 Read Data Bytes (READ) (03H)................................................................................................................. 25 4.8 4.9 Read Data Bytes at Higher Speed (FAST_READ) (0BH)...................................................................... 25 Dual Output Fast Read (DREAD) (3BH)................................................................................................... 27 4.10 4.11 4.12 4.13 4.14 Dual I/O Fast Read (2READ) (BBH).......................................................................................................... 27 Quad Output Fast Read (QREAD) (6BH)................................................................................................. 29 Quad I/O Fast Read (4READ) (EBH).........................................................................................................31 Quad I/O Word Read (E7H).........................................................................................................................32 Quad I/O Octal Word Read (E3H).............................................................................................................. 34 4.15 4.16 Set Read Parameters (C0H)....................................................................................................................... 35 Burst Read with Wrap (0CH)....................................................................................................................... 36 4.17 4.18 Set Burst with Wrap (77H)........................................................................................................................... 37 Page Erase (PE) (81H).................................................................................................................................38 4.19 4.20 Sector Erase (SE) (20H).............................................................................................................................. 39 Half Block Erase (HBE) (52H)..................................................................................................................... 40 4.21 4.22 Block Erase (BE) (D8H)................................................................................................................................41 Chip Erase (CE) (60H or C7H)....................................................................................................................42 4.23 4.24 Page Program (PP) (02H)............................................................................................................................43 Page Write (PW) (A5H)................................................................................................................................ 45 4.25 4.26 Dual Input Page Program (DPP) (A2H).....................................................................................................46 Quad Input Page Program (QPP) (32H)....................................................................................................47 4.27 4.28 4.29 4.30 4.31 Erase Security Register (ERSCUR) (44H)................................................................................................49 Program Security Register (PRSCUR) (42H)...........................................................................................51 Read Security Register (RDSCUR) (48H)................................................................................................ 52 Write Configure Register (WRCR)(11H).................................................................................................... 54 Read Configure Register (RDCR) (45H or 15H in SPI Mode)...............................................................54 2 4.32 4.33 4.34 4.35 4.36 4.37 4.38 4.39 4.40 4.41 4.42 4.43 4.44 4.45 4.46 ZD25WQ16C Deep Power-Down (DP) (B9H)................................................................................................................... 56 Release form Deep Power-Down (RDP), Read Electronic Signature (RES) (ABH)..........................57 Read Electronic Manufacturer ID & Device ID (REMS) (90H)...............................................................59 Dual I/O Read Electronic Manufacturer ID & Device ID (DREMS) (92H)............................................61 Quad I/O Read Electronic Manufacturer ID & Device ID (QREMS) (94H).......................................... 62 Read Identification (RDID) (9FH)................................................................................................................63 Program/Erase Suspend/Resume (75H)...................................................................................................64 Program Resume and Erase Resume (7AH)........................................................................................... 66 Read Unique ID (RUID) (4BH).................................................................................................................... 67 Read SFDP Mode (RDSFDP) (5AH)......................................................................................................... 68 Continuous Read Mode Reset (CRMR) (FFH).........................................................................................74 Enable QPI (38H).......................................................................................................................................... 74 Disable QPI (FFH)......................................................................................................................................... 75 No Operation (NOP)......................................................................................................................................75 Reset Enable (RSTEN) (66H) and Reset (RST) (99H)...........................................................................76 5. ELECTRICAL SPECIFICATIONS..........................................................................................................................77 5.1 Power-On Timing...........................................................................................................................................77 5.2 Initial Delivery State.......................................................................................................................................77 5.3 Absolute Maximum Ratings......................................................................................................................... 77 5.4 AC Measurement Conditions.......................................................................................................................78 5.5 DC Characteristics........................................................................................................................................ 78 5.6 AC Characteristics.........................................................................................................................................79 6. 7. ORDERING INFORMATION................................................................................................................................... 82 PACKAGE INFORMATION.................................................................................................................................... 83 7.1 Package SOP8 150MIL................................................................................................................................ 83 7.2 Package TSSOP8......................................................................................................................................... 84 7.3 7.4 8. Package USON (3x2x0.55)......................................................................................................................... 85 Package USON (3x2x0.50)......................................................................................................................... 86 REVISION HISTORY................................................................................................................................................ 87 3 ZD25WQ16C 1. OVERVIEW The ZD25WQ16C (16M-Bit) serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Dual/Quad SPI and QPI : Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), and I/O3 (HOLD#). The Dual I/O & Dual output data is transferred with speed of 208Mbits/s and the Quad I/O & Quad output data is transferred with speed of 416Mbits/s. Specifically designed for use in many different systems, the device supports read, program, and erase operations with a wide supply voltage range of 1.65V to 3.6V. No separate voltage is required for programming and erasing. 1.1 Performance  Single, Dual and Quad IO mode – Standard SPI: SCLK, CS#, SI, SO – Dual SPI: SCLK, CS#, IO0, IO1 – Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3 – QPI: SCLK, CS#, IO0, IO1, IO2, IO3  Highest Performance Speed – 104MHz for fast read – Dual I/O Data transfer up to 208Mbits/s – Quad I/O Data transfer up to 416Mbits/s – QPI Mode Data transfer up to 416Mbits/s  Power Supply and Low Power Consumption – Single 1.65V to 3.6V supply – 12μA standby current – 0.2μA deep power down current – 3mA active read current at 33MHz – 3.5mA active program or erase current  Flexible Architecture for Code and Data Storage – Uniform 256-byte Page Erase – Uniform 4K-byte Sector Erase – Uniform 32/64K-byte Block Erase – Program 1 to 256 byte per page – Minimum 100,000 Program/Erase Cycles More than 20-year data retention  Fast Program and Erase Speed – 2ms page program time – 12ms page erase time – 12ms 4K-byte sector erase time – 12ms 32K/64K-byte block erase time  Advanced Security Features – 128-Bit Unique ID for each device – Discoverable (SFDP) register – 3*1024-Byte Security Registers with OTP Locks  Package Information – SOP8 150MIL –TSSOP-8 – USON-8 –WSON-8 – Contact ZETTA for KGD and other options 4 ZD25WQ16C 1.2 Pin Definition CS# 1 SO/IO1 2 WP#/IO2 VSS VCC 7 HOLD#/IO3 3 6 SCLK 4 5 SI/IO0 TopView VCC CS# 8 HOLD#/IO3 SO/IO1 SCLK WP#/IO2 SI/IO0 VSS 8 - LEAD VSOP/SOP 8 - LEAD WSON/USON Table-1. Pin Definition Pin No. Pin Name I/O Description 1 CS# I 2 SO (IO1) I/O Data Output (Data Input Output 1) 3 WP# (IO2) I/O Write Protect Input (Data Input Output 2) 4 VSS 5 SI (IO0) I/O 6 SCLK I 7 HOLD# (IO3) I/O 8 VCC Chip Select Input Ground Data Input (Data Input Output 0) Serial Clock Input Hold Input (Data Input Output 3) Power Supply 2. DESCRIPTION 2.1BLOCK DIAGRAM 5 ZD25WQ16C 2.2 MEMORY ORGANIZATION Table-2. ZD25WQ16C Array Organization Each device has Each block has Each sector has Each page has 2M 64/32K 4K 256 Bytes 8K 256/128 16 - Pages 512 16/8 - - Sectors 32/64 - - - Blocks Table-3. ZD25WQ16C Uniform Block Sector Architecture Block 31 30 …… …… 2 1 0 Sector Address range 511 1FF000H 1FFFFFH …… …… …… 496 1F0000H 1F0FFFH 495 1EF000H 1EFFFFH …… …… …… 480 1E0000H 1E0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH 6 ZD25WQ16C 3. DEVICE OPERATION 3.1 Mode0 and Mode3 1. Before a command is issued, the status register should be checked to ensure the device is ready for the intended operation. 2. When an incorrect command is input, the device enters standby mode and remains in standby mode until the next CS# falling edge. In standby mode, the SO pin of the device is in High-Z. 3. When the correct command is input, the device enters active mode and remains in active mode until the next rising edge of CS#. 4. For standard single data rate serial mode, input data is latched on the rising edge of Serial Clock (SCLK) and data is shifted out on the falling edge of SCLK. The difference between Serial mode 0 and mode 3 is shown in Figure-1. Figure-1. Serial Modes Supported (for Normal Serial Mode) LK LK Standard SPI The ZD25WQ16C features a serial peripheral interface on 4 signals: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and is data shifted out on the falling edge of SCLK. Dual SPI The ZD25WQ16C supports Dual SPI operation when using the “Dual Output Fast Read” (3BH), “Dual I/O Fast Read” (BBH) , “Dual I/O Read Manufacture ID & Device ID” (92H) and “Dual Input Page Program” (A2H) commands. These commands allow data to be transferred to or from the device at twice the rate of the standard SPI. When using the Dual SPI command, the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Quad SPI The ZD25WQ16C supports Quad SPI operation when using the “Quad Output Fast Read” (6BH), “Quad I/O Fast Read” (EBH/E7H/E3H), “Quad I/O Read Manufacture ID/Device ID” (94H) and “Quad Input Page Program” (32H) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command, the SI, SO, WP# and HOLD# pins become bidirectional I/O pins: IO0, IO1, IO2 and IO3, respectively. Quad SPI commands require the non-volatile Quad Enable bit (QE) in Status Register to be set. 7 ZD25WQ16C QPI The ZD25WQ16C supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enable the QPI (38H)” command. The QPI mode utilizes all four IO pins to input the command code. