BCIHP1040SC-680M
BCIHP1040SC-680M
    BC(台湾诚阳)
    SMD,10x11.6mm
BCIHP1040SC-680M 数据手册
(SMD Power Inductors) 1 Powder Molding Type BCIHP10SC-Series ● Photograph picture BCIHP10SC ● Dimensions XXX ITEM BCIHP1030SC-Series BCIHP1040SC-Series BCIHP1050SC-Series A(mm) B(mm) 10.0±0.3 11.6MAX 10.0±0.3 11.6MAX 10.0±0.3 11.6MAX C(mm) D(mm) 3.0MAX 3.00±0.5 4.0MAX 3.00±0.5 5.0MAX 3.00±0.5 E(mm) a(mm) b(mm) c(mm) 2.0±0.5 5.4 13.6 4.1 2.0±0.5 5.4 13.6 4.1 2.0±0.5 5.4 13.6 4.1 ● Part Numbering BCIHP 1040SC – 4R7 M S A B C D A:Series(系列代號) B:Dimension( 尺 寸 ) B×C C:Inductance( 電 感 值 ) 4R7=4.7uH D:Inductance Tolerance(電感值公差) M=±20% N=±30% ● Features 1. 2. 3. 4. 5. Compliance with RoHs. Lowest DCR. Frequency range up to 3.0MHz. Handles high transient current spikes without saturation Ultra low buzz noise, due to composite construction. ● Applications 1. DC/DC converter for CPU in Notebook PC. 2. Battery powered devices. 3. Cellular phones LCD displays, HDDs, DVCs, DSCs, PDA etc. 4. Thin type on-board power supply module. TEL:+86-756-3383909 TAX:+86-756-3380704 ● 特點 1. 2. 3. 4. 5. 符合 RoHs. 低電阻. 頻率可達到 3.0 MHz. 可處理在未飽和時的高瞬間電流. 設計緊湊/超低噪音 ● 應用 1. 用於筆記本電腦處理器的DC/DC 轉換設備. 2. 電源,電池設備. 3. 適用於手機液晶屏顯示,HDD, DVC, DSC, PDA 等. 4. 薄型車載電源模組. Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 1 / 9 (SMD Power Inductors) 2 Powder Molding Type BCIHP10SC-Series ● Specification ITEM BCIHP1030SC-R22M BCIHP1030SC-R33M BCIHP1030SC-R36M BCIHP1030SC-R47M BCIHP1030SC-R82M BCIHP1030SC-1R0M BCIHP1030SC-2R2M BCIHP1030SC-3R3M BCIHP1030SC-4R7M BCIHP1030SC-8R2M BCIHP1030SC-330M BCIHP1040SC-R15M BCIHP1040SC-R22M BCIHP1040SC-R30M BCIHP1040SC-R36M BCIHP1040SC-R47M BCIHP1040SC-R56M BCIHP1040SC-R68M BCIHP1040SC-R80M BCIHP1040SC-1R0M BCIHP1040SC-1R5M BCIHP1040SC-2R2M BCIHP1040SC-3R3M BCIHP1040SC-4R7M BCIHP1040SC-6R8M BCIHP1040SC-8R2M BCIHP1040SC-100M BCIHP1040SC-150M BCIHP1040SC-220M BCIHP1040SC-330M BCIHP1040SC-470M BCIHP1040SC-680M BCIHP1040SC-101M BCIHP1050SC-R22M BCIHP1050SC-1R0M BCIHP1050SC-1R5M BCIHP1050SC-2R2M BCIHP1050SC-3R3M BCIHP1050SC-4R7M BCIHP1050SC-5R6M BCIHP1050SC-6R8M BCIHP1050SC-100M TEL:+86-756-3383909 TAX:+86-756-3380704 INDUCTANCE uH DCR mΩ @100KHZ,1.0V,0A(1) 25℃ MAX. 0.22 0.33 0.36 0.47 0.82 1.0 2.2 3.3 4.7 8.2 33.0 0.15 0.22 0.30 0.36 0.47 0.56 0.68 0.80 1.0 1.5 2.2 3.3 4.7 6.8 8.2 10.0 15.0 22.0 33.0 47.0 68.0 100.0 0.22 1.0 1.5 2.2 3.3 4.7 5.6 6.8 10.0 1.2 1.6 1.6 2.5 3.7 6.0 9.0 16.0 24.0 45.0 160.0 0.65 1.0 1.1 1.2 1.7 1.8 2.4 2.7 3.3 4.2 7.0 13.2 20.0 25.0 29.0 30.0 45.0 72.0 110.0 158.0 195.0 340.0 0.8 3.0 4.2 6.5 11.0 14.0 17.0 18.5 28.0 HEAT RATING SATURATION CURRENT DC AMPS CURRENT DC AMPS (5) (6) TYPICAL(Irms) TYPICAL(Isat) 33.0 50.0 23.0 32.0 23.0 28.0 22.0 26.0 18.0 23.0 15.0 21.0 11.0 14.0 9.0 12.0 7.0 10.0 5.0 7.0 2.6 4.0 45.0 75.0 35.0 45.5 34.5 45.0 31.0 42.0 30.0 38.0 25.0 33.0 23.0 30.0 22.5 29.0 19.0 26.0 16.0 22.0 12.0 16.0 11.0 12.0 9.0 12.0 6.5 10.0 6.0 9.0 5.5 7.0 5.25 6.0 5.0 5.5 3.2 5.0 2.8 4.5 2.5 3.0 1.5 2.0 37.0 65.0 23.0 30.0 16.0 22.0 13.0 18.0 11.0 16.0 10.0 14.0 9.5 14.0 9.0 12.0 8.0 10.0 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 2 / 9 (SMD Power Inductors) 3 Powder Molding Type