S9014
NPN GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 45Volts POWER 300mWatts
FEATURES
NPN epitaxial silicon, planar design.
Collector-emitter voltage VCE=45V.
Collector current IC=0.1A.
Transition frequency f T >150MHz @
IC=10mAdc, VCE=5Vdc, f=30MHz.
In compliance with ER RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking: J6
3
C
J6
1
2
B
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
VCBO
VCEO
VEBO
IC
PD
RθJA
TJ
TSTG
Parameter
Vaule
Collector-Base Voltage
50
Collector-Emitter Voltage
45
Emitter-Base Voltage
5
Collector Current
0.1
Total Device Dissipation
0.3
Thermal Resistance Form Junction to Ambient
625
Junction Temperature
150
Storage Temperature
-55~+150
Unit
V
V
V
A
W
O
C/W
O
C
O
C
E
S9014
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Collector-Emitter breakdown voltage
Emitter-Base breakdown voltage
Collector cut-off current
Base cut-off current
Emitter cut-off current
DC current gain*
Symbol
V(BR)CBO
V(BR)CEO
V(BR)EBO
ICBO
ICEX
IBEX
IEBO
HFE
Collector-Emitter saturation voltage VCE(SAT)
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
Output capacitance
CIB
COB
Transition ferquency
fT
Delay time
Rise time
Storage time
Fall time
td
tr
ts
tf
Test Condition
IC=100uA,IE=0
IC=1mA,IB=0
IE=100uA,IC=0
VCB=45V,IC=0
Min. Typ.Max.Units
50
45
5
VCE=35V,IB=0
VEB=3V,IC=0
IC=1mA,VCE=5V
IC=20mA,IB=1mA
IC=100mA,IB=5mA
IC=20mA,IB=1mA
IC=100mA,IB=5mA
VCB=5V,IE=0,f=1MHZ
VEB=0.5V,IC=0,f=1MHZ
IC=10mA,VCE=5V,
f=30MHZ
VCC=3V,VBE=-0.5V,
IC=10mA,IB=1mA
VCC=3V,VBE=-0.5V,
IB1=IB2=1mA
200
0.1
0.1
0.1
0.1
600
0.2
0.3
0.85
0.95
4.0
8.0
150
V
V
V
uA
uA
uA
uA
V
V
V
V
pF
pF
MHZ
35
35
200
50
nS
nS
nS
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.13200
- 200+0.04389
- 1500+0.02750
- 3000+0.02178
- 国内价格
- 50+0.06772
- 500+0.05459
- 3000+0.04340
- 6000+0.03899
- 30000+0.03509
- 45000+0.03304
