MMBT2907A
PNP GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 60Volts POWER 300mWatts
FEATURES
PNP epitaxial silicon, planar design.
Collector-emitter voltage VCE=-60V.
Collector current IC=-0.6A.
Transition frequency f T >200MHz @ IC=
20mAdc, VCE=-50Vdc, f=100MHz.
In compliance with EU RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking:2F
3
C
2F
B
2
1
E
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Vaule
Unit
VCBO
Collector-Base Voltage
-60
V
VCEO
Collector-Emitter Voltage
-60
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-0.6
A
PC
Total Device Dissipation
0.3
W
Thermal Resistance Form Junction to Ambient
416
Junction Temperature
150
O
-55~+150
O
RθJA
TJ
TSTG
Storage Temperature
O
C/W
C
C
MMBT2907A
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
Min. Typ. Max. Units
IC=-100uA,IE=0
-60
V
Collector-Emitter breakdown voltage V(BR)CEO
IC=-1mA,IB=0
-60
V
Emitter-Base breakdown voltage
V(BR)EBO
IE=-100uA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-50V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
VEB=-5V,IC=0
HFE
IC=-1mA,VCE=-10V
40
HFE
IC=-10mA,VCE=-10V
70
HFE
IC=-150mA,VCE=-10V
100
HFE
IC=-200mA,VCE=-10V
60
HFE
IC=-500mA,VCE=-10V
30
DC current gain*
V(BR)CBO
Test Condition
Collector-Emitter saturation voltage VCE(SAT)
VCE=-50V,IB=0
-0.02
uA
-0.05
uA
-0.05
uA
-0.01
uA
300
IC=-150mA,IB=-15mA
-0.5
V
IC=-500mA,IB=-50mA
-1.6
V
IC=-150mA,IB=-15mA
-1.3
V
IC=-500mA,IB=-50mA
-2.6
V
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
CIB
VCB=-10V,IE=0,f=1MHZ
5.0
pF
Ouput capacitance
COB
8.0
pF
Transition ferquency
fT
VEB=-0.5V,IC=0,f=1MHZ
IC=-50mA,VCE=-20V,
f=100MHZ
Delay time
td
Rise time
tr
Storage time
ts
Fall time
tf
200
MHZ
VCC=-20V,VBE=0.5V,
IC=-150mA,IB=-15mA
35
nS
35
nS
VCC=-6V,VBE=0.5V,
IB1=IB2=-15mA
200
nS
50
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.10076
- 200+0.07973
- 600+0.06802
- 3000+0.05552
- 9000+0.04946
- 30000+0.04617