BCIHP10SC-Series ● Specification ITEM BCIHP1050SC-150M BCIHP1050SC-220M BCIHP1050SC-330M BCIHP1050SC-470M BCIHP1050SC-101M TEL:+86-756-3383909 TAX:+86-756-3380704 INDUCTANCE uH DCR mΩ @100KHZ,1.0V,0A(1) 25℃ MAX. 15.0 22.0 33.0 47.0 100.0 42.0 50.0 86.0 127.0 290.0 HEAT RATING SATURATION CURRENT DC AMPS CURRENT DC AMPS (5) (6) TYPICAL(Irms) TYPICAL(Isat) 6.5 7.5 5.5 6.0 4.8 5.2 3.7 4.5 2.1 2.8 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 3 / 9 4 (SMD Power Inductors) Powder Molding Type BCIHP10SC-Series Note: (1) (2) (3) (4) (5) (6) (7) Tolerance of Inductance: N=±30% ,M=±20%. All test data is referenced to 25℃ ambient. Inductance is measured at 100KHz. 25℃ ambient. Operating Temperature Range-50℃ to +125℃. DC current (Irms) (A) that will cause an approximate △T of 40℃. DC current (Isat) (A) that will cause Lo to drop approximately 30%. The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature Part temperature should be verified in the end application. (1) 電感的公差:N=±30 ,M=±20 . (2) 所有的測試資料應該是在 25℃的環境溫度下測試. (3) 感值測試頻率 100KHz. (4) 操作溫度範圍-50℃到+125℃. (5) 加 DC(Irms)電流值(A)會導致△T 40℃左右的變化. (6) 加 DC(Isat)電流值(A)會導致初始值下降 30 左右. (7) 產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度, 氣流和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證. TEL:+86-756-3383909 TAX:+86-756-3380704 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 4 / 9 (SMD Power Inductors) 5 Powder Molding Type BCIHP10SC-Series ● Material List NO 1 2 3 ITEM Core Wire External Electode Electroplating Materials Magnetic Metal Powder FeSiCr or equivalen Polyester Wire or equivalen Copper Sn ● Packaging Information (1) Reel Dimension & Tape Dimension / Packaging Quantity ITEN DIMENSIONS (m/m) Q’TY (PCS) BCIHP1030SC BCIHP1040SC BCIHP1050SC W1±0.3 W2±0.5 W±0.3 A0±0.1 B0±0.1 K0±0.1 P±0.1 F±0.1 T±0.05 500 24.80 29.00 24.00 10.50 11.30 4.50 16.00 11.50 0.40 500 24.80 29.00 24.00 10.50 11.30 4.50 16.00 11.50 0.40 500 24.80 29.00 24.00 10.50 11.30 5.50 16.00 11.50 0.40 (2) Tearing Off Force The force tearing off cover 10 to 130 grams (0.1N to 1.3N) in the arrow direction under the following conditions. ● Storage conditions/Note things (1) Storage temperature and humidity conditions : 1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH. 2. Product alone: -20℃~+60℃ and less than 60% RH. (2) Products should be used within 6 months. (3) The packaging material should be kept where no chlorine or sulfur exists in the air. (4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability. (5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (6) Bulk handling should ensure that abrasion and mechanical shock are minimized. TEL:+86-756-3383909 TAX:+86-756-3380704 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 5 / 9 (SMD Power Inductors) 6 SMD Power Inductors BCIHP10SC-Series ITEM Packing method & Dimensions Box Size W=345mm D=345mm H=185mm ITEM BCIHP1030SC BCIHP1040SC BCIHP1050SC TEL:+86-756-3383909 TAX:+86-756-3380704 Packing Quantity Reel Quantity Total Quantity 500 Pcs/Reel 500 Pcs/Reel 500 Pcs/Reel 5 Reel/Box 5 Reel/Box 5 Reel/Box 2500Pcs/Box 2500Pcs/Box 2500Pcs/Box Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 6 / 9