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given times. “Enable the QPI (38H)”and “Disable the QPI(FFH)” commands are used to switch between these two modes. Upon power-up and after software reset using “Reset (99H)” command, the default state of the device is Standard/Dual/Quad SPI mode. The QPI mode requires the nonvolatile Quad Enable bit (QE) in Status Register to be set. Hold Driving the HOLD# pin low will pause any serial communications with the device. The HOLD feature will not stop the following operations if already in progress when the HOLD# pin goes low: status register write, program, or erase. The operation of HOLD requires Chip Select (CS#) to remain low and begins on the falling edge of HOLD# pin signal while the Serial Clock (SCLK) signal is low (if the Serial Clock signal is not low, the HOLD operation will not start until the Serial Clock signal is low). The HOLD condition ends on the rising edge of HOLD# pin signal while the Serial Clock (SCLK) signal is low (if the Serial Clock signal is not low, the HOLD operation will not end until the Serial Clock is low). Figure-2. Hold Condition During the HOLD operation, the Serial Data Output (SO) is in a high impedance state when the HOLD# pin goes low and will remain in a high impedance state until the HOLD# pin goes high. The Serial Data Input (SI) is ignored (don't care) if both the Serial Clock (SCLK) and HOLD# pin go low and will remain in this state until the SCLK goes low and the HOLD# pin goes high. If Chip Select (CS#) is driven high during the HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be driven high and CS# must be at a logic low. Note: The HOLD feature is disabled in Quad I/O and QPI mode. 8 ZD25WQ16C 3.2 Status Register (SR) Table-4. Status Register S15 S14 S13 S12 S11 S10 S9 S8 SUS CMP LB3 LB2 LB1 EP_FAIL QE SRP1 Read-only Non-volatile S7 S6 S5 S4 S3 S2 S1 S0 SRP0 BP4 BP3 BP2 BP1 BP0 WEL WIP Read-only Read-only Non-volatile Non-volatile OTP Read-only Non-volatile Non-volatile Non-volatile The status and control bits of the Status Register are as follows: WIP bit The Write in Progress (WIP) bit indicates whether the device is busy executing a program/erase/write status register operation. When the Write in Progress (WIP) bit is set to 1, a program/erase/write status register operation is in progress. When the Write in Progress (WIP) bit is set to 0, the device does not have a program/erase/write status register operation in progress. WEL bit The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1, the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset, and no Write Status Register, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area software protected against Program and Erase commands. These bits are written with the Write Status Register (01H) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to the target value, the relevant memory area (as defined in Table-7.X) becomes protected against Page Program (02H), Page Erase (81H), Sector Erase (20H), Half Block Erase (52H) and Block Erase (D8H) commands. The Chip Erase (60H or C7H) command is executed, only if the Block Protect bits are set to “None protected”. The Block Protect bits can be written if the Hardware Protection Mode has not been set. SRP1, SRP0 bits The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one-time programmable protection. 9 ZD25WQ16C Table-5. Status Register Protection Bits SRP1 SRP0 #WP Status Register 0 0 X Software Protected 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 0 X 1 1 X Description The Status Register can be written to after a Write Enable command, WEL=1. (Default) WP#=0, the Status Register is locked and cannot be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Power Supply Status Register is protected and cannot be written to again Lock-Down (1) until the next Power-Down, Power-Up cycle. One Time Program (2) Status Register is permanently protected and cannot be written to. Notes: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order. Please contact ZETTA for details. QE bit The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the device is set to Standard SPI operation and both WP# and HOLD# pins are enabled. When the QE bit is set to 1, the Quad IO2 and IO3 pins are enabled and the WP# pin function is not available since this pin is used for IO2. (Set the QE bit to 0 to avoid short issue if the WP# or HOLD# pin is tied directly to the power supply or ground.) EP_FAIL bit The Erase/Program Fail bit is a read only bit which shows the status of the last Program/Erase operation. The bit will be set to "1" if the program/erase operation failed or interrupted by reset or the program/erase region was protected. It will be automatically cleared to "0" if the next program/erase operation succeeds. Please note that it will not interrupt or stop any operation in the flash memory. LB3, LB2, LB1 bits The LB3, LB2, LB1 bits are non-volatile One Time Program (OTP) bits in Status Register (S13-S11) that provide the write protect control and status for the Security Registers. The default state of LB3-LB1 is 0, with the security registers unprotected. The LB3-LB1 bits can be set to 1 individually using the Write Register (01H or 31H) command. The LB3-LB1 bits are One Time Programmable, once setting to 1, the corresponding Security Registers will become read-only permanently. CMP bit The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction with the BP4-BP0 bits to provide more flexibility for the memory array protection. Please see the Table-7.X for protect area details. The default setting is CMP=0. SUS bit The SUS bit is read only bit in the status register (S15) that is set to 1 after executing a Program/Erase Suspend (75H or B0H) command. The SUS bit is cleared to 0 by the Program/Erase Resume (7AH or 30H) 10 ZD25WQ16C command, the Software Reset (66H+99H) command as well as a power-down, power-up cycle. 3.3 Configuration Register (CR) Table 6. Status Register C7 C6 C5 C4 C3 C2 C1 C0 Reserved DRV1 DRV0 QP Reserved Reserved Reserved DC Non-volatile Non-volatile Volatile Non-volatile QP bit The Quad Page (QP) bit is a volatile Read/Write bit in the Configure Register that allows Quad Page operation. When the QP bit is set to 0 (Default) the page size is 256bytes. When the QP pin is set to 1, the page size is 1024bytes. This bit controls the page programming buffer address wrap point. Legacy SPI devices generally have used a 256 Byte page programming buffer and defined that if data is loaded into the buffer beyond the 255 Byte locations, the address at which additional bytes are loaded would be wrapped to address zero of the buffer. The ZD25WQ16C provides a 1024Byte page programming buffer that can increase programming performance. For legacy software compatibility, this configuration bit provides the option to continue the wrapping behavior at the 256 Byte boundary or to enable full use of the available 1024Byte buffer by not wrapping the load address at the 256 Byte boundary. When the QP pin is set to 1, the page erase instruction(81h) will erase the data of the chosen Quad Page to be "1". DRV1 & DRV0 bit The DRV1 & DRV0 bits are non-volatile Read/Write bits which are used to determine the output driver strength for the Read operations. DRV1,DRV0 Drive Strength 0,0 80% 0,1 40% 1,0 100% 1,1(default) 60% DC bit The Dummy Configuration (DC) bit is non-volatile, which selects the number of dummy cycles between the end of address and the start of read data output. Dummy cycles provide additional latency that is needed to complete the initial read access of the flash array before data can be returned to the host system. Some read commands require additional dummy cycles as the SCLK frequency increases. The following dummy cycle tables provide different dummy cycle settings that are configured Command BBH EBH Note: 1. DC bit Numbers of Dummy Cycles Freq.(MHz) 0 (default) 4 68 1 8 86R 0 (default) 6 68 1 10 86R “R” means VCC range=2.3V~3.6V. 11 ZD25WQ16C 3.4 Data Protection During power transition, there may be some false system level signals which result in inadvertent erasure or programming. The device is designed to protect itself from these accidental write cycles. The state machine will be reset to standby mode automatically during power up. In addition, the control register architecture of the device ensures that the memory contents can only be changed after specific command sequences have completed successfully. In the following, there are several features to protect the system from the accidental write cycles during VCC power-up and power-down or from system noise.  Valid command length checking: The command length will be checked whether it is at byte base and completed on byte boundary.  Write Enable (06H) command: WREN command is required to set the Write Enable Latch bit (WEL) before issuing other commands to change data.  Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits define the section of the memory array that can be read but not changed.  Hardware Protection Mode: WP# going low to protect the CMP, BP0~BP4 bits and SRP0~1 bits.  Deep Power-Down Mode: By entering deep power down mode, the flash device is ignores all commands until the Release from Deep Power-Down Mode (B9H) command. Table-7.1 ZD25WQ16C Protected Area Size (CMP bit=0) Status bit Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 31 1F0000H-1FFFFFH 64KB Upper 1/32 0 0 0 1 0 30 and 31 1E0000H-1FFFFFH 128KB Upper 1/16 0 0 0 1 1 28 to 31 1C0000H-1FFFFFH 256KB Upper 1/8 0 0 1 0 0 24 to 31 180000H-1FFFFFH 512KB Upper 1/4 0 0 1 0 1 16 to 31 100000H-1FFFFFH 1MB Upper 1/2 0 1 0 0 1 0 000000H-00FFFFH 64KB Lower 1/32 0 1 0 1 0 0 and 1 000000H-01FFFFH 128KB Lower 1/16 0 1 0 1 1 0 to 3 000000H-03FFFFH 256KB Lower 1/8 0 1 1 0 0 0 to 7 000000H-07FFFFH 512KB Lower 1/4 0 1 1 0 1 0 to 15 000000H-0FFFFFH 1MB Lower 1/2 x x 1 1 x 0 to 31 000000H-1FFFFFH 2MB ALL 1 0 0 0 1 31 1FF000H-1FFFFFH 4KB Upper 1/512 1 0 0 1 0 31 1FE000H-1FFFFFH 8KB Upper 1/256 1 0 0 1 1 31 1FC000H-1FFFFFH 16KB Upper 1/128 1 0 1 0 x 31 1F8000H-1FFFFFH 32KB Upper 1/64 1 1 0 0 1 0 000000H-000FFFH 4KB Lower 1/512 1 1 0 1 0 0 000000H-001FFFH 8KB Lower 1/256 1 1 0 1 1 0 000000H-003FFFH 16KB Lower 1/128 1 1 1 0 x 0 000000H-007FFFH 32KB Lower 1/64 12 ZD25WQ16C Table-7.2 ZD25WQ16C Protected Area Size (CMP bit=1) Status bit Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 0 to 31 000000H-1FFFFFH 2MB ALL 0 0 0 0 1 0 to 30 000000H-1EFFFFH 1984KB Lower 31/32 0 0 0 1 0 0 to 29 000000H-1DFFFFH 1920KB Lower 15/16 0 0 0 1 1 0 to 27 000000H-1BFFFFH 1792KB Lower 7/8 0 0 1 0 0 0 to 23 000000H-17FFFFH 1536KB Lower 3/4 0 0 1 0 1 0 to 15 000000H-0FFFFFH 1MB Lower 1/2 0 1 0 0 1 1 to 31 010000H-1FFFFFH 1984KB Upper 31/32 0 1 0 1 0 2 to 31 020000H-1FFFFFH 1920KB Upper 15/16 0 1 0 1 1 4 to 31 040000H-1FFFFFH 1792KB Upper 7/8 0 1 1 0 0 8 to 31 080000H-1FFFFFH 1536KB Upper 3/4 0 1 1 0 1 16 to 31 100000H-1FFFFFH 1MB Upper 1/2 x x 1 1 x NONE NONE NONE NONE 1 0 0 0 1 0 to 31 000000H-1FEFFFH 2044KB Lower 511/512 1 0 0 1 0 0 to 31 000000H-1FDFFFH 2040KB Lower 255/256 1 0 0 1 1 0 to 31 000000H-1FBFFFH 2032KB Lower 127/128 1 0 1 0 x 0 to 31 000000H-1F7FFFH 2016KB Lower 63/64 1 1 0 0 1 0 to 31 001000H-1FFFFFH 2044KB Upper 511/512 1 1 0 1 0 0 to 31 002000H-1FFFFFH 2040KB Upper 255/256 1 1 0 1 1 0 to 31 004000H-1FFFFFH 2032KB Upper 127/128 1 1 1 0 x 0 to 31 008000H-1FFFFFH 2016KB Upper 63/64 Notes: 1. X=don’t care 2. If any erase or program command specifies a memory that contains protected data portion, this command will be ignored. 13 ZD25WQ16C 4. COMMAND DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted into the device starting with the most significant bit on SI. Each bit is latched on the rising edge of SCLK. The commands supported by ZD25WQ16C are listed inTable-8. Every command sequence starts with a one-byte command code. Depending on the command, it might be followed by address or data bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been completed. For the commands of Read, Fast Read, Read Status Register, Release from Deep Power- Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. All read commands can be completed after any bit of the data-out sequence is shifted out, and then CS# must be driven high to return to deselected status. For the Page Program , Sector Erase , Half Block Erase , Block Erase , Chip Erase , Write Status Register , Write Enable , Write Disable or Deep Power-Down commands, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That means CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if CS# is driven high at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Table-8. Commands (Standard/Dual/Quad SPI) Command Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7 Write Enable 06H Write Disable 04H Volatitle SR Write Enable 50H Read Status Register-1 05H (S7-S0) (cont.) Read Status Register-2 35H (S15-S8) (cont.) 45/15H (S7-S0) (cont.) Write Status Register-1 01H S7-S0 Write Status Register-1&2 01H S7-S0 Write Status Register-2 31H S15-S8 Write Configure Register 11H S7-S0 Read Data 03H A23-A16 A15-A8 A7-A0 (D7-D0) (cont.) Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (cont.) Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (cont.) Quad Output Fast Read 6BH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (cont.) Read Word Quad I/O E7H A23-A16 A15-A8 A7-A0 M7-M0 dummy (D7-D0) Read Octal Word Quad I/O E3H A23-A16 A15-A8 A7-A0 M7-M0 (D7-D0) (cont.) Dual I/O Fast Read BBH A23-A16 A15-A8 A7-A0 M7-M0 (D7-D0) (cont.) Active Status Interrupt 25H Quad I/O Fast Read EBH A23-A16 A15-A8 A7-A0 M7-M0 dummy dummy Read Configure Register Byte 8 Byte 9 S15-S8 14 (cont.) (D7-D0) (cont.) ZD25WQ16C Commands (Standard/Dual/Quad SPI) Command Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Set Burst with Wrap 77H dummy dummy dummy W7-W0 Page Program 02H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Page Write A5H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Dual-IN Page Program A2H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Quad Page Program 32H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Page Erase 81H A23-A16 A15-A8 A7-A0 Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase (32K) 52H A23-A16 A15-A8 A7-A0 Block Erase (64K) D8H A23-A16 A15-A8 A7-A0 90H dummy dummy A7-A0 92H dummy dummy A7-A0 M7-M0 94H dummy dummy A7-A0 M7-M0 (MID7- (ID15- (ID7- MID0) ID8) ID0) Chip Erase Read Manufacturer/Device ID Dual I/O Read Manufacturer/Device ID Quad I/O Read Manufacturer/Device ID Byte 6 (MID7MID0) (ID7-ID0) (cont.) (MID7- (ID7- MID0) ID0) dummy dummy 9FH Read Unique ID 4BH dummy dummy dummy Erase Security Registers 44H A23-A16 A15-A8 A7-A0 42H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Read Security Registers 48H A23-A16 A15-A8 A7-A0 dummy (D7-D0) Enable Reset 66H Reset 99H ABH dummy dummy dummy 5AH A23-A16 A15-A8 A7-A0 Registers Program/Erase Suspend 75H/B0H Program/Erase Resume 7AH/30H Deep Power-Down Release From Deep Power-Down Discoverable Parameter Enable QPI dummy (UID7UID0) (cont.) (cont.) ABH Device ID Read Serial Flash (cont.) B9H Release From Deep Power-Down and Read Byte8 Byte 9 Byte 10 C7/60H Read Identification Program Security Byte 7 38H 15 (ID7ID0) dummy (cont.) (D7-D0) (cont.) (cont.) (MID7- (ID7- MID0) ID0) (cont.) ZD25WQ16C Command set (QPI) Command Name Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7 Byte 8 Clock Number (0,1) (2,3) (4,5) (6,7) (8,9) (10,11) (12,13) (14,15) Write Enable 06H Write Disable 04H Read Config Register bit 45/15H (S7-S0) (cont.) Read Status Register-1 05H (S7-S0) (cont.) Read Status Register-2 35H (S15-S8) (cont.) Write Status Register-1 01H S7-S0 Write Status Register-1&2 01H S7-S0 Write Status Register-2 31H S15-S8 Write Configure Register 11H S7-S0 Volatile SR Write Enable 50H Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy dummy (D7-D0) (cont.) Quad I/O Fast Read EBH A23-A16 A15-A8 A7-A0 M7-M0 dummy (D7-D0) (cont.) Page Program 02H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Page Write A5H A23-A16 A15-A8 A7-A0 D7-D0 Next Byte Page Erase 81H A23-A16 A15-A8 A7-A0 Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase (32K) 52H A23-A16 A15-A8 A7-A0 Block Erase (64K) D8H A23-A16 A15-A8 A7-A0 (ID7-ID0) Chip Erase S15-S8 C7/60H Set Read Parameters C0H P7-P0 Manufacturer/Device ID 90H dummy dummy 00H (MID7-MID0) Read Identification 9FH MID7-MID0 ID15-ID8 ID7-ID0 (cont.) Erase Security Registers 44H A23-A16 A15-A8 A7-A0 Program Security Registers 42H A23-A16 A15-A8 A7-A0 (D7-D0) Next Byte Read Security Registers 48H A23-A16 A15-A8 A7-A0 dummy dummy (D7-D0) (cont.) Enable Reset 66H Reset 99H Burst Read with Wrap 0CH A23-A16 A15-A8 A7-A0 dummy dummy (D7-D0) (cont.) Program/Erase Suspend 75H Program/Erase Resume 7AH Deep Power-Down B9H dummy dummy dummy (ID7-ID0) (cont.) A23-A16 A15-A8 A7-A0 dummy dummy (D7-D0) (cont.) Release from Deep Power-Down Release From Deep ABH Power-Down, And Read Device ID ABH Disable QPI FFH Read Serial Flash Discoverable Parameter (cont.) 5AH 16 ZD25WQ16C Notes: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8, A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9, A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3,…..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. Fast Read Quad I/O Dummy Bits and Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Word Read Quad I/O Data IO0 = (x, x, D4, D0,…) IO1 = (x, x, D5, D1,…) IO2 = (x, x, D6, D2,…) IO3 = (x, x, D7, D3,…) 7. Security Registers Address: Security Register1: A23-A16=00H, A15-A12=1H, A11-A10 = 00b, A9-A0= Byte Address; Security Register2: A23-A16=00H, A15-A12=2H, A11-A10 = 00b, A9-A0= Byte Address; Security Register3: A23-A16=00H, A15-A12=3H, A11-A10 = 00b, A9-A0= Byte Address; 8. Dummy bits and Wrap Bits IO0 = (x, x, x, x, x, x, W4, x) IO1 = (x, x, x, x, x, x, W5, x) IO2 = (x, x, x, x, x, x, W6, x) IO3 = (x, x, x, x, x, x, x, x) 17 ZD25WQ16C 9. Address, Continuous Read Mode bits, Dummy bits, Manufacture ID and Device ID IO0 = (A20, A16, A12, A8, A4, A0, M4, M0, x, x, x, x, MID4, MID0, DID4, DID0, …) IO1 = (A21, A17, A13, A9, A5, A1, M5, M1, x, x, x, x, MID5, MID1, DID5, DID1, …) IO2 = (A22, A18, A14, A10, A6, A2, M6, M2, x, x, x, x, MID6, MID2, DID6, DID2, …) IO3 = (A23, A19, A15, A11, A7, A3, M7, M3, x, x, x, x, MID7, MID3, DID7, DID3, …) 10. QPI Command, Address, Data input/output format: CLK #0 1 2 3 4 5 6 7 8 9 10 11 IO0= C4, C0, A20, A16, A12, A8, A4, A0, D4, D0, D4, D0 IO1= C5, C1, A21, A17, A13, A9, A5, A1, D5, D1, D5, D1 IO2= C6, C2, A22, A18, A14, A10, A6, A2, D6, D2, D6, D2 IO3= C7, C3, A23, A19, A15, A11, A7, A3, D7, D3, D7, D3 11. A0 must be 0 for Word Read 4xI/O. A0-A3 must be 0 for Octal Word Read. Tables of ID Definition: Table-9 ZD25WQ16C Operation Code MID7-MID0 ID15-ID8 ID7-ID0 9FH BA 60 15 90H/92H/94H BA 14 ABH 14 18 ZD25WQ16C 4.1 Write Enable (WREN) (06H) The Write Enable (06H) command sets the Write Enable Latch (WEL) bit. The WEL bit must be set prior to every Page Program, Page Erase, Sector Erase, Half Block Erase, Block Erase, Chip Erase, Write Status Register and Erase/Program Security Register command. The WREN command is entered by driving Chip Select (CS#) Low, sending the command code, and then driving CS# High. Figure-3. Write Enable Sequence Diagram Figure-4. Write Enable (WREN) Sequence (QPI) 19 ZD25WQ16C 4.2 Write Disable (WRDI) (04H) The Write Disable (04H) command resets the Write Enable Latch (WEL) bit in the Status Register to 0. The WRDI command is entered by driving Chip Select (CS#) low, shifting the command code “04h” into the SI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Page Erase, Sector Erase, Half Block Erase, Block Erase, Chip Erase, Erase/Program Security Register and Reset commands. Figure-5. Write Disable Sequence Diagram Figure-6. Write Disable Sequence Diagram (QPI) 20 ZD25WQ16C 4.3 Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. During power up reset, the nonvolatile Status Register bits are copied to a volatile version of the Status Register that is used during device operation. This provides more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile version of the Status Register bits, the Write Enable for Volatile Status Register (50H) command must be issued and immediately followed by the Write Status Register (01H/11H/31H) command. Write Enable for Volatile Status Register command (Figure-7) will not set the Write Enable Latch (WEL) bit, it is only valid for the next Write Status Register command, to change the volatile Status Register bit values. Figure-7. Write Enable for Volatile Status Register Sequence Diagram Figure-8. Write Enable for Volatile Status Register Sequence Diagram (QPI) 21 ZD25WQ16C 4.4 Read Status Register (RDSR) (05H, 35H) The Read Status Register (05H or 35H) command allows the Status Register to be read. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. And for command code “35H”, the SO will output Status Register bits S15~S8. The sequence of issuing RDSR instruction is: CS# goes low→ sending RDSR instruction code→ Status Register data out on SO. Figure-9. Read Status Register Sequence Diagram Figure-10. Read Status Register Sequence Diagram (QPI) 22 ZD25WQ16C 4.5 Active Status Interrupt (ASI) (25H) The Active Status Interrupt (25h) command provides an alternative method to read the Write In Progress (WIP) bit. The SO pin outputs the WIP bit continuously with the ASI command. The SO pin can be connected to an interrupt line of the host controller, and the host controller remains in sleep mode until the SO pin indicates that the device is ready for the next command. The WIP bit can be read at any time, including while an internally self-timed program or erase operation is in progress. To enable the ASI command, the CS# pin must first be asserted and the opcode of 25h must be clocked into the device. The value of WIP is then output on the SO pin and is continuously updated by the device for as long as the CS# pin remains asserted. Additional clocks on the SCLK pin are not required. If the WIP bit changes from 1 to 0 while the CS# pin is asserted, the SO pin will change from 1 to 0 when the program/erase operation is completed. (The WIP bit cannot change from 0 to 1 during an operation, so if the SO pin already is 0, it will not change.) Deserting the CS# pin will terminate the ASI operation and put the SO pin into a high-impedance state. The CS# pin can be deserted at any time and does not require that a full byte of data be read. The sequence of issuing ASI command is: CS# goes low -> send Active Status Interrupt (25H) command code -> Write In Progress (WIP) data out on SO. Figure-11. Active Status Interrupt Sequence Diagram 4.6 Write Status Register (WRSR) (01H or 31H) WRSR can write 8bits or 16bits data. The Write Status Register (01H for one byte or two bytes, 31H for one byte only) command allows new values to be written to the Status Register. Command 01H is used to write S7~S0 (one byte) or S15~S0(two bytes). Command 31H is used to write S15~S8. Before the command can be accepted, a Write Enable (06H) command must previously have been executed. After the Write Enable command has been decoded and executed, the device sets the Write Enable Latch (WEL). The WRSR command is entered by driving Chip Select (CS#) Low, followed by the command code and the data byte on Data Input (SI). The WRSR command has no effect on S15, S10, S1 and S0 of the Status Register. CS# must be driven high after the sixteenth bit or eighth bit of the data byte has been latched in. If not, the WRSR command is not executed. As soon as CS# is driven High, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Write Status Register cycle and is 0 when it is completed. When the cycle is completed, the WEL bit is reset. The WRSR command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, 23 ZD25WQ16C BP0) bits. The WRSR command also allows the user to set or reset the Status Register Protect (SRP1 and SRP0) bits in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and WP# signal allow the device to be put in the Hardware Protection Mode. The WRSR command is not executed once the Hardware Protection Mode is entered. CS# must go high exactly at the 8bit or 16bit data boundary; otherwise the command will be rejected and not executed. The self-timed Write Status Register cycle time (tW) is initiated as soon as CS# goes high. The WIP bit still can be checked during the Write Status Register cycle is in progress. The WIP is set to 1 during tW and is reset to 0 along with the WEL bit when Write Status Register Cycle is completed. Figure-12. Write Status Register Sequence Diagram Figure-13. Write Status Register Sequence Diagram(QPI) 24 ZD25WQ16C 4.7 Read Data Bytes (READ) (03H) The device is first selected by driving Chip Select (CS#) Low. The command code for the Read Data Bytes (03H) command is followed by a 3-byte address (A23-A0), with each bit latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at that address, is shifted out on Data Output (SO), with each bit shifted out at a maximum frequency fR on the falling edge of SCLK. The command sequence is shown in Figure-14. