ES2A THRU ES2K
2.0AMP Surface Mount Glass Superfast Recovery Rectifier
Features
Case: SMA(DO-214AC)
· Low Power Loss, High Efficiency
· Ideally Suited for Automatic Assembly
· Guard Ring Die Construction
· Plastic Case Material has UL Flammability
Classification Rating 94V- 0
Mechanical Data
· Case: Molded plastic SMA
· Terminals: Plated leads solderable per
MIL-STD-750,Method 2026 guaranteed
· Polarity: Color band dentes cathode end
· Mounting Position: Any
· Making: Type Number
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified
Single phase,half wave,60Hz,resistive or inductive load
For capacitive load derate current by 20%
Type Number
SYMBOL ES2A
ES2B
ES2D
ES2G
ES2J
ES2K
Unit
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
800
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
V
Average Rectified Output Current @TL =100 ℃
IF(AV)
Non-Repetitive Peak Forward Surge @Tj=25 ℃
Current 8.3ms Single half sine-wave @Tj=125 ℃
IFSM
2.0
A
60
A
48
Superimposed On Rated Load (JEDEC Method)
Current 1.0ms Single half sine-wave @T j=125℃
IFSM
10000 times of the wave surge current
( time width 1ms, time interval 3s )
IFSM
Rating for fusing (t
很抱歉,暂时无法提供与“ES2G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12443
- 200+0.09764
- 600+0.08273
- 2000+0.07371
- 7500+0.06596
- 22500+0.06183
