SF56G
SF56G
    DY(迪一电子)
    DO-27(DO-201AD)
    耐压:400V 电流:5A 反向恢复时间:35NS
SF56G 数据手册
SF51G THRU SF58G 5 .0 AMPS. Glass Passivated Super Fast Rectifiers Features · Low forward voltage drop Case: DO-201AD · High current capability · High reliability · High surge current capability · Plastic material-UL flammability 94V-0 0.945(24.0) MIN. DIA. Mechanical Data · Case: Molded plastic DO-201AD · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end 0.945(24.0) DIA. MIN. · Mounting Position: Any · Making: Type Number · Lead Free: For RoHS/Lead Free Version Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL SF51G SF52G SF53G SF54G SF55G SF56G SF58G Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 104 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current.375"(9.5mm) lead length@TL =100℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=5.0A Peak Reverse Current IF(AV) 5.0 A IFSM 150 A I 2t 93.375 A2s V VFM 1.30 0.95 5.0 @TA=25℃ uA 100 At Rated DC Blocking Voltage @TA=125℃ 85 1.7 40 Typical Junction Capacitance (Note 1) CJ Typical Thermal Resistance Junction to Ambient(Note 2) RθJA 45 ℃ /W Maximum Reverse Recovery Time(Note 3) Trr 35 ns Operating Temperature Range TJ -55 to +150 ℃ TSTG -55 to +150 ℃ /Storage Temperature Range Note:1. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 2. Leads maintained at ambient temperature at a distance of 9.5mm from the case 3.Reverse Recovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A version:05 1 of 3 pF SF51G THRU SF58G 5 .0 AMPS. Glass Passivated Super Fast Rectifiers FIG. 1 – FORWARD CURRENT DERATING CURVE 3.0 2.0 1.0 0 25 50 75 100 125 150 175 SF 54 G 10 3. 0 SF 58 G 4.0 -S F5 6G 5.0 50 SF 55 G AVERAGE FORWARD CURRENT ( A ) 6.0 SF 51 G- INSTANTANEOUS FORWARD CURRENT,(A) FIG.2-TYPICAL FORWARD CHARACTERISTICS 1.0 TA =25 C 0.1 Pulse Width 300us 1% Duty Cycle O LEAD TEMPERATURE( C) 01 .4 .6 .8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE (V) FIG. 4 TYPICAL REVERSE CHARACTERISTICS 100 200 REVERSE LREAKAGE CURRENT (μA) PEAK FORWARD SURGE CURRENT, ( A ) FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 150 100 50 0 PULSE WIDTH 8.3mS SINGLE HALF-SINE-WAVE (JEDEC METHOD) 1 2 5 10 20 50 100 10 TJ =125℃ 1 0.1 TJ =25 ℃ 0.01 20 30 40 50 60 70 80 90 NUMBER OF CYCLES AT 60Hz PERCENT OF RATED PEAK REVERSE VOLTAGE (%) version:05 2 of 3 100 SF51G THRU SF58G 5 .0 AMPS. Glass Passivated Super Fast Rectifiers Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:05 3 of 3
SF56G 价格&库存
很抱歉,暂时无法提供与“SF56G”相匹配的价格&库存,您可以联系我们找货
SF56G
  • 5+0.60718
  • 50+0.48320
  • 150+0.42120
库存:248