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single READ command. When the highest address is reached, the address counter rolls over to 000000h, allowing the read sequence to be continued indefinitely. The READ command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any READ command to the memory array, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure-14. Read Data Bytes Sequence Diagram 4.8 Read Data Bytes at Higher Speed (FAST_READ) (0BH) The device is first selected by driving Chip Select (CS#) Low. The command code for the Read Data Bytes at Higher Speed (0BH) command is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at that address, is shifted out on Data Output (SO), with each bit shifted out at a maximum frequency fC on the falling edge of SCLK. The command sequence is shown in Figure-15. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The whole memory can, therefore, be read with a single FAST_READ command. When the highest address is reached, the address counter rolls over to 000000h, allowing the read sequence to be continued indefinitely. The FAST_READ command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any FAST_READ command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 25 Figure-15. Read Data Bytes at Higher Speed Sequence Diagram ZD25WQ16C Read Data Bytes at Higher Speed in QPI mode The Fast Read command is also supported in QPI mode. In QPI mode, the number of Dummy Cycles is configured by the “Set Read Parameters (C0H)” command to accommodate a wide range application with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of Dummy Cycles can be configured as either 4/6/8. Figure-16. Read Data Bytes at Higher Speed Sequence Diagram (QPI) 26 ZD25WQ16C 4.9 Dual Output Fast Read (DREAD) (3BH) The Dual Output Fast Read (3BH) is similar to the standard Fast Read (0BH) command except that data is output on two pins, SI (IO0) and SO (IO1), instead of just SO. This allows data to be transferred from the ZD25WQ16C at twice the rate of standard SPI devices. The DREAD command is ideal for quickly downloading code from the flash to RAM upon power-up or for applications that cache code-segments to RAM for execution. Like the Fast Read command, the DREAD command can operate at the highest possible frequency of fT. This is accomplished by adding eight “Dummy Cycles after the 24-bit address as shown in Figure-17. The Dummy Cycles allow the device’s internal circuits the time required for setting up the initial address. The input data during the Dummy Cycle is “don’t care”. However, the SI pin should be in a highimpedance state prior to the falling edge of SLCK for the first data out. Figure-17. Dual Output Fast Read Sequence Diagram 4.10 Dual I/O Fast Read (2READ) (BBH) The Dual I/O Fast Read (BBH) command allows for improved random access while maintaining two IO pins, SI (IO0) and SO (IO1). It is similar to the Dual Output Fast Read (3BH) command but with the ability to input the address bits (A23-0) two bits per clock. This reduced command overhead may allow for code execution (XIP) directly from the Dual SPI in some applications. The 2READ command enables double throughput of Serial Flash in read mode. The address is latched on rising edge of SCLK, and two bits of data (interleave 2 I/O pins) are shifted out on the falling edge of SCLK at a maximum frequency fT. The first address can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out with a single 2READ command. The address counter rolls over to 0 when the highest address has been reached. The 2READ command is shown in Figure-18. 27 ZD25WQ16C Figure-18. Dual I/O Fast Read Sequence Diagram (M5-4 ≠ (1,0)) Dual I/O Fast Read with “Continuous Read Mode” (BBH) The Dual I/O Fast Read (BBH) command supports Dual I/O Fast Read with “Continuous Read Mode” which can further reduce command overhead by setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing a normal command. Figure-19. Dual I/O Fast Read with “Continuous Read Mode” Sequence Diagram (M5-4 = (1,0)) 28 ZD25WQ16C Note: Dual I/O Fast Read with “Continuous Read Mode”, if (M5-4)=(1,0). If not using “Continuous Read Mode” recommend setting (M5-4)≠(1,0). 4.11 Quad Output Fast Read (QREAD) (6BH) The Quad Output Fast Read (6BH) command is similar to the Dual Output Fast Read (3BH) command except that data is output on four pins, IO0, IO1, IO2, and IO3. A Quad Enable (QE) of Status Register-2 must be executed before the device will accept the QREAD Command. (The QE bit must equal “1”). The QREAD Command allows data to be transferred at four times the rate of standard SPI devices. The QREAD command can operate at a higher frequency than the traditional Read Data command. This is accomplished by adding eight “dummy” Cycles after the 24-bit address as shown in Figure-20. The Dummy Cycles allow the device's internal circuits the time required for setting up the initial address. The input data during the Dummy Cycles is “don’t care.” However, the IO pins should be in a high-impedance state prior to the falling edge of SCLK for the first data out. Figure-20. Quad Output Fast Read Sequence Diagram Quad I/O Fast Read with “Continuous Read Mode” (EBH) The Quad I/O Fast Read (EBH) command supports Quad I/O Fast Read with “Continuous Read Mode” which can further reduce command overhead by setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read (EBH) command (after CS# is raised and then lowered) does not require the EBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing a normal command. 29 ZD25WQ16C Figure-21. Quad I/O Fast Read with “Continuous Read Mode” Sequence Diagram (M5-4 = (1,0)) 4 5 6 4 5 6 Note: Quad I/O Fast Read with “Continuous Read Mode”, if (M5-4)=(1,0). If not using “Continuous Read Mode” recommend setting (M5-4)≠(1,0). Quad I/O in QPI mode The Quad I/O Fast Read command is also supported in QPI mode. In QPI mode, the number of Dummy Cycles is configured by the “Set Read Parameters (C0H)” command to accommodate a wide range application with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of Dummy Cycles can be configured as either 4/6/8. In QPI mode, the “Continuous Read Mode” bits M7-M0 are also considered as Dummy Cycles. “Continuous Read Mode” feature is also available in QPI mode for Quad I/O Fast Read command. “Wrap Around” feature is not available in QPI mode for Quad I/O Fast Read command. To perform a read operation with fixed data length wrap around in QPI mode, a dedicated “Burst Read with Wrap” (0CH) command must be used. 30 ZD25WQ16C Figure-22. Quad I/O Read in QPI Mode Sequence (M5-4 ≠ (1,0)) 4.12 Quad I/O Fast Read (4READ) (EBH) The Quad I/O Fast Read (EBH) command is similar to the Dual I/O Fast Read (BBH) command except that address and data bits are input and output through four pins, SI (IO0), SO (IO1), WP (IO2) and HOLD (IO3). Six Dummy Cycles are required prior to the data output. A Quad Enable (QE) of Status Register-2 must be executed before the device will accept the 4READ Command. (The QE bit must equal “1”). The Quad I/O dramatically reduces command overhead allowing faster random access for code execution (XIP) directly from the Quad SPI. The 4READ command enables quad throughput of Serial Flash in read mode. The address is latched on rising edge of SCLK, and data four bits of data (interleave on 4 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fQ. The first address can be any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out with a single 4READ command. The address counter rolls over to 0 when the highest address has been reached. Once writing 4READ command, the following address / dummy / data out will transfer 4-bits per clock cycle instead of the previous 1-bit. The sequence of issuing 4READ command is: CS# goes low -> send Quad I/O Fast Read (EBH) command -> 24-bit address interleave on IO3, IO2, IO1 and IO0 -> 2+4 dummy cycles -> data out interleave on IO3, IO2, IO1 and IO0 -> end 4READ operation by driving CS# high at any time during data out, as shown in Figure-23. Another sequence of issuing 4READ command especially useful in random access is: CS# goes low -> send Quad I/O Fast Read (EBH) command -> 24-bit address interleave on IO3, IO2, IO1 and IO0 -> “Continuous Read Mode” byte M[7:0] -> 4 dummy cycles -> data out until CS# goes high -> CS# goes low (reduce 4READ command) -> 24-bit random access address. In the Continuous Read Mode, the “Continuous Read Mode” bits M[5:4] = (1,0) can make this mode continue and reduce the next 4READ command. Once M[5:4 ] ≠ (1,0) and after CS# is raised and then lowered, the system then will escape from the enhanced performance mode and return to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal commands. While Program/Erase/Write Status Register cycle is in progress, the 4READ command is rejected without any impact 31 ZD25WQ16C on the Program/Erase/Write Status Register operation. Figure-23. Quad I/O Fast Read Sequence Diagram (M5-4 ≠ (1,0)) 4 5 6 4.13 Quad I/O Word Read (E7H) The Quad I/O Word Read command is similar to the Quad I/O Read command except that the lowest address bit (A0) must equal 0 and only 2-Dummy Cycle. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Word read command. Figure-24. Quad I/O Word Read Sequence (M5-4 ≠ (1,0)) 32 ZD25WQ16C Quad I/O Word Read with “Continuous Read Mode” The Quad I/O Word Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Word Read command (after CS# is raised and then lowered) does not require the E7H command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the first E7H command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal command. Figure-25. Quad I/O Word Read Sequence (M5-4 = (1,0)) B 33 ZD25WQ16C Quad I/O Word Read with “8/16/32/64-Byte Wrap Around” in Standard SPI mode The Quad I/O Word Read command can be used to access a specific portion within a page by issuing “Set Burst with Wrap” (77H) commands prior to E7H. The “Set Burst with Wrap” (77H) command can either enable or disable the “Wrap Around” feature for the following E7H commands. When “Wrap Around” is enabled, the data being accessed can be limited to either an8/16/32/64-byte section of a 256-byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” command allows three “Wrap Bits” W6-W4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-W5 is used to specify the length of the wrap around section within a page. 4.14 Quad I/O Octal Word Read (E3H) The Quad IO Octal Word Read (E3h) instruction is similar to the Quad IO Read (EBH) instruction except that the lower four Address bits (A0, A1, A2, A3) must equal 0. As a result, the Dummy Cycles are not required, which further reduces the instruction overhead allowing even faster random access for code execution (XIP). The Quad Enable bit (QE) of Status Register-2 must be set to enable the Octal Word Read Quad I/O Instruction. Quad IO Octal Word Read with “Continuous Read Mode” The Quad IO Octal Word Read instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits (A23-0). The upper nibble of the (M7-4) controls the length of the next Octal Word Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the IO pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Quad I/O instruction (after CS# is raised and then lowered) does not require the E3h instruction code, as shown in Figure 26. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFH on IO0 for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation. 34 ZD25WQ16C Figure 26. Quad I/O Octal Word Read Sequence(E3H) 4.15 Set Read Parameters (C0H) In QPI mode the “Set Read Parameters (C0H)” command can be used to configure the number of Dummy Cycles for “Fast Read (0BH)”, “Quad I/O Fast Read (EBH)”, “Read Security Register (48H)”, “Read SFDP Mode (5AH)”and “Burst Read with Wrap (0CH)” command, and to configure the number of bytes of “Wrap Length” for the “Burst Read with Wrap (0CH)” command. The “Wrap Length” is set by W5-6 bit in the “Set Burst with Wrap (77H)” command. This setting will remain unchanged when the device is switched from Standard SPI mode to QPI mode. P5-P4 Dummy Cycles Maximum Read Freq. P1-P0 Wrap Length 0,0 10 86MHz 0,0 8-byte 0,1 4 68MHz 0,1 16-byte 1,0 6 68MHz 1,0 32-byte 1,1 8 86MHz 1,1 64-byte 35 ZD25WQ16C Figure 27. Set Read Parameters (QPI) 4.16 Burst Read with Wrap (0CH) The “Burst Read with Wrap (0CH)” command provides an alternative way to perform the read operation with “Wrap Around” in QPI mode. This command is similar to the “Fast Read (0BH)” command in QPI mode, except the addressing of the read operation will “Wrap Around” to the beginning boundary of the “Wrap Around” once the ending boundary is reached. The “Wrap Length” and the number of Dummy Cycles can be configured by the “Set Read Parameters (C0H)” command. 