E1J
E1J
    DY(迪一电子)
    SMAF(DO-214AD)
    耐压:600V 电流:1A 反向恢复时间:35NS
E1J 数据手册
E1A THRU E1J 1.0AMP Surface Mount Glass Superfast Recovery Rectifier Features Case: SMAF · Low Power Loss, High Efficiency · Ideally Suited for Automatic Assembly ·Guard Ring Die Construction · Plastic Case Material has UL Flammability Classification Rating 94V - 0 0.063(1.6) 0.047(1.2) Mechanical Data · Case: Molded plastic SMAF · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed · Polarity: Color band dentes cathode end · Mounting Position: Any · Making: Type Number Dimiensions in inches and (milimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL E1A E1B E1D E1G E1J Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 V Maximum RMS Voltage VRMS 35 70 140 280 420 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 V Average Rectified Output Current @TL=90 ℃ IF(AV) 1.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 35 A I 2t 5.084 A2s I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=1.0A Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @T A =125 ℃ VFM 0.95 1.3 5.0 IR 150 1.7 V uA Maximum Reverse Recovery Time (Note1) Trr 35 ns Typical Junction Capacitance (Note 2) CJ 10 pF Typical Thermal Resistance Junction to Ambient(Note 3) Rθ JA 75 ℃ /W -55 to+150 ℃ -55 to +150 ℃ Operating Temperature Range Storage Temperature Range TJ TSTG Note: 1.Reverse Recovery Test Conditions:IF=0.5A,IR=1.0A,IRR=0.25A. 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 3.Device mounted on FR-4 substrate, 1"*1", 2oz, single-sided, PC boards with 0.06"*0.09" copper pad. version:05 1 of 3 E1A THRU E1J 1.0AMP Surface Mount Glass Superfast Recovery Rectifier INSTANTANEOUS FORWARD CURRENT, (A) 1.5 1.0 0.5 0 SINGLE PHASE, HALF-WAVE, 60Hz RESISTIVE OR INDUCTIVE LOAD P.C.B MOUNTED ON 0.3 x 0.3" (8.0 x 8.0 mm)COPPER PAD AREAS 0 20 40 60 80 100 120 140 160 180 O LEAD TEMPERATURE( C) 1.0 .1 600V .01 O TA= 25 C .001 0.4 35 30 FIG.1 MAXIMUM AVERAGE FORWARD CURRENT DERATING 0.6 0.8 1.0 1.4 1.2 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE(V) 25 FIG.4TYPICAL JUNCTION CAPACITANCE 18 20 16 15 10 5 1 4 2 6 8 10 20 40 60 80 100 NUMBER OF CYCLES AT 60Hz CAPACITANCE, (pF) O Tj= 25 C f= 1 .0MHz Vsig = 50mVp -p 14 12 10 8.0 6.0 4.0 FIG.5TYPICAL REVERSE CHRACTERISTICS 2.0 1000 0 0.1 100 10 1 REVERSE VOLTAGE, (V) O TA = 125 C Fig.6 TYPICAL CAPACITANCE 100 0.224 (5.7) O TA = 75 C 0.098 (2.5) 10 1.0 0.1 O TA = 25 C 20 40 60 80 100 120 PERCENT OF RATED PEAK INVERSE VOLTGE version:05 0.063 (1.6) 0.059 (1.5) MICROAMPERES (u A) INVSTANTANEOUS REVERSE CURRENT, 400V 50-200V FIG.3MAXIMUM NON-REPEITIVE SURGE CURRENT IFSM, PEAK FORWARD SURGE CURRENT (A) AVERAGE FORWARD RECIFIED CURRENT (A) FIG.2TYPICAL FORWARD CHARACTERISTICS 10 FIG.1MAXIMUM AVERAGE FORWARD CURRENT DERATING 2 of 3 E1A THRU E1J 1.0AMP Surface Mount Glass Superfast Recovery Rectifier Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:05 3 of 3
很抱歉,暂时无法提供与“E1J”相匹配的价格&库存,您可以联系我们找货
E1J
  • 50+0.04979
  • 500+0.03905
  • 1500+0.03305
  • 10000+0.02949
  • 20000+0.02641
  • 50000+0.02474
库存:48
