R1M
R1M
    DY(迪一电子)
    SMAF(DO-214AD)
    R1M
R1M 数据手册
R1A THRU R1M 1.0AMP Surface Mount Glass Superfast Recovery Rectifier Features Case: SMAF · Fast switching for high efficiency · Low Power Loss,High Efficiency · High current capability · For Use in Low Voltage Application · Plastic Case Material has UL Flammability 0.063(1.6) 0.047(1.2) Classication Rating 94V -0 Mechanical Data · Case: Molded plastic SMAF · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed · Polarity:Cathode Band or Cathode Notch · Mounting Position: Any · Making: Type Number Dimiensions in inches and (milimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% SYMBOL R1A Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Average Rectified Output Current @T L =90 ℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=1.0A Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage@TA =125 ℃ Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) VRRM VRMS VDC 50 35 50 R1B R1D R1G R1J R1K R1M Unit 100 200 400 600 800 1000 V 70 140 560 700 V 100 200 800 1000 V 280 400 420 600 IF(AV) 1.0 A IFSM 30 A I 2t V FM 1.3 V 5.0 IR Trr CJ A2s 3.735 uA 150 250 150 500 ns 7 pF 70 ℃/W Typical Thermal Resistance Junction to Ambient(Note 3) RθJA Operating Temperature Range TJ -55 to+150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range Note: 1.Reverse Recovery Test Conditions:IF=0.5A,IR=1.0A,IRR=0.25A. 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 3.Device mounted on FR-4 substrate, 1"*1", 2oz, single-sided, PC boards with 0.06"*0.09" copper pad. version:06 1 of 3 R1A THRU R1M 1.0AMP Surface Mount Glass Superfast Recovery Rectifier FIG.1MAXIMUM AVERAGE FORWARD CURRENT DERATING 2.0 1.0 0.5 0 0 50 100 10 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) FIG.2TYPICAL FORWARD CHARACTERISTICS 150 1.0 0.1 O TA = 25 C .0 1 O LEAD TEMPERATURE( C) .00 1 0.3 0.5 0.7 0.9 1.1 1.3 1.7 1.5 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4TYPICAL JUNCTION CAPACITANCE 30 100 8.3ms Single Half Sine-Wave JEDEC Method 25 O CAPACITANCE, (pF) PEAK FORWARD SURGE CURRENT,(A) FIG.3MAXIMUM NON-REPEITIVE SURGE CURRENT 20 15 10 Tj= 25 C f= 1.0MHz Vsig = 50mVp -p 10 5 0 1 6 2 10 20 40 60 1 100 0.1 NUMBER OF CYCLES AT 60Hz 100 10 1 REVERSE VOLTAGE, (V) FIG.5TYPICAL REVERSE CHRACTERISTICS Fig.6 TYPICAL CAPACITANCE 0.224 (5.7) O TA = 150 C 100 0.098 (2.5) TA = 100 OC 10 1.0 O TA = 25 C 0.1 20 40 60 80 100 120 140 PERCENT OF RATED PEAK INVERSE VOLTGE version:06 0.063 (1.6) 0.059 (1.5) INVSTANTANEOUS REVERSE CURRENT, MICROAMPERES 1000 2 of 3 R1A THRU R1M 1.0AMP Surface Mount Glass Superfast Recovery Rectifier Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:06 3 of 3
很抱歉,暂时无法提供与“R1M”相匹配的价格&库存,您可以联系我们找货