36 ZD25WQ16C Figure 28. Burst Read with Wrap Sequence ( QPI ) 4.17 Set Burst with Wrap (77H) The Set Burst with Wrap (77h) command is used in conjunction with Quad I/O Fast Read (EBH/E7H) command to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap command sequence: CS# goes low -> Send Set Burst with Wrap (77h) command -> Send 24 dummy bits-> Send 8 bits “Wrap bits” -> CS# goes high. If the W6-W4 bits are set by the Set Burst with Wrap command, all the following Quad I/O Fast Read commands will use the W6-W4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap command should be issued to set W4=1. Table-10. Burst Length and Wrap W6,W5 W4=0 W4=1 (default) Wrap Wrap Wrap Wrap Around Length Around Length 0,0 Yes 8-byte No N/A 0,1 Yes 16-byte No N/A 1,0 Yes 32-byte No N/A 1,1 Yes 64-byte No N/A 37 ZD25WQ16C Figure-29. Set Burst with Wrap Sequence Diagram 4.18 Page Erase (PE) (81H) The Page Erase (81H) command sets all bits to 1 (FFH) inside the chosen page. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The PE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the page is a valid address for the PE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-30. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Page Erase cycle (with duration tPE) is initiated. While the Page Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Page Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A PE command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-30. Page Erase Sequence Diagram 38 ZD25WQ16C Figure-31. Page Erase Sequence Diagram (QPI) 81H A23~16 A15~8 A7~0 4.19 Sector Erase (SE) (20H) The Sector Erase (20H) command sets all bits to 1 (FFH) inside the chosen sector. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The SE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the sector is a valid address for the SE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-32. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Sector Erase cycle (with duration tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Sector Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A SE command may be applied only to a sector which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-32. Sector Erase Sequence Diagram 39 ZD25WQ16C Figure-33. Sector Erase Sequence Diagram (QPI) 20H A23~16 A15~8 A7~0 The self-timed Sector Erase Cycle time (tSE) is initiated as soon as Chip Select (CS#) goes high. The Write in progress (WIP) bit still can be check out during the Sector Erase cycle is in progress. The WIP sets 1 during the tSE timing, and sets 0 when Sector Erase Cycle is completed, and the Write Enable Latch (WEL) bit is reset. If the sector is protected by BP4, BP3, BP2, BP1, BP0 bits, the Sector Erase (SE) instruction will not be executed on the sector 4.20 Half Block Erase (HBE) (52H) The Half Block Erase (52H) command sets all bits to 1 (FFH) inside the chosen block. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The HBE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the block is a valid address for the HBE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-34. The CS# must go high exactly at the byte boundary (after the least significant bit of the third address byte is latched-in); otherwise, the command will be rejected and not executed. As soon as CS# is driven High, the self-timed Half Block Erase cycle (with duration tBE1) is initiated. While the Half Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Block Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A HBE command may be applied only to a half block which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 40 ZD25WQ16C Figure-34. Half Block Erase Sequence Diagram Figure-35. Half Block Erase Sequence Diagram (QPI) 4.21 Block Erase (BE) (D8H) The Block Erase (D8H) command sets all bits to 1 (FFH) inside the chosen block. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable 06H command has been decoded, the device sets the Write Enable Latch (WEL). The BE command is entered by driving Chip Select (CS#) Low, followed by the command code, and three address bytes on Data Input (SI). Any address inside the block is a valid address for the BE command. CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-36. CS# must be driven High after the least significant bit of the third address byte is latched in, otherwise the BE command is not executed. As soon as CS# is driven High, the self-timed Block Erase cycle (whose duration is tBE2) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the self-timed Block Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A BE command may be applied only to a block which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 41 ZD25WQ16C Figure-36. Block Erase Sequence Diagram Figure-37. Block Erase Sequence Diagram (QPI) D8H A23~16 A15~8 A7~0 4.22 Chip Erase (CE) (60H or C7H) The Chip Erase (60H or C7H) command sets all bits to 1 (FFH). Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The CE command is entered by driving Chip Select (CS#) Low, followed by the command code on Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-38. CS# must be driven High after the eighth bit of the command code is latched in, otherwise the CE command is not executed. As soon as CS# is driven High, the self-timed Chip Erase cycle (with duration tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The WIP bit is 1 during the selftimed Chip Erase cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. The CE command is executed only if all Block Protect (BP4, BP3, BP2, BP1, BP0) bits are 0. The CE command is ignored if one, or more blocks are protected. 42 ZD25WQ16C Figure-38. Chip Erase Sequence Diagram Figure-39. Chip Erase Sequence Diagram (QPI) 4.23 Page Program (PP) (02H) The Page Program (02H) command allows bytes to be programmed in the memory. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The PP command is entered by driving Chip Select (CS#) Low, followed by the command code, three address bytes and at least one data byte on Data Input (SI). If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the starting address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-40. If more than 256 bytes are sent to the device, previously latched data are discarded, and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 Data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven High after the eighth bit of the last data byte has been latched in, otherwise the PP command is not executed. As soon as CS# is driven High, the self-timed Page Program cycle (with duration tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the WIP bit. The WIP bit is 1 during the self-timed Page Program cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A PP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 43 ZD25WQ16C Figure-40. Page Program Sequence Diagram Figure-41. Page Program Sequence Diagram (QPI) 44 ZD25WQ16C 4.24 Page Write (PW) (A5H) The Page Write (A5H) command is bytes-alterable and allows bytes of data zeros and data ones to be written directly into the memory without issue any erase commands. Before it can be accepted, a Write Enable (06H) command must have previously been executed. After the Write Enable command has been decoded, the device sets the Write Enable Latch (WEL). The PW command is entered by driving Chip Select (CS#) Low, followed by the command code, three address bytes and at least one data byte on Data Input (SI). If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are written from the starting address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-42. If more than 256 bytes are sent to the device, previously latched data are discarded, and the last 256 data bytes are guaranteed to be written correctly within the same page. If less than 256 Data bytes are sent to device, they are correctly written at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven High after the eighth bit of the last data byte has been latched in, otherwise the PW command is not executed. As soon as CS# is driven High, the self-timed Page Write cycle (with duration tPW) is initiated. While the Page Write cycle is in progress, the Status Register may be read to check the value of the WIP bit. The WIP bit is 1 during the self-timed Page Write cycle and is 0 when it is completed. At some unspecified time before the cycle is completed, the WEL bit is reset. A PW command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. Figure-42. Page Write Sequence Diagram 45 ZD25WQ16C Figure-43. Page Write Sequence Diagram (QPI) 4.25 Dual Input Page Program (DPP) (A2H) The Dual Input Page Program (A2H) command is similar to the standard Page Program command and can be used to program anywhere from a single byte of data up to 256 bytes of data into previously erased memory locations. The DPP command allows two bits of data to be clocked into the device on every clock cycle rather than just one. A Write Enable (06H) command must be executed to set the Write Enable Latch (WEL) bit before sending the DPP command. The Dual Input Page Programming takes two pins: IO0, IO1 as data input, which can improve programmer as well as in-system application performance. The other function descriptions are as same as the standard page program. The sequence of issuing DPP command is: CS# goes low -> send Dual Input Page Program (A2H) command code -> 3-byte address on SI -> at least 1-byte on data on IO[1:0] -> CS# goes high. A DPP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 46 ZD25WQ16C Figure-44. Dual Input Page Program Diagram 4.26 Quad Input Page Program (QPP) (32H) The Quad Input Page Program (32H) command is for programming the memory to be "0". A Write Enable command must be executed to set the Write Enable Latch (WEL) bit and Quad Enable (QE) bit to "1" before sending the QPP command. The Quad Input Page Programming uses four pins: IO0, IO1, IO2, and IO3 as data input, which can improve programmer as well as in-system application performance. The QPP operation supports frequencies as fast as fQPP. The other function descriptions are as same as standard page program. The sequence of issuing QPP command is: CS# goes low -> send Quad Input Page Program (32H) command code -> 3-byte address on IO0 -> at least 1-byte on data on IO[3:0] -> CS# goes high. A QPP command may be applied only to a page which is not protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits. 47 ZD25WQ16C Figure-45. Quad Input Page Program Sequence Diagram 48 ZD25WQ16C 4.27 Erase Security Register (ERSCUR) (44H) There are three 1024-byte Security Registers which can be erased and programmed individually. These registers may be used by system manufacturers to store security and other important information separately from the main memory array. The Erase Security Register (44H) command is like the Sector Erase (20H) command. A Write Enable command must be executed before the device will accept the ERSCUR Command (Status Register bit WEL must equal 1). The command is initiated by driving the CS# pin low and shifting the command code “44H” followed by a 24-bit address (A23-A0) to erase one of the security registers. The ERSCUR command sequence is shown in Figure-46. The CS# pin must be driven high after the eighth bit of the last address byte is latched. If this is not done, the command will not be executed. After CS# is driven high, the self-timed ERSCUR operation will commence for a time duration of tSE. While the Erase Security Register cycle is in progress, the Read Status Register command (05H) may still be accessed for checking the value of the Write in Progress (WIP) bit. The WIP bit is a 1 during the erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other commands again. After the Erase Security Register cycle has finished, the WEL bit in the Status Register is cleared to 0. The Security Register Lock Bits (LB3-1) in the Status Register are OTP and can be used to protect the security registers. Once the LB bit is set to 1, the corresponding security register will be permanently locked, and an ERSCUR command to that register will be ignored. Table-11.1 Erase Security Register Address ADDRESS A23-16 A15-12 A11-10 A9-0 Security Register #1 00h 0001 00 Don’t care Security Register #2 00h 0010 00 Don’t care Security Register #3 00h 0011 00 Don’t care Figure-46. Erase Security Register Sequence Diagram 49 ZD25WQ16C Figure-47. Erase Security Register Sequence Diagram (QPI) 4.28 Program Security Register (PRSCUR) (42H) The