MMBTA92
MMBTA92
    GOODWORK(固得沃克)
    SOT-23
    耐压:300V 电流:200mA PNP (hFE):200@10mA,10V
MMBTA92 数据手册
MMBTA92 PNP GENERAL PURPOSE SWITCHING TRANSISTOR VOLTAGE -300Volts POWER 300mWatts FEATURES PNP epitaxial silicon, planar design. Ÿ Collector-emitter voltage VCE=-300V. Ÿ Collector current IC=-0.3A. Ÿ Transition frequency f T >200MHz @ IC=20mAdc, VCE=-50Vdc, f=100MHz. Ÿ In compliance with ER RoHS 2002/95/EC directives. Ÿ MECHANICAL DATA Case: SOT-23, Plastic Terminals: Solderable per MIL-STD-750, method 2026 Approx. Weight: 0.008gram Marking: 2D 3 C 2D 2 1 B MAXIMUM RATINGS(Ta=25℃ unless otherwise noted) Symbol VCBO VCEO VEBO IC PD RθJA TJ TSTG Parameter Vaule Collector-Base Voltage -300 Collector-Emitter Voltage -300 Emitter-Base Voltage -5 Collector Current -0.3 Total Device Dissipation(FR-5 BOARD) 0.3 Thermal Resistance Form Junction to Ambient 416 Junction Temperature 150 Storage Temperature -55~+150 Unit V V V A W O C/W O C O C E MMBTA92 ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Collector-Base breakdown voltage Symbol Min.Typ.Max. Units IC=-100uA,IE=0 -300 V Collector-Emitter breakdown voltage V(BR)CEO IC=-1mA,IB=0 -150 V Emitter-Base breakdown voltage V(BR)EBO IE=-100uA,IC=0 -5 V Collector cut-off current ICBO VCB=-200V,IC=0 Collector cut-off current ICEX Base cut-off current IBEX Emitter cut-off current IEBO VEB=-5V,IC=0 HFE IC=-0.1mA,VCE=-10V 40 HFE IC=-1mA,VCE=-10V 70 HFE IC=-10mA,VCE=-10V 100 HFE IC=-20mA,VCE=-10V 60 HFE IC=-50mA,VCE=-10V 30 DC current gain* V(BR)CBO Test Condition Collector-Emitter saturation voltage VCE(SAT) VCE=-200V,IB=0 -0.25 uA -0.25 uA -0.25 uA -0.10 uA 200 IC=-20mA,IB=-2mA -0.2 V IC=-50mA,IB=-10mA -1.6 V IC=-20mA,IB=-2mA -0.9 V IC=-50mA,IB=-10mA -2.6 V Base-Emitter Saturation voltage* VBE(SAT) Input capacitance CIB VCB=-10V,IE=0,f=1MHZ 5.0 pF Output capacitance COB 8.0 pF Transition ferquency fT Delay time td Rise time tr VEB=-0.5V,IC=0,f=1MHZ IC=-10mA,VCE=-20V, f=100MHZ VCC=-20V,VBE=0.5V, IC=-150mA,IB=-15mA Storage time ts Fall time tf VCC=-6V,VBE=0.5V, IB1=IB2=-15mA 50 MHZ 35 nS 35 nS 200 nS 50 nS *Pulse Test: Pulse Width
MMBTA92
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装方式。
MMBTA92 价格&库存
很抱歉,暂时无法提供与“MMBTA92”相匹配的价格&库存,您可以联系我们找货
MMBTA92
  • 20+0.17367
  • 200+0.13922
  • 600+0.12010
  • 3000+0.09180
  • 9000+0.08187
  • 30000+0.07647
库存:9497
