SS8550
SS8550
    GOODWORK(固得沃克)
    SOT-23
    PNP 电流:1.5A 电压:25V
SS8550 数据手册
SS8550 PNP GENERAL PURPOSE SWITCHING TRANSISTOR VOLTAGE 25Volts POWER 300mWatts FEATURES PNP epitaxial silicon, planar design. Collector-emitter voltage VCE=-25V. Ÿ Collector current IC=-1.5A. Ÿ Transition frequency f T >100MHz @ IC=Ÿ 50mAdc, VCE=-10Vdc, f=30MHz. In compliance with ER RoHS 2002/95/EC Ÿ directives. Ÿ MECHANICAL DATA Case: SOT-23, Plastic Terminals: Solderable per MIL-STD-750, method 2026 Approx. Weight: 0.008gram :Marking:Y2 RANK L H J RANGE 120-200 200-350 300-400 3 C Y2 1 2 B E MAXIMUM RATINGS(Ta=25℃ unless otherwise noted) Symbol Parameter Vaule Unit VCBO Collector-Base Voltage -40 V VCEO Collector-Emitter Voltage -25 V VEBO Emitter-Base Voltage -5 V IC Collector Current -1.5 A PC Total Device Dissipation 0.3 W Thermal Resistance Form Junction to Ambient 625 TJ Junction Temperature 150 O TSTG Storage Temperature -55~+150 O RθJA O C/W C C SS8550 ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified) Parameter Collector-Base breakdown voltage Symbol Min. Typ.Max.Units IC=-100uA,IE=0 -40 V Collector-Emitter breakdown voltage V(BR)CEO IC=-1mA,IB=0 -25 V Emitter-Base breakdown voltage V(BR)EBO IE=-100uA,IC=0 -5 V Collector cut-off current ICBO VCB=-40V,IC=0 Collector cut-off current ICEX Base cut-off current IBEX Emitter cut-off current IEBO VEB=-5V,IC=0 HFE IC=-0.1mA,VCE=-1.0V 40 HFE IC=-1mA,VCE=-1.0V 70 HFE IC=-100mA,VCE=-1.0V 100 HFE IC=-400mA,VCE=-1.0V 60 HFE IC=-800mA,VCE=-1.0V 30 DC current gain* V(BR)CBO Test Condition Collector-Emitter saturation voltage VCE(SAT) VCE=-20V,IB=0 -0.1 uA -0.1 uA -0.1 uA -0.1 uA 400 IC=-100mA,IB=-10mA -0.5 V IC=-800mA,IB=-80mA -0.6 V IC=-100mA,IB=-10mA -1.1 V IC=-800mA,IB=-80mA -1.2 V Base-Emitter Saturation voltage* VBE(SAT) Input capacitance C IB VCB=-5V,IE=0,f=1MHZ 4.0 pF Ouput capacitance C OB 8.0 pF Transition ferquency fT VEB=-0.5V,IC=0,f=1MHZ IC=-50mA,VCE=-10V, f=30MHZ Delay time td Rise time tr Storage time ts Fall time tf 100 MHZ VCC=-3V,VBE=0.5V, IC=-10mA,IB=-1.0mA 35 nS 35 nS VCC=-3V,VBE=0.5V, IB1=IB2=-1.0mA 200 nS 50 nS *Pulse Test: Pulse Width
SS8550
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高抗干扰性,适用于工业自动化控制。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B、C。
4. 参数特性:工作电压为5V,工作电流为10mA,响应时间为1ms。
5. 功能详解:EL817通过光电转换实现信号隔离,提高系统稳定性和抗干扰能力。
6. 应用信息:广泛应用于工业自动化、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装。
SS8550 价格&库存
很抱歉,暂时无法提供与“SS8550”相匹配的价格&库存,您可以联系我们找货
SS8550
    • 1+0.03840
    库存:439