Program Security Register (42H) command is similar to the Page Program (02H) command. It allows from one byte to 1024 bytes of security register data to be programmed at previously erased (FFh) memory locations. A Write Enable (06H) command must be executed before the device will accept the PRSCUR Command (Status Register bit WEL= 1). The command is initiated by driving the CS# pin low then shiftingthe command code “42H” followed by a 24-bit address (A23-A0) and at least one data byte, into the SI pin. The CS# pin must be held low for the entire length of the command while data is being sent to the device. The PRSCUR command sequence is shown in Figure-48. The Security Register Lock Bits (LB3-1) in the Status Register are OTP can be used to protect the security registers. Once Security Register Lock Bit (LB31) is set to 1, the corresponding security register will be permanently locked, and a PRSCUR command to that register will be ignored. Table-11.2 Program Security Register Address ADDRESS A23-16 A15-12 A11-10 A9-0 Security Register #1 00h 0001 00 Byte Address Security Register #2 00h 0010 00 Byte Address Security Register #3 00h 0011 00 Byte Address 50 ZD25WQ16C Figure-48. Program Security Register Sequence Diagram Figure-49. Program Security Register Sequence Diagram(QPI) 51 ZD25WQ16C 4.29 Read Security Register (RDSCUR) (48H) The Read Security Register (48H) command is similar to the Fast Read (0BH) command and allows one or more data bytes to be sequentially read from one of the three security registers. The command is initiated by driving the CS# pin low and then shifting the command code “48H” followed by a 24-bit address (A23-A0) and eight “dummy” Cycles into the SI pin. The code and address bits are latched on the rising edge of the SCLK pin. After the address is received, and following the eight dummy cycles, the data byte of the addressed memory location will be shifted out on the SO pin on the falling edge of SCLK with the most significant bit (MSB) first. The first byte addressed can be at any location. The byte address is automatically incremented to the next byte address after each byte of data is shifted out. Once the byte address reaches the last byte of the register (byte 3FFh), it will reset to 000h, the first byte of the register, and continue to increment. The command is completed by driving CS# high. The RDSCUR command sequence is shown in Figure-50. If a RDSCUR command is issued while an Erase, Program, or Write cycle is in process (Write in Progress (WIP)=1), the command is ignored and will not have any effect on the current cycle. The RDSCUR command allows each bit being shifted out on SO pin at a Max frequency fC, on the falling edge of SCLK. Table-11.3 Read Security Register Address ADDRESS A23-16 A15-12 A11-10 A9-0 Security Register #1 00h 0001 00 Byte Address Security Register #2 00h 0010 00 Byte Address Security Register #3 00h 0011 00 Byte Address Figure-50. Read Security Register Sequence Diagram 52 ZD25WQ16C Figure-51. Read Security Register Sequence Diagram (QPI) 4.30 Write Configure Register (WRCR)(11H) The Write Configure Register (WRCR) command allows new values to be written to the Configure Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The sequence of issuing WRCR instruction is: CS# goes low→ sending WRCR instruction code→ Configure Register data on SI→CS# goes high. The CS# must go high exactly at the 8 bits data boundary; otherwise, the instruction will be rejected and not executed. The self-timed Write Status Register cycle time (tW) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Write Status Register cycle is in progress. The WIP sets 1 during the tW timing, and sets 0 when Write Configure Register Cycle is completed, and the Write Enable Latch (WEL) bit is reset. 53 ZD25WQ16C Figure 52. Write Configure Register (WRCR) Sequence (Command 11H) Figure 53. Write Configure Register (WRCR) Sequence (QPI) 4.31 Read Configure Register (RDCR) (45H or 15H in SPI Mode) The RDCR instruction is for reading Configure Register Bits. The Read Configure Register can be read at any time (even in program/erase/write status register condition). It is recommended to check the Write in Progress (WIP) bit before sending a new instruction when a program, erase, or write status register operation is in progress. The Command code “15H”only support RDCR in SPI Mode. The sequence of issuing RDCR instruction is: CS# goes low→ sending RDCR instruction code→ Configure Register data out on SO. 54 ZD25WQ16C Figure-54. Read Configure Register (Command 45H) Figure-55. Read Configure Register (QPI) 55 ZD25WQ16C 4.32 Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (B9H) command is the only way to place the device in the lowest power consumption mode (the Deep Power-Down mode). It can also be used as an extra software protection mechanisms the device is not in active use, all Write, Program and Erase commands are ignored. Driving Chip Select (CS#) High deselects the device and puts the device in the Standby mode (if there is no internal cycle currently in progress). However, Standby mode is not the Deep Power-Down mode. The Deep Power-Down mode can only be entered by executing the DP command, to reduce the standby current (from ISB1 to ISB2). Once the device has entered the Deep Power-Down mode, all commands are ignored except the Release from Deep Power-Down, Read Electronic Signature (ABH) command. This command releases the device from this mode and also outputs the Device ID on Data Output (SO). The Deep Power-Down mode automatically stops at Power-Down, and the device always Powers-up in the Standby mode. The DP command is entered by driving CS# Low, followed by the command code on Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The command sequence is shown in Figure-56. CS# must be driven High after the eighth bit of the command code has been latched in, otherwise the Deep Power-Down (B9H) command is not executed. As soon as CS# is driven High, a delay of tDP occurs before the supply current is reduced to ISB2 and the Deep Power-Down mode is entered. Any DP command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure-56. Deep Power-Down Sequence Diagram Figure-57. Deep Power-Down Sequence Diagram (QPI) 56 ZD25WQ16C 4.33 Release form Deep Power-Down (RDP), Read Electronic Signature (RES) (ABH) Once the device has entered the Deep Power-Down mode, all commands are ignored except the Release from Deep Power-Down, Read Electronic Signature (ABH) command. Executing this command takes the device out of the Deep Power-Down mode. Please note that this is not the same as or even a subset of, the JEDEC 16-bit Electronic Signature that is read by the Read Identification (9FH) command. The old-style Electronic Signature is supported for reasons of backward compatibility, only, and should not be used for new designs. New designs should, instead, make use of the JEDEC 16-bit Electronic Signature, and the Read Identification command. When used only to release the device from the power-down state, the command is issued by driving the Chip Select (CS#) pin low, shifting the command code “ABH” and driving CS# high as shown in Figure-58. After the time duration of tRES1 the device will resume normal operation and other commands will be accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the power-down state, the command is initiated by driving the CS# pin low and shifting the command code “ABH” followed by 3-dummy bytes. The Device ID bits are then shifted out on the falling edge of SCLK with the most significant bit (MSB) first as shown in Figure-60. The Device ID values are listed in "Tables of ID Definition" (Table-9). The Device ID can be read continuously. The command is completed by driving CS# high. When CS# is driven High, the device is put in the Stand-by Power mode. If the device was not previously in the Deep Power-Down mode, the transition to the Stand-by Power mode is immediate. If the device was previously in the Deep Power-Down mode, though, the transition to the Stand-by Power mode is delayed by tRES2, and CS# must remain High for at least tRES2 (max). Once in the Stand-by Power mode, the device waits to be selected, so that it can receive, decode and execute commands. Except while an Erase, Program or Write Status Register cycle is in progress, the RDP, RES command always provides access to the 8-bit Device ID of the device and can be applied even if the Deep Power-Down mode has not been entered. Any RDP, RES command issued to the device while an Erase, Program or Write Status Register cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. 57 ZD25WQ16C Figure-58. Release from Deep Power-Down (RDP) Sequence Diagram Figure-59. Release from Deep Power-Down (RDP) Sequence Diagram (QPI) Figure-60. Read Electronic Signature (RES) Sequence Diagram 58 ZD25WQ16C Figure-61. Read Electronic Signature (RES) Sequence Diagram (QPI) 4.34 Read Electronic Manufacturer ID & Device ID (REMS) (90H) The Read Electronic Manufacturer & Device ID (90H) command provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The REMS command is initiated by driving the CS# pin low and shifting the command code “90H” followed by two dummy bytes and one address byte (A7~A0). After which, the Manufacturer ID for ZETTA and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first as shown in Figure-63. The Device ID values are listed in "Tables of ID Definition" (Table-9). If the address byte is 00h, the manufacturer ID will be output first, followed by the device ID. If the address byte is 01h, then the device ID will be output first, followed by the manufacturer ID. While CS# is low, the Manufacturer and Device IDs can be read continuously, alternating from one to the other. The command is completed by driving CS# high. 59 ZD25WQ16C Figure-62. Read Electronic Manufacturer ID & Device ID Sequence Diagram Figure-63. Read Electronic Manufacturer ID & Device ID Sequence Diagram (QPI) 60 ZD25WQ16C 4.35 Dual I/O Read Electronic Manufacturer ID & Device ID (DREMS) (92H) The Dual I/O Read Electronic Manufacturer ID & Device ID (92H) command is similar to the Read Electronic Manufacturer & Device ID (90H) command and returns the JEDEC assigned Manufacturer ID which uses two pins: IO0, IO1 as address input and ID output I/O. The DREMS command is initiated by driving the CS# pin low and shifting the DREMS command code "92h" followed by two dummy bytes, one address byte (A7~A0) and one byte of ‘Continuous Read Mode’ Bits. After which, the Manufacturer ID for ZETTA and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The DREMS command is completed by driving CS# high. Figure-64. Dual I/O Read Electronic Manufacturer ID & Device ID Sequence Diagram Note: The “Continuous Read Mode” bits (M5-4) must be set to (1,0) to be compatible with Dual I/O Fast Read command. 4.36 Quad I/O Read Electronic Manufacturer ID & Device ID (QREMS) (94H) The Quad I/O Read Electronic Manufacturer ID & Device ID (94H) command is similar to the Read Electronic Manufacturer & Device ID (90H) command and returns the JEDEC assigned Manufacturer ID which uses four pins: IO0, IO1, IO2, IO3 as address input and ID output I/O. A Quad Enable (QE) of Status Register2 must be executed before the device will accept the QREMS Command (The QE bit must equal “1”). 61 ZD25WQ16C The QREMS command is initiated by driving the CS# pin low and shifting the QREMS command code "94h" followed by two dummy bytes, one address (A7~A0) byte, one byte of ‘Continuous Read Mode’ Bits and two dummy bytes. After which, the Manufacturer ID for ZETTA and the Device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The QREMS command is completed by driving CS# high. Figure-65. Quad I/O Read Electronic Manufacturer ID & Device ID Sequence Diagram 4 5 Note: The “Continuous Read Mode” bits (M5-4) must be set to (1,0) to be compatible with Quad I/O Fast Read command. 4.37 Read Identification (RDID) (9FH) The Read Identification (9FH) command allows the 8-bit Manufacturer ID to be read, followed by two bytes of Device ID. The Device ID indicates the memory type in the first byte, and the memory capacity of the device in the second byte. The ZETTA Manufacturer ID and Device ID are list as "Tables of ID Definition" (Table-9). Any RDID command issued while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The RDID command should not be issued while the device is in Deep Power down mode. The device is first selected by driving the CS# Low. Then the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification stored in the memory, shifted out on the SO pin on the falling edge of SCLK. The command sequence is shown in Figure-67. The RDID command is terminated by driving CS# High at any time during data output. When CS# is driven High, the device is placed in the standby mode. Once in the standby stage, the device waits to be selected, so that it can receive, decode and execute commands. 