S9013
NPN GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 25Volts POWER 300mWatts
FEATURES
NPN epitaxial silicon, planar design.
Collector-emitter voltage VCE=25V.
Collector current IC=0.5A.
Transition frequency f T >150MHz @
IC=20mAdc, VCE=6Vdc, f=30MHz.
In compliance with ER RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking: J3
RANK
RANGE
L
120-200
H
200-350
3
C
J3
1
2
B
J
300-40
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
VCBO
VCEO
VEBO
IC
PD
RθJA
TJ
TSTG
Parameter
Vaule
Collector-Base Voltage
40
Collector-Emitter Voltage
25
Emitter-Base Voltage
5
Collector Current
0.5
Total Device Dissipation
0.3
Thermal Resistance Form Junction to Ambient
416
Junction Temperature
150
Storage Temperature
-55~+150
Unit
V
V
V
A
W
O
C/W
O
C
O
C
E
S9013
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
V(BR)CBO
Test Condition
Min. Typ.Max.Units
IC=100uA,IE=0
40
V
Collector-Emitter breakdown voltage V(BR)CEO
IC=1mA,IB=0
25
V
Emitter-Base breakdown voltage
V(BR)EBO
IE=100uA,IC=0
5
V
Collector cut-off current
ICBO
VCB=40V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
VEB=5V,IC=0
DC current gain*
HFE
IC=50mA,VCE=1V
Collector-Emitter saturation voltage VCE(SAT)
VCE=20V,IB=0
120
0.1
uA
0.1
uA
0.1
uA
0.1
uA
400
IC=100mA,IB=10mA
0.5
V
IC=500mA,IB=50mA
0.6
V
IC=100mA,IB=10mA
1.1
V
IC=500mA,IB=50mA
1.2
V
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
C IB
VCB=6V,IE=0,f=1MHZ
4.0
pF
Output capacitance
C OB
8.0
pF
Transition ferquency
fT
Delay time
td
Rise time
tr
VEB=0.5V,IC=0,f=1MHZ
IC=10mA,VCE=6V,
f=30MHZ
VCC=3V,VBE=-0.5V,
IC=10mA,IB=1mA
Storage time
ts
Fall time
tf
VCC=3V,VBE=-0.5V,
IB1=IB2=1mA
150
MHZ
35
nS
35
nS
200
nS
50
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“S9013”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08065
- 500+0.06505
- 3000+0.05254
- 6000+0.04731
- 30000+0.04278
- 45000+0.04043
