S9012
PNP GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 25Volts POWER 300mWatts
FEATURES
PNP epitaxial silicon, planar design.
Collector-emitter voltage VCE=-25V.
Collector current IC=-0.5A.
Transition frequency f T >150MHz @ IC=20mAdc, VCE=-6Vdc, f=30MHz.
In compliance with ER RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking: 2T1
3
C
2T1
1
2
B
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
VCBO
VCEO
VEBO
IC
PD
RθJA
TJ
TSTG
Parameter
Vaule
Collector-Base Voltage
-40
Collector-Emitter Voltage
-25
Emitter-Base Voltage
-5
Collector Current
-0.5
Total Device Dissipation(FR-5 BOARD)
0.3
Thermal Resistance Form Junction to Ambient
416
Junction Temperature
150
Storage Temperature
-55~+150
Unit
V
V
V
A
W
O
C/W
O
C
O
C
E
S9012
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
V(BR)CBO
Test Condition
Min. Typ.Max.Units
IC=-100uA,IE=0
-40
V
Collector-Emitter breakdown voltage V(BR)CEO
IC=-1mA,IB=0
-25
V
Emitter-Base breakdown voltage
V(BR)EBO
IE=-100uA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-40V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
VEB=-5V,IC=0
DC current gain*
HFE
IC=-50mA,VCE=-1V
Collector-Emitter saturation voltage VCE(SAT)
VCE=-20V,IB=0
120
-0.1
uA
-0.1
uA
-0.1
uA
-0.1
uA
400
IC=-100mA,IB=-10mA
-0.5
V
IC=-500mA,IB=-50mA
-0.6
V
IC=-100mA,IB=-10mA
-1.1
V
IC=-500mA,IB=-50mA
-1.2
V
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
CIB
VCB=-10V,IE=0,f=1MHZ
5.0
pF
Output capacitance
COB
8.0
pF
Transition ferquency
fT
Delay time
td
Rise time
tr
VEB=-0.5V,IC=0,f=1MHZ
IC=-10mA,VCE=-20V,
f=30MHZ
VCC=-3V,VBE=0.5V,
IC=-10mA,IB=-1mA
Storage time
ts
Fall time
tf
VCC=-3V,VBE=0.5V,
IB1=IB2=-1mA
150
MHZ
35
nS
35
nS
200
nS
50
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“S9012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05823
- 500+0.04608
- 3000+0.03587
- 6000+0.03189
- 30000+0.02839
- 45000+0.02654