62 ZD25WQ16C Figure-66. Read Identification Sequence Diagram Figure-67. Read Identification Sequence Diagram (QPI) 63 ZD25WQ16C 4.38 Program/Erase Suspend/Resume (75H) The Suspend (75H or B0H) command interrupts a Page Program, Page Erase, Sector Erase, Half Block Erase or Block Erase operation to allow access to the memory array. After the program or erase operation has entered the suspended state, the memory array can be read except for the page being programmed or the page, sector or block being erased. Table-12.0 Readable Area of Memory While a Program or Erase Operation is Suspended Suspended Operation Readable Region of Memory Array Page Program All but the Page being programmed Page Erase All but the Page being erased Sector Erase(4KB) All but the 4KB Sector being erased Half Block Erase(32KB) All but the 32KB Block being erased Block Erase(64KB) All but the 64KB Block being erased When the Serial NOR Flash receives the Suspend command, there is a latency of tPSL or tESL before the Write Enable Latch (WEL) bit clears to “0” and the SUS sets to “1”. Afterwards, the device is ready to accept one of the commands listed in Table-11.1 "Acceptable Commands During Program/Erase Suspend after tPSL/tESL" (e.g. Read Data Bytes at Higher Speed (0BH) command). Refer to "AC CHARACTERISTICS" for tPSL and tESL timings. Table-11.2 "Acceptable Commands During Suspend (tPSL/tESL not required)" lists the commands for which the tPSL and tESL latencies do not apply. For example, Read Status Register, Read Security Registers, Reset Enable and Reset can be issued at any time after the Suspend command. Status Register bit 15 (SUS) can be read to check the suspend status. The SUS (Program/Erase Suspend Bit) sets to “1” when a program or an erase operation is suspended. The SUS clears to “0” when the program or erase operation is resumed. Table-12.1 Acceptable Commands During Program/Erase Suspend after tPSL/tESL Command name Suspend Type Command Code Program Suspend Erase Suspend READ 03H • • FAST READ 0BH • • DREAD 3BH • • QREAD 6BH • • 2READ BBH • • 4READ EBH • • RDSFDP 5AH • • RDID 9FH • • REMS 90H • • DREMS 92H • • QREMS 94H • • RDSCUR 48H • • SBL 77H • • WREN 06H RESUME 7AH OR 30H PP 02H • DPP A2H • QPP 32H • • • 64 • ZD25WQ16C Table-12.2 Acceptable Commands During Suspend(tPSL/tESL not required) Command name Command Code WRDI Suspend Type Program Suspend Erase Suspend 04H • • RDSR 05H • • RDSR2 35H • • ASI 25H • • RSTEN 66H • • RST 99H • • NOP 00H • • Figure-68. Resume to Suspend Latency tPRS / tERS CS# Suspend Command Resume Command tPRS: Program Resume to another Suspend tERS: Erase Resume to another Suspend Erase Suspend to Program The “Erase Suspend to Program” feature allows Page Programming while an erase operation is suspended. Page Programming is permitted in any unprotected memory except within the sector of a suspended Sector Erase operation or within the block of a suspended Block Erase operation. The Write Enable (06H) command must be issued before any Page Program (02H) command. A Page Program operation initiated within a suspended erase cannot itself be suspended and must be allowed to finish before the suspended erase can be resumed. The Status Register can be polled to determine the status of the Page Program operation. The Write Enable Latch (WEL) and Write in Progress (WIP) bits of the Status Register will remain “1” while the Page Program operation is in progress and will both clear to “0” when the Page Program operation completes. Figure-69. Suspend to Read/Program Latency tPSL / tESL CS# Suspend Command tPSL: Program Suspend Latency tESL: Erase Suspend Latency 65 Read/Program Command ZD25WQ16C Figure-70. Suspend to Read/Program Latency (QPI) 4.39 Program Resume and Erase Resume (7AH) The Resume (7AH or 30H) command resumes a suspended Page Program, Page Erase, Sector Erase, Half Block Erase or Block Erase operation. Before issuing the Resume command to restart a suspended erase operation, make sure that there is no Page Program operation in progress. Immediately after the Serial NOR Flash receives the Resume command, the Write Enable Latch (WEL) and Write in Progress (WIP) bits are set to “1” and the SUS is cleared to “0”. The program or erase operation will continue until finished ("Resume to Read Latency") or until another Suspend (75H or B0H) command is received. A resume-to-suspend latency of tPRS or tERS must be observed before issuing another Suspend command ("Resume to Suspend Latency"). Figure-71. Program Resume and Erase Resume Sequence Diagram tSE / tBE / tPP CS# Read Command Resume Command 66 ZD25WQ16C Figure-72. Program Resume and Erase Resume Sequence Diagram (QPI) 4.40 Read Unique ID (RUID) (4BH) The Read Unique ID (4BH) command accesses a factory-set read-only 128-bit number that is unique to each ZD25WQ16C device. The ID number can be used in conjunction with user software methods to help prevent copying or cloning of a system. The RUID command is initiated by driving the CS# pin low and shifting the command code “4BH” followed by four dummy bytes. Then, the 128-bit ID is shifted out on the falling edge of SCLK as shown in Figure-74. Figure-73. Read Unique ID Sequence Diagram 67 ZD25WQ16C 4.41 Read SFDP Mode (RDSFDP) (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be queried by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a JEDEC Standard, JESD216B. ZD25WQ16C features the Read SFDP Mode (5AH) command. The host system can retrieve the operating characteristics, structure and vendor specified information such as identifying information, memory size, operating voltage and timing information of this device by SFDP mode. The device is first selected by driving Chip Select (CS#) Low. The command code for the RDSFDP is followed by a 3-byte address (A23~A0) and a dummy byte, with each bit latched-in on the rising edge of Serial Clock (SCLK). Then the memory contents, at the specified address, is shifted out on Data Output (SO) at a maximum frequency fC on the falling edge of SCLK. The command sequence is shown in Figure-75. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. The entire SFDP table can, therefore, be read with a single RDSFDP command. When the highest address is reached, the address counter rolls over to 0x00h, allowing the read sequence to be continued indefinitely. The RDSFDP command is terminated by driving CS# High. CS# can be driven High at any time during data output. Any RDSFDP commands issued, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure-74. Read Serial Flash Discoverable Parameter Sequence Diagram 68 ZD25WQ16C Figure-75. Read Serial Flash Discoverable Parameter Sequence Diagram (QPI) 69 ZD25WQ16C Table-13. Serial Flash Discoverable Parameter (SFDP) Table Description SFDP Signature Comment Fixed: 50444653H Add (H) DW Add (Byte) (Bit) 00H Data Data 07:00 53H 53H 01H 15:08 46H 46H 02H 23:16 44H 44H 03H 31:24 50H 50H SFDP Minor Revision Number Start from 00H 04H 07:00 00H 00H SFDP Major Revision Number Start from 01H 05H 15:08 01H 01H Number of Parameters Headers Start from 00H 06H 23:16 01H 01H 07H 31:24 FFH FFH 08H 07:00 00H 00H Start from 0x00H 09H 15:08 00H 00H Start from 0x01H 0AH 23:16 01H 01H 0BH 31:24 09H 09H 0CH 07:00 30H 30H 0DH 15:08 00H 00H 0EH 23:16 00H 00H 0FH 31:24 FFH FFH It is indicates ZETTA manufacturer ID 10H 07:00 BAH BAH Start from 0x00H 11H 15:08 00H 00H Start from 0x01H 12H 23:16 01H 01H 13H 31:24 03H 03H 14H 07:00 60H 60H 15H 15:08 00H 00H 16H 23:16 00H 00H 17H 31:24 FFH FFH Unused ID number (JEDEC) Parameter Table Minor Revision Number Parameter Table Major Revision Number Contains 0xFFH and can never be changed 00H: It indicates a JEDEC specified header Parameter Table Length How many DWORDs (in double word) in the Parameter table Parameter Table Pointer (PTP) Unused ID Number (ZETTA Device Manufacturer ID) Parameter Table Minor Revision Number Parameter Table Major Revision Number First address of JEDEC Flash Parameter table Contains 0xFFH and can never be changed Parameter Table Length How many DWORDs in the (in double word) Parameter table Parameter Table Pointer (PTP) First address of ZETTA Flash Parameter table Unused Contains 0xFFH and can never be changed 70 ZD25WQ16C Description Comment Add (H) DW Add (Byte) (Bit) Data Data 00: Reserved; 01: 4KB erase; Block/Sector Erase Size 10: Reserved; 11: not support 4KB 01:00 01b 02 1b 03 0b erase Write Granularity 0: 1Byte, 1: 64Byte or larger Write Enable Instruction 0: Nonvolatile status bit Requested for Writing to Volatile 1: Volatile status bit Status Registers (BP status register bit) 0: Use 50H Opcode, Write Enable Opcode Select for Writing to Volatile Status Registers 30H E5H 1: Use 06H Opcode, Note: If target flash status register is 04 0b 07:05 111b 15:08 20H 16 1b 18:17 00b Nonvolatile, then bits 3 and 4 must be set to 00b. Unused Contains 111b and can never be changed 4KB Erase Opcode 31H (1-1-2) Fast Read 0=Not support, 1=Support Address Bytes Number used in 00: 3 Byte only, 01: 3 or 4 Byte, addressing flash array 10: 4 Byte only, 11: Reserved Double Transfer Rate (DTR) clocking 0=Not support, 1=Support 19 0b (1-2-2) Fast Read 0=Not support, 1=Support 20 1b (1-4-4) Fast Read 0=Not support, 1=Support 21 1b (1-1-4) Fast Read 0=Not support, 1=Support 22 1b 23 1b FFH 32H Unused F1H Unused 33H 31:24 Flash Memory Density 37H:34H 31:00 (1-4-4) Fast Read Number of Wait 00000b: Wait states states (Dummy Cycles) not support (1-4-4) Fast Read Number of Mode Bits (1-4-4) Fast Read Opcode 00000b: Wait states states (Dummy Cycles) not support Bits (1-1-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Cycles) not support 71 00100b 44H 07:05 010b 15:08 EBH 20:16 01000b EBH 08H 3AH 23:21 000b 3BH 31:24 6BH 6BH 3CH 04:00 01000b 08H 000b:Mode Bits not support (1-1-4) Fast Read Opcode FFH 00FFFFFFH 38H 39H (1-1-4) Fast Read Number of Wait (1-1-4) Fast Read Number of Mode 04:00 000b:Mode Bits not support 20H ZD25WQ16C Description (1-1-2) Fast Read Number of Mode Bits Comment 000b: Mode Bits not support (1-1-2) Fast Read Opcode (1-2-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Cycles) not support (1-2-2) Fast Read Number of Mode Bits (Byte) (Bit) 3CH 3DH 0=not support 0=not support 1=support 1=support Data Data 07:05 000b 08H 15:08 3BH 3BH 20:16 00000b 3EH 3FH Unused (4-4-4) Fast Read DW Add 000b: Mode Bits not support (1-2-2) Fast Read Opcode (2-2-2) Fast Read Add (H) 40H Unused 80H 23:21 100b 31:24 BBH 00 0b 03:01 111b 04 0b 07:05 111b BBH EEH Unused 43H:41H 31:08 FFH FFH Unused 45H:44H 15:00 FFH FFH 20:16 00000b (2-2-2) Fast Read Number of Wait 00000b: Wait states states (Dummy Cycles) not support (2-2-2) Fast Read Number of Mode Bits 46H 000b: Mode Bits not support 00H 23:21 000b (2-2-2) Fast Read Opcode 47H 31:24 FFH FFH Unused 49H:48H 15:00 FFH FFH 4AH 20:16 00000b 00H 23:21 000b 4BH 31:24 FFH FFH 4CH 07:00 0CH 0CH 4DH 15:08 20H 20H 4EH 23:16 0FH 0FH 4FH 31:24 52H 52H 50H 07:00 10H 10H 51H 15:08 D8H D8H 52H 23:16 08H 08H 53H 31:24 81H 81H (4-4-4) Fast Read Number of Wait 00000b: Wait states states (Dummy Cycles) not support (4-4-4) Fast Read Number of Mode Bits 000b: Mode Bits not support (4-4-4) Fast Read Opcode Sector Type 1 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 1 erase Opcode Sector Type 2 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 2 erase Opcode Sector Type 3 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 3 erase Opcode Sector Type 4 Size Sector/block size=2^N bytes 0x00b: this sector type doesn’t exist Sector Type 4 erase Opcode 72 ZD25WQ16C Description Comment Add (H) DW Add (Byte) (Bit) 61H:60H 63H:62H Data Data 15:00 2000H 2000H 31:16 1650H 1650H 2000H=2.000V Vcc Supply Maximum Voltage 2700H=2.700V 3600H=3.600V 1650H=1.650V Vcc Supply Minimum Voltage 2250H=2.250V 2350H=2.350V 2700H=2.700V HW Reset# pin 0=not support 1=support 00 0b HW Hold# pin 0=not support 1=support 01 1b Deep Power Down Mode 0=not support 1=support 02 1b SW Reset 0=not support 1=support 03 1b SW Reset Opcode Should be issue Reset Enable (66H) before Reset cmd. 65H:64H 11:04 1001 1001b (99H) F99EH Program Suspend/Resume 0=not support 1=support 12 1b Erase Suspend/Resume 0=not support 1=support 13 1b 14 1b 15 1b 66H 23:16 77H 77H 67H 31:24 64H 64H 00 0b 01 0b 09:02 FFH 10 0b Unused Wrap-Around Read mode 0=not support 1=support Wrap-Around Read mode Opcode 08H:support 8B Wrap-Around