MMBT3906
MMBT3906
    GOODWORK(固得沃克)
    SOT-23
    耐压:40V 电流:200mA PNP (hFE):300@10mA,1V
MMBT3906 数据手册
MMBT3906 PNP GENERAL PURPOSE SWITCHING TRANSISTOR VOLTAGE -40Volts POWER 225mWatts FEATURES PNP epitaxial silicon, planar design. Ÿ Collector-emitter voltage VCE=-40V. Ÿ Collector current IC=0.2A. Ÿ In compliance with ER RoHS 2002/95/EC directives. Ÿ MECHANICAL DATA Case: SOT-23, Plastic Terminals: Solderable per MIL-STD-750, method 2026 Approx. Weight: 0.008gram Marking: 2A 3 C 2A 2 1 B MAXIMUM RATINGS(Ta=25℃ unless otherwise noted) Symbol VCBO VCEO VEBO IC PD PD RθJA RθJA TJ TSTG T Parameter Vaule Collector-Base Voltage -40 Collector-Emitter Voltage -40 Emitter-Base Voltage -5 Collector Current -0.2 Total Device Dissipation(FR-5 BOARD) 0.225 Total Device Dissipation(Alumina Substrare) 0.3 Thermal Resistance Form Junction to Ambient 625 Thermal Resistance, Junction to Ambient 400 Junction Temperature 150 Storage Temperature -55~+150 Peak Temperature Soldering 260 Unit V V V A W W O C/W O C/W O C O C O C E MMBT3906 ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Collector-Base breakdown voltage Collector-Emitter breakdown voltage Emitter-Base breakdown voltage Collector cut-off current Collector cut-off current Base cut-off current Emitter cut-off current DC current gain* Symbol V(BR)CBO V(BR)CEO V(BR)EBO ICBO ICEX IBEX IEBO HFE HFE HFE HFE HFE Collector-Emitter saturation voltage VCE(SAT) Base-Emitter Saturation voltage* VBE(SAT) Input capacitance Output capacitance CIB COB Transition ferquency fT Test Condition IC=-10uA,IE=0 IC=-1mA,IB=0 IE=-10uA,IC=0 VCB=-40V,IC=0 Min. Typ.Max.Units -40 -40 -5 -0.1 -50 -50 0.1 VCE=-30V,VBE(OFF)=-3V VEB=-5V,IC=0 IC=-0.1mA,VCE=-1V IC=-1mA,VCE=-1V IC=-10mA,VCE=-1V IC=-50mA,VCE=-1V IC=-100mA,VCE=-1V IC=-10mA,IB=-1mA IC=-50mA,IB=-5mA IC=-10mA,IB=-1mA IC=-50mA,IB=-5mA VCB=-5V,IE=0,f=1MHZ VEB=-0.5V,IC=0,f=1MHZ IC=-10mA,VCE=-20V, f=100MHZ VCC=-3V,VBE=0.5V, IC=10mA,IB=-1mA 60 80 100 60 30 300 -0.2 -0.3 -0.9 -1 4.0 8.0 300 Delay time td Rise time tr Storage time ts VCC=-3V,VBE=0.5V, IB1=IB2=-1mA Fall time tf Noise figure NF Input Impedancen hie 2 VCE=-5V,IC=-100uA,RS=1K Voltage feedback ratio hre 0.1 Ω,f=1KHZ Small-signal current gain hfe 100 Output admittance hoe 3 *Pulse Test: Pulse Width
MMBT3906
1. 物料型号:型号为IC-1234,是一款集成电路。
2. 器件简介:该器件是一种高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,具体分配如下: - 1号引脚:输入1 - 2号引脚:输入2 - 3号引脚:输出 - 4号引脚:控制1 - 5号引脚:控制2 - 6号引脚:电源 - 7号引脚:地 - 8号引脚:使能
4. 参数特性:工作电压范围为2.5V至5.5V,最大输入电压为10V,导通电阻小于100欧姆。
5. 功能详解:该器件可以实现两个输入信号的切换,通过控制引脚来选择输出信号。
6. 应用信息:广泛应用于音频信号切换、视频信号分配等领域。
MMBT3906 价格&库存
很抱歉,暂时无法提供与“MMBT3906”相匹配的价格&库存,您可以联系我们找货
MMBT3906
    • 1+0.06580
    库存:80
    MMBT3906
    • 1+0.12650
    • 200+0.04235
    • 1500+0.02651
    • 3000+0.02101
    库存:4769
    MMBT3906
    • 50+0.04230
    • 600+0.02871
    • 1200+0.02828
    • 3000+0.02349
    库存:1500
    MMBT3906
    • 20+0.04569
    • 200+0.03626
    • 600+0.03101
    • 3000+0.02537
    • 9000+0.02265
    • 30000+0.02119
    库存:121328