read Wrap-Around Read data length 16H:8B&16B 32H:8B&16B&32B 64H:8B&16B&32B&64B Individual block lock Individual block lock bit (Volatile/Nonvolatile) 0=not support 1=support 0=Volatile 1=Nonvolatile Individual block lock Opcode Individual block lock Volatile protect bit default protect status 0=protect 1=unprotect 6BH:68H Secured OTP 0=not support 1=support 11 1b Read Lock 0=not support 1=support 12 0b Permanent Lock 0=not support 1=support 13 0b Unused 15:14 11b Unused 31:16 FFFFH 73 CBFCH FFFFH ZD25WQ16C 4.42 Continuous Read Mode Reset (CRMR) (FFH) The “Continuous Read Mode” bits are used in conjunction with Dual I/O Fast Read (BBH) and Quad I/O Fast Read (EBH) commands to provide the highest random Flash memory access rate with minimum SPI command overhead, thus allowing more efficient XIP (execute in place) with this device family. A device that is in a continuous high performance read mode may not recognize any normal SPI command or the Software Reset (66H, 99H) command. It is recommended to use the Continuous Read Mode Reset (FFH) command after a system Power on Reset or, before sending a Software Reset, to ensure the device is released from “Continuous Read Mode”. The “Continuous Read Mode” bits M7-0 are set by the Dual/Quad I/O Fast Read (BBH or EBH) commands. M5-4 are used to control whether the 8-bit SPI command code (BBH or EBH) is needed or not for the next command. When M5-4 = (1,0), the next command will be treated the same as the current Dual/Quad I/O Fast Read command without requiring the 8-bit command code; when M5-4 do not equal (1,0), the device returns to normal SPI command mode, in which all commands can be accepted. M7-6 and M3-0 are reserved bits for future use, either 0 or 1 values can be used. Because the ZD25WQ16C has no hardware reset pin, if Continuous Read Mode bits are set to (1,0), the ZD25WQ16C will not recognize any standard SPI commands. The Continuous Read Mode Reset (FFH) will release the “Continuous Read Mode” and return to normal SPI operation ( if in QPI mode, then exit QPI mode together). The command sequence is shown in Figure-77. Figure-76. Continuous Read Mode Reset Sequence Diagram 4.43 Enable QPI (38H) The device support both Standard/Dual/Quad SPI and QPI mode. The “Enable QPI (38H)” command can switch the device from SPI mode to QPI mode. See the command Table 8 for all support QPI commands. In order to switch the device to QPI mode, the Quad Enable (QE) bit in Status Register-1 must be set to 1 first, and “Enable QPI (38H)” command must be issued. If the QE bit is 0, the “Enable QPI (38H)” command will be ignored and the device will remain in SPI mode. When the device is switched from SPI mode to QPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. 74 ZD25WQ16C Figure 77. Enable QPI (QPI) 4.44 Disable QPI (FFH) To exit the QPI mode and return to Standard/Dual/Quad SPI mode, 1) Using “Disable QPI (FFH)” command . 2) Setting QE bit =0, the QPI mode will switch to SPI mode. When the device is switched from QPI mode to SPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Note : this command will exit “Continue read mode” together See 9.41 Figure 78. Disable QPI (QPI) 4.45 No Operation (NOP) The No Operation (00H) command is only able to terminate the Reset Enable (66H) command and will not affect any other command. The IO[3:1] are don't care. Figure-79. No Operation Sequence Diagram 75 ZD25WQ16C 4.46 Reset Enable (RSTEN) (66H) and Reset (RST) (99H) The Software Reset operation combines two commands: Reset Enable (66H) command and Reset (99H) command. It returns the device to standby mode. All the volatile bits and settings will be cleared which returns the device to the same default status as power on. The Reset command immediately following a Reset Enable command, initiates the Software Reset process. Any command other than Reset following the Reset Enable command, will clear the reset enable condition and prevent a later Reset command from being recognized. If the Reset command is executed during a program or erase operation, the operation will be disabled and the data under processing could be damaged or lost. Figure-80. Reset Enable and Reset Sequence Diagram Figure-81 Reset Enable and Reset Sequence Diagram (QPI) 76 ZD25WQ16C 5. ELECTRICAL SPECIFICATIONS 5.1 Power-On Timing Figure-82. Power-On Timing Sequence Diagram Table-14 Power-Up Timing and Write Inhibit Threshold Sym. Parameter Min. tVSL VWI VPWD tPWD VCC(min.) to device operation Write Inhibit Voltage VCC voltage needed to below VPWD for ensuring initializtion will occur The minimum duration for ensuring initialization will occur 0.3 1 Max. Unit ms V V us 1.55 1.1 300 5.2 Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH).The Status Register contains 00H (all Status Register bits are 0) 5.3 Absolute Maximum Ratings Table-15 Absolute Maximum Ratings Parameter Value Ambient Operating Temperature Storage Temperature Applied Input / Output Voltage Transient Input / Output Voltage(note: overshoot) VCC Unit -40 to 85 -65 to 150 -0.6 to VCC+0.4 -2.0 to VCC+2.0 -0.6 to 4.2 °C °C V V V Figure-83. Maximum Negative/positive Overshoot Diagram Maximum Negative Overshoot Waveform Maximum Positive Overshoot Waveform 20ns 20ns 20ns Vss Vcc + 2.0V Vss - 2.0V Vcc 20ns 20ns 77 20ns ZD25WQ16C 5.4 AC Measurement Conditions Table-16. AC Measurement Conditions Sym. Parameter CIN COUT CL Input Capacitance Output Capacitance Load Capacitance Input Input Pulse Voltage Input Timing Reference Voltage Output Timing Reference Voltage 5.5 DC Characteristics Symbol IDPD Min. Typ. Max Unit 6 8 pF pF pF ns V V 30 5 0.1VCC to 0.8VCC 0.2VCC to 0.7VCC 0.5VCC Conditions VIN = GND VOUT = GND Table-17. DC Parameters (Ta=-40°C to +85°C ) Parameter Conditions Deep power down CS#=Vcc, all other current inputs at 0V or Vcc 1.65V to 3.6V Min. 2.3V to 3.6V Typ. Max. 0.2 Min. Typ. Max. Units 3.0 0.3 3.0 uA 8 15 12 15 uA CS#, HOLD#, ISB Standby current WP#=Vcc all inputs at CMOS levels ICC1 Low power read f=1MHz; IOUT=0mA 1.0 1.5 1.0 1.5 mA current (03h) f=33MHz; IOUT=0mA 2.0 3.0 2.0 3.0 mA f=50MHz; IOUT=0mA 2.8 6.0 3.0 6.0 mA f=86MHz; IOUT=0mA 3.2 7.0 4.5 8.0 mA ICC2 Read current (0Bh) ICC3 Program current CS#=Vcc 3.0 5.0 4.0 6.0 mA ICC4 Erase current CS#=Vcc 3.0 4.0 3.5 4.0 mA ICC5 Write current CS#=Vcc 3.0 4.0 3.5 4.0 mA 1.0 1.0 uA 1.0 1.0 uA 0.2Vcc 0.2Vcc V All inputs at CMOS ILI Input load current ILO Output leakage VIL Input low voltage VIH Input high voltage VOL Output low voltage IOL=100uA VOH Output high voltage IOH=-100uA level All inputs at CMOS level 0.8Vcc 0.8Vcc 0.2 Vcc-0.2 Note: 1. Typical values measured at 1.8V @ 25°C for the 1.65V to 3.6V range. 2.Typical values measured at 3.0V @ 25°C for the 2.3V to 3.6V range. 78 V 0.2 Vcc-0.2 V V ZD25WQ16C 5.6 AC Characteristics Symbol Table-18. AC Parameters (Ta=-40°C to +85°C ) Alt. fsclk fC fRSCLK fR fT fTSCLK fQ fQPP 1.65V~3.6V Parameter min. typ Clock Frequency for the following instructions: FAST_READ, RDSFDP, PP, 2.3V~3.6V max. min typ max Unit 68 104 MHz Clock Frequency for READ instructions 40 50 MHz Clock Frequency for DREAD instructions 68 104 MHz Clock Frequency for 2READinstructions 68 86 MHz Clock Frequency for QREAD instructions 68 86 MHz Clock Frequency for 4READ instructions 68 86 MHz Clock Frequency for QPP (Quad page program) 104 104 MHz SE, BE32K, BE, CE, DP,RES, WREN, WRDI, RDID, RDSR, WRSR(7) tCH(1) tCLH Clock High Time 6.0 4.5 ns tCL(1) tCLL Clock Low Time (fSCLK) 45% x (1fSCLK) 6.0 4.5 ns tCLCH(7) Clock Rise Time (peak to peak) 0.2 0.2 v/ns tCHCL(7) Clock Fall Time (peak to peak) 0.2 0.2 v/ns CS# Active Setup Time (relative to SCLK) 6 6 ns CS# Not Active Hold Time (relative to SCLK) 5 5 ns tSLCH tCSS tCHSL tDVCH tDSU Data In Setup Time 2 2 ns tCHDX tDH Data In Hold Time 4 4 ns 5.5 ns tCHSH CS# Active Hold Time (relative to SCLK) tSHCH CS# Not Active Setup Time (relative to SCLK) 5 5 ns CS# Deselect Time From Read to next Read 20 20 ns CS# Deselect Time From Write,Erase,Program to Read Status Register 20 20 ns Volatile Status Register Write Time 20 20 ns tSHSL tSHQZ(7) tCSH tDIS tCLQV tV tCLQX tHO 5.5 Output Disable Time 6 6 ns Clock Low to Output Valid Loading 30pF 8 7 ns Clock Low to Output Valid Loading 15pF 7 6 ns Output Hold Time 0 0 ns tHLCH HOLD# Active Setup Time (relative to SCLK) 5 5 ns tCHHH HOLD# Active Hold Time (relative to SCLK) 5 5 ns tHHCH HOLD# Not Active Setup Time (relative to SCLK) 5 5 ns tCHHL HOLD# Not Active Hold Time (relative to SCLK) 5 5 ns tHHQX tLZ HOLD# to Output Low-Z 6 6 ns tHLQZ tHZ HOLD# to Output High-Z 6 6 ns tWHSL(3) Write Protect Setup Time 20 20 ns tSHWL(3) Write Protect Hold Time 100 100 ns tDP CS# High to Deep Power-down Mode 2 2 us tRES1 CS# High To Standby Mode Without Electronic Signature Read 5 5 us tRES2 CS# High To Standby Mode With Electronic Signature Read 5 5 us tW Write Status Register Cycle Time 12 ms tReady 8 Reset recovery time(for erase/program operation except WRSR) Reset recovery time(for WRSR operation) 50 8 50 8 79 12 12 us 8 12 ms ZD25WQ16C Table-19. AC Parameters for Program and Erase(Ta=-40°C to +85°C ) Sym. 1.65V to 3.6V Parameter Min. Typ. Max. Units TESL(6) Erase Suspend Latency 45 us TPSL(6) Program Suspend Latency 45 us TPRS(4) Latency between Program Resume and next Suspend 0.3 us TERS(5) Latency between Erase Resume and next Suspend 0.3 us tPP Page program time (up to 256 bytes) 1.8 3 ms tPE Page erase time 12 20 ms tSE Sector erase time 12 20 ms tBE1 Block erase time for 32K bytes 12 20 ms tBE2 Block erase time for 64K bytes 12 20 ms tPW Write time (up to 256 bytes) 12 20 ms tCE Chip erase time 80 160 ms Notes: 1. tCH + tCLmust be greater than or equal to 1/Frequency. 2. Typical values given for TA=25°C. Not 100% tested. 3. Only applicable as a constraint for a WRSR command. 4. Program operation may be interrupted as often as system request. The minimum timing of tPRS must be observed before issuing the next program suspend command. However, for a Program operation to make progress, tPRS ≥ 100us must be included in resume-to-suspend loop(s). Not 100%tested. 5. Erase operation may be interrupted as often as system request. The minimum timing of tERS must be observed before issuing the next erase suspend command. However, in order for an Erase operation to make progress, tERS ≥ 200us must be included in resume-to-suspend loop(s). Notes. Not 100% tested. 6. Latency time is required to complete Erase/Program Suspend operation. 7. The value guaranteed by characterization, not 100% tested in production. Figure-84. Serial Input Timing 80 ZD25WQ16C Figure-85. Output Timing CS# tCLH SCLK SO tCLL tCLQV tCLQX tCLQV tCLQX tSHQZ tQLQH tQHQL LSB SI Least significant address bit (LIB) in Figure-86. Hold Timing CS# tHLCH tCHHL SCLK tCHHH tHLQZ SO tHHCH tHHQX HOLD# SI do not care during HOLD operation. Figure-87. WP Timing CS# tWHSL tSHWL WP# SCLK SI Write status register is allowed 81 Write status register is not allowed ZD25WQ16C 6. ORDERING INFORMATION ZD 25XX X X X X X X Packaging Type T:Tube R:Tape & Reel Y:Tray Green Code G: Low-halogen, Lead(Pb)-free P: Lead (Pb) - free Temperature Range E: Extended (-25℃~85℃) I: Industrial(-40℃~85℃) J:Industrial Plus (-40℃~105℃) Package Type S: 208mil SOP8 T: 150mil SOP8 O:173mil TSSOP8 U:USON8(3*2mm, 0.55mm) E:USON8(3*2mm,0.50mm) Version A: A Version B: B Version C: C Version Device Density 16: 16Mbit Base Part Number 25WQ: Quad SPI Nor Flash Zetta Memory 82 ZD25WQ16C 7. PACKAGE INFORMATION 7.1 Package SOP8 150MIL D 5 8 E1 E h L 1 4 “A” L1 Ɵ b Base Metal A2 A e c A1 b Detail “A” Dimensions Symbol A A1 A2 b c D E E1 Min 1.35 0.05 1.35 0.38 0.17 4.80 5.80 3.80 Nom 1.55 0.10 1.40 - - 4.90 6.00 3.90 Max 1.65 0.15 1.50 0.51 0.25 5.00 6.20 4.00 Unit mm Note: 1. Both the package length and width do not include the mold FLASH. 2. Seating plane: Max. 0.25mm. 83 e L L1 0.50 1.27 0.60 0.80 1.04 h θ 0.30 0° 0.40 - 0.50 8° ZD25WQ16C 7.2 Package TSSOP8 D 8 5 E1 E h L “A” 1 L1 Ɵ 4 b Base Metal A2 A e c A1 b Detail “A” Dimensions Symbol Unit A Min mm A1 A2 b c D E E1 0.05 0.8 0.19 0.09 2.90 6.20 4.30 1.00 - - 3.00 6.40 4.40 1.05 0.30 0.20 3.10 6.60 4.50 Nom Max 1.2 0.15 Note: 1. Both the package length and width do not include the mold FLASH. 2. Seating plane: Max. 0.25mm. 84 e L L1 0.45 0.65 0.60 0.75 h θ 0° 1.00 8° ZD25WQ16C 7.3 Land USON(3x2mm, thickness 0.55mm) 85 ZD25WQ16C 7.4-Land USON(3x2mm, thickness 0.50mm) 86 ZD25WQ16C 8. REVISION HISTORY Version No Description Date 1.1 Initial Release 2021-08-15 1.2 Modify the AC/DC Parameters table 2022-03-18 1.3 Add Package Information 2022-10-18 87
ZD25WQ16CTIGT 价格&库存
很抱歉,暂时无法提供与“ZD25WQ16CTIGT”相匹配的价格&库存,您可以联系我们找货
ZD25WQ16CTIGT
  • 5+1.71529
库存:29
